Hi ,
yesterday update from Manjaro XFCE 21.3.5 on Manjaro XFCE 21.3.6 and update of kernel 5.15.55_rt48-1 maked me problems with speed of internet wifi connection on laptop Asus . Internet connection speed is now 1.5 MB/s and should be 3.5 MB/s and also wifi showing less internet sites . What to do ? Thank you .
Kernel: 5.15.55-1-rt48-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-rt-x86_64
root=UUID=302727e3-3f89-4267-ad73-68a326057b09 rw quiet apparmor=1
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X571GD_X571GD
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: X571GD v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X571GD.312 date: 09/15/2021
ID-1: BAT1 charge: 23.7 Wh (88.1%) condition: 26.9/42.3 Wh (63.6%)
volts: 11.0 min: 11.6 model: ASUS A32-K55 type: Li-ion serial: N/A
status: discharging
RAM: total: 7.62 GiB used: 1.66 GiB (21.8%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 0xA (10) microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/4000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 36799
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
prctl and seccomp
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: ASUSTeK
driver: N/A alternate: nouveau non-free: 515.xx+ status: current (as of
2022-07) arch: Pascal code: GP10x process: TSMC 16nm built: 2016-21 pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1c92
class-ID: 0302
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-7:4 chip-ID: 13d3:56a8 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: LG Display 0x0563 built: 2018 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 22.1.4
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
Sound Server-1: ALSA v: k5.15.55-1-rt48-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 03:00.0
chip-ID: 10ec:c821 class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s port: 3000 bus-ID: 04:00.0
IF: enp4s0 state: down mac: <filter>
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-14:5 chip-ID: 13d3:3529 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.14 TiB used: 120.49 GiB (10.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFM256GDJTNG-8310A size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
rev: 80001C00 temp: 31.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100
type: HDD rpm: 5400 serial: <filter> rev: 1J scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%) used: 120.49 GiB
(13.2%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 302727e3-3f89-4267-ad73-68a326057b09
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: B50C-F27D
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 512 MiB fs: vfat label: N/A
uuid: 94C7-8681
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 237.97 GiB fs: ext4 label: N/A
uuid: 5ab257b6-d061-403a-8735-39b0d4d13e0e
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-1:2 info: Sunplus Innovation Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 98mA chip-ID: 1bcf:0005 class-ID: 0301
Device-2: 1-6:3 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-3: 1-7:4 info: IMC Networks USB2.0 HD UVC WebCam type: Video
Device-4: 1-14:5 info: IMC Networks Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 36.0 C pch: 44.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 295 Uptime: 4m wakeups: 4 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: 1196
pacman: 1189 lib: 346 flatpak: 7 Shell: Bash v: 5.1.16
running-in: xfce4-terminal inxi: 3.3.20
