Proton games frozen when they have focus
All the proton games I try to run display a few frames, then appear to be frozen. This includes old games marked as platinum on proton db like Nier Automata.
If I alt-tab to another app, the game in the background unfreezes and seems to run normally. If I focus back to the game, it freezes again and ultimately becomes completely unresponsive.
Here is some context:
  • I use proprietary nvidia drivers with a RTX 2080
Things I tried to resolve the issue:
  • Tried to run games from a new user account to rule out any configuration issue in my home
  • Tried all proton versions
Hello flupke, please post your system if you need help:
inxi --admin --verbosity=5 --filter --no-host --width
Also errors outputs:
systemctl --failed
journalctl -p 3 -xb
Also check for native Linux games, if they are freezing too or not.
Hello Kobold, thanks for you help.
All native games run fine, and there is nothing relevant in systemctl or journalctl.
  Kernel: 6.1.92-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=a514a2b0-d4ef-429c-bf79-2d9d714ba982 rw quiet
    cryptdevice=UUID=11ebe887-a587-4328-a9b1-edf8e8977154:luks-11ebe887-a587-4328-a9b1-edf8e8977154
    root=/dev/mapper/luks-11ebe887-a587-4328-a9b1-edf8e8977154 apparmor=1
    security=apparmor
    resume=/dev/mapper/luks-3e7888b9-de0a-4ee3-bf5f-81ccf8cd8533
    udev.log_priority=3
  Desktop: i3 v: 4.23 with: i3bar tools: xss-lock avail: i3lock,xautolock
    vt: 7 dm: 1: GDM v: 46.0 note: stopped 2: LightDM v: 1.32.0 Distro: Manjaro
    base: Arch Linux
  Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: X570 AORUS ELITE v: x.x serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: F35
    date: 07/08/2021
  Device-1: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 64 GiB available: 62.74 GiB used: 13.93 GiB (22.2%)
    (unregistered) size: 16 GiB speed: 2133 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
    part-no: F4-3200C16-16GVK serial: N/A
    part-no: F4-3200C15-16GVK serial: N/A
  Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
  Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
  Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
    L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 2640 high: 3992 min/max: 2200/5083 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 3400
    3: 3400 4: 2200 5: 2885 6: 3170 7: 3343 8: 2878 9: 3596 10: 2200 11: 2822
    12: 2200 13: 2847 14: 2879 15: 2200 16: 2879 17: 3992 18: 3636 19: 2200
    20: 2200 21: 2200 22: 2200 23: 2200 24: 2200 25: 2503 26: 2200 27: 2878
    28: 2200 29: 2200 30: 2200 31: 2200 32: 2200 bogomips: 217673
  Type: spec_rstack_overflow mitigation: safe RET, no microcode
    affected
  Device-1: NVIDIA TU104 [GeForce RTX 2080 Rev. A] vendor: eVga.com.
    driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 09:00.0 chip-ID: 10de:1e87 class-ID: 0300
  Device-2: Elgato Systems GmbH Cam Link 4K
    driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.0
    speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 8-1:2 chip-ID: 0fd9:0066
    class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 162 s-size: 602x341mm (23.70x13.43")
    s-diag: 692mm (27.24")
  Monitor-1: DP-4 res: 3840x2160 dpi: 163 size: 600x340mm (23.62x13.39")
    diag: 690mm (27.15") modes: N/A
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce RTX 2080/PCIe/SSE2
    memory: 7.81 GiB
  API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 2080 driver: nvidia v: 550.78 device-ID: 10de:1e87
    surfaces: xcb,xlib
  Device-1: NVIDIA TU104 HD Audio vendor: eVga.com. driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 09:00.1
    chip-ID: 10de:10f8 class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
    bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Logitech Blue Microphones
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 046d:0ab7 class-ID: 0300
    serial: <filter>
  Device-4: Audient iD22 driver: snd-usb-audio type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3.3:7 chip-ID: 2708:0001
    class-ID: fe01
  Device-5: Elgato Systems GmbH Cam Link 4K
  API: ALSA v: k6.1.92-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.7 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
    type: plugin tools: pacat,pactl,pavucontrol,pulsemixer
  Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
  IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: br-0c3841ca9851 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IF-ID-2: br-2cebdbe8db1d state: down mac: <filter>
  IF-ID-3: br-57aa4ae71b35 state: down mac: <filter>
  IF-ID-4: br-77dd6dd853bf state: down mac: <filter>
  IF-ID-5: br-bf08237c468b state: down mac: <filter>
  IF-ID-6: docker0 state: down mac: <filter>
  IF-ID-7: vetha131cb7 state: up speed: 10000 Mbps duplex: full mac: <filter>
  Info: services: mld, NetworkManager, smbd, systemd-timesyncd
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 7-4.2:4 chip-ID: 0bda:8771
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.1
    lmp-v: 10 status: discoverable: no pairing: no class-ID: 6c0104
  Local Storage: total: 14.1 TiB used: 8.87 TiB (62.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QGXA7 temp: 44.9 C
    scheme: MBR
  ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QGXA7 temp: 51.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 1TB
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
  ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
  ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: Expansion HDD
    size: 10.91 TiB block-size: physical: 4096 B logical: 512 B type: USB
    rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 1801 scheme: GPT
  ID-1: / raw-size: 896.8 GiB size: 881.65 GiB (98.31%)
    used: 454.01 GiB (51.5%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-11ebe887-a587-4328-a9b1-edf8e8977154 label: N/A
    uuid: a514a2b0-d4ef-429c-bf79-2d9d714ba982
    used: 25.8 MiB (8.6%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3 label: N/A
    uuid: BFBD-CCE8
  ID-1: swap-1 type: partition size: 34.42 GiB used: 2.53 GiB (7.4%)
    priority: -2 dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-3e7888b9-de0a-4ee3-bf5f-81ccf8cd8533 label: swap
    uuid: 669b99c5-8d42-489a-9c19-1f0138078872
  System Temperatures: cpu: 52.1 C mobo: 37.0 C gpu: nvidia temp: 50 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
  Processes: 755 Power: uptime: 4d 13h 58m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 0 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 25.09 GiB services: upowerd
    Init: systemd v: 255 default: graphical tool: systemctl
  Packages: pm: nix-default pkgs: 0 pm: nix-sys pkgs: 0 pm: nix-usr pkgs: 0
    pm: pacman pkgs: 2274 libs: 527 tools: pamac,yay Compilers: clang: 17.0.6
    gcc: 14.1.1 Shell: Zsh v: 5.9 running-in: tmux: inxi: 3.3.34
You using i3 DE on X11? Im only using KDE and its hard to compare for me our both Inxi. Sry but im not sure about the other configurations.
  1. You are using nvidia Proprietary drivers?
  2. You have the steam games installed on a ext4 partition?
  3. You have Proton activated in Steam? And did you try different Proton Version? Like Proton 9 or Experimental?
  4. You could also try another LTS Kernel like 6.6
Maybe my Steam Linux Guide can help you, which includes few FAQ around Linux Gaming:
Yes, I’m using i3 on X11. Also tried gnome in a new user account and the issue is the same.
To answer your questions:
  1. Yes I use proprietary nvidia drivers
  2. Yes, ext4
  3. Yes, I only have issues with Proton games, and with all proton versions including GE or experimental; if the proton version is too old the game does not crash, and if it is recent enough it starts and freezes on the first frame
  4. Just tried to switch to kernel 6.6, same
Might be worth trying gamescope (it’s in Manjaro repositories).
Because the game is running in its own personal Xwayland sandbox desktop, it can’t interfere with your desktop and your desktop can’t interfere with it.
Instructions - GitHub - ValveSoftware/gamescope: SteamOS session compositing window manager
Note the part that says
For NVIDIA’s proprietary driver, version 515.43.04+ is required (make sure the nvidia-drm.modeset=1 kernel parameter is set).
You haven’t said if using Steam, Lutris, or what. For Steam the Launch Options;
gamescope -w 1920 -h 1080 -f -- %command%
runs the game fullscreen at 1920x1080. Or for borderless window
gamescope -w 1920 -h 1080 -W 1920 -H 1080 -b -- %command%
Thanks MrLavender, yes I’m using Steam.
I just tried adding the kernel parameter and running games in gamescope, but it did not fix the issue. In my tests I managed to run Nine Sols once, then I tried to launch it a second time and it froze.
Some Googling suggests this is a known issue with some Nvidia cards and certain displays when using DXVk. Sources: 1 2 3
Assuming it is indeed this issue, then disabling the ForceFullCompositionPipeline option should get you in running games. However, it seems like it comes with some downsides, so you’ll also want to turn it back on after playing games as well. For testing, the command to turn it off is: nvidia-settings -a CurrentMetaMode="nvidia-auto-select +0+0 { ForceFullCompositionPipeline=Off }"; links 2/3 above have some ideas for how to do it automatically for games.
Oh brilliant that was it!
This config is necessary to avoid screen tearing when scrolling and in videos, and manjaro enables it by default when using proprietary nvidia drivers. Here is mine that also forces the refresh rate to 120 Hz because nvidia-auto-select is 60 Hz:
# /etc/X11/mhwd.d/nvidia.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 525.60.11
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0"
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
	Option "NoLogo" "1"
#	Option         "metamodes" "nvidia-auto-select +0+0 {ForceCompositionPipeline=On}"
    Option         "metamodes" "3840x2160_120 +0+0 {ForceCompositionPipeline=On}"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Section "Extensions"
    Option         "COMPOSITE" "Enable"
EndSection
Section "InputClass"
    Identifier          "Keyboard Defaults"
    MatchIsKeyboard        "yes"
    Option              "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
