Hello,
I am running a manjaro architect server. I successfully update the system with pamac update
. Since I have several AUR packages installed such as snapraid and mergerfs, I tried to update the system later with pamac update -a
One of python library (mako) fails to build because of failure in signature check.
To build (6):
python2-mako 1.1.5-1 (1.1.2-1) AUR
python2-pynacl-git 1.4.0.r31.f6c17a3-1 AUR
python2-paramiko 2.7.2-1 (2.7.1-1) AUR
python2-simplejson 3.17.5-1 (3.17.2-3) AUR
ssmtp 2.64-16 (2.64-11) AUR
python2-hupper 1.9.1-1 AUR
To remove (1):
python2-pynacl 1.3.0-3 (Conflicts With: python2-pynacl-git)
Total removed size: 648.0 kB
Edit build files : [e]
Apply transaction ? [e/y/N] y
Building python2-mako...
Running as unit: run-u32.service
Press ^] three times within 1s to disconnect TTY.
==> Making package: python2-mako 1.1.5-1 (Tue 14 Sep 2021 12:15:11 AM +03)
==> Retrieving sources...
-> Found Mako-1.1.5.tar.gz
-> Found Mako-1.1.5.tar.gz.asc
==> Validating source files with sha512sums...
Mako-1.1.5.tar.gz ... Passed
Mako-1.1.5.tar.gz.asc ... Skipped
==> Verifying source file signatures with gpg...
Mako-1.1.5.tar.gz ... cat: write error: Broken pipe
FAILED
==> ERROR: One or more PGP signatures could not be verified!
Finished with result: exit-code
Main processes terminated with: code=exited/status=1
Service runtime: 804ms
CPU time consumed: 793ms
Error: Failed to build python2-mako
I appreciate any help or guidance about resolving this problem.
