Problems with v4l2loopback
I am trying to output from obs to virual cam, but I can’t load the v4l2loopback module. I have installed it using the following command:
sudo pacman -S v4l2loopback-dkms
When I run “sudo modprobe v4l2loopback” and similar commands (with different options), I’m getting an error:
modprobe: FATAL: Module v4l2loopback not found in directory /lib/modules/5.10.23-1-MANJARO
Thanks in advance.
I am guessing droidcam or similar.
dkms requires kernel headers - did you remember to install linux510-headers?
