Hello,
I’ve been going crazy with this issue of Tearing in the XFCE environment, I’ve made some attempts both changing the parameters xorg 20-intel.conf (in this the screen is black at boot) and also installing picom according to this tutorial https: / / terminaldopenguin. blogspot. com /2020/06/ resolvendo-tearing-com-o-picom . html) (sorry it’s in Pt-br).
Follow the ixni -G and the xorg.log below.
$ inxi -G
raphics:
Device-1: Intel 3rd Gen Core processor Graphics driver: i915 v: kernel
Display: x11 server: X.Org v: 21.1.3 driver: X: loaded: modesetting
gpu: i915 resolution: 1: 1536x864~60Hz 2: N/A
Message: Unable to show GL data. Required tool glxinfo missing.
cat /var/log/Xorg.0.log
688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 58.155] (--) modeset(0): HDMI max TMDS frequency 150000KHz
[ 211.578] (II) modeset(0): EDID vendor "GSM", prod id 1
[ 211.578] (II) modeset(0): Using hsync ranges from config file
[ 211.578] (II) modeset(0): Using vrefresh ranges from config file
[ 211.578] (II) modeset(0): Printing DDC gathered Modelines:
[ 211.578] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 211.578] (II) modeset(0): Modeline "1360x768"x0.0 85.50 1360 1424 1536 1792 768 771 777 795 +hsync +vsync (47.7 kHz e)
[ 211.578] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 211.578] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 211.578] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 211.578] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 211.578] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 211.578] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 211.578] (II) modeset(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 211.578] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 211.578] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e)
[ 211.578] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[ 211.578] (II) modeset(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[ 211.578] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 211.578] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 211.578] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 211.578] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 211.578] (II) modeset(0): Modeline "1152x864"x60.0 81.62 1152 1216 1336 1520 864 865 868 895 -hsync +vsync (53.7 kHz e)
[ 211.578] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 211.578] (--) modeset(0): HDMI max TMDS frequency 150000KHz
[ 345.529] (II) modeset(0): EDID vendor "GSM", prod id 1
[ 345.529] (II) modeset(0): Using hsync ranges from config file
[ 345.529] (II) modeset(0): Using vrefresh ranges from config file
[ 345.529] (II) modeset(0): Printing DDC gathered Modelines:
[ 345.529] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 345.529] (II) modeset(0): Modeline "1360x768"x0.0 85.50 1360 1424 1536 1792 768 771 777 795 +hsync +vsync (47.7 kHz e)
[ 345.529] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 345.529] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 345.529] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 345.529] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 345.529] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 345.529] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 345.529] (II) modeset(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 345.529] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 345.529] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e)
[ 345.529] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[ 345.529] (II) modeset(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[ 345.529] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 345.529] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 345.529] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 345.529] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 345.529] (II) modeset(0): Modeline "1152x864"x60.0 81.62 1152 1216 1336 1520 864 865 868 895 -hsync +vsync (53.7 kHz e)
[ 345.529] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 345.529] (--) modeset(0): HDMI max TMDS frequency 150000KHz
[ 447.984] (II) modeset(0): EDID vendor "GSM", prod id 1
[ 447.984] (II) modeset(0): Using hsync ranges from config file
[ 447.984] (II) modeset(0): Using vrefresh ranges from config file
[ 447.984] (II) modeset(0): Printing DDC gathered Modelines:
[ 447.984] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 447.984] (II) modeset(0): Modeline "1360x768"x0.0 85.50 1360 1424 1536 1792 768 771 777 795 +hsync +vsync (47.7 kHz e)
[ 447.984] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 447.984] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 447.984] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 447.984] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 447.984] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 447.985] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 447.985] (II) modeset(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 447.985] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 447.985] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (28.1 kHz e)
[ 447.985] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (33.8 kHz e)
[ 447.985] (II) modeset(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[ 447.985] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 447.985] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 447.985] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 447.985] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 447.985] (II) modeset(0): Modeline "1152x864"x60.0 81.62 1152 1216 1336 1520 864 865 868 895 -hsync +vsync (53.7 kHz e)
[ 447.985] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 447.985] (--) modeset(0): HDMI max TMDS frequency 150000KHz
and finally cat ~/.config/picom/picom.conf
backend = "glx";
glx-no-stencil = true;
glx-no-rebind-pixmap = true;
use-damage = true;
xrender-sync-fence = true;
refresh-rate = 0;
vsync = true;
mark-wmwin-focused = true;
mark-ovredir-focused = true;
use-ewmh-active-win = true;
shadow = true;
shadow-radius = 3;
shadow-offset-x = -3;
shadow-offset-y = -3;
shadow-opacity = 0.5;
shadow-exclude = [
"! name~=''",
"name = 'Notification'",
"name = 'xfce4-notifyd'",
"name *= 'picom'",
"name *= 'Chromium'",
"class_g = 'Navigator' && argb",
"class_g ?= 'Notify-osd'",
"class_g ?= 'Cairo-dock'",
"class_g ?= 'Xfce4-notifyd'",
"class_g ?= 'Xfce4-power-manager'",
"_GTK_FRAME_EXTENTS@:c",
"bounding_shaped && !rounded_corners"
fading = true;
fade-delta = 5;
fade-in-step = 0.03;
fade-out-step = 0.03;
no-fading-openclose = true;
fade-exclude = [ ];
active-opacity = 1;
inactive-opacity = 0.9;
frame-opacity = 1;
inactive-opacity-override = false;
opacity-rule = [
"100:class_g = 'Termite' && _NET_WM_STATE@:32a",
"95:class_g = 'Termite' && !_NET_WM_STATE@:32a",
"0:_NET_WM_STATE@:32a *= '_NET_WM_STATE_HIDDEN'"
# blur-background = true;
# blur-background-frame = true;
blur-background-fixed = false;
blur-kern = "3x3box";
blur-background-exclude = [
"window_type = 'dock'",
"window_type = 'desktop'",
unredir-if-possible = false;
detect-rounded-corners = true;
detect-client-opacity = true;
detect-transient = true;
detect-client-leader = true;
wintypes:
tooltip = { opacity = 0.95; shadow = false; fade = true; focus = true; };
dock = { shadow = false; };
dnd = { shadow = false; };
Default xfce compositor is off in window tweaks
Neofetch
OS: Manjaro Linux x86_64
██████████████████ ████████ Host: Infoway w7730 Inft
████████ ████████ Kernel: 5.15.48-1-MANJARO
████████ ████████ ████████ Uptime: 15 mins
████████ ████████ ████████ Packages: 1172 (pacman)
████████ ████████ ████████ Shell: bash 5.1.16
████████ ████████ ████████ Resolution: 1536x864
████████ ████████ ████████ DE: Xfce 4.16
████████ ████████ ████████ WM: Xfwm4
████████ ████████ ████████ WM Theme: Matcha-sea
████████ ████████ ████████ Theme: Matcha-dark-sea [GTK2/3]
████████ ████████ ████████ Icons: Papirus-Maia [GTK2], Adwaita [GTK3]
Terminal: xfce4-terminal
Terminal Font: Monospace 12
CPU: Intel i3-3110M (4) @ 2.400GHz
GPU: Intel 3rd Gen Core processor Graphics Contr
Memory: 1326MiB / 3818MiB
Your inxi output shows you have the modesetting driver loaded; if you created the /etc/X11/xorg.conf.d/20-intel.conf
file as detailed on the Arch wiki you need to be using the xf86-video-intel driver. This is probably why you had a black screen on boot. You could try installing that driver then recreating the file.
Hi,
I installed xf86-video-intel as shows
$ sudo pacman -Q xf86-video-intel
xf86-video-intel 1:2.99.917+916+g31486f40-2
and create the following 20-intel.conf file
Section "Device"
Identifier "Intel Graphics"
Driver "intel"
Option "TearFree" "true"
EndSection
When I reboot my X is stuck and I need to login thriugh CLI ctrl_alt_f3
Heres the tail of xorg.log
[ 9.161] (II) XINPUT: Adding extended input device "2.4G Composite Devic" (type: KEYBOARD, id 10)
[ 9.161] (**) Option "xkb_layout" "br"
[ 9.165] (II) event4 - 2.4G Composite Devic: is tagged by udev as: Keyboard
[ 9.165] (II) event4 - 2.4G Composite Devic: device is a keyboard
[ 9.166] (II) config/udev: removing device 2.4G Composite Devic System Control
[ 9.166] (II) event8 - 2.4G Composite Devic System Control: device removed
[ 9.181] (II) UnloadModule: "libinput"
[ 9.182] (II) config/udev: Adding input device 2.4G Composite Devic System Control (/dev/input/event8)
[ 9.182] (**) 2.4G Composite Devic System Control: Applying InputClass "evdev keyboard catchall"
[ 9.182] (**) 2.4G Composite Devic System Control: Applying InputClass "libinput keyboard catchall"
[ 9.182] (**) 2.4G Composite Devic System Control: Applying InputClass "system-keyboard"
[ 9.182] (II) Using input driver 'libinput' for '2.4G Composite Devic System Control'
[ 9.182] (**) 2.4G Composite Devic System Control: always reports core events
[ 9.182] (**) Option "Device" "/dev/input/event8"
[ 9.185] (II) event8 - 2.4G Composite Devic System Control: is tagged by udev as: Keyboard
[ 9.185] (II) event8 - 2.4G Composite Devic System Control: device is a keyboard
[ 9.186] (II) event8 - 2.4G Composite Devic System Control: device removed
[ 9.211] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:4037:2804.0002/input/input9/event8"
[ 9.211] (II) XINPUT: Adding extended input device "2.4G Composite Devic System Control" (type: KEYBOARD, id 13)
[ 9.211] (**) Option "xkb_layout" "br"
[ 9.213] (II) event8 - 2.4G Composite Devic System Control: is tagged by udev as: Keyboard
[ 9.214] (II) event8 - 2.4G Composite Devic System Control: device is a keyboard
[ 9.214] (II) config/udev: removing device 2.4G Composite Devic Consumer Control
[ 9.215] (II) UnloadModule: "libinput"
[ 9.215] (II) config/udev: removing device 2.4G Composite Devic Consumer Control
[ 9.215] (II) event7 - 2.4G Composite Devic Consumer Control: device removed
[ 9.227] (II) UnloadModule: "libinput"
[ 9.229] (II) config/udev: Adding input device 2.4G Composite Devic Consumer Control (/dev/input/event7)
[ 9.229] (**) 2.4G Composite Devic Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 9.229] (**) 2.4G Composite Devic Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 9.229] (**) 2.4G Composite Devic Consumer Control: Applying InputClass "system-keyboard"
[ 9.229] (II) Using input driver 'libinput' for '2.4G Composite Devic Consumer Control'
[ 9.229] (**) 2.4G Composite Devic Consumer Control: always reports core events
[ 9.229] (**) Option "Device" "/dev/input/event7"
[ 9.231] (II) event7 - 2.4G Composite Devic Consumer Control: is tagged by udev as: Keyboard
[ 9.231] (II) event7 - 2.4G Composite Devic Consumer Control: device is a keyboard
[ 9.232] (II) event7 - 2.4G Composite Devic Consumer Control: device removed
[ 9.254] (II) libinput: 2.4G Composite Devic Consumer Control: needs a virtual subdevice
[ 9.254] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:4037:2804.0002/input/input8/event7"
[ 9.254] (II) XINPUT: Adding extended input device "2.4G Composite Devic Consumer Control" (type: MOUSE, id 12)
[ 9.254] (**) Option "AccelerationScheme" "none"
[ 9.254] (**) 2.4G Composite Devic Consumer Control: (accel) selected scheme none/0
[ 9.254] (**) 2.4G Composite Devic Consumer Control: (accel) acceleration factor: 2.000
[ 9.254] (**) 2.4G Composite Devic Consumer Control: (accel) acceleration threshold: 4
[ 9.257] (II) event7 - 2.4G Composite Devic Consumer Control: is tagged by udev as: Keyboard
[ 9.257] (II) event7 - 2.4G Composite Devic Consumer Control: device is a keyboard
[ 9.257] (**) 2.4G Composite Devic Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 9.257] (**) 2.4G Composite Devic Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 9.257] (**) 2.4G Composite Devic Consumer Control: Applying InputClass "system-keyboard"
[ 9.257] (II) Using input driver 'libinput' for '2.4G Composite Devic Consumer Control'
[ 9.257] (**) 2.4G Composite Devic Consumer Control: always reports core events
[ 9.257] (**) Option "Device" "/dev/input/event7"
[ 9.257] (II) libinput: 2.4G Composite Devic Consumer Control: is a virtual subdevice
[ 9.257] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:4037:2804.0002/input/input8/event7"
[ 9.257] (II) XINPUT: Adding extended input device "2.4G Composite Devic Consumer Control" (type: KEYBOARD, id 16)
[ 9.257] (**) Option "xkb_layout" "br"
[ 10.407] (--) intel(0): HDMI max TMDS frequency 150000KHz
[ 12.081] (--) intel(0): HDMI max TMDS frequency 150000KHz
[ 16.875] (--) intel(0): HDMI max TMDS frequency 150000KHz
[ 31.991] (--) intel(0): HDMI max TMDS frequency 150000KHz
[ 52.588] (II) event3 - Power Button: device removed
[ 52.629] (II) event11 - Video Bus: device removed
[ 52.735] (II) event0 - Power Button: device removed
[ 52.776] (II) event1 - Sleep Button: device removed
[ 52.802] (II) event5 - AT Translated Set 2 keyboard: device removed
[ 52.829] (II) event10 - SynPS/2 Synaptics TouchPad: device removed
[ 52.882] (II) event6 - 2.4G Composite Devic Mouse: device removed
[ 52.923] (II) event4 - 2.4G Composite Devic: device removed
[ 52.936] (II) event8 - 2.4G Composite Devic System Control: device removed
[ 52.963] (II) event7 - 2.4G Composite Devic Consumer Control: device removed
Theres any idea ?
Hi,
I solved my problem right now with this config.
$ cat /etc/X11/xorg.conf.d/20-intel.conf
Section "Device"
Driver "intel"
Option "DRI" "2" # DRI3 is now default
Option "AccelMethod" "sna" # default
# Option "AccelMethod" "uxa" # fallback
EndSection
Now everything works fine!
system
Closed
28 June 2022 07:51
6
