can anyone explain me whats up with this and how to solve this
sudo pacman -S Libreoffice
[sudo] password for PC:
error: failed to init transaction (unable to lock database)
error: could not lock database: File exists
if you’re sure a package manager is not already
running, you can remove /var/lib/pacman/db.lck
I think if you’re sure there’s no other instance of pacman running, you can do as the message say and remove db.lck:
sudo rm /var/lib/pacman/db.lck
Also, I’d suggest not using pacman any more, and rather use pamac as that is developed by Manjaro devs for Manjaro. So your pacman comand would become:
