nVidia drivers not working properly
Hi guys!
II have just installed the latest Manjaro Xfce and it seems like a great linux. Fast and straightforward installation and even HDMI seems to work. However, the same usual nVidia linux problem appeared. It looks like the driver is installed but won’t work.
[pepe999@pepe999 ~]$ inxi -G
  Device-1: Intel CometLake-H GT2 [UHD Graphics] driver: i915 v: kernel
  Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] driver: nvidia
  v: 470.63.01
  Device-3: Acer BisonCam NB Pro type: USB driver: uvcvideo
  Display: x11 server: X.Org 1.20.13 driver: loaded: modesetting,nvidia
  unloaded: nouveau resolution: 1: 1920x1080~240Hz 2: 1920x1080~60Hz
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.3
Is there a way how to start a game with the nVidia drivers? The Prime manager or whatever is in charge of switching the graphics doesn’t seem work which was the same issue as on Debian Bullseye.
[pepe999@pepe999 ~]$ DR_PRIME=1 glxinfo | grep 'renderer string'
OpenGL renderer string: Mesa Intel(R) UHD Graphics (CML GT2```
Thanks!!
Hi @pepe999, and welcome!
AFAIK it’s not
DR_PRIME=1 glxinfo
but actually
prime-run glxinfo
for Nvidia.
Hope this helps!
Hi Mirdarthos!!
Thanks, that shows it’s installed!!
prime-run glxinfo
name of display: :0.0
display: :0  screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
    GLX_ARB_context_flush_control, GLX_ARB_create_context,
    GLX_ARB_create_context_no_error, GLX_ARB_create_context_profile,
    GLX_ARB_create_context_robustness, GLX_ARB_fbconfig_float,
    GLX_ARB_multisample, GLX_EXT_buffer_age,
    GLX_EXT_create_context_es2_profile, GLX_EXT_create_context_es_profile,
    GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context, GLX_EXT_libglvnd,
    GLX_EXT_stereo_tree, GLX_EXT_swap_control, GLX_EXT_swap_control_tear,
    GLX_EXT_texture_from_pixmap, GLX_EXT_visual_info, GLX_EXT_visual_rating,
    GLX_NV_copy_image, GLX_NV_delay_before_swap, GLX_NV_float_buffer,
    GLX_NV_multigpu_context, GLX_NV_robustness_video_memory_purge,
    GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGI_swap_control,
    GLX_SGI_video_sync
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
    GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_buffer_age,
    GLX_EXT_fbconfig_packed_float, GLX_EXT_framebuffer_sRGB,
    GLX_EXT_import_context, GLX_EXT_stereo_tree, GLX_EXT_swap_control,
    GLX_EXT_swap_control_tear, GLX_EXT_texture_from_pixmap,
    GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_NV_copy_buffer,
    GLX_NV_multigpu_context, GLX_NV_multisample_coverage,
    GLX_NV_robustness_video_memory_purge, GLX_NV_swap_group,
    GLX_SGI_video_sync
GLX version: 1.4
GLX extensions:
    GLX_EXT_framebuffer_sRGB, GLX_EXT_import_context, GLX_EXT_stereo_tree,
    GLX_SGI_video_sync
Memory info (GL_NVX_gpu_memory_info):
    Dedicated video memory: 6144 MB
    Total available memory: 6144 MB
    Currently available dedicated video memory: 5897 MB
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: NVIDIA GeForce RTX 3060 Laptop GPU/PCIe/SSE2
OpenGL core profile version string: 4.6.0 NVIDIA 470.63.01
OpenGL core profile shading language version string: 4.60 NVIDIA
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
    GL_AMD_multi_draw_indirect, GL_AMD_seamless_cubemap_per_texture,
    GL_AMD_vertex_shader_layer, GL_AMD_vertex_shader_viewport_index,
    GL_ARB_ES2_compatibility, GL_ARB_ES3_1_compatibility,
    GL_ARB_ES3_2_compatibility, GL_ARB_ES3_compatibility,
    GL_ARB_arrays_of_arrays, GL_ARB_base_instance, GL_ARB_bindless_texture,
    GL_ARB_blend_func_extended, GL_ARB_buffer_storage,
    GL_ARB_clear_buffer_object, GL_ARB_clear_texture, GL_ARB_clip_control,
    GL_ARB_color_buffer_float, GL_ARB_compressed_texture_pixel_storage,
    GL_ARB_compute_shader, GL_ARB_compute_variable_group_size,
    GL_ARB_conditional_render_inverted, GL_ARB_conservative_depth,
    GL_ARB_copy_buffer, GL_ARB_copy_image, GL_ARB_cull_distance,
    GL_ARB_debug_output, GL_ARB_depth_buffer_float, GL_ARB_depth_clamp,
    GL_ARB_depth_texture, GL_ARB_derivative_control,
    GL_ARB_direct_state_access, GL_ARB_draw_buffers,
    GL_ARB_draw_buffers_blend, GL_ARB_draw_elements_base_vertex,
    GL_ARB_draw_indirect, GL_ARB_draw_instanced, GL_ARB_enhanced_layouts,
    GL_ARB_explicit_attrib_location, GL_ARB_explicit_uniform_location,
    GL_ARB_fragment_coord_conventions, GL_ARB_fragment_layer_viewport,
    GL_ARB_fragment_program, GL_ARB_fragment_program_shadow,
    GL_ARB_fragment_shader, GL_ARB_fragment_shader_interlock,
    GL_ARB_framebuffer_no_attachments, GL_ARB_framebuffer_object,
    GL_ARB_framebuffer_sRGB, GL_ARB_geometry_shader4,
    GL_ARB_get_program_binary, GL_ARB_get_texture_sub_image, GL_ARB_gl_spirv,
    GL_ARB_gpu_shader5, GL_ARB_gpu_shader_fp64, GL_ARB_gpu_shader_int64,
    GL_ARB_half_float_pixel, GL_ARB_half_float_vertex, GL_ARB_imaging,
    GL_ARB_indirect_parameters, GL_ARB_instanced_arrays,
    GL_ARB_internalformat_query, GL_ARB_internalformat_query2,
    GL_ARB_invalidate_subdata, GL_ARB_map_buffer_alignment,
    GL_ARB_map_buffer_range, GL_ARB_multi_bind, GL_ARB_multi_draw_indirect,
    GL_ARB_multisample, GL_ARB_multitexture, GL_ARB_occlusion_query,
    GL_ARB_occlusion_query2, GL_ARB_parallel_shader_compile,
    GL_ARB_pipeline_statistics_query, GL_ARB_pixel_buffer_object,
    GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_polygon_offset_clamp,
    GL_ARB_post_depth_coverage, GL_ARB_program_interface_query,
    GL_ARB_provoking_vertex, GL_ARB_query_buffer_object,
    GL_ARB_robust_buffer_access_behavior, GL_ARB_robustness,
    GL_ARB_sample_locations, GL_ARB_sample_shading, GL_ARB_sampler_objects,
    GL_ARB_seamless_cube_map, GL_ARB_seamless_cubemap_per_texture,
    GL_ARB_separate_shader_objects, GL_ARB_shader_atomic_counter_ops,
    GL_ARB_shader_atomic_counters, GL_ARB_shader_ballot,
    GL_ARB_shader_bit_encoding, GL_ARB_shader_clock,
    GL_ARB_shader_draw_parameters, GL_ARB_shader_group_vote,
    GL_ARB_shader_image_load_store, GL_ARB_shader_image_size,
    GL_ARB_shader_objects, GL_ARB_shader_precision,
    GL_ARB_shader_storage_buffer_object, GL_ARB_shader_subroutine,
    GL_ARB_shader_texture_image_samples, GL_ARB_shader_texture_lod,
    GL_ARB_shader_viewport_layer_array, GL_ARB_shading_language_100,
    GL_ARB_shading_language_420pack, GL_ARB_shading_language_include,
    GL_ARB_shading_language_packing, GL_ARB_shadow, GL_ARB_sparse_buffer,
    GL_ARB_sparse_texture, GL_ARB_sparse_texture2,
    GL_ARB_sparse_texture_clamp, GL_ARB_spirv_extensions,
    GL_ARB_stencil_texturing, GL_ARB_sync, GL_ARB_tessellation_shader,
    GL_ARB_texture_barrier, GL_ARB_texture_border_clamp,
    GL_ARB_texture_buffer_object, GL_ARB_texture_buffer_object_rgb32,
    GL_ARB_texture_buffer_range, GL_ARB_texture_compression,
    GL_ARB_texture_compression_bptc, GL_ARB_texture_compression_rgtc,
    GL_ARB_texture_cube_map, GL_ARB_texture_cube_map_array,
    GL_ARB_texture_env_add, GL_ARB_texture_env_combine,
    GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
    GL_ARB_texture_filter_anisotropic, GL_ARB_texture_filter_minmax,
    GL_ARB_texture_float, GL_ARB_texture_gather,
    GL_ARB_texture_mirror_clamp_to_edge, GL_ARB_texture_mirrored_repeat,
    GL_ARB_texture_multisample, GL_ARB_texture_non_power_of_two,
    GL_ARB_texture_query_levels, GL_ARB_texture_query_lod,
    GL_ARB_texture_rectangle, GL_ARB_texture_rg, GL_ARB_texture_rgb10_a2ui,
    GL_ARB_texture_stencil8, GL_ARB_texture_storage,
    GL_ARB_texture_storage_multisample, GL_ARB_texture_swizzle,
    GL_ARB_texture_view, GL_ARB_timer_query, GL_ARB_transform_feedback2,
    GL_ARB_transform_feedback3, GL_ARB_transform_feedback_instanced,
    GL_ARB_transform_feedback_overflow_query, GL_ARB_transpose_matrix,
    GL_ARB_uniform_buffer_object, GL_ARB_vertex_array_bgra,
    GL_ARB_vertex_array_object, GL_ARB_vertex_attrib_64bit,
    GL_ARB_vertex_attrib_binding, GL_ARB_vertex_buffer_object,
    GL_ARB_vertex_program, GL_ARB_vertex_shader,
    GL_ARB_vertex_type_10f_11f_11f_rev, GL_ARB_vertex_type_2_10_10_10_rev,
    GL_ARB_viewport_array, GL_ARB_window_pos, GL_ATI_draw_buffers,
    GL_ATI_texture_float, GL_ATI_texture_mirror_once,
    GL_EXTX_framebuffer_mixed_formats, GL_EXT_Cg_shader, GL_EXT_abgr,
    GL_EXT_bgra, GL_EXT_bindable_uniform, GL_EXT_blend_color,
    GL_EXT_blend_equation_separate, GL_EXT_blend_func_separate,
    GL_EXT_blend_minmax, GL_EXT_blend_subtract, GL_EXT_compiled_vertex_array,
    GL_EXT_depth_bounds_test, GL_EXT_direct_state_access,
    GL_EXT_draw_buffers2, GL_EXT_draw_instanced, GL_EXT_draw_range_elements,
    GL_EXT_fog_coord, GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
    GL_EXT_framebuffer_multisample_blit_scaled, GL_EXT_framebuffer_object,
    GL_EXT_framebuffer_sRGB, GL_EXT_geometry_shader4,
    GL_EXT_gpu_program_parameters, GL_EXT_gpu_shader4,
    GL_EXT_import_sync_object, GL_EXT_memory_object, GL_EXT_memory_object_fd,
    GL_EXT_multi_draw_arrays, GL_EXT_multiview_texture_multisample,
    GL_EXT_multiview_timer_query, GL_EXT_packed_depth_stencil,
    GL_EXT_packed_float, GL_EXT_packed_pixels, GL_EXT_pixel_buffer_object,
    GL_EXT_point_parameters, GL_EXT_polygon_offset_clamp,
    GL_EXT_post_depth_coverage, GL_EXT_provoking_vertex,
    GL_EXT_raster_multisample, GL_EXT_rescale_normal, GL_EXT_secondary_color,
    GL_EXT_semaphore, GL_EXT_semaphore_fd, GL_EXT_separate_shader_objects,
    GL_EXT_separate_specular_color, GL_EXT_shader_image_load_formatted,
    GL_EXT_shader_image_load_store, GL_EXT_shader_integer_mix,
    GL_EXT_shadow_funcs, GL_EXT_sparse_texture2, GL_EXT_stencil_two_side,
    GL_EXT_stencil_wrap, GL_EXT_texture3D, GL_EXT_texture_array,
    GL_EXT_texture_buffer_object, GL_EXT_texture_compression_dxt1,
    GL_EXT_texture_compression_latc, GL_EXT_texture_compression_rgtc,
    GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
    GL_EXT_texture_edge_clamp, GL_EXT_texture_env_add,
    GL_EXT_texture_env_combine, GL_EXT_texture_env_dot3,
    GL_EXT_texture_filter_anisotropic, GL_EXT_texture_filter_minmax,
    GL_EXT_texture_integer, GL_EXT_texture_lod, GL_EXT_texture_lod_bias,
    GL_EXT_texture_mirror_clamp, GL_EXT_texture_object, GL_EXT_texture_sRGB,
    GL_EXT_texture_sRGB_R8, GL_EXT_texture_sRGB_decode,
    GL_EXT_texture_shadow_lod, GL_EXT_texture_shared_exponent,
    GL_EXT_texture_storage, GL_EXT_texture_swizzle, GL_EXT_timer_query,
    GL_EXT_transform_feedback2, GL_EXT_vertex_array, GL_EXT_vertex_array_bgra,
    GL_EXT_vertex_attrib_64bit, GL_EXT_window_rectangles,
    GL_EXT_x11_sync_object, GL_IBM_rasterpos_clip,
    GL_IBM_texture_mirrored_repeat, GL_KHR_blend_equation_advanced,
    GL_KHR_blend_equation_advanced_coherent, GL_KHR_context_flush_control,
    GL_KHR_debug, GL_KHR_no_error, GL_KHR_parallel_shader_compile,
    GL_KHR_robust_buffer_access_behavior, GL_KHR_robustness,
    GL_KHR_shader_subgroup, GL_KTX_buffer_region,
    GL_NVX_blend_equation_advanced_multi_draw_buffers,
    GL_NVX_conditional_render, GL_NVX_gpu_memory_info, GL_NVX_nvenc_interop,
    GL_NVX_progress_fence, GL_NV_ES1_1_compatibility,
    GL_NV_ES3_1_compatibility, GL_NV_alpha_to_coverage_dither_control,
    GL_NV_bindless_multi_draw_indirect,
    GL_NV_bindless_multi_draw_indirect_count, GL_NV_bindless_texture,
    GL_NV_blend_equation_advanced, GL_NV_blend_equation_advanced_coherent,
    GL_NV_blend_minmax_factor, GL_NV_blend_square, GL_NV_clip_space_w_scaling,
    GL_NV_command_list, GL_NV_compute_program5,
    GL_NV_compute_shader_derivatives, GL_NV_conditional_render,
    GL_NV_conservative_raster, GL_NV_conservative_raster_dilate,
    GL_NV_conservative_raster_pre_snap,
    GL_NV_conservative_raster_pre_snap_triangles,
    GL_NV_conservative_raster_underestimation, GL_NV_copy_depth_to_color,
    GL_NV_copy_image, GL_NV_depth_buffer_float, GL_NV_depth_clamp,
    GL_NV_draw_texture, GL_NV_draw_vulkan_image, GL_NV_explicit_multisample,
    GL_NV_feature_query, GL_NV_fence, GL_NV_fill_rectangle,
    GL_NV_float_buffer, GL_NV_fog_distance, GL_NV_fragment_coverage_to_color,
    GL_NV_fragment_program, GL_NV_fragment_program2,
    GL_NV_fragment_program_option, GL_NV_fragment_shader_barycentric,
    GL_NV_fragment_shader_interlock, GL_NV_framebuffer_mixed_samples,
    GL_NV_framebuffer_multisample_coverage, GL_NV_geometry_shader4,
    GL_NV_geometry_shader_passthrough, GL_NV_gpu_multicast,
    GL_NV_gpu_program4, GL_NV_gpu_program4_1, GL_NV_gpu_program5,
    GL_NV_gpu_program5_mem_extended, GL_NV_gpu_program_fp64,
    GL_NV_gpu_shader5, GL_NV_half_float, GL_NV_internalformat_sample_query,
    GL_NV_light_max_exponent, GL_NV_memory_attachment,
    GL_NV_memory_object_sparse, GL_NV_mesh_shader, GL_NV_multisample_coverage,
    GL_NV_multisample_filter_hint, GL_NV_occlusion_query,
    GL_NV_packed_depth_stencil, GL_NV_parameter_buffer_object,
    GL_NV_parameter_buffer_object2, GL_NV_path_rendering,
    GL_NV_path_rendering_shared_edge, GL_NV_pixel_data_range,
    GL_NV_point_sprite, GL_NV_primitive_restart, GL_NV_primitive_shading_rate,
    GL_NV_query_resource, GL_NV_query_resource_tag, GL_NV_register_combiners,
    GL_NV_register_combiners2, GL_NV_representative_fragment_test,
    GL_NV_robustness_video_memory_purge, GL_NV_sample_locations,
    GL_NV_sample_mask_override_coverage, GL_NV_scissor_exclusive,
    GL_NV_shader_atomic_counters, GL_NV_shader_atomic_float,
    GL_NV_shader_atomic_float64, GL_NV_shader_atomic_fp16_vector,
    GL_NV_shader_atomic_int64, GL_NV_shader_buffer_load,
    GL_NV_shader_storage_buffer_object, GL_NV_shader_subgroup_partitioned,
    GL_NV_shader_texture_footprint, GL_NV_shader_thread_group,
    GL_NV_shader_thread_shuffle, GL_NV_shading_rate_image,
    GL_NV_stereo_view_rendering, GL_NV_texgen_reflection,
    GL_NV_texture_barrier, GL_NV_texture_compression_vtc,
    GL_NV_texture_dirty_tile_map, GL_NV_texture_env_combine4,
    GL_NV_texture_multisample, GL_NV_texture_rectangle,
    GL_NV_texture_rectangle_compressed, GL_NV_texture_shader,
    GL_NV_texture_shader2, GL_NV_texture_shader3, GL_NV_timeline_semaphore,
    GL_NV_transform_feedback, GL_NV_transform_feedback2,
    GL_NV_uniform_buffer_unified_memory, GL_NV_vdpau_interop,
    GL_NV_vdpau_interop2, GL_NV_vertex_array_range, GL_NV_vertex_array_range2,
    GL_NV_vertex_attrib_integer_64bit, GL_NV_vertex_buffer_unified_memory,
    GL_NV_vertex_program, GL_NV_vertex_program1_1, GL_NV_vertex_program2,
    GL_NV_vertex_program2_option, GL_NV_vertex_program3,
    GL_NV_viewport_array2, GL_NV_viewport_swizzle, GL_OVR_multiview,
    GL_OVR_multiview2, GL_S3_s3tc, GL_SGIS_generate_mipmap,
    GL_SGIS_texture_lod, GL_SGIX_depth_texture, GL_SGIX_shadow,
    GL_SUN_slice_accum
OpenGL version string: 4.6.0 NVIDIA 470.63.01
OpenGL shading language version string: 4.60 NVIDIA
OpenGL context flags: (none)
OpenGL profile mask: (none)
OpenGL extensions:
    GL_ARB_color_buffer_float, GL_ARB_compatibility,
    GL_ARB_compressed_texture_pixel_storage, GL_ARB_compute_shader,
    GL_ARB_compute_variable_group_size, GL_ARB_conditional_render_inverted,
    GL_ARB_conservative_depth, GL_ARB_copy_buffer, GL_ARB_copy_image,
    GL_ARB_cull_distance, GL_ARB_debug_output, GL_ARB_depth_buffer_float,
    GL_ARB_depth_clamp, GL_ARB_depth_texture, GL_ARB_derivative_control,
    GL_SUN_slice_accum
OpenGL ES profile version string: OpenGL ES 3.2 NVIDIA 470.63.01
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
OpenGL ES profile extensions:
    GL_ANDROID_extension_pack_es31a, GL_EXT_EGL_image_external_wrap_modes,
    GL_EXT_base_instance, GL_EXT_blend_func_extended, GL_EXT_blend_minmax,
    GL_EXT_buffer_storage, GL_EXT_clear_texture, GL_EXT_clip_control,
    GL_EXT_clip_cull_distance, GL_EXT_color_buffer_float,
    GL_EXT_color_buffer_half_float, GL_EXT_compressed_ETC1_RGB8_sub_texture,
    GL_EXT_conservative_depth, GL_EXT_copy_image, GL_EXT_debug_label,
    GL_EXT_depth_clamp, GL_EXT_discard_framebuffer,
    GL_EXT_disjoint_timer_query, GL_EXT_draw_buffers_indexed,
    GL_EXT_draw_elements_base_vertex, GL_EXT_draw_transform_feedback,
    GL_EXT_float_blend, GL_EXT_frag_depth, GL_EXT_geometry_point_size,
    GL_EXT_geometry_shader, GL_EXT_gpu_shader5, GL_EXT_map_buffer_range,
    GL_EXT_memory_object, GL_EXT_memory_object_fd, GL_EXT_multi_draw_indirect,
    GL_EXT_multisample_compatibility, GL_EXT_multisampled_render_to_texture,
    GL_EXT_multisampled_render_to_texture2,
    GL_EXT_multiview_texture_multisample, GL_EXT_multiview_timer_query,
    GL_EXT_occlusion_query_boolean, GL_EXT_polygon_offset_clamp,
    GL_EXT_post_depth_coverage, GL_EXT_primitive_bounding_box,
    GL_EXT_raster_multisample, GL_EXT_render_snorm, GL_EXT_robustness,
    GL_EXT_sRGB, GL_EXT_sRGB_write_control, GL_EXT_semaphore,
    GL_EXT_shader_group_vote, GL_EXT_shader_implicit_conversions,
    GL_EXT_shader_integer_mix, GL_EXT_shader_io_blocks,
    GL_EXT_shader_non_constant_global_initializers, GL_EXT_shader_texture_lod,
    GL_EXT_shadow_samplers, GL_EXT_sparse_texture, GL_EXT_sparse_texture2,
    GL_EXT_tessellation_point_size, GL_EXT_tessellation_shader,
    GL_EXT_texture_border_clamp, GL_EXT_texture_buffer,
    GL_EXT_texture_compression_bptc, GL_EXT_texture_compression_dxt1,
    GL_EXT_texture_compression_rgtc, GL_EXT_texture_compression_s3tc,
    GL_EXT_texture_cube_map_array, GL_EXT_texture_filter_anisotropic,
    GL_EXT_texture_filter_minmax, GL_EXT_texture_format_BGRA8888,
    GL_EXT_texture_mirror_clamp_to_edge, GL_EXT_texture_norm16,
    GL_EXT_texture_query_lod, GL_EXT_texture_rg, GL_EXT_texture_sRGB_R8,
    GL_EXT_texture_sRGB_decode, GL_EXT_texture_shadow_lod,
    GL_EXT_texture_storage, GL_EXT_texture_view, GL_EXT_unpack_subimage,
    GL_EXT_window_rectangles, GL_KHR_blend_equation_advanced,
    GL_KHR_shader_subgroup, GL_KHR_texture_compression_astc_hdr,
    GL_KHR_texture_compression_astc_ldr,
    GL_KHR_texture_compression_astc_sliced_3d,
    GL_NVX_blend_equation_advanced_multi_draw_buffers, GL_NV_bgr,
    GL_NV_bindless_texture, GL_NV_blend_equation_advanced,
    GL_NV_blend_equation_advanced_coherent, GL_NV_blend_minmax_factor,
    GL_NV_clip_space_w_scaling, GL_NV_compute_shader_derivatives,
    GL_NV_conditional_render, GL_NV_conservative_raster,
    GL_NV_conservative_raster_pre_snap_triangles, GL_NV_copy_buffer,
    GL_NV_copy_image, GL_NV_draw_buffers, GL_NV_draw_instanced,
    GL_NV_explicit_attrib_location, GL_NV_fbo_color_attachments,
    GL_NV_fill_rectangle, GL_NV_fragment_coverage_to_color,
    GL_NV_fragment_shader_barycentric, GL_NV_fragment_shader_interlock,
    GL_NV_framebuffer_blit, GL_NV_framebuffer_mixed_samples,
    GL_NV_framebuffer_multisample, GL_NV_generate_mipmap_sRGB,
    GL_NV_geometry_shader_passthrough, GL_NV_gpu_shader5, GL_NV_image_formats,
    GL_NV_instanced_arrays, GL_NV_internalformat_sample_query,
    GL_NV_memory_attachment, GL_NV_memory_object_sparse, GL_NV_mesh_shader,
    GL_NV_non_square_matrices, GL_NV_occlusion_query_samples,
    GL_NV_pack_subimage, GL_NV_packed_float, GL_NV_packed_float_linear,
    GL_NV_path_rendering, GL_NV_path_rendering_shared_edge,
    GL_NV_pixel_buffer_object, GL_NV_polygon_mode,
    GL_NV_primitive_shading_rate, GL_NV_read_buffer, GL_NV_read_depth,
    GL_NV_read_depth_stencil, GL_NV_read_stencil,
    GL_NV_representative_fragment_test, GL_NV_sRGB_formats,
    GL_NV_sample_locations, GL_NV_sample_mask_override_coverage,
    GL_NV_scissor_exclusive, GL_NV_shader_atomic_fp16_vector,
    GL_NV_shader_noperspective_interpolation,
    GL_NV_shader_subgroup_partitioned, GL_NV_shader_texture_footprint,
    GL_NV_shading_rate_image, GL_NV_shadow_samplers_array,
    GL_NV_shadow_samplers_cube, GL_NV_stereo_view_rendering,
    GL_NV_texture_array, GL_NV_texture_barrier, GL_NV_texture_border_clamp,
    GL_NV_texture_compression_latc, GL_NV_texture_compression_s3tc,
    GL_NV_texture_compression_s3tc_update, GL_NV_texture_dirty_tile_map,
    GL_NV_timeline_semaphore, GL_NV_timer_query, GL_NV_viewport_array,
    GL_OES_compressed_ETC1_RGB8_texture, GL_OES_copy_image, GL_OES_depth24,
    GL_OES_depth32, GL_OES_depth_texture, GL_OES_depth_texture_cube_map,
    GL_OES_draw_buffers_indexed, GL_OES_draw_elements_base_vertex,
    GL_OES_element_index_uint, GL_OES_fbo_render_mipmap,
    GL_OES_geometry_point_size, GL_OES_geometry_shader,
    GL_OES_get_program_binary, GL_OES_gpu_shader5, GL_OES_mapbuffer,
    GL_OES_packed_depth_stencil, GL_OES_primitive_bounding_box,
    GL_OES_rgb8_rgba8, GL_OES_sample_shading, GL_OES_sample_variables,
    GL_OES_shader_image_atomic, GL_OES_shader_io_blocks,
    GL_OES_shader_multisample_interpolation, GL_OES_standard_derivatives,
    GL_OES_tessellation_point_size, GL_OES_tessellation_shader,
    GL_OES_texture_border_clamp, GL_OES_texture_buffer,
    GL_OES_texture_cube_map_array, GL_OES_texture_float,
    GL_OES_texture_float_linear, GL_OES_texture_half_float,
    GL_OES_texture_half_float_linear, GL_OES_texture_npot,
    GL_OES_texture_stencil8, GL_OES_texture_storage_multisample_2d_array,
    GL_OES_texture_view, GL_OES_vertex_array_object, GL_OES_vertex_half_float,
    GL_OES_viewport_array, GL_OVR_multiview, GL_OVR_multiview2,
    GL_OVR_multiview_multisampled_render_to_texture
12 GLX Visuals
    visual  x   bf lv rg d st  colorbuffer  sr ax dp st accumbuffer  ms  cav
  id dep cl sp  sz l  ci b ro  r  g  b  a F gb bf th cl  r  g  b  a ns b eat
0x021 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x022 24 dc  0  24  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x715 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x716 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x717 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x718 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4  0  0 16 16 16 16  0 0 None
0x719 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4  0  0 16 16 16 16  0 0 None
0x834 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x835 24 dc  0  24  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x836 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x837 24 dc  0  24  0 r  y .   8  8  8  0 .  s  4  0  0 16 16 16 16  0 0 None
0x838 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4  0  0 16 16 16 16  0 0 None
215 GLXFBConfigs:
0x15e 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x15f 24 dc  0  24  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x160 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x161 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x162 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x163 24 dc  0  24  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x164 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x165 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x166 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x167 24 dc  0  24  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x168 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x169 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x16a 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x16b 24 dc  0  24  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x16c 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x16d 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x16e 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4  0  0 16 16 16 16  0 0 None
0x16f 24 dc  0  24  0 r  y .   8  8  8  0 .  s  4  0  0 16 16 16 16  0 0 None
0x170 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4  0  0 16 16 16 16  0 0 None
0x171 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4  0  0 16 16 16 16  0 0 None
0x172 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4  0  0 16 16 16 16  0 0 None
0x173 24 dc  0  24  0 r  . .   8  8  8  0 .  s  4  0  0 16 16 16 16  0 0 None
0x174 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4  0  0 16 16 16 16  0 0 None
0x175 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4  0  0 16 16 16 16  0 0 None
0x176 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  2 1 None
0x177 24 dc  0  24  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  2 1 None
0x178 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  2 1 None
0x179 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  2 1 None
0x17a 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  4 1 None
0x17b 24 dc  0  24  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  4 1 None
0x17c 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  4 1 None
0x17d 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  4 1 None
0x17e 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  2 1 None
0x17f 24 dc  0  24  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  2 1 None
0x180 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  2 1 None
0x181 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  2 1 None
0x182 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  4 1 None
0x183 24 dc  0  24  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  4 1 None
0x184 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  4 1 None
0x185 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  4 1 None
0x186 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  2 1 None
0x187 24 dc  0  24  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  2 1 None
0x188 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  2 1 None
0x189 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  2 1 None
0x18a 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  4 1 None
0x18b 24 dc  0  24  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  4 1 None
0x18c 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  4 1 None
0x18d 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  4 1 None
0x18e 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  2 1 None
0x18f 24 dc  0  24  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  2 1 None
0x190 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  2 1 None
0x191 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  2 1 None
0x192 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  4 1 None
0x193 24 dc  0  24  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  4 1 None
0x194 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  4 1 None
0x195 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  4 1 None
0x196 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 None
0x197 24 dc  0  24  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 None
0x198 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 None
0x199 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 None
0x19a 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 None
0x19b 24 dc  0  24  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 None
0x19c 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 None
0x19d 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 None
0x19e 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 None
0x19f 24 dc  0  24  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 None
0x1a0 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 None
0x1a1 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 None
0x1a2 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 None
0x1a3 24 dc  0  24  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 None
0x1a4 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 None
0x1a5 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 None
0x1a6 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 None
0x1a7 24 dc  0  24  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 None
0x1a8 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 None
0x1a9 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 None
0x1aa 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 None
0x1ab 24 dc  0  24  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 None
0x1ac 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 None
0x1ad 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 None
0x1ae 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 None
0x1af 24 dc  0  24  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 None
0x1b0 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 None
0x1b1 24 dc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 None
0x1b2 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 None
0x1b3 24 dc  0  24  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 None
0x1b4 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 None
0x1b5 24 dc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 None
0x1b6 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x1b7 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x1b8 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  0 0 None
0x1b9 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  0 0 None
0x1ba 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x1bb 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x1bc 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  0 0 None
0x1bd 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  0 0 None
0x1be 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4  0  0 16 16 16 16  0 0 None
0x1bf 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4  0  0 16 16 16 16  0 0 None
0x1c0 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4  0  0 16 16 16 16  0 0 None
0x1c1 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4  0  0 16 16 16 16  0 0 None
0x1c2 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  2 1 None
0x1c3 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  2 1 None
0x1c4 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  4 1 None
0x1c5 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  4 1 None
0x1c6 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  2 1 None
0x1c7 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  2 1 None
0x1c8 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  4 1 None
0x1c9 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  4 1 None
0x1ca 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  2 1 None
0x1cb 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  2 1 None
0x1cc 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  4 1 None
0x1cd 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  4 1 None
0x1ce 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  2 1 None
0x1cf 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  2 1 None
0x1d0 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  4 1 None
0x1d1 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  4 1 None
0x1d2 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 None
0x1d3 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 None
0x1d4 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16  8 1 None
0x1d5 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16  8 1 None
0x1d6 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 None
0x1d7 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 None
0x1d8 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16  8 1 None
0x1d9 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16  8 1 None
0x1da 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 None
0x1db 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 None
0x1dc 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  0 16 16 16 16 16 1 None
0x1dd 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  0 16 16 16 16 16 1 None
0x1de 24 tc  0  24  0 r  y .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 None
0x1df 24 tc  0  32  0 r  y .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 None
0x1e0 24 tc  0  24  0 r  . .   8  8  8  0 .  s  4 24  8 16 16 16 16 16 1 None
0x1e1 24 tc  0  32  0 r  . .   8  8  8  8 .  s  4 24  8 16 16 16 16 16 1 None
0x1e2  0 sg  0  16  0 r  y .   5  6  5  0 .  .  4 16  0 16 16 16 16  0 0 None
0x1e3  0 sg  0  16  0 r  . .   5  6  5  0 .  .  4 16  0 16 16 16 16  0 0 None
0x1e4  0 sg  0  16  0 r  y .   5  6  5  0 .  .  4 24  0 16 16 16 16  0 0 None
0x1e5  0 sg  0  16  0 r  . .   5  6  5  0 .  .  4 24  0 16 16 16 16  0 0 None
0x1e6  0 sg  0  16  0 r  y .   5  6  5  0 .  .  4 24  8 16 16 16 16  0 0 None
0x1e7  0 sg  0  16  0 r  . .   5  6  5  0 .  .  4 24  8 16 16 16 16  0 0 None
0x1e8  0 sg  0  16  0 r  y .   5  6  5  0 .  .  4  0  0 16 16 16 16  0 0 None
0x1e9  0 sg  0  16  0 r  . .   5  6  5  0 .  .  4  0  0 16 16 16 16  0 0 None
0x1ea  0 sg  0   0  0 r  . .   0  0  0  0 .  .  4 16  0 16 16 16 16  0 0 None
0x1eb  0 sg  0   0  0 r  . .   0  0  0  0 .  .  4 24  0 16 16 16 16  0 0 None
0x1ec  0 sg  0   0  0 r  . .   0  0  0  0 .  .  4 24  8 16 16 16 16  0 0 None
0x1ed  0 sg  0  32  0 r  . .  16 16  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x1ee  0 sg  0  32  0    . .  16 16  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x1ef  0 sg  0  32  0 r  y .  16 16  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x1f0  0 sg  0  32  0    y .  16 16  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x1f1  0 sg  0  32  0 r  . .  32  0  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x1f2  0 sg  0  32  0    . .  32  0  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x1f3  0 sg  0  32  0 r  y .  32  0  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x1f4  0 sg  0  32  0    y .  32  0  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x1f5  0 sg  0  64  0 r  . .  16 16 16 16 f  .  4  0  0 16 16 16 16  0 0 None
0x1f6  0 sg  0  64  0    . .  16 16 16 16 f  .  4  0  0 16 16 16 16  0 0 None
0x1f7  0 sg  0  64  0 r  y .  16 16 16 16 f  .  4  0  0 16 16 16 16  0 0 None
0x1f8  0 sg  0  64  0    y .  16 16 16 16 f  .  4  0  0 16 16 16 16  0 0 None
0x1f9  0 sg  0 128  0 r  . .  32 32 32 32 f  .  4  0  0 16 16 16 16  0 0 None
0x1fa  0 sg  0 128  0    . .  32 32 32 32 f  .  4  0  0 16 16 16 16  0 0 None
0x1fb  0 sg  0 128  0 r  y .  32 32 32 32 f  .  4  0  0 16 16 16 16  0 0 None
0x1fc  0 sg  0 128  0    y .  32 32 32 32 f  .  4  0  0 16 16 16 16  0 0 None
0x1fd  0 sg  0  32  0 r  . .  16 16  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x1fe  0 sg  0  32  0    . .  16 16  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x1ff  0 sg  0  32  0 r  y .  16 16  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x200  0 sg  0  32  0    y .  16 16  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x201  0 sg  0  32  0 r  . .  16 16  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x202  0 sg  0  32  0    . .  16 16  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x203  0 sg  0  32  0 r  y .  16 16  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x204  0 sg  0  32  0    y .  16 16  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x205  0 sg  0  32  0 r  . .  32  0  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x206  0 sg  0  32  0    . .  32  0  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x207  0 sg  0  32  0 r  y .  32  0  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x208  0 sg  0  32  0    y .  32  0  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x209  0 sg  0  32  0 r  . .  32  0  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x20a  0 sg  0  32  0    . .  32  0  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x20b  0 sg  0  32  0 r  y .  32  0  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x20c  0 sg  0  32  0    y .  32  0  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x20d  0 sg  0  64  0 r  . .  16 16 16 16 f  .  4 24  0 16 16 16 16  0 0 None
0x20e  0 sg  0  64  0    . .  16 16 16 16 f  .  4 24  0 16 16 16 16  0 0 None
0x20f  0 sg  0  64  0 r  y .  16 16 16 16 f  .  4 24  0 16 16 16 16  0 0 None
0x210  0 sg  0  64  0    y .  16 16 16 16 f  .  4 24  0 16 16 16 16  0 0 None
0x211  0 sg  0  64  0 r  . .  16 16 16 16 f  .  4 24  8 16 16 16 16  0 0 None
0x212  0 sg  0  64  0    . .  16 16 16 16 f  .  4 24  8 16 16 16 16  0 0 None
0x213  0 sg  0  64  0 r  y .  16 16 16 16 f  .  4 24  8 16 16 16 16  0 0 None
0x214  0 sg  0  64  0    y .  16 16 16 16 f  .  4 24  8 16 16 16 16  0 0 None
0x215  0 sg  0 128  0 r  . .  32 32 32 32 f  .  4 24  0 16 16 16 16  0 0 None
0x216  0 sg  0 128  0    . .  32 32 32 32 f  .  4 24  0 16 16 16 16  0 0 None
0x217  0 sg  0 128  0 r  y .  32 32 32 32 f  .  4 24  0 16 16 16 16  0 0 None
0x218  0 sg  0 128  0    y .  32 32 32 32 f  .  4 24  0 16 16 16 16  0 0 None
0x219  0 sg  0 128  0 r  . .  32 32 32 32 f  .  4 24  8 16 16 16 16  0 0 None
0x21a  0 sg  0 128  0    . .  32 32 32 32 f  .  4 24  8 16 16 16 16  0 0 None
0x21b  0 sg  0 128  0 r  y .  32 32 32 32 f  .  4 24  8 16 16 16 16  0 0 None
0x21c  0 sg  0 128  0    y .  32 32 32 32 f  .  4 24  8 16 16 16 16  0 0 None
0x21d  0 sg  0  16  0 r  . .  16  0  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x21e  0 sg  0  16  0    . .  16  0  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x21f  0 sg  0  16  0 r  y .  16  0  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x220  0 sg  0  16  0    y .  16  0  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x221  0 sg  0  64  0 r  . .  32 32  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x222  0 sg  0  64  0    . .  32 32  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x223  0 sg  0  64  0 r  y .  32 32  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x224  0 sg  0  64  0    y .  32 32  0  0 f  .  4  0  0 16 16 16 16  0 0 None
0x225  0 sg  0  16  0 r  . .  16  0  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x226  0 sg  0  16  0    . .  16  0  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x227  0 sg  0  16  0 r  y .  16  0  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x228  0 sg  0  16  0    y .  16  0  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x229  0 sg  0  16  0 r  . .  16  0  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x22a  0 sg  0  16  0    . .  16  0  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x22b  0 sg  0  16  0 r  y .  16  0  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x22c  0 sg  0  16  0    y .  16  0  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x22d  0 sg  0  64  0 r  . .  32 32  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x22e  0 sg  0  64  0    . .  32 32  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x22f  0 sg  0  64  0 r  y .  32 32  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x230  0 sg  0  64  0    y .  32 32  0  0 f  .  4 24  0 16 16 16 16  0 0 None
0x231  0 sg  0  64  0 r  . .  32 32  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x232  0 sg  0  64  0    . .  32 32  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x233  0 sg  0  64  0 r  y .  32 32  0  0 f  .  4 24  8 16 16 16 16  0 0 None
0x234  0 sg  0  64  0    y .  32 32  0  0 f  .  4 24  8 16 16 16 16  0 0 None
This looks like the card is installed but how to run a game/application using the nVidia drivers? Standard launch results in running the game/application with the Intel Mesa driver with the high performance mode selected.
Thanks for the prompt reply!! I really appreciate it!!
Depends. I think.
I’m not a gamer and very rarely play the 1 game I have, so cannot give you exact instructions. And also, you use Xfce while I use KDE so the procedure might be different than what I’ve got, so I’ll explain only what has to be done, not how to do it.
For Steam:
Edit the game’s Properties or Preferences or Settings or Whateveryouwannacallit and change the execution command to:
prime-run %command%
I think.
Direct shortcuts:
Right-click on the shortcut and open it’s Properties/Preferences. Where the executable is specified, prepend:
prime-run
To the line.
.desktop files:
Edit the file. In the Exec= line, make sure it starts with prime-run:
Exec=prime-run <command>
Where <command> is the command previously used. So prime-run is just prepended to the command.
Hope this helps!
Edit:
This might be of use: Steam Support :: Setting Game Launch Options
And this: Need help to set up prime-run %command% for steam games - Newbie Corner - Manjaro Linux Forum
Also Steam Support :: Optimus and Steam for Linux
According to the steampowered.com website that I linked to:
To make a game run using the discrete GPU, use these simple steps:
  1. Select a game - that you want to run using your discrete Nvidia card - from the Library
    page of the Steam client, right-click, and select Properties…
  2. On the General tab go to the section LAUNCH OPTIONS and enter the command: primusrun %command% for the command line.
  3. Close the window. This method allows you to pick when the discrete NVidia GPU should be used on a per-game basis.
But:
Instead of primusrun %command% use prime-run %command%.
I only play X-Plane that is installed in my home folder using the official installer. Never managed to properly install nVidia on Debian so switched to Mint and it all worked well until Mint started having issues with sound. It worked out of the box after the Driver Manager installed the proprietary drivers. X-Plane wouldn’t even start with the Intel Mesa drivers. However, there is the opposite issue as it start with the Intel Mesa and ignores the nVidia as it is now. When I try to run “prime-run X-Plane_x86-64” it gives me an error.
X-Plane 11]$ prime-run X-Plane-x86_64
/usr/bin/prime-run: line 2: X-Plane-x86_64: command not found
Tried to open the launcher with /usr/bin/prime-run and no luck.
This is the command it can’t find, not prime-run. prime-run is producing the error. So find the correct path for X-Plane-x86_64 and use that.
Edit:
You can also see if the game is installed and where it’s installed with:
which X-Plane-x86_64
And if it is installed you can try and run it with:
prima-run </path/returned/by/which/command>
or, perhaps simpler would be
prime-run $(which X-Plane-x86_64)
to run it if it is installed.
It doesnt appear the file is found. (because it is typed incorrectly?)
Use ls to list things there …
You may even begin to start typing and hit Tab to autofill the path.
prime-run ./X-Plane-x86_64 ?
I was gonna download/run the installer to check … but its a binary, so I will pass :sweat_smile:
Maybe you need optimus-manager to switch between Intel and Nvidia? Might be useful if you are on a laptop. Don’t know how it will work with LightDM, but you should be able to find instructions here
I personally have never needed to use prime-run %command% with optimus-manager.
optimus manager is for changing modes.
The ‘dynamic’ prime-run should work once OP figures out how to launch the desired application.
Hi guys,
Nothing suggested worked but I followed your advice and installed the optimus-manager and optimus-manager-qt. It all works now and it’s easy to switch between the graphics. This video helped extremely(should be on wiki)!!
Once I installed those packages and tried to switch the graphics it told me that there is not a power management installed on my system as I assumed it’s automatic. That could have been the reason why the nVidia didn’t work properly because the power management was missing(I wondered where the battery icon was :slight_smile: ). Laptop-mode installed and the fun may begin. My sincere thanks and appreciation to all of you guys!!!
But … but … I dont think you needed or wanted to do that. laptop-modetools is old, and conflicts with the preferred TLP.
In examples above there was nothing wrong with your setup - you just did not launch your X-Plane correctly.
If you had power issues that was a different problem.
I guess if it works it works … but I think this may not have been the optimal solution.
Yes, installed TLP this morning instead as none of them was installed. That’s the thing I had no idea how to launch it. I assumed that nVidia should be up as the main vga at the time of launching X-Plane as I did it on linux Mint. The HDMI is still a bit tricky and the TV has to be on at boot but I’ve bought mini display cable to HDMI so this could sort the HDMI issue. Don’t care about sound as I use headphones for the game.
It sounds like on Mint you just installed nvidia and bypassed the intel entirely.
You could still do that … but you lose out on powersaving, and have to contend with nvidia compatibility with your whole desktop.
