Problems with Nvidia Driver on Hybrid Laptop
dual-gpu
#1
I have Manjaro installed on a Dell 7567, it has a external gpu. I tried installing the bumblebees drivers, but had problems with resolution, and it didn't recognize the HDMI output. Then i installed the video-nvidia driver, and the resolution and the HDMI works fine, but i can only use the HDMI, the laptop screen freeze on the boot.
And using "xrandr --listmonitors", it only sees the HDMI.
The video-nvidia driver only supports the HDMI output?
#2
Please post:
inxi -Fxxxz
from terminal, copy that text and paste it here.
Use ``` above.
Did you install Bumblebee after the instructions?
https://wiki.archlinux.org/index.php/Bumblebee
