New to linux ,tried reinstalling still didn’t work on both wine and wine-staging
wine: created the configuration directory '/home/reshavp/.wine'
002c:fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
002c:fixme:winediag:LdrInitializeThunk wine-staging 7.5 is a testing version containing experimental patches.
002c:fixme:winediag:LdrInitializeThunk Please mention your exact version when filing bug reports on winehq.org.
0048:fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
0050:fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
wine: Unhandled page fault on execute access to 00007F3FAAA08E30 at address 00007F3FAAA08E30 (thread 0050), starting debugger...
wine: Unhandled page fault on execute access to 00007FE83733A6B0 at address 00007FE83733A6B0 (thread 0048), starting debugger...
0048:err:seh:start_debugger Couldn't start debugger L"winedbg --auto 68 92" (2)
Read the Wine Developers Guide on how to set up winedbg or another debugger
0050:err:seh:start_debugger Couldn't start debugger L"winedbg --auto 76 88" (2)
002c:err:winediag:nodrv_CreateWindow Application tried to create a window, but no driver could be loaded.
002c:err:winediag:nodrv_CreateWindow L"The explorer process failed to start."
0040:err:winediag:nodrv_CreateWindow Application tried to create a window, but no driver could be loaded.
0040:err:winediag:nodrv_CreateWindow L"The explorer process failed to start."
0070:err:winedevice:ServiceMain Failed to load L"C:\\windows\\system32\\win32k.sys"
0070:err:winedevice:ServiceMain Failed to load L"C:\\windows\\system32\\drivers\\dxgkrnl.sys"
0070:err:winedevice:ServiceMain Failed to load L"C:\\windows\\system32\\drivers\\dxgmms1.sys"
0080:err:winediag:nodrv_CreateWindow Application tried to create a window, but no driver could be loaded.
0080:err:winediag:nodrv_CreateWindow L"The explorer process failed to start."
0088:fixme:file:NtLockFile I/O completion on lock not implemented yet
0088:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0088:err:mscoree:LoadLibraryShim error reading registry key for installroot
0090:fixme:file:NtLockFile I/O completion on lock not implemented yet
0090:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0090:err:mscoree:LoadLibraryShim error reading registry key for installroot
00a0:err:winediag:nodrv_CreateWindow Application tried to create a window, but no driver could be loaded.
00a0:err:winediag:nodrv_CreateWindow L"The explorer process failed to start."
00b0:err:winediag:nodrv_CreateWindow Application tried to create a window, but no driver could be loaded.
00b0:err:winediag:nodrv_CreateWindow L"The explorer process failed to start."
0090:fixme:msi:internal_ui_handler internal UI not implemented for message 0x0b000000 (UI level = 5)
0088:fixme:msi:internal_ui_handler internal UI not implemented for message 0x0b000000 (UI level = 1)
00fc:err:winediag:nodrv_CreateWindow Application tried to create a window, but no driver could be loaded.
00fc:err:winediag:nodrv_CreateWindow L"The explorer process failed to start."
00fc:err:winediag:gnutls_process_attach failed to load libgnutls, no support for encryption
00fc:err:winediag:process_attach failed to load libgnutls, no support for pfx import/export
wine: configuration in L"/home/reshavp/.wine" has been updated.
wine: Unhandled page fault on execute access to 00007FD5977E66B0 at address 00007FD5977E66B0 (thread 015c), starting debugger...
