Hello, I am new to manjaro and new to linux. I am having issues with my bluetooth and and wifi. After boot, only one of them works at a time. Sometimes the wifi card is not found or it is found but it cannot find any wifi network. Other times, I can turn the bluetooth on but I cannot see available devices. Seems like bluetooth is only on according to the UI toggle but there is something missing.
on shutdown, I always see
sd-unmoun[2249]: failed to unmount /oldroot : Device or resource busy
sd-unmoun[2250]: failed to unmount /oldroot/sys : Device or resource busy
shutdown[1]: failed to finalize file systems, ignoring
Bluetooth: Received HCI_IBS_WAKE_ACK in tx state 0
mhi: Device failed to exit MHI reset state
journal wifi errors
-- Journal begins
kernel: ioremap error for 0x55d73000-0x55d74000, requested 0x2, got 0x0
kernel: Bluetooth: Received HCI_IBS_WAKE_ACK in tx state 0
kernel: ath11k_pci 0000:05:00.0: failed to enable PMF QOS: (-11
wpa_supplicant[1450]: Could not set interface wlp5s0 flags (UP): Resource temporarily unavailable
wpa_supplicant[1450]: nl80211: Could not set interface 'wlp5s0' UP
NetworkManager[833]: <error> device (wlp5s0): Couldn't initialize supplicant interface: Timeout was reached
wpa_supplicant[1450]: WEXT: Could not set interface 'wlp5s0' UP
wpa_supplicant[1450]: wlp5s0: Failed to initialize driver interface
systemd[1868]: Failed to start Application launched by gnome-session-binary.
░░ Subject: A start job for unit UNIT has failed
░░ Defined-By: systemd
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 359 and the job result is failed.
journal bluetooth errors
-- Journal begins
kernel: Bluetooth: hci0: Frame reassembly failed (-84)
bluetoothd[821]: Failed to set mode: Failed (0x03)
kernel: Bluetooth: hci0: unexpected event for opcode 0x0c14
kernel: Bluetooth: hci0: unexpected event for opcode 0x0c25
kernel: Bluetooth: hci0: unexpected event for opcode 0x0c38
Kindly help me get bluetooth and wifi working well
