This happens for example in Nautilus when the FileChooser is called to appear.
Here is the error. I have already ran sudo pacman -Syyu
GLib-GIO-ERROR **: 14:40:51.399: Settings schema 'org.gtk.gtk4.Settings.FileChooser' does not contain a key named 'view-type'
Running the following command shows that the key does exist:
cat /usr/share/glib-2.0/schemas/org.gtk.gtk4.Settings.FileChooser.gschema.xml | grep "view"
<key name="view-type" enum="org.gtk.gtk4.Settings.FileChooser.ViewType">
Hi @Yiannis128,
Almost looks like the gtk4 GObject-based multi-platform GUI toolkit is missing, if I’m correct. I use KDE, and I have it installed:
$ pamac search 'libgtk'
gtk4 [Installed] 1:4.8.3-3 extra
…and it’s in the extra
repository. So can be installed with:
pamac install gtk4
…or if it is already installed, reinstall it with:
pamac reinstall gtk4 --overwrite='/usr/*'
Followed by a reboot ans seeing if it helps!
Hope it helps!
Hi, gtk4 is already installed, so I ran the command to reinstall it and nothing has changed. The same error.
In that case, I have to be honest with you:
