Pulseaudio jacksink stopped playing sounds
Hi,
I’ve been using jack with pulseaudio with usb devices for a while, and everything worked perfectly until yesterday : For a reason I can’t find, the Pulseaudio jacksink (the bridge between jack and pulseaudio) seems dead since yesterday. I haven’t changed any settings, the only unusual thing I did was playing audio through bluetooth with jack running. Playing sound through jack or pulseaudio only still works though.
Also the jack log does not return any error related to this.
Here is some of my system info : (I use testing branch)
  ~ $ inxi -F
  Host: ZaManjaro Kernel: 6.4.0-1-MANJARO arch: x86_64 bits: 64 Desktop: bspwm
    v: 0.9.10 Distro: Manjaro Linux
  Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X570ZD_R570ZD
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: X570ZD v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: X570ZD.310 date: 07/04/2019
  ID-1: BAT0 charge: 3.3 Wh (10.5%) condition: 31.3/48.1 Wh (65.2%)
    volts: 11.7 min: 11.7
  Info: quad core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
    bits: 64 type: MT MCP cache: L2: 4 MiB
  Speed (MHz): avg: 1662 min/max: 1600/2000 cores: 1: 1514 2: 1600 3: 1513
    4: 1600 5: 1600 6: 2271 7: 1600 8: 1600
  Device-1: NVIDIA GP107M [GeForce GTX 1050 Mobile] driver: N/A
  Device-2: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
    driver: amdgpu v: kernel
  Device-3: IMC Networks USB2.0 VGA UVC WebCam driver: uvcvideo type: USB
  Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: modesetting
    dri: radeonsi gpu: amdgpu resolution: 1920x1080~60Hz
  API: OpenGL v: 4.6 Mesa 23.0.4 renderer: AMD Radeon Vega 8 Graphics
    (raven LLVM 15.0.7 DRM 3.52 6.4.0-1-MANJARO)
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
  Device-2: AMD Family 17h/19h HD Audio driver: snd_hda_intel
  Device-3: Mark of the Unicorn M4 driver: cdc_acm,snd-usb-audio type: USB
  API: ALSA v: k6.4.0-1-MANJARO status: kernel-api
  Server-1: PulseAudio v: 16.1 status: active
  Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
    driver: ath10k_pci
  IF: wlp2s0 state: up mac: c0:e4:34:18:d6:45
    driver: r8169
  IF: enp3s0 state: down mac: 04:d9:f5:01:0a:82
  Device-1: IMC Networks driver: btusb type: USB
  Local Storage: total: 476.94 GiB used: 196.92 GiB (41.3%)
  ID-1: /dev/sda vendor: Kingston model: RBUSNS8180DS3512GJ size: 476.94 GiB
  ID-1: / size: 468.09 GiB used: 196.92 GiB (42.1%) fs: ext4 dev: /dev/sda2
  ID-2: /boot/efi size: 299.4 MiB used: 280 KiB (0.1%) fs: vfat
    dev: /dev/sda1
  System Temperatures: cpu: 79.5 C mobo: N/A gpu: amdgpu temp: 79.0 C
  Fan Speeds (RPM): cpu: 5200
  Processes: 256 Uptime: 5h 29m Memory: available: 6.72 GiB
  used: 2.54 GiB (37.8%) Shell: fish inxi: 3.3.27
Does anyone know how to fix this ? Not even the arch wiki could help me :cry:
Thanks
Solved, it was muted in pavucontrol… I didn’t try to click there until now :triumph: :roll_eyes:
