Hello all,
My pacman package “python-dbus” is the current one. In spite of this I get a module “dbus” error as follows:
python3 gnome-randr.py
Traceback (most recent call last):File “/home/leder/bin/gnome-randr.py”, line 3, in import sys, os, dbusModuleNotFoundError: No module named ‘dbus’
pip3 install dbus
ERROR: Could not find a version that satisfies the requirement dbus (from versions: none)ERROR: No matching distribution found for dbus
any ideas? I installed
Pakete (1) dbus-1.16.2-1
inxi -zv8
Kernel: 6.17.7-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.17-x86_64
root=UUID=319bf7d3-8a5c-4792-8db7-4df6981a2bbc rw quiet splash
pcie_aspm=off apparmor=1 security=apparmor
resume=UUID=fc9e3ee8-7dee-416a-a1ec-e6d6b877967c udev.log_priority=3
nvidia-drm.modeset=1
Desktop: GNOME v: 49.1 tk: GTK v: 3.24.51 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 49.1 Distro: Manjaro
base: Arch Linux
Mobo: ASUSTeK model: ROG CROSSHAIR VIII DARK HERO v: Rev X.0x
UEFI: American Megatrends v: 5201 date: 09/10/2025
Device-1: hidpp_battery_0 model: Logitech PRO X 2 DEX serial: <filter>
charge: 100% rechargeable: yes status: charging
System RAM: total: 64 GiB available: 62.69 GiB used: 11.09 GiB (17.7%)
Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 16 GiB speed: 2666 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMD32GX4M2C3200C16 serial: N/A
Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
part-no: CMD32GX4M2B3000C15 serial: N/A
Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 0 microcode: 0xA201030
Topology: cpus: 1x dies: 1 clusters: 1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB
desc: 16x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 1746 min/max: 582/5086 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 1746 2: 1746 3: 1746
4: 1746 5: 1746 6: 1746 7: 1746 8: 1746 9: 1746 10: 1746 11: 1746 12: 1746
13: 1746 14: 1746 15: 1746 16: 1746 17: 1746 18: 1746 19: 1746 20: 1746
21: 1746 22: 1746 23: 1746 24: 1746 25: 1746 26: 1746 27: 1746 28: 1746
29: 1746 30: 1746 31: 1746 32: 1746 bogomips: 217614
xsaves xtopology
affected
Device-1: NVIDIA AD102 [GeForce RTX 4090] vendor: ZOTAC driver: nvidia
v: 580.105.08 alternate: nouveau,nova_core,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-08) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
ports: active: DP-1,DP-2,DP-3 empty: HDMI-A-1 bus-ID: 0c:00.0
chip-ID: 10de:2684 class-ID: 0300
Device-2: Logitech Webcam C930e driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-3.1:4
chip-ID: 046d:0843 class-ID: 0102 serial: <filter>
Display: wayland server: X.org v: 1.21.1.20 with: Xwayland v: 24.1.9
compositor: gnome-shell driver: X: loaded: nvidia
gpu: nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: DP-1 model: Philips PHL 329P1 serial: <filter> built: 2022
res: 3840x2160 dpi: 140 gamma: 1.2 chroma: red: x: 0.682 y: 0.314 green:
x: 0.286 y: 0.659 blue: x: 0.153 y: 0.039 white: x: 0.314 y: 0.329
size: 697x392mm (27.44x15.43") diag: 800mm (31.5") ratio: 16:9
modes: 3840x2160, 1920x2160, 2560x1440, 1920x1080, 1680x1050, 1280x1024,
1440x900, 1280x960, 1280x720, 1024x768, 800x600, 720x576, 720x480,
640x480
Monitor-2: DP-2 model: Gigabyte AORUS FO32U2P serial: <filter> built: 2024
res: 3840x2160 dpi: 141 gamma: 1.2 chroma: red: x: 0.686 y: 0.306 green:
x: 0.243 y: 0.710 blue: x: 0.141 y: 0.055 white: x: 0.314 y: 0.329
size: 699x395mm (27.52x15.55") diag: 793mm (31.2") ratio: 16:9
modes: 3840x2160, 2560x1440, 1920x1080, 1680x1050, 1600x900, 1280x1024,
1440x900, 1280x960, 1280x800, 1152x864, 1280x720, 1024x768, 1440x480,
800x600, 720x480, 640x480
EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid:
unhandled CEA mode 117 3: parse_edid: unhandled CEA mode 118 4: parse_edid:
unhandled CEA mode 94 5: parse_edid: unhandled CEA mode 95 6: parse_edid:
unhandled CEA mode 96 7: parse_edid: unknown tag 112
Monitor-3: DP-3 model: Acer XV322QK KV serial: <filter> built: 2022
res: 3840x2160 dpi: 140 gamma: 1.2 chroma: red: x: 0.678 y: 0.314 green:
x: 0.271 y: 0.627 blue: x: 0.145 y: 0.051 white: x: 0.314 y: 0.329
modes: 3840x2160, 2560x1440, 1920x1080, 1680x1050, 1280x1024, 1440x900,
1280x960, 1152x864, 1280x720, 1024x768, 800x600, 720x576, 720x480,
640x480
unhandled CEA mode 118 3: parse_edid: unknown tag 112
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
x11: drv: nvidia inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.105.08
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4090/PCIe/SSE2
memory: 23.43 GiB display-ID: :0.0
API: Vulkan v: 1.4.328 layers: 7 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4090 driver: nvidia v: 580.105.08
device-ID: 10de:2684 surfaces: N/A
Info: Tools: api: eglinfo, glxinfo, vulkaninfo
gpu: nvidia-settings,nvidia-smi x11: xprop,xrandr
Device-1: NVIDIA AD102 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel alternate: nova_core pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 0c:00.1 chip-ID: 10de:22ba class-ID: 0403
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech Webcam C930e driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.17.7-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
Device-1: Aquantia AQtion AQC107 NBase-T/IEEE 802.3an Ethernet [Atlantic
10G] vendor: ASUSTeK driver: atlantic v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 4 port: N/A bus-ID: 05:00.0 chip-ID: 1d6a:07b1 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 07:00.0
IF: enp7s0 state: down mac: <filter>
Device-4: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp8s0 state: up mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:5 chip-ID: 8087:0029
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 4.89 TiB used: 3.44 TiB (70.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 960 PRO 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B6QCXP7 temp: 28.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Lexar model: SSD NM790 4TB
size: 3.73 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 12237 temp: 50.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: OCZ model: VERTEX4 size: 238.47 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD
serial: <filter> fw-rev: 1.5 scheme: GPT
ID-1: / raw-size: 3.66 TiB size: 3.6 TiB (98.40%) used: 2.45 TiB (68.1%)
fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:4 label: N/A
uuid: 319bf7d3-8a5c-4792-8db7-4df6981a2bbc
used: 308 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3 label: N/A
uuid: 1B4B-4B52
ID-3: /mnt/data raw-size: 952.65 GiB size: 936.63 GiB (98.32%)
used: 836.99 GiB (89.4%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:1
label: N/A uuid: ac045e9d-3702-464e-b302-e3f3272276ee
ID-4: /mnt/data2 raw-size: 237.5 GiB size: 232.71 GiB (97.98%)
used: 177.08 GiB (76.1%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 5ee340bd-d824-4be0-9bf9-ca6b25e2cd31
ID-1: swap-1 type: partition size: 68.98 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:5 label: swap
uuid: fc9e3ee8-7dee-416a-a1ec-e6d6b877967c
Hub-2: 1-3:2 info: ATEN USB2.1 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0557:5411
Device-1: 1-3.1:4 info: Google Titan Security Key v2 type: HID
lanes: 1 mode: 1.1 power: 60mA chip-ID: 18d1:9470 class-ID: 0300
serial: <filter>
Hub-3: 1-3.3:6 info: ATEN Hub ports: 4 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0557:8021 class-ID: 0900
Device-1: 1-3.3.1:8 info: ATEN CS1942DP_1944DP type: keyboard,mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0557:2200 class-ID: 0301
Hub-4: 1-5:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-5.3:7 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
serial: <filter>
Device-2: 1-6:5 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Hub-5: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-6: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Hub-7: 3-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
chip-ID: 174c:2074 class-ID: 0900
Hub-8: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-9: 4-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
chip-ID: 174c:3074 class-ID: 0900
Hub-10: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-11: 5-3:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
Device-1: 5-3.1:4 info: Logitech Webcam C930e type: video,audio
Device-2: 5-3.2:5 info: Logitech PowerPlay Wireless Charging System
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 498mA
chip-ID: 046d:c53a class-ID: 0300
Device-3: 5-3.3:6 info: Keychron Q0 type: keyboard,HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 3434:0130 class-ID: 0300
serial: <filter>
Device-4: 5-3.4:7 info: Keychron Q3 keychron/q3/iso_encoder
type: keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 3434:0123 class-ID: 0300 serial: <filter>
Device-5: 5-4:3 info: Reiner SCT Kartensysteme GmbH cyberJack RFID
comfort dual interface smartcard reader type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 350mA chip-ID: 0c4b:0501 class-ID: 0000 serial: <filter>
Hub-12: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-13: 6-3:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0817
System Temperatures: cpu: 45.0 C mobo: 39.0 C
Fan Speeds (rpm): cpu: 0
Packages: 2643 pm: pacman pkgs: 2598 libs: 538
tools: gnome-software,pamac,yay pm: flatpak pkgs: 45
1: https://mirror.23m.com/manjaro/testing/$repo/$arch
2: https://ask4.mm.fcix.net/manjaro/testing/$repo/$arch
3: https://ftp.belnet.be/mirrors/manjaro/repos/testing/$repo/$arch
4: https://ftp.halifax.rwth-aachen.de/manjaro/testing/$repo/$arch
5: https://mirror.dkm.cz/manjaro/testing/$repo/$arch
6: https://mirror.xeonbd.com/manjaro/testing/$repo/$arch
7: https://mirror.freedif.org/Manjaro/testing/$repo/$arch
8: https://mirror.phoepsilonix.love/manjaro/testing/$repo/$arch
Processes:
CPU top: 5 of 691
1: cpu: 21.6% command: exe pid: 37239 mem: 574.1 MiB (0.8%)
2: cpu: 16.6% command: localsearch-extractor-3 pid: 38484
mem: 46.8 MiB (0.0%)
3: cpu: 7.7% command: vivaldi-bin pid: 38308 mem: 198.9 MiB (0.3%)
4: cpu: 7.6% command: gnome-shell pid: 4746 mem: 1047.6 MiB (1.6%)
5: cpu: 7.0% command: vesktop.bin pid: 37143 mem: 246.7 MiB (0.3%)
Memory top: 5 of 691
1: mem: 1047.6 MiB (1.6%) command: gnome-shell pid: 4746 cpu: 7.6%
2: mem: 574.1 MiB (0.8%) command: exe pid: 37239 cpu: 21.6%
3: mem: 543.9 MiB (0.8%) command: vivaldi-bin pid: 19369 cpu: 3.9%
4: mem: 517.6 MiB (0.8%) command: java pid: 12126 cpu: 0.6%
5: mem: 462.7 MiB (0.7%) command: jetbrains-toolbox pid: 5005 cpu: 0.9%
Processes: 691 Power: uptime: 51m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.97 GiB services: gsd-power,
power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
tool: systemctl
Compilers: clang: 21.1.5 gcc: 15.2.1 alt: 13/14 Shell: Zsh v: 5.9
running-in: ghostty inxi: 3.3.39
