Qt: Segmentation fault while starting program
qt5ct, qt6ct, keepassxc are quitting. Running Manjaro Linux with i3, updates are installed. No missing library (checked with ldd). Problem maybe: ~ is from previous install (arcolinux). Thanx for any help!
Hello @macspyral and wlcome to the Manjaro Community! :vulcan_salute:
It will of course help if you provide some system information. Could you provide the output of this Terminal command? (quick guide below):
inxi -zv8
Note that the output produced by this command is privacy-filtered.
Please also remember to use proper code formatting as this makes it much easier to read on the Forum:
[Mini How-To] format code or command output
Select and copy all the text in the Terminal window (minus the prompt, if you are using zsh).
Then paste the output in between two lines containing three backticks
or three tildes
Or:
Copy & paste, then highlight the pasted text and click the </> button at the top of the reply window (easier for smaller outputs).
Cheers! :wink:
Thank you for Your quick respones, output follows (hope I do it right):
  Kernel: 6.18.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    root=
  Desktop: i3 v: 4.25.1 with: i3bar tools: avail: i3lock,
    xfce4-screensaver, xss-lock vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: LENOVO product: 21HM004HGE v: ThinkPad X1 Carbon Gen 11
  Mobo: LENOVO model: 21HM004HGE v: SDK0T76530 WIN
    serial: <superuser required> part-nu: LENOVO_MT_21HM_BU_Think_FM_ThinkPad
    X1 Carbon Gen 11 uuid: <superuser required> Firmware: UEFI vendor: LENOVO
    v: N3XET54W (1.29 ) date: 05/13/2024
  ID-1: BAT0 charge: 57 Wh (99.1%) condition: 57.6/57 Wh (101%) volts: 17.13
    min: 15.44 model: Sunwoda 5B11M90058 type: Li-poly serial: <filter>
    charging: status: full control: start: 0% end: 100% cycles: 45
  System RAM: total: 16 GiB available: 15.28 GiB used: 1.02 GiB (6.7%)
  Array-1: capacity: 16 GiB slots: 8 modules: 8 EC: None
    max-module-size: 2 GiB note: est.
  Device-1: Controller0-ChannelA type: LPDDR5 detail: synchronous
    size: 2 GiB speed: 6400 MT/s volts: curr: 0.5 width (bits): data: 16
    total: 16 manufacturer: Micron Technology part-no: MT62F1G32D2DS-026 WT
    serial: N/A
  Device-2: Controller0-ChannelB type: LPDDR5 detail: synchronous
    serial: N/A
  Device-3: Controller0-ChannelC type: LPDDR5 detail: synchronous
    serial: N/A
  Device-4: Controller0-ChannelD type: LPDDR5 detail: synchronous
    serial: N/A
  Device-5: Controller1-ChannelA type: LPDDR5 detail: synchronous
    serial: N/A
  Device-6: Controller1-ChannelB type: LPDDR5 detail: synchronous
    serial: N/A
  Device-7: Controller1-ChannelC type: LPDDR5 detail: synchronous
    serial: N/A
  Device-8: Controller1-ChannelD type: LPDDR5 detail: synchronous
    serial: N/A
  Info: model: 13th Gen Intel Core i5-1335U bits: 64 type: MST AMCP
    arch: Raptor Lake level: v3 note: check built: 2022+ process: Intel 7 (10nm)
    family: 6 model-id: 0xBA (186) stepping: 3 microcode: 0x6134
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 10 threads: 12 mt: 2 tpc: 2
    st: 8 smt: enabled cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32
    KiB, 8x64 KiB L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB
    desc: 1x12 MiB
  Speed (MHz): avg: 400 min/max: 400/4600:3400 scaling: driver: intel_pstate
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
    8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 59904
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
    rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
    ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    xtopology xtpr
    conditional; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: Lenovo driver: i915
    v: kernel alternate: xe arch: Xe process: Intel 7 (10nm) built: 2022+ ports:
    active: DP-5,eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-6, DP-7, HDMI-A-1
    bus-ID: 00:02.0 chip-ID: 8086:a7a1 class-ID: 0300
  Device-2: Luxvisions Innotech Integrated RGB Camera driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:5
    chip-ID: 30c9:0052 class-ID: fe01 serial: <filter>
  Display: x11 server: X.org v: 1.21.1.24 driver: X: loaded: modesetting
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1200 s-size: <missing: xdpyinfo>
  Monitor-1: DP-5 mapped: DP-3-1 pos: right model: Idek Iiyama X2485
    serial: <filter> built: 2012 res: mode: 1920x1200 hz: 60 scale: 100% (1)
    dpi: 94 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.310 y: 0.627
    blue: x: 0.153 y: 0.071 white: x: 0.314 y: 0.329
    size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10
    modes: 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900,
    1024x768, 800x600, 640x480, 720x400
  Monitor-2: eDP-1 pos: primary,left model: AU Optronics 0xd291 built: 2020
    res: mode: 1920x1200 hz: 60 scale: 100% (1) dpi: 162 gamma: 1.2 chroma: red:
    x: 0.651 y: 0.337 green: x: 0.294 y: 0.612 blue: x: 0.137 y: 0.051 white:
    x: 0.314 y: 0.341 size: 301x188mm (11.85x7.4") diag: 355mm (14")
    ratio: 16:10 modes: 1920x1200
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 vendor: intel mesa v: 26.1.4-arch1.1 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel Iris Xe Graphics (RPL-U)
    device-ID: 8086:a7a1 memory: 14.92 GiB unified: yes
    x11: xprop,xrandr
  Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Lenovo
    driver: sof-audio-pci-intel-tgl alternate: snd_soc_avs,
    snd_sof_pci_intel_tgl, snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:51ca
    class-ID: 0403
  Device-2: Lenovo USB-C Dock USB Audio
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-3.2:6 chip-ID: 17ef:3103 class-ID: 0300
    serial: <filter>
  API: ALSA v: k6.18.38-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
  Device-2: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
    rev: 3.2 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-3.1:3
    chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp0s13f0u3u1 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:7 chip-ID: 8087:0033
    class-ID: e001
  Local Storage: total: 931.51 GiB used: 272.31 GiB (29.2%)
    model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 4B2QEXM7 temp: 35.9 C scheme: GPT
  ID-1: / raw-size: 91.27 GiB size: 89.28 GiB (97.82%) used: 24.97 GiB (28.0%)
    fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 3f475214-b9f0-47e4-8021-222837b24c12
  ID-2: /boot/efi raw-size: 1.95 GiB size: 1.95 GiB (99.80%)
    used: 488 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 08AA-813A
  ID-3: /home raw-size: 838.29 GiB size: 824.06 GiB (98.30%)
    used: 247.33 GiB (30.0%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
    label: N/A uuid: 7863bd8b-bbe0-45ea-a77f-35b81266592a
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 2-3:2 info: Lenovo USB3.1 Hub ports: 4 rev: 3.2
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 17ef:30fe
  Device-1: 2-3.1:3 info: Realtek RTL8153 Gigabit Ethernet Adapter
    type: Network driver: r8152 interfaces: 1 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 112mA
  Hub-4: 2-3.3:4 info: Lenovo USB3.1 Hub ports: 4 rev: 3.2
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 17ef:3100
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-6: 3-3:2 info: Lenovo USB2.0 Hub ports: 3 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:3102
  Hub-7: 3-3.1:4 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:30ff
  Hub-8: 3-3.1.3:9 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:3101
  Hub-9: 3-3.1.3.2:34 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 3-3.1.3.2.1:35 info: Corsair Gaming K65 RGB RAPIDFIRE Keyboard
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 1b1c:1b39 class-ID: 0300 serial: <filter>
  Device-2: 3-3.1.3.2.4:36 info: SHARKOON GmbH 2.4GHz Wireless rechargeable
    vertical mouse [More&Better] type: mouse driver: hid-generic,usbhid
    interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 1ea7:0064 class-ID: 0301
  Device-3: 3-3.2:6 info: Lenovo USB-C Dock USB Audio type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 30mA
    chip-ID: 17ef:3103 class-ID: 0300 serial: <filter>
  Device-4: 3-3.3:8 info: Lenovo 40B5 type: billboard driver: N/A
    chip-ID: 17ef:30fc class-ID: 1100 serial: <filter>
  Device-5: 3-6:3 info: Synaptics Prometheus Fingerprint Reader
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
    chip-ID: 06cb:00fc class-ID: ff00 serial: <filter>
  Device-6: 3-8:5 info: Luxvisions Innotech Integrated RGB Camera
    type: video driver: uvcvideo interfaces: 5 rev: 2.0
  Device-7: 3-10:7 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0033 class-ID: e001
  Hub-10: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 50.0 C mobo: N/A
  Fan Speeds (rpm): fan-1: 0 fan-2: 0
  Packages: pm: pacman pkgs: 1609 libs: 414 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    2: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    3: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    4: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    5: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    6: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    7: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 253
  1: cpu: 1.6% command: Xorg pid: 979 mem: 84.0 MiB (0.5%)
  2: cpu: 0.7% command: i3bar pid: 1389 mem: 21.0 MiB (0.1%)
  3: cpu: 0.5% command: py3status pid: 1396 mem: 43.8 MiB (0.2%)
  4: cpu: 0.5% command: terminator started-by: python pid: 1533
    mem: 95.4 MiB (0.6%)
  5: cpu: 0.2% command: i3status pid: 1425 mem: 9.80 MiB (0.0%)
  Memory top: 5 of 253
  1: mem: 95.4 MiB (0.6%) command: terminator started-by: python pid: 1533
    cpu: 0.5%
  2: mem: 84.0 MiB (0.5%) command: Xorg pid: 979 cpu: 1.6%
  3: mem: 46.6 MiB (0.2%) command: i3 pid: 1364 cpu: 0.0%
  4: mem: 43.8 MiB (0.2%) command: py3status pid: 1396 cpu: 0.5%
  5: mem: 34.0 MiB (0.2%) command: xfce4-notifyd pid: 3133 cpu: 0.0%
  Processes: 253 Power: uptime: 1h 12m states: freeze,mem,disk suspend: s2idle
    image: 6.04 GiB services: upowerd Init: systemd v: 261 default: graphical
    tool: systemctl
  Compilers: clang: 22.1.6 gcc: 16.1.1 Shell: Zsh v: 5.9.1
    running-in: terminator inxi: 3.3.41
Thanks. I have practically no knowledge of i3 but hopefully someone who does will see this. :eyes:
I do note that neither qt5ct or qt6ct are present on my KDE Plasma system; I would also have thought the former would be obsolete by now? (I don’t have keepassxc either).
I also see you have no swap defined; likely not the issue but it’s something you might want to attend to. :wink:
It may be a good idea to start these from the Terminal and paste the output messages here. :slight_smile:
That is an easy task: all tested Qt-Programs are quitting with a one-liner “segmentation fault (core dumped)”. No further explanation.
I have no knowledge of i3, i am an xfce user (and my keepassxc, qt5 and qt6 apps are working) but something in the user profile can indeed be the reason. Or some aur package. How is the situation with the theming, maybe you use some qt theme that is old and got removed?
To rule out the first hypothesis create one brand new test user and see if it happens there.
That was spot on. Programs are running under new user, thank You for this! So, some old stuff blocks. Well, I’ll give it a go then.
Close all open programs, clean ~/.cache/* and reboot. Let us know, if that changes anything.
Perfect, removed .cache/*, reboot, everything works fine. Thank You, too! Running with this problem for 2 months, you both solved it in one session. Great help!!!
