the Theme of Easy Effects is not in dark mode, as the system is configured to use it.
Also happend to other qt6 applications.:
Hi, i am also on xfce and most of the qt apps, 5 and 6, are correctly themed. Testing with ark, qbittorrent, audacious and kde connect. For some reason kde connect is white, but everything else follows the dark theme.
I have qt6 config tool installed and there kvantum-dark selected. (kvantum is also installed obviously, and the theme is compatible - matcha dark). Qt5 config tool is also installed and configured the same way
I also have the QT_QPA_PLATFORMTHEME="qt5ct" variable exported. Not sure if it changes anything (you can also try qt6ct nowadays, should also work)
Some of the newer qt6 applications have their own settings for colors and styling, and easyeffects is one of those. ![]()
