Qps -- no function good
After installing the 2023-12-10 stable update, I was able to build and install qps version 2.8.0, using Qt library 5.15.11. Now, however, it does not run. This is what comes out when I try to run it:
DEBUG: version = 51640
"Icon Theme not set. Fallbacking to Oxygen, if installed"
"Fallback Icon Theme (Oxygen) not found"
Qps(0x560c21e0f810, name="qps_main_window")
The is nothing labelled qps in Manjaro Linux repo.
If it is a custom script from AUR then check the dependency list at the relevant page - if it is your script check the dependencies.
In either case installing oxygen icon theme may solve the issue.
That might explain it, though…the icons are in the extra repository:
$ pamac search oxygen
oxygen-icons  1:5.112.0-1 [Installed]        extra
The Oxygen Icon Theme
…and can thus be installed using:
pamac install oxygen-icons
Hope this helps!
a Reminder: While use of the AUR is possible, it’s neither recommended nor supported.
I receive the same output, however it runs fine. The Oxygen icon theme is not required.
Ahhh, feels better already! Thanks.
BTW, I have all the dependencies installed, and yet mine requires the Oxygen icons. It didn’t used to.
All I can say is:
:man_shrugging:
