Cause of error:
Downloading a few needed scripts for certain mods to work on Final Fantasy XV.
Kernel: 5.13.13-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=e577da92-ef1b-4176-bf41-140994193173 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Micro-Star model: MAG X570 TOMAHAWK WIFI (MS-7C84)
v: 1.0 serial: <filter> UEFI: American Megatrends LLC. v: 1.60
date: 05/28/2021
RAM: total: 31.28 GiB used: 7.36 GiB (23.5%)
Info: 12-Core model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3
family: 19 (25) model-id: 21 (33) stepping: 0 microcode: A201009 cache:
L2: 6 MiB bogomips: 177686
Speed: 3349 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz):
1: 3349 2: 2547 3: 2511 4: 2568 5: 2615 6: 2553 7: 2383 8: 2565 9: 2879
10: 2876 11: 3595 12: 2879 13: 2872 14: 2880 15: 2880 16: 2877 17: 3596
18: 2873 19: 2876 20: 2875 21: 3600 22: 2874 23: 2878 24: 2878
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean
vme vmmcall vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: NVIDIA GA102 [GeForce RTX 3080] vendor: eVga.com. driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 2d:00.0
chip-ID: 10de:2206 class-ID: 0300
Screen-1: 0 s-res: 3840x1080 s-dpi: 81 s-size: 1204x343mm (47.4x13.5")
s-diag: 1252mm (49.3")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 81 size: 600x340mm (23.6x13.4")
diag: 690mm (27.2")
Monitor-2: DP-0 res: 1920x1080 dpi: 82 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
OpenGL: renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: NVIDIA GA102 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus-ID: 2d:00.1 chip-ID: 10de:1aef
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 2f:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel port: f000 bus-ID: 26:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp38s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
Local Storage: total: 2.73 TiB used: 134.75 GiB (4.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 35.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 21.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
type: SSD serial: <filter> rev: 4B6Q scheme: GPT
ID-1: / raw-size: 50 GiB size: 48.91 GiB (97.83%) used: 12.69 GiB (26.0%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:3 label: root
uuid: e577da92-ef1b-4176-bf41-140994193173
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:2 label: BOOT
uuid: 3930-31C8
ID-3: /home raw-size: 881.01 GiB size: 866.11 GiB (98.31%)
used: 122.05 GiB (14.1%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:4
label: home uuid: b4012f31-1b13-4654-9385-9a1a3eb8bada
ID-1: /dev/nvme1n1p1 maj-min: 259:5 size: 931.51 GiB fs: ext4 label: N/A
uuid: b79d2e91-769a-4b8c-ae3b-6c3f72fc21ba
ID-2: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ext4 label: backup
uuid: 65e8e9bb-d885-48cd-bc7c-966ea0e5993e
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 1-4:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-2: 1-6:3 info: Glorious Model O Wireless type: Mouse,Keyboard
power: 500mA chip-ID: 258a:2011 class-ID: 0301 serial: <filter>
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 3-1:2 info: GreenAsia multimedia keyboard controller
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 100mA chip-ID: 0e8f:0022 class-ID: 0300
Device-2: 3-5:3 info: Micro Star MYSTIC LIGHT type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7c84 class-ID: 0300 serial: <filter>
Hub-4: 3-6:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-7: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 41.5 C mobo: N/A gpu: nvidia temp: 27 C
Processes: 448 Uptime: 7h 19m wakeups: 0 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1305 pacman: 1300 lib: 396
flatpak: 0 snap: 5 Shell: Zsh v: 5.8 default: Bash v: 5.1.8
running-in: konsole inxi: 3.3.06
How to cause said error:
protontricks 637650 vcrun2017 d3dcompiler_47
Error:
Executing mkdir -p /home/ltn/.steam/steam/steamapps/compatdata/637650
warning: You are using a 64-bit WINEPREFIX. Note that many verbs only install 32-bit versions of packages. If
you encounter problems, please retest in a clean 32-bit WINEPREFIX before reporting a bug.
Using winetricks 20210206-next - sha256sum: 0769bbcdbd92c407f4eacaa85acc1339f607dbeafe2febd1be0912034c7af3a1
with wine-6.16 (Staging) and WINEARCH=win64
Executing w\_do\_call vcrun2017
Executing load\_vcrun2017
Using native,builtin override for following DLLs: api-ms-win-crt-private-l1-1-0 api-ms-win-crt-conio-l1-1-0 ap
i-ms-win-crt-heap-l1-1-0 api-ms-win-crt-locale-l1-1-0 api-ms-win-crt-math-l1-1-0 api-ms-win-crt-runtime-l1-1-0
api-ms-win-crt-stdio-l1-1-0 api-ms-win-crt-time-l1-1-0 atl140 concrt140 msvcp140 msvcp140\_1 msvcp140\_2 msvcr1
40 ucrtbase vcomp140 vcruntime140
Executing /home/ltn/.cache/protontricks/proton/Proton-6.16-GE-1/bin/wine regedit C:\\windows\\Temp\\override-dll.
reg
pressure-vessel-wrap\[204835\]: W: Binding directories that are located under "/usr/" is not supported!
wineserver: using server-side synchronization.
002c:fixme:winediag:LdrInitializeThunk wine-staging 6.16 is a testing version containing experimental patches.
002c:fixme:winediag:LdrInitializeThunk Please mention your exact version when filing bug reports on winehq.org
warning: Working around wine bug 50894 -- Working around failing wusa.exe lookup via C:\\windows\\SysNative
Executing /home/ltn/.cache/protontricks/proton/Proton-6.16-GE-1/bin/wine winecfg -v winxp64
pressure-vessel-wrap\[205466\]: W: Binding directories that are located under "/usr/" is not supported!
warning: Running /home/ltn/.cache/protontricks/proton/Proton-6.16-GE-1/bin/wineserver -w. This will hang until
all wine processes in prefix=/home/ltn/.steam/steam/steamapps/compatdata/637650/pfx terminate
pressure-vessel-wrap\[206396\]: W: Binding directories that are located under "/usr/" is not supported!
Executing cabextract -q --directory=/home/ltn/.steam/steam/steamapps/compatdata/637650/pfx/dosdevices/c:/windo
ws/temp/win32 /home/ltn/.cache/winetricks/vcrun2017/vc\_redist.x86.exe -F a10
pressure-vessel-wrap\[206628\]: W: Binding directories that are located under "/usr/" is not supported!
ws/syswow64 /home/ltn/.steam/steam/steamapps/compatdata/637650/pfx/dosdevices/c:/windows/temp/win32/a10 -F ucr
tbase.dll
pressure-vessel-wrap\[206860\]: W: Binding directories that are located under "/usr/" is not supported!
/home/ltn/.steam/steam/steamapps/compatdata/637650/pfx/dosdevices/c:/windows/temp/win32/a10: WARNING; possible
16776 extra bytes at end of file.
Executing cd /home/ltn/.cache/winetricks/vcrun2017
Executing /home/ltn/.cache/protontricks/proton/Proton-6.16-GE-1/bin/wine vc\_redist.x86.exe
pressure-vessel-wrap\[207091\]: W: Binding directories that are located under "/usr/" is not supported!
0024:fixme:heap:RtlSetHeapInformation unimplemented HeapEnableTerminationOnCorruption
0024:fixme:advapi:DecryptFileW (L"C:\\\\users\\\\steamuser\\\\Temp\\\\{A43F13E5-1C90-4169-B5D8-DB8A71C3938E}\\\\", 00000
000): stub
0128:fixme:heap:RtlSetHeapInformation unimplemented HeapEnableTerminationOnCorruption
0128:fixme:advapi:DecryptFileW (L"C:\\\\users\\\\steamuser\\\\Temp\\\\{FEADA5C0-A962-4CA9-A5AC-7CD49F995878}\\\\", 00000
000): stub
0134:fixme:shell:SHAutoComplete stub
0134:err:richedit:ReadColorTbl malformed entry
0134:err:richedit:ReadStyleSheet skipping optional destination #(This repeated 50 times.)
000): stub
0128:fixme:exec:SHELL\_execute flags ignored: 0x00000100
013c:fixme:heap:RtlSetHeapInformation unimplemented HeapEnableTerminationOnCorruption
013c:fixme:ole:CoInitializeSecurity 0067F5E8, -1, 00000000, 00000000, 6, 2, 00000000, 12288, 00000000 stub
013c:fixme:wuapi:automatic\_updates\_Pause
013c:fixme:sfc:SRSetRestorePointW 0067F4B0 0067F6C0
0148:fixme:advapi:DecryptFileW (L"C:\\\\ProgramData\\\\Package Cache\\\\{D5AEE36E-4771-4F65-BDB6-8C59077BFBE4}v14.16
.27033\\\\packages\\\\vcRuntimeMinimum\_x86\\\\vc\_runtimeMinimum\_x86.msi", 00000000): stub
.27033\\\\packages\\\\vcRuntimeMinimum\_x86\\\\cab1.cab", 00000000): stub
0148:fixme:advapi:DecryptFileW (L"C:\\\\ProgramData\\\\Package Cache\\\\{88D1025F-45D0-45C6-9EDB-379C2EE07AD7}v14.16
.27033\\\\packages\\\\vcRuntimeAdditional\_x86\\\\vc\_runtimeAdditional\_x86.msi", 00000000): stub
.27033\\\\packages\\\\vcRuntimeAdditional\_x86\\\\cab1.cab", 00000000): stub
013c:fixme:file:NtLockFile I/O completion on lock not implemented yet
013c:fixme:ntdll:NtQuerySystemInformation info\_class SYSTEM\_PERFORMANCE\_INFORMATION
013c:err:msi:extract\_cabinet FDICopy failed
013c:err:msi:ACTION\_InstallFiles Failed to extract cabinet: L"cab1.cab"
013c:err:msi:execute\_script Execution of script 0 halted; action L"InstallFiles" returned 1603
013c:err:msi:ITERATE\_Actions Execution halted, action L"InstallFinalize" returned 1603
00d8:fixme:explorer:webbrowser\_QueryInterface (000000014001A220)->({00000003-0000-0000-c000-000000000046} 0000
00000021DC48) interface not supported
00000021DBA8) interface not supported
00d8:fixme:explorer:webbrowser\_QueryInterface (000000014001A220)->({00000019-0000-0000-c000-000000000046} 0000
0000004F8270) interface not supported
013c:fixme:wuapi:automatic\_updates\_Resume
013c:fixme:ver:GetCurrentPackageId (0067FE94 00000000): stub
0128:fixme:ver:GetCurrentPackageId (0067FE94 00000000): stub
0024:fixme:ver:GetCurrentPackageId (0032FE94 00000000): stub
warning: Note: command /home/ltn/.cache/protontricks/proton/Proton-6.16-GE-1/bin/wine vc\_redist.x86.exe return
ed status 67. Aborting.
Further reporting of error:
While it does launch the window necessary to initiate the vcrun2017 download, once you try to download it, immediately after it fails to download and does not continue to try to download d3dcompiler_47 once you exit out of the failed vcrun2017 window.
What do I need to do to install what I need to install using Protontricks without error?
