I have the window placement under setting set to ‘centered’. I’m able to move Firefox and other application windows to different places. When I close them and open them again they’re centered. qBittorrent is the only application that does not once to center again. Has anybody come across this issue? I’ve tried uninstalling and reinstalling, but for some reason it retains that info. I even rebooted my system before installing it again. Any help would be great because I can’t seem to Google this one. Thank you.
Uninstalling the program wont touch your home folder … maybe you would have luck nuking your ~/.config/qBittorrent
directory ?
That worked. Thank you.
