Since the first release of the Kernel 6.5, Display is missing the Thunderbolt dockingstation and cannot find my monitor. Anyone around here with ideas what I can do? Everything else is working with the dockingstation.
Monitor is a 27" Samsung and my machine is a Lenovo X1 Carbon 7th Gen. inxi -b:
Any particular reason why? 6.5 is the current mainline kernel, and it’s not mature yet because it’s still too fresh. Furthermore, it’ll be EOL in a couple of months time.
6.1 is a mature long-term-support kernel and will continue receiving security updates and bug fixes until at least December 2026.
Reason why I want 6.5 is simply because other things is getting better with the OS. But knowing what’s causing the Display program from not finding the monitor should have a fix and hope these problems will not follow the later development of the Kernel and other packages Manjaro is using.
On my intel Jasper lake system, booting the system services takes about a second more on 6.5 as it did with 6.1. And it stutters for a couple of seconds on spectre checker, and it shows even more bluetooth errors. And there is no performance increase on simple benchmarks like sysbench. No point at all in my case. Maybe someone on a workstation or server will see a difference because there are supposed to be performance improvements in the multithreading.
I’m sorry, but that doesn’t make any sense at all. Just because the kernel has a higher version doesn’t mean it’s going to be better — as you can see for yourself.
If it works with a kernel of a lower version, then it’s only one more evidence of the fact that 6.5 isn’t mature yet, and that you shouldn’t be using it.
Whatever the incompatibility is in 6.5, it’ll get fixed at some point, but we’re obviously not there yet, and this has nothing to do with the rest of the operating system. The kernel and the other packages evolve independently from one another.
