Hi I have a issue, none of my games will no longer launch via any proton version, i have remove and reinstalled them on Steam and no I am not using a NTFS drive, I know it has to be Ext4
here is a log of Steam and the same proton error comes up
[corey@corey-pc ~]$ steam
Running Steam on manjarolinux 20.2.1 64-bit
STEAM_RUNTIME is enabled automatically
Found newer runtime version for 32-bit libjack.so.0. Host: 0.0.28 Runtime: 0.1.0
Forced use of runtime version for 32-bit libdbusmenu-gtk.so.4. Host: 4.0.12 Runtime: 4.0.13
Forced use of runtime version for 32-bit libdbusmenu-glib.so.4. Host: 4.0.12 Runtime: 4.0.13
Forced use of runtime version for 32-bit libgtk-x11-2.0.so.0. Host: 0.2400.32 Runtime: 0.2400.10
Found newer runtime version for 32-bit libGLU.so.1. Host: 1.3.1 Runtime: 1.3.8004
Forced use of runtime version for 32-bit libcurl.so.4. Host: 4.7.0 Runtime: 4.2.0
Found newer runtime version for 64-bit libjack.so.0. Host: 0.0.28 Runtime: 0.1.0
Found newer runtime version for 64-bit libdbusmenu-gtk.so.4. Host: 4.0.12 Runtime: 4.0.13
Found newer runtime version for 64-bit libdbusmenu-glib.so.4. Host: 4.0.12 Runtime: 4.0.13
Found newer runtime version for 64-bit libGLU.so.1. Host: 1.3.1 Runtime: 1.3.8004
Forced use of runtime version for 64-bit libcurl.so.4. Host: 4.7.0 Runtime: 4.2.0
Forced use of runtime version for 32-bit libdbus-1.so.3. Host: 3.19.13 Runtime: 3.5.8
Found newer runtime version for 32-bit libudev.so.0. Host: 0.0.9999 Runtime: 0.13.0
Found newer runtime version for 64-bit libudev.so.0. Host: 0.0.9999 Runtime: 0.13.0
Steam client's requirements are satisfied
/home/corey/.local/share/Steam/ubuntu12_32/steam
[2021-02-02 03:30:13] Startup - updater built Dec 20 2020 23:07:02
Installing breakpad exception handler for appid(steam)/version(1608507519)
[2021-02-02 03:30:13] Loading cached metrics from disk (/home/corey/.local/share/Steam/package/steam_client_metrics.bin)
[2021-02-02 03:30:13] Using the following download hosts for Public, Realm steamglobal
[2021-02-02 03:30:13] 1. https://cdn.akamai.steamstatic.com, /client/, Realm 'steamglobal', weight was 100, source = 'update_hosts_cached.vdf'
[2021-02-02 03:30:13] Verifying installation...
[2021-02-02 03:30:13] Verification complete
Loaded SDL version 2.0.14-6278618
(steam:20005): Gtk-WARNING **: 03:30:13.880: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Materia-dark/gtk-2.0/main.rc:790: error: unexpected identifier 'direction', expected character '}'
(steam:20005): Gtk-WARNING **: 03:30:13.882: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Materia-dark/gtk-2.0/hacks.rc:28: error: invalid string constant "normal_entry", expected valid string constant
STEAM_RUNTIME_HEAVY: ./steam-runtime-heavy
[0202/033014.150086:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: browser
[0202/033014.167593:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0202/033014.167640:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1608505622
[0202/033014.167644:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0202/033014.167648:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0202/033014.249001:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0202/033014.249048:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1608505622
[0202/033014.249052:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0202/033014.249055:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0202/033014.249474:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: gpu-process
[0202/033014.426151:WARNING:crash_reporting.cc(286)] Failed to set crash key: UserID with value: 0
[0202/033014.426197:WARNING:crash_reporting.cc(286)] Failed to set crash key: BuildID with value: 1608505622
[0202/033014.426201:WARNING:crash_reporting.cc(286)] Failed to set crash key: SteamUniverse with value: Public
[0202/033014.426204:WARNING:crash_reporting.cc(286)] Failed to set crash key: Vendor with value: Valve
[0202/033014.426630:INFO:crash_reporting.cc(247)] Crash reporting enabled for process: utility
CAppInfoCacheReadFromDiskThread took 78 milliseconds to initialize
Local Device Found
type: 046d c21d
path: sdl://0
serial_number: - 0
Manufacturer:
Product: Logitech F310 Gamepad (XInput)
Release: 4014
Interface: -1
!! Steam controller device opened for index 0.
Steam Controller reserving XInput slot 0
CApplicationManagerPopulateThread took 837 milliseconds to initialize (will have waited on CAppInfoCacheReadFromDiskThread)
Proceed to auto login
Opted-in Controller Mask for AppId 0: 0
Controller 0 connected, configuring it now...
Controller has an Invalid or missing unit serial number, setting to '46d-c21d-33d080f'
BYieldingQueryAccountsRegisteredToController
(steam:20005): Gtk-WARNING **: 03:30:16.975: gtk_disable_setlocale() must be called before gtk_init()
!! Controller 0 attributes:
Type: 31
ProductID: 49693
Serial: 46d-c21d-33d080f
Capabilities: 001843ff
Firmware Version: 0
Firmware Build Time: 2147483647 (Tue, 19 Jan 2038 03:14:07 GMT)
Bootloader Build Time: 2147483647 (Tue, 19 Jan 2038 03:14:07 GMT)
Could not load local selection (), local override (/home/corey/.local/share/Steam//controller_config/bigpicture_gamepad.vdf), or user path (/home/corey/.local/share/Steam/userdata/54331407/config/controller_configs/bigpicture_gamepad.vdf), checking last resort path: /home/corey/.local/share/Steam//controller_base/bigpicture_gamepad.vdf
Loaded Config for Last Resort Path for App ID 413090, Controller 0: /home/corey/.local/share/Steam//controller_base/bigpicture_gamepad.vdf
[413090]Non-Steam Controller Configs Enabled: 1
Loaded Config for Local Selection Path for App ID 413090, Controller 0: /mnt/GameDrive/Steam/steamapps/workshop/content/241100/1557881022/956347096063773104_legacy.bin
Opted-in Controller Mask for AppId 413080: 0
Loaded Config for Local Override Path for App ID 413080, Controller 0: /home/corey/.local/share/Steam//controller_base/empty.vdf
[413080]Non-Steam Controller Configs Enabled: 1
Controller device closed after hid_read failure
Controller 0 disconnected
Local Device Found
type: 046d c21d
path: sdl://0
serial_number: - 0
Manufacturer:
Release: 4014
Interface: -1
local (potentially out of sync) copy of roaming config loaded - 4284 bytes.
BYieldingQueryAccountsRegisteredToController - controller disconnected while waiting.
Type: 31
ProductID: 49693
Firmware Version: 0
Loaded Config for Local Selection Path for App ID 413090, Controller 0: /mnt/GameDrive/Steam/steamapps/workshop/content/241100/1689651975/1007024772344596662_legacy.bin
roaming config store loaded successfully - 4284 bytes.
migrating temporary roaming config store
BRefreshApplicationsInLibrary 1: 25ms
Fetching Config Sets 0
CClientJobFetchPersonalizationFileID
[0202/033019.356470:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[0202/033019.427712:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[0202/033019.512628:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
Set Account Config Sets 0 1 1
Failed to init SteamVR because it isn't installed
ExecCommandLine: "'/home/corey/.local/share/Steam/ubuntu12_32/steam'"
System startup time: 6.42 seconds
Type: 31
ProductID: 49693
Firmware Version: 0
OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
[0202/033019.988920:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[0202/033019.989752:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
[0202/033019.991728:INFO:crash_reporting.cc(270)] Crash reporting enabled for process: renderer
src/common/singleprocesspipe_any.cpp (200) : Assertion Failed: m_Peeked.second == false || m_nEventCount > 0
crash_20210202033020_30.dmp[20180]: Uploading dump (out-of-process)
/tmp/dumps/crash_20210202033020_30.dmp
BuildCompleteAppOverviewChange: 332
RegisterForAppOverview 1: 11ms
RegisterForAppOverview 2: 12ms
ExecuteSteamURL: "steam://open/downloads"
crash_20210202033020_30.dmp[20180]: Finished uploading minidump (out-of-process): success = yes
crash_20210202033020_30.dmp[20180]: response: CrashID=bp-8213fe52-39d9-4852-bc2a-f8fa52210201
crash_20210202033020_30.dmp[20180]: file ''/tmp/dumps/crash_20210202033020_30.dmp'', upload yes: ''CrashID=bp-8213fe52-39d9-4852-bc2a-f8fa52210201''
[945360]Non-Steam Controller Configs Enabled: 1
Opted-in Controller Mask for AppId 945360: 0
CAPIJobRequestUserStats - Server response failed 2
Loaded Config for Local Override Path for App ID 945360, Controller 0: /home/corey/.local/share/Steam//controller_base/empty.vdf
GameAction [AppID 945360, ActionID 1] : LaunchApp changed task to ProcessingInstallScript with ""
pressure-vessel-adverb[20670]: Unable to generate locales: Child process exited with code 139
/mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: 5: /mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: import: not found
/mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: 6: /mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: import: not found
/mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: 7: /mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: import: not found
/mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: 8: /mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: import: not found
/mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: 9: /mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: import: not found
/mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: 10: /mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: import: not found
/mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: 11: /mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: import: not found
/mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: 12: /mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: import: not found
/mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: 13: /mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: import: not found
/mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: 14: /mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: import: not found
/mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: 15: /mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: import: not found
/mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: 16: /mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: import: not found
/mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: 18: /mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: from: not found
/mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: 26: /mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: ld_path_var: not found
/mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: 28: /mnt/GameDrive/Steam/steamapps/common/Proton 5.13/proton: Syntax error: "(" unexpected
src/clientdll/installscript_posix.cpp (419) : Assertion Failed: Standalone evaluator returned error code for app 945360
crash_20210202033032_38.dmp[20726]: Uploading dump (out-of-process)
/tmp/dumps/crash_20210202033032_38.dmp
GameAction [AppID 945360, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 945360, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 945360, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 945360, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
Game update: AppID 945360 "", ProcID 20728, IP 0.0.0.0:0
ERROR: ld.so: object '/home/corey/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
Starting app 945360
>>> Adding process 20728 for game ID 945360
GameAction [AppID 945360, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
pid 20733 != 20729, skipping destruction (fork without exec?)
GameAction [AppID 945360, ActionID 1] : LaunchApp changed task to Completed with ""
>>> Adding process 20729 for game ID 945360
pid 20740 != 20729, skipping destruction (fork without exec?)
>>> Adding process 20731 for game ID 945360
>>> Adding process 20732 for game ID 945360
>>> Adding process 20734 for game ID 945360
>>> Adding process 20735 for game ID 945360
>>> Adding process 20736 for game ID 945360
>>> Adding process 20742 for game ID 945360
Game removed: AppID 945360 "", ProcID 20728
Uploaded AppInterfaceStats to Steam
>>> Adding process 20743 for game ID 945360
Exiting app 945360
No cached sticky mapping in ActivateActionSet.No cached sticky mapping in ActivateActionSet.crash_20210202033032_38.dmp[20726]: Finished uploading minidump (out-of-process): success = yes
crash_20210202033032_38.dmp[20726]: response: CrashID=bp-e8478975-f734-4ab9-9c86-5863b2210201
crash_20210202033032_38.dmp[20726]: file ''/tmp/dumps/crash_20210202033032_38.dmp'', upload yes: ''CrashID=bp-e8478975-f734-4ab9-9c86-5863b2210201''
