Diferencia entre actualizacion estable y estable staging
Stable Staging is used for testing quick updates before they go directly to Stable. Use it if you want to test these updates and report if everything is OK or not. Do not use this branch as a normal branch it is only for quick testing purpose and it may not be kept up to date properly, I mean it got left ‘un-updated’ in the past when other branches (Testing, Stable) were receiving updates. From my understanding Stable Staging should be used only when some tests are occurring on it, before going back to Stable or Testing branch.
I agree otherwise. But it is for testing the batch which is supposed to go to stable. It is like a full simulation test of the planned stable update.
