Trying to build python2-urllib3
[user@manjaro-kde ~]$ pamac update -a
Preparing...
Refreshing AUR...
Cloning python2-urllib3 build files...
Generating python2-urllib3 information...
Checking python2-urllib3 dependencies...
Checking python2-toml dependencies...
Checking python2-requests dependencies...
Checking python2-webencodings dependencies...
Checking python2-cachecontrol dependencies...
Cloning python2-typing build files...
Generating python2-typing information...
Checking python2-typing dependencies...
Checking python2-html5lib dependencies...
Checking python2-retrying dependencies...
Checking python2-colorama dependencies...
Checking python2-chardet dependencies...
Checking python2-numpy dependencies...
Checking python2-pytest-expect dependencies...
Checking python2-u-msgpack dependencies...
Resolving dependencies...
Checking inter-conflicts...
To build (13):
python2-urllib3 1.26.11-1 (1.26.7-1) AUR
python2-chardet 4.0.0-3 (4.0.0-2) AUR
python2-requests 2.27.1.r5.gfa1b0a36-1 (2.26.0-1) AUR
python2-cachecontrol 0.12.6-7 (0.12.6-5) AUR
python2-colorama 0.4.5-1 (0.4.4-3) AUR
python2-webencodings 0.5.1-7 (0.5.1-6) AUR
python2-u-msgpack 2.7.1-3 AUR
python2-pytest-expect 1.1.0-8 AUR
python2-html5lib 1.1-12 (1.1-8) AUR
python2-retrying 1.3.3-13 (1.3.3-9) AUR
python2-numpy 1.16.6-2 AUR
python2-toml 0.10.2-7 (0.10.2-3) AUR
python2-typing 3.10.0.2-1 (3.10.0.0-1) AUR
Edit build files : [e]
Apply transaction ? [e/y/N]
test_source_address failed (1 runs remaining out of 2).
<type 'exceptions.AssertionError'>
assert '::1' == '127.0.0.1'
- ::1
+ 127.0.0.1
[<TracebackEntry /var/tmp/pamac-build-user/python2-urllib3/src/urllib3-1.26.11/test/with_dummyserver/test_connectionpool.py:714>]
test_source_address failed; it passed 0 out of the required 1 times.
- ::1
+ 127.0.0.1
test_source_address_error failed (1 runs remaining out of 2).
<class 'builtins.Failed'>
DID NOT RAISE <class 'urllib3.exceptions.NewConnectionError'>
[<TracebackEntry /var/tmp/pamac-build-user/python2-urllib3/src/urllib3-1.26.11/test/with_dummyserver/test_connectionpool.py:728>]
test_source_address_error failed; it passed 0 out of the required 1 times.
test_stream_keepalive passed 1 out of the required 1 times. Success!
test_connect_reconn passed 1 out of the required 1 times. Success!
test_connect_ipv6_addr passed 1 out of the required 1 times. Success!
test_https_proxymanager_connected_to_http_proxy[http] passed 1 out of the required 1 times. Success!
test_ssl_failure_midway_through_conn passed 1 out of the required 1 times. Success!
test_ssl_read_timeout failed (1 runs remaining out of 2).
<class 'urllib3.exceptions.MaxRetryError'>
HTTPSConnectionPool(host='localhost', port=39387): Max retries exceeded with url: / (Caused by ReadTimeoutError("HTTPSConnectionPool(host='localhost', port=39387): Read timed out. (read timeout=0.01)",))
[<TracebackEntry /var/tmp/pamac-build-user/python2-urllib3/src/urllib3-1.26.11/test/with_dummyserver/test_socketlevel.py:1264>, <TracebackEntry /var/tmp/pamac-build-user/python2-urllib3/src/urllib3-1.26.11/src/urllib3/connectionpool.py:788>, <TracebackEntry /var/tmp/pamac-build-user/python2-urllib3/src/urllib3-1.26.11/src/urllib3/util/retry.py:592>]
test_ssl_read_timeout failed; it passed 0 out of the required 1 times.
HTTPSConnectionPool(host='localhost', port=38597): Max retries exceeded with url: / (Caused by ReadTimeoutError("HTTPSConnectionPool(host='localhost', port=38597): Read timed out. (read timeout=0.01)",))
test_ssl_failed_fingerprint_verification passed 1 out of the required 1 times. Success!
test_retry_ssl_error passed 1 out of the required 1 times. Success!
test_ssl_load_default_certs_when_empty passed 1 out of the required 1 times. Success!
test_ssl_dont_load_default_certs_when_given passed 1 out of the required 1 times. Success!
test_load_verify_locations_exception passed 1 out of the required 1 times. Success!
test_ssl_custom_validation_failure_terminates passed 1 out of the required 1 times. Success!
test_requesting_large_resources_via_ssl[True-None] passed 1 out of the required 1 times. Success!
test_requesting_large_resources_via_ssl[False-None] passed 1 out of the required 1 times. Success!
test_requesting_large_resources_via_ssl[False-2147483648] passed 1 out of the required 1 times. Success!
test_bad_statusline passed 1 out of the required 1 times. Success!
test_unknown_protocol passed 1 out of the required 1 times. Success!
test_headers_are_sent_with_the_original_case passed 1 out of the required 1 times. Success!
test_ua_header_can_be_overridden passed 1 out of the required 1 times. Success!
test_request_headers_are_sent_in_the_original_order passed 1 out of the required 1 times. Success!
test_response_headers_are_returned_in_the_original_order passed 1 out of the required 1 times. Success!
test_header_text_plain passed 1 out of the required 1 times. Success!
test_header_message_rfc822 passed 1 out of the required 1 times. Success!
test_chunked_head_response_does_not_hang passed 1 out of the required 1 times. Success!
test_empty_head_response_does_not_hang passed 1 out of the required 1 times. Success!
test_stream_none_unchunked_response_does_not_hang passed 1 out of the required 1 times. Success!
test_enforce_content_length_get passed 1 out of the required 1 times. Success!
test_enforce_content_length_no_body passed 1 out of the required 1 times. Success!
test_pool_size_retry_drain_fail passed 1 out of the required 1 times. Success!
test_ignore_broken_pipe_errors passed 1 out of the required 1 times. Success!
test_multipart_assert_header_parsing_no_defects passed 1 out of the required 1 times. Success!
===End Flaky Test Report===
============================================================================ 4 failed, 1615 passed, 286 skipped, 56 deselected, 148 warnings in 161.28 seconds =============================================================================
==> ERROR: A failure occurred in check().
Aborting...
