PulseAudio problems
I installed pulseaudio and the equaliser. Then when I went to Youtube, there was no sound and the picture was always still.
Please post more information about PulseAudio
pacmd list-sinks
pactl list sink-inputs
pacmd list-sinks
1 sink(s) available.
  * index: 0
	driver: <module-alsa-card.c>
	flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
	state: RUNNING
	suspend cause: (none)
	priority: 9039
	volume: front-left: 89061 / 136% / 7.99 dB,   front-right: 89061 / 136% / 7.99 dB,   rear-left: 89061 / 136% / 7.99 dB,   rear-right: 89061 / 136% / 7.99 dB,   front-center: 90439 / 138% / 8.39 dB,   lfe: 90439 / 138% / 8.39 dB
	        balance 0.00
	base volume: 65536 / 100% / 0.00 dB
	volume steps: 65537
	muted: no
	current latency: 75.32 ms
	max request: 38 KiB
	max rewind: 38 KiB
	monitor source: 0
	sample spec: s16le 6ch 44100Hz
	channel map: front-left,front-right,rear-left,rear-right,front-center,lfe
	             Surround 5.1
	used by: 1
	linked by: 1
	configured latency: 75.01 ms; range is 0.50 .. 2000.00 ms
	card: 1 <alsa_card.pci-0000_00_1f.3>
	module: 7
	properties:
		alsa.resolution_bits = "16"
		device.api = "alsa"
		device.class = "sound"
		alsa.class = "generic"
		alsa.subclass = "generic-mix"
		alsa.name = "ALC892 Analog"
		alsa.id = "ALC892 Analog"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		alsa.device = "0"
		alsa.card = "0"
		alsa.long_card_name = "HDA Intel PCH at 0xa3530000 irq 152"
		sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
		device.bus = "pci"
		device.vendor.id = "8086"
		device.product.id = "a348"
		device.product.name = "Cannon Lake PCH cAVS"
		device.string = "surround51:0"
		device.buffering.buffer_size = "1058400"
		device.buffering.fragment_size = "529200"
		device.access_mode = "mmap+timer"
		device.profile.name = "analog-surround-51"
		device.profile.description = "Surround 5.1 analógico"
		device.description = "Áudio Interno Surround 5.1 analógico"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-pci"
	ports:
		analog-output-lineout: Linha de saída (priority 9000, latency offset 0 usec, available: yes)
			properties:
	active port: <analog-output-lineout>
Entrada de depósito #0
	Controlador: protocol-native.c
	Módulo proprietário: 9
	Cliente: 8
	Depósito: 0
	Especificação da amostra: float32le 2ch 44100Hz
	Mapa de canais: front-left,front-right
	Formato: pcm, format.sample_format = "\"float32le\""  format.rate = "44100"  format.channels = "2"  format.channel_map = "\"front-left,front-right\""
	Mudo: não
	Volume: não
		front-left: 43379 /  66% / -10,75 dB,   front-right: 43379 /  66% / -10,75 dB
	        balanço 0,00
	Latência do buffer: 124988 usec
	Latência do Depósito: 44009 usec
	Método de reamostragem: copy
	Propriedades:
		media.name = "CNN - Direto"
		application.name = "Firefox"
		native-protocol.peer = "UNIX socket client"
		native-protocol.version = "35"
		application.process.id = "1679"
		application.process.user = "fernando"
		application.process.host = "fernando-ms7b18"
		application.process.binary = "firefox"
		application.language = "pt_PT.utf8"
		window.x11.display = ":0.0"
		application.process.machine_id = "7bab7f4379864c40a4f32236d9f2aac5"
		application.process.session_id = "2"
		application.icon_name = "firefox"
		module-stream-restore.id = "sink-input-by-application-name:Firefox"
I don’t have a PulseAudio equaliser at the moment. I’ve uninstalled it.
I solved the problem with the command : pamac install manjaro-pulse
