Qt6 file selection not responding
In QT6 programs, after clicking on the local file selection (“browse file”), it freezes for a few minutes, after the window appears, it hangs as “Not Responding”, but they can select the desired file (directories also take a long time to open)
Hi @kousa – Welcome to the Manjaro forum.
Thank you for providing feedback. Cheers.
Is OBS installed as Flatpak?
Which programs … ?
Custom themes may trigger such behavior - recheck with default Plasma theme.
And please remove the screenshot - in future don’t use screen shots - carefully explain your issue using words only as this will yield better response.
Forum Rules - Manjaro
@medmedin
no
Changing the theme did not solve the problem.
This problem exists for example in telegram, obs, qpwgraph
I added a screenshot because it shows strange symbols in the sidebar
https://0x0.st/H3jr.webp
your issue is still local …
I created a new user, it works as it should, maybe there are suggestions which files to delete to reset the cache or something?
The ArchWiki suggests some ways to reset configurations and clear caches for KDE Plasma:
https://wiki.archlinux.org/title/KDE#Configuration_related
I’ll simply drop this in here: Be wary of packages you might install from sources other than the official repo’s. That is all. Cheers.
