Process 4963 (ksysguard) dumped core - inxi and output included
log states to post in Support: https://forum.manjaro.org/c/technical-issues-and-assistance but that no longer exists so i decided to post here
i have been doing a lot of edits, installing of things,removing of things to my install. i decided to run journalctl -x -p3 -b1 to make sure nothing else was really too broken. after doing google searches and also searching the archived fourms, i havent been able to find good steps to try to correct this error in journalctl
Here’s my info first
inxi -Fza
System:    Kernel: 5.7.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=7cca64bd-2b23-436e-a24d-07819efcff73 rw quiet
           nmi_watchdog=0 apparmor=1 security=apparmor udev.log_priority=3 radeon.cik_support=0 radeon.si_support=0
           amdgpu.cik_support=1 amdgpu.si_support=1 amdgpu.dc=1
           Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Desktop Mobo: ASUSTeK model: Z170 PRO GAMING v: Rev X.0x serial: <filter> UEFI: American Megatrends v: 3805
           date: 05/16/2018
Battery:   Device-1: hidpp_battery_0 model: Logitech K850 Performance Wireless Keyboard serial: <filter>
           charge: 100% (should be ignored) rechargeable: yes status: Discharging
CPU:       Topology: Quad Core model: Intel Core i5-6600K bits: 64 type: MCP arch: Skylake-S family: 6 model-id: 5E (94)
           stepping: 3 microcode: D6 L2 cache: 6144 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28009
           Speed: 800 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
           Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
           Type: srbds status: Vulnerable: No microcode
           Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Hawaii PRO [Radeon R9 290/390] vendor: PC Partner Limited driver: amdgpu
           v: kernel alternate: radeon bus ID: 01:00.0 chip ID: 1002:67b1
           Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: amdgpu FAILED: ati unloaded: modesetting
           alternate: fbdev,vesa display ID: :0 screens: 1
           Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1016x317mm (40.0x12.5") s-diag: 1064mm (41.9")
           Monitor-1: DisplayPort-2 res: 1920x1200 hz: 60 dpi: 94 size: 518x324mm (20.4x12.8") diag: 611mm (24.1")
           Monitor-2: DisplayPort-3 res: 1920x1200 hz: 60 dpi: 94 size: 518x324mm (20.4x12.8") diag: 611mm (24.1")
           OpenGL: renderer: AMD Radeon R9 390 Series (HAWAII DRM 3.37.0 5.7.14-1-MANJARO LLVM 10.0.1) v: 4.6 Mesa 20.1.5
           direct render: Yes
Audio:     Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
           bus ID: 00:1f.3 chip ID: 8086:a170
           Device-2: Advanced Micro Devices [AMD/ATI] Hawaii HDMI Audio [Radeon R9 290/290X / 390/390X]
           vendor: PC Partner Limited driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 1002:aac8
           Device-3: Logitech HD Pro Webcam C920 type: USB driver: snd-usb-audio,uvcvideo bus ID: 1-5:4 chip ID: 046d:082d
           serial: <filter>
           Sound Server: ALSA v: k5.7.14-1-MANJARO
Network:   Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: 3.2.6-k port: f000 bus ID: 00:1f.6
           chip ID: 8086:15b8
           IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 15.71 TiB used: 389.06 GiB (2.4%)
           ID-1: /dev/nvme0n1 vendor: A-Data model: SX8200PNP size: 953.87 GiB block size: physical: 512 B logical: 512 B
           speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 42AZS6AC scheme: GPT
           ID-2: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB block size: physical: 512 B logical: 512 B
           speed: 6.0 Gb/s serial: <filter> rev: 1B6Q scheme: GPT
           ID-3: /dev/sdb vendor: Seagate model: ST8000DM004-2CX188 size: 7.28 TiB block size: physical: 4096 B logical: 512 B
           speed: 6.0 Gb/s rotation: 5425 rpm serial: <filter> rev: 0001 scheme: GPT
           ID-4: /dev/sdc type: USB vendor: Western Digital model: WD My Book 25EE size: 7.28 TiB block size: physical: 4096 B
           logical: 512 B serial: <filter> rev: 4004 scheme: GPT
Partition: ID-1: / raw size: 121.09 GiB size: 118.19 GiB (97.60%) used: 17.03 GiB (14.4%) fs: ext4 dev: /dev/nvme0n1p2
           ID-2: /home raw size: 832.27 GiB size: 818.21 GiB (98.31%) used: 87.46 GiB (10.7%) fs: ext4 dev: /dev/nvme0n1p3
Swap:      Alert: No Swap data was found.
Sensors:   System Temperatures: cpu: 31.0 C mobo: N/A gpu: amdgpu temp: 29 C
           Fan Speeds (RPM): N/A gpu: amdgpu fan: 1340
Info:      Processes: 230 Uptime: 56m Memory: 7.72 GiB used: 2.33 GiB (30.2%) Init: systemd v: 245 Compilers: gcc: 10.1.0
           Packages: pacman: 1360 lib: 383 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
Here is journalctl -x -p3 -b1
-- Logs begin at Fri 2020-08-21 18:32:11 MST, end at Fri 2020-08-21 22:06:15 MST. --
Aug 21 18:46:48 manjaropc systemd-coredump[5004]: Process 4963 (ksysguard) of user 1000 dumped core.
                                                  Stack trace of thread 4963:
                                                  #0  0x00007fb73326e9b4 _ZNK7QWidget10sizePolicyEv (libQt5Widgets.so.5 + 0x1859b4)
                                                  #1  0x00007fb73337e514 n/a (libQt5Widgets.so.5 + 0x295514)
                                                  #2  0x00007fb73337fb94 _ZN6QLabel7setTextERK7QString (libQt5Widgets.so.5 + 0x296b94)
                                                  #3  0x00007fb72e585134 n/a (libkdeinit5_ksysguard.so + 0x68134)
                                                  #4  0x00007fb72e50b36a _ZN5KSGRD11SensorAgent13processAnswerEPKci (libksgrd.so.9 + 0x836a)
                                                  #5  0x00007fb72e5117a3 n/a (libksgrd.so.9 + 0xe7a3)
                                                  #6  0x00007fb733ec2a26 n/a (libQt5Core.so.5 + 0x2eaa26)
                                                  #7  0x00007fb733df730e _ZN8QProcess23readyReadStandardOutputENS_14QPrivateSignalE (libQt5Core.so.5 + 0x21f30e)
                                                  #8  0x00007fb733dfca56 n/a (libQt5Core.so.5 + 0x224a56)
                                                  #9  0x00007fb733dfcfb5 n/a (libQt5Core.so.5 + 0x224fb5)
                                                  #10 0x00007fb733ec2a60 n/a (libQt5Core.so.5 + 0x2eaa60)
                                                  #11 0x00007fb733ec5f90 _ZN15QSocketNotifier9activatedE17QSocketDescriptorNS_4TypeENS_14QPrivateSignalE (libQt5Core.so.5 + 0x2edf90)
                                                  #12 0x00007fb733ec679d _ZN15QSocketNotifier5eventEP6QEvent (libQt5Core.so.5 + 0x2ee79d)
                                                  #13 0x00007fb733245702 _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt5Widgets.so.5 + 0x15c702)
                                                  #14 0x00007fb733e8b7ba _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x2b37ba)
                                                  #15 0x00007fb733ee4f46 n/a (libQt5Core.so.5 + 0x30cf46)
                                                  #16 0x00007fb7325c843c g_main_context_dispatch (libglib-2.0.so.0 + 0x5243c)
                                                  #17 0x00007fb7326161d9 n/a (libglib-2.0.so.0 + 0xa01d9)
                                                  #18 0x00007fb7325c7221 g_main_context_iteration (libglib-2.0.so.0 + 0x51221)
                                                  #19 0x00007fb733ee4331 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x30c331)
                                                  #20 0x00007fb733e8a13c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2b213c)
                                                  #21 0x00007fb733e925c4 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x2ba5c4)
                                                  #22 0x00007fb72e5862f8 kdemain (libkdeinit5_ksysguard.so + 0x692f8)
                                                  #23 0x000055a8ecfec5bd n/a (kdeinit5 + 0x75bd)
                                                  #24 0x000055a8ecfeda59 n/a (kdeinit5 + 0x8a59)
                                                  #25 0x000055a8ecfee21d n/a (kdeinit5 + 0x921d)
                                                  #26 0x000055a8ecfe9b54 n/a (kdeinit5 + 0x4b54)
                                                  #27 0x00007fb733a38002 __libc_start_main (libc.so.6 + 0x27002)
                                                  #28 0x000055a8ecfea6be n/a (kdeinit5 + 0x56be)
                                                  Stack trace of thread 4973:
                                                  #0  0x00007fb7330d6e32 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xfe32)
                                                  #1  0x00007fb71ad4699c n/a (radeonsi_dri.so + 0x4af99c)
                                                  #2  0x00007fb71ad45398 n/a (radeonsi_dri.so + 0x4ae398)
                                                  #3  0x00007fb7330d0422 start_thread (libpthread.so.0 + 0x9422)
                                                  #4  0x00007fb733b10bf3 __clone (libc.so.6 + 0xffbf3)
                                                  Stack trace of thread 4965:
                                                  Stack trace of thread 4975:
                                                  Stack trace of thread 4974:
                                                  Stack trace of thread 4984:
                                                  #0  0x00007fb7330d7158 pthread_cond_timedwait@@GLIBC_2.3.2 (libpthread.so.0 + 0x10158)
                                                  #1  0x00007fb733cace08 _ZN14QWaitCondition4waitEP6QMutex14QDeadlineTimer (libQt5Core.so.5 + 0xd4e08)
                                                  #2  0x00007fb733cab084 n/a (libQt5Core.so.5 + 0xd3084)
                                                  #3  0x00007fb733ca6e0f n/a (libQt5Core.so.5 + 0xcee0f)
                                                  #4  0x00007fb7330d0422 start_thread (libpthread.so.0 + 0x9422)
                                                  #5  0x00007fb733b10bf3 __clone (libc.so.6 + 0xffbf3)
                                                  Stack trace of thread 4983:
                                                  Stack trace of thread 4972:
                                                  Stack trace of thread 4970:
                                                  Stack trace of thread 4969:
                                                  Stack trace of thread 4967:
                                                  Stack trace of thread 4966:
                                                  Stack trace of thread 4964:
                                                  #0  0x00007fb733b0605f __poll (libc.so.6 + 0xf505f)
                                                  #1  0x00007fb73485963b n/a (libxcb.so.1 + 0xc63b)
                                                  #2  0x00007fb73485b37b xcb_wait_for_event (libxcb.so.1 + 0xe37b)
                                                  #3  0x00007fb72194ec51 n/a (libQt5XcbQpa.so.5 + 0x5dc51)
                                                  #4  0x00007fb733ca6e0f n/a (libQt5Core.so.5 + 0xcee0f)
                                                  #5  0x00007fb7330d0422 start_thread (libpthread.so.0 + 0x9422)
                                                  #6  0x00007fb733b10bf3 __clone (libc.so.6 + 0xffbf3)
                                                  Stack trace of thread 4968:
                                                  Stack trace of thread 4971:
                                                  Stack trace of thread 4976:
                                                  #1  0x00007fb732616168 n/a (libglib-2.0.so.0 + 0xa0168)
                                                  #2  0x00007fb7325c7221 g_main_context_iteration (libglib-2.0.so.0 + 0x51221)
                                                  #3  0x00007fb733ee4331 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x30c331)
                                                  #4  0x00007fb733e8a13c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2b213c)
                                                  #5  0x00007fb733ca5c32 _ZN7QThread4execEv (libQt5Core.so.5 + 0xcdc32)
                                                  #6  0x00007fb72feb9098 n/a (libQt5DBus.so.5 + 0x17098)
                                                  #7  0x00007fb733ca6e0f n/a (libQt5Core.so.5 + 0xcee0f)
                                                  #8  0x00007fb7330d0422 start_thread (libpthread.so.0 + 0x9422)
                                                  #9  0x00007fb733b10bf3 __clone (libc.so.6 + 0xffbf3)
                                                  Stack trace of thread 4981:
                                                  Stack trace of thread 4982:
-- Subject: Process 4963 (ksysguard) dumped core
-- Defined-By: systemd
-- Support: https://forum.manjaro.org/c/technical-issues-and-assistance
-- Documentation: man:core(5)
-- Process 4963 (ksysguard) crashed and dumped core.
-- This usually indicates a programming error in the crashing program and
-- should be reported to its vendor as a bug.
Aug 21 18:49:01 manjaropc plasmashell[1396]: Couldn't start kuiserver from org.kde.kuiserver.service: QDBusError("org.freedesktop.DBus.Error.ServiceUnknown", "The name org.kde.kuiserver was not provided by an>
Any help pointing me in the right direction would be great
I usually take notes if i go into such tasks, and i take heed to package dependencies at removal. Of course an alternative is to check /var/log/pacman.log and revert if needed.
Are you using some mixed packaged from the git version of KDE Plasma or the kuiserver-standalone-git from AUR ?
Try this:
sudo pacman -Syu plasma-desktop plasma-workspace ksysguard libksysguard qt5-base glibc lib32-glibc
maybe i over exaggerate a bit more than i meant… i usually keep general tabs on what i install. what i was referring to by this was troubleshooting this issue
No. i dont run any git that i have explicitly installed… this is pretty much a Manjaro kde default install
These all are currently installed
I understand. My point was to reinstall them.
looks like that worked…thanks
