Summary
Installing video-hybrid-intel-nvidia-prime…
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-prime/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
core downloading…
extra downloading…
community downloading…
multilib downloading…
resolving dependencies…
warning: dependency cycle detected:
warning: eglexternalplatform will be installed before its nvidia-utils dependency
Packages (8) egl-wayland-2:1.1.11-3 eglexternalplatform-1.1-2 libxnvctrl-525.89.02-1 lib32-nvidia-utils-525.89.02-1 linux61-nvidia-525.89.02-2 linux62-nvidia-525.89.02-0.1 nvidia-prime-1.0-4 nvidia-utils-525.89.02-1
Total Installed Size: 932.91 MiB
checking keyring…
checking package integrity…
loading package files…
checking for file conflicts…
checking available disk space…
:: Processing package changes…
installing eglexternalplatform…
installing egl-wayland…
installing libxnvctrl…
installing nvidia-utils…
If you run into trouble with CUDA not being available, run nvidia-modprobe first.
If you use GDM on Wayland, you might have to run systemctl enable --now nvidia-resume.service
Optional dependencies for nvidia-utils
xorg-server-devel: nvidia-xconfig
opencl-nvidia: OpenCL support
installing nvidia-prime…
installing lib32-nvidia-utils…
Optional dependencies for lib32-nvidia-utils
lib32-opencl-nvidia
installing linux61-nvidia…
installing linux62-nvidia…
:: Running post-transaction hooks…
(1/9) Creating system user accounts…
(2/9) Reloading system manager configuration…
(3/9) Reloading device manager configuration…
(4/9) Arming ConditionNeedsUpdate…
(5/9) Updating module dependencies…
(6/9) Updating Kernel initcpios for Nvidia-DRM…
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: ‘default’
→ -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64.img
==> Starting build: 6.1.11-1-MANJARO
→ Running build hook: [base]
→ Running build hook: [udev]
→ Running build hook: [autodetect]
→ Running build hook: [modconf]
→ Running build hook: [block]
==> WARNING: Possibly missing firmware for module: xhci_pci
→ Running build hook: [keyboard]
→ Running build hook: [keymap]
→ Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
→ Running build hook: [plymouth]
→ Running build hook: [filesystems]
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.1-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: ‘fallback’
→ -k /boot/vmlinuz-6.1-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.1-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: aic94xx
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla1280
module: qla2xxx
==> WARNING: Possibly missing firmware for module: wd719x
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.1-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux62.preset: ‘default’
→ -k /boot/vmlinuz-6.2-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.2-x86_64.img
==> Starting build: 6.2.0-2-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.2-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux62.preset: ‘fallback’
→ -k /boot/vmlinuz-6.2-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.2-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: qla2xxx
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.2-x86_64-fallback.img
(7/9) Refreshing PackageKit…
(8/9) Reloading system bus configuration…
(9/9) Updating the desktop file MIME type cache…
nvidia-utils: install reason has been set to ‘explicitly installed’
nvidia-prime: install reason has been set to ‘explicitly installed’
lib32-nvidia-utils: install reason has been set to ‘explicitly installed’
linux61-nvidia: install reason has been set to ‘explicitly installed’
linux62-nvidia: install reason has been set to ‘explicitly installed’
xorg configuration file: ‘/etc/X11/mhwd.d/nvidia.conf’
Successfully installed video-hybrid-intel-nvidia-prime
Done …
