Some apps on my Manjaro GNOME are not using the theme i chose in teaks tool, and are instead using this broken theme that has light background, but black buttons with black text on it, making the text unreadable. It has happened after i removed orphaned packages using pamac. What happened and how do i fix it?
Cadence and VLC are Qt software, did you remove kvantum or qt5ct? If you don’t remember which packages were removed, you can check history in View History (hamburger menu) in Pamac.
