Problems with switching off the laptop in Manjaro KDE
HY so i’m being realy unliky or something because everything seems to have bugs lately so this one is wierd as well i instaled Manjaro KDE and it kida works ok but having wierd problem when i hit the turn off buton in app its turns off but after 2 secondes its turn the leptop on again like a reboot reather than turn off the, cmd comand for shut down same thing.Any fix for this? Something for a rookie.
Hi @Vash101,
Please use proper pronunciation, formatting and spelling in your post. That is very difficult to read as it is and we can’t see your face to pick up on visual cues. We only have the text to go on.
That said, there are multiple reasons that can happen. But we need more informatio9n to diagnose the issue. To that end, see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Something that might provide a clue as to what’s happening is inspecting the logs. Please provide the output of the following according to the guide I provided above:
journalctl --boot=0 --priority=warning..error --no-pager
Where:
  • --boot= will limit the output to bee of the current (0) boot;
  • --priority=warning..error will limit the log to show only warnings and errors;
  • --no-pager will format the output for use here, on the forum.
I searched for “plasma resarts instead of shutting down” and found this (Updated) plasma restarts instead of powering off the computer. / Newbie Corner / Arch Linux Forums
Yea so wheres the solution i only see the problem posted similar to mine
