[Profiles] Bootloader
Because Manjaro comes with many different variations, i like the Desktop info in the profile but why not have an info box for the Bootloader used also?
Yes sure most maybe use Grub2 but there are many others to choose from.
Eg. I use sd-boot someone else might be using rEFInd etc…
So please, if possible, add an extra infobox to our profiles labeled “Bootloader” :wink:
The type could also be added like “BIOS” or “UEFI” but i think the time that people have “BIOS only” is or will be in the past soon…
I have Bios, so other members of the team same with many users.
Ofcourse, that’s why i made a forecast about what is in future (IMHO).
But for time being i mentioned to add both as “Type” label’s value. :wink:
PS: Why was the category changed?
This is about the Forum profiles, not some app in our system…
Now I understand what you talking about, we don’t need one because default is Grub, if a user is using a modified version of Manjaro then it up to them to specify what modifications were done when he posts.
If you go by that thought then we don’t need any…
You personally only choose to Display your Branch, but others choose to display more…
I have added the field under user profile.
