Hi, i have been using manjaro for a while and finally figured why my system kept freezing out of no where. it only happens when im watching any kind of video on any browser (i tried firefox and chrome) i can’t figure out what is wrong here is my pc spec
pcie_acs_override=downstream, i am using this to properly passtrough my gpu to my kvm by default 2 of my gpu are in the same iommu group using the pcie acs patch it resolves that problem so i can properly do the gpu passtrough
Kernel: 5.4.69-1-MANJARO i am using this one because when i use kernel 58 the problem is even worst.
I see … you are manually building your own kernel ?
Well then yes … it makes sense to match up with whatever branch you are using.
And of course … you are going to need to make sure the modules are loaded and all … so either make sure mhwd is integrated, or to do it manually, etc.
Hi, I have the same problem for about a year and it is exactly the same as Cobiyyy described: It is always a chance, that my system freezes, when I am watching a video or even watching GIFs or making a video call or doing a screen share for example in Discord.
I also have the Kernel Version 5.4.101-1-MANJARO x86_64, is there any chance that I can switch to a stable branch if that one is unstable or do I have to wait until maybe there will be a stable update?
Here are more infos I got from using the inxi-command:
I’m not sure about AMD graphics, check which config is active now with mhdw -limhwd -li. If it shows something like video-linux, try changing it to modesetting with sudo mhwd -i pci video-modesetting and reboot then.
If that doesn’t help, I can only suggest installing some newer kernel to see how it works with your APU, maybe linux 5.10 is better in this sense: sudo pacman -S linux510 linux510-headers.
Hello and thank you for your advice. mhdw is unfortunately a command my linux does not know. Is there also another command or what do I have to install?
Ah alright Thank you,
I have done that and I had indeed the video-linux. I changed it now and hope that it helps. I will write again in about a month if I had any more Problems or if the problem is solved.
Regardless, thanks a lot for your help
Hello,
The Problem got a little better when I watch Videos, but my System still freezes, when I do a Screenshare or Video-Call. I installed the Linux510 kernel as well, is there anything I can do additionally?
