Hello everyone!
This is my first post on the forum so, thanks in advance and thanks for all the previous help you provided me!
So, as the title says, I did a major update some days ago and started noticing “visual” differences but was not sure what it was. After some more usage I realized a couple of things:
- The “Screen Edge” feature is not working: I use the top-left corner of the screen to show all opened windows. When I move the mouse there nothing is beign triggered, nothing happens.
- When usign alt+tab I get not previews of the windows but only the app icon
- When moving windows to the edges and letting plasma to do the resize I think that previously there was some kind of smooth transition effect but now I only get a black rectangle showing the new shape that the window is going to be resized to.
- I have not transparency in windows/themes: For example Alacritty or Konsole show that cannot use/show using transparency. Also the Latte Dock docker transparency section on the config is deactivated.
I’m not sure what can I drop here to let you know about my system but I can tell you somethings:
- Manjaro Stable
- AMD Ryzen CPU
- RX 580 Radeon GPU
