So I got this error when I tried to run vscode cli:
~/crashvue/tasktracker main ?1 code . 127 ✘
zsh: correct 'code' to '_code' [nyae]? n
zsh: command not found: code
I installed vscode with snap and idk how to configure vscode cli to work in command promt
I got this following response:
~/crashvue/tasktracker main ?1 snap run code 127 ✘
error: cannot find current revision for snap code: readlink /var/lib/snapd/snap/code/current: no such file or directory
Oh I use insiders version and It did opened vscode.
But are there any way to configure the command to just code
make a alias alias <flag> <alias_name>=”command”
and put it in .zshrc or .bashrc:
alias code="snap run code-insiders"
Can you send the command?
I’m thinking this might be the/a reason. See if there is a .desktop
file for it in /usr/share/application
. (I think that’s the location anyway.)
system
Closed
#10
