Wifi unreliable
Hello, since recent update (6.0.13-1-MANJARO-ARM-AML) I have been noticing that my wifi network is almost unusable, it seems to de-associate or similar, I’m not sure but i looks like it happen as soon as there’s some load.
What I was able to get from dmesg was:
[ 4139.527813] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
[ 4139.531120] ieee80211 phy0: brcmf_cfg80211_dump_station: BRCMF_C_GET_ASSOCLIST failed, err=-110
[ 4157.527770] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
[ 4157.531072] ieee80211 phy0: brcmf_cfg80211_dump_station: BRCMF_C_GET_ASSOCLIST failed, err=-110
[ 4193.527762] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
[ 4193.531064] ieee80211 phy0: brcmf_cfg80211_dump_station: BRCMF_C_GET_ASSOCLIST failed, err=-110
[ 4205.687755] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
[ 4211.527719] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
[ 4211.531061] ieee80211 phy0: brcmf_cfg80211_dump_station: BRCMF_C_GET_ASSOCLIST failed, err=-110
[ 4217.527728] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
[ 4217.531032] ieee80211 phy0: brcmf_cfg80211_dump_station: BRCMF_C_GET_ASSOCLIST failed, err=-110
[ 4224.407712] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
[ 4229.527696] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
[ 4229.531003] ieee80211 phy0: brcmf_cfg80211_dump_station: BRCMF_C_GET_ASSOCLIST failed, err=-110
[ 4237.457703] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
[ 4242.407714] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
[ 4242.411017] ieee80211 phy0: brcmf_cfg80211_dump_station: BRCMF_C_GET_ASSOCLIST failed, err=-110
[ 4248.567674] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
[ 4248.570974] ieee80211 phy0: brcmf_cfg80211_dump_station: BRCMF_C_GET_ASSOCLIST failed, err=-110
[ 4255.847662] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
[ 4258.407648] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
[ 4258.410952] ieee80211 phy0: brcmf_cfg80211_get_station: GET STA INFO failed, -110
[ 4261.377650] ieee80211 phy0: brcmf_proto_bcdc_query_dcmd: brcmf_proto_bcdc_msg failed w/status -110
How could I debug it further? if I disconnect and reconnect it works again for a while and then same issue.
This sounds like the same as @JFL and one other user was experiencing.
@spikerguy Maybe it’s a firmware issue or a brcm driver update in the kernel?
It’s too early but so far it seems that sudo iw dev wlan0 set power_save off is helping…
There is a slight difference. In my case WIFI is only available for a minute or two, load or NO load. After that WIFI and Network is no logner available and if you close Chromium and try to relaunch Chromium or other applications, most of the time it will NOT launch anymore. The system basically become unstable – this is with 6.1.y. It might be mainline upstream 6.1.y issue as I had also tried 2 other kernels 6.1.y (build by ophub/unifreq and Armbian 6.1.0-meson64) and both also had the same issue.
On linux-6.0.y the last i tried the earlier version, I did not face any WIFI issue.
@everybody Linux 6.1.6-2 from unstable branch solved the problem for me
So it works on your ugoos??
Which device?
Yep, very well on am6b+
Which firmware are you using?
Operating System: Manjaro ARM
KDE Plasma Version: 5.26.5
KDE Frameworks Version: 5.101.0
Qt Version: 5.15.8
Kernel Version: 6.1.6-2-MANJARO-ARM (64-bit)
Graphics Platform: Wayland
Processors: 2 × ARM Cortex-A53, 4 × ARM Cortex-A73
Memory: 3.6 Gio of RAM
Graphics Processor: Mali-G52
Product Name: Ugoos AM6b Plus
Firmware? i use my own dtb
Beelink GT King Pro, the linux-6.1.6-1 resolved the WIFI issue. Thank you.
Wifi6 firmware you used ?
BCM43752/2 wl0: Jul 13 2020 18:32:45 version 18.35.387.23.7
from here : firmware/brcm at master · armbian/firmware · GitHub
Can you share your DTB files and firmware with me?I also have the AM6B+ model. Thank you very much.my email is c18122583370@gmail.com
Hello
You can find it here.
it is patch,how can i get dtb file from it
