Wascar
8 December 2020 14:09
1
Hi everyone.
I have some issue with Pulseaudio. After startup, i have no sound in my jack headset and changing volume has no effects. I need to restart pulseaudio manually with pulseaudio --kill && pulseaudio --start
to temporary fix the issue but this is not convenient.
Can you help me ?
Desktop Environment : GNOME
Sound Card : Realtek ALC887-VD
Motherboard : GIGABYTE 970A-DS3P v1
pobrn
8 December 2020 22:47
2
Please post the output of inxi -Fazy
, pa-info
when it does not work, and pa-info
when it does work.
Wascar
9 December 2020 18:30
3
Result of inxi - Fazy
: inxi -Fazy - Pastebin.com
Result of pa-info
(Broken) : pa-info broken - Pastebin.com
Result of pa-info
(Working) : pa-info working - Pastebin.com
pobrn
9 December 2020 19:28
4
You shouldn’t have run pa-info
as root. Please run them as your user.
Simple mixer control 'Master',0`
[broken] Mono: Playback 45 [70%] [-19.00dB] [off]
[working] Mono: Playback 47 [73%] [-17.00dB] [on]
Simple mixer control 'Headphone',0
[broken] Front Left: Playback 0 [0%] [-64.00dB] [off]
Front Right: Playback 0 [0%] [-64.00dB] [off]
[working] Front Left: Playback 64 [100%] [0.00dB] [on]
Front Right: Playback 64 [100%] [0.00dB] [on]
Simple mixer control 'Front',0
[broken] Front Left: Playback 64 [100%] [0.00dB] [off]
Front Right: Playback 64 [100%] [0.00dB] [off]
[working] Front Left: Playback 0 [0%] [-64.00dB] [on]
Front Right: Playback 0 [0%] [-64.00dB] [on]
Simple mixer control 'IEC958',0`
[broken] Mono: Playback [off]
[working] Mono: Playback [on]
I suggest you run these commands to unmute speakers and headphones in ALSA
amixer sset 'Master' 47 unmute
amixer sset 'Headphone' 64 unmute
amixer sset 'Front' 64 unmute
and this to ensure settings are saved
sudo alsactl store
