Hey there, I’m not an expert with everything about booting manjaro on laptops, but I experienced an issue and I found a solution.
This is about my DELL XPS 15 9560 and the last update.
My setup :
Linux etienne 5.10.15-1-MANJARO #1 SMP PREEMPT Wed Feb 10 10:42:47 UTC 2021 x86_64 GNU/Linux
When I first install manjaro I didn’t had to change anything (using UEFI). But with this last update I was not able to boot at all (black screen).
The only way I found is by adding this kernel parameter :
acpi_rev_override=1
Steps :
- boot with a manjaro live CD
- manjaro-chroot -a
- nano
/etc/default/grub
- add the parameter to this line :
GRUB_CMDLINE_LINUX_DEFAULT="...acpi_rev_override=1"
- RUN
update-grub
I hope this will help some of you guys.
HF <3
PS: I tried this because I remember that when I first installed manjaro (~=v17) I had to add some kernel parameters
