“Worry” is too strong a word - if you don’t see problems, this can be left as is.
Your local package is slightly newer than the currently offered one.
If you’re unsure, you might “doowngrade” that package to exactly match the current version on stable.
Just FYI;
There is no reason to do these 2 together.
They are the same command except uu allows downgrades.
So, with X is newer than.. it was the right way to sync with current branch package version, just no need to do the second one.
