Hi a couple of days ago I decided to boot into manjaro again I updated everything including kernel, everything started breaking, I had problems with nvidia proprietary drivers I got “Failed to start Load kernel…” which btw gives 0 information so I have no idea what the f*** is failing. I managed to fix it by uninstalling the proprietary driver and installing the free one so far so good but know the kernel still had the “Failed to start Load kernel…” but it did boot at least.
After all those problems I decided to install another kernel and 5.11 and now it is booting but it has so many problems, system is slow and I mean really slow and intellij is unusable (even after reinstalling) I get random system crashes and the list grows.
I don’t know what to do I really like manjaro but I feel like I can’t fix anything and whenever I try to fix something other components tend to break.
Reinstalling the distro is not really an option I don’t want to lose all the files and configurations that I have that would mean a whole day of re configuring everything I picked manjaro and unluckily I will be stuck with it until I have some free time.
-- Journal begins at Thu 2020-08-20 18:28:52 CEST, ends at Thu 2021-04-15 16:05:55 CEST. --
abr 15 15:35:39 systemd-modules-load[438]: Inserted module 'crypto_user'
abr 15 15:35:39 systemd-modules-load[438]: Inserted module 'sg'
abr 15 15:35:39 systemd-modules-load[438]: Inserted module 'videodev'
abr 15 15:35:39 systemd-modules-load[438]: Failed to find module 'v4l2loopback-dc'
abr 15 15:35:39 systemd-modules-load[438]: Inserted module 'snd_aloop'
abr 15 15:35:39 systemd-modules-load[438]: Module 'msr' is built in
abr 15 15:35:39 systemd-modules-load[438]: Inserted module 'uinput'
abr 15 15:35:39 systemd[1]: Finished Load Kernel Modules.
inxi -Fazy
Kernel: 5.11.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.11-x86_64
root=UUID=3004b35a-ed65-4865-9f5c-b8eae578088e rw quiet
cryptdevice=UUID=0ad6ed0a-4e5b-4534-9f70-b7f1a4f5a0b4:luks-0ad6ed0a-4e5b-4534-9f70-b7f1a4f5a0b4
root=/dev/mapper/luks-0ad6ed0a-4e5b-4534-9f70-b7f1a4f5a0b4 apparmor=1
security=apparmor
resume=/dev/mapper/luks-139bcda6-74f1-4678-8cea-cb94f58c5ccf
udev.log_priority=3 snd_hda_intel.dmic_detect=0
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: Z390 AORUS MASTER v: N/A
serial: <filter>
Mobo: Gigabyte model: Z390 AORUS MASTER-CF v: x.x serial: <filter>
UEFI: American Megatrends v: F11c date: 12/18/2019
Device-1: hidpp_battery_0 model: Logitech G603 Wireless Gaming Mouse
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Info: 8-Core model: Intel Core i9-9900KF bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: C (12)
microcode: DE cache: L2: 16 MiB
bogomips: 115232
Speed: 800 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 800 2: 4896
3: 3803 4: 2743 5: 2216 6: 844 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
13: 800 14: 800 15: 801 16: 800
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: ASUSTeK driver: nouveau
v: kernel bus-ID: 01:00.0 chip-ID: 10de:13c2 class-ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: nouveau unloaded: modesetting alternate: fbdev,nv,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
s-diag: 1055mm (41.5")
Monitor-1: HDMI-1 res: 1920x1080 hz: 60 dpi: 3048 size: 16x9mm (0.6x0.4")
diag: 18mm (0.7")
Monitor-2: DP-1 res: 1920x1080 dpi: 92 size: 531x299mm (20.9x11.8")
diag: 609mm (24")
OpenGL: renderer: NV124 v: 4.3 Mesa 20.3.4 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
Device-2: NVIDIA GM204 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fbb
class-ID: 0403
Device-3: Logitech Logitech USB Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-10:5 chip-ID: 046d:0a8f
class-ID: 0300
Device-4: VIA SMSL AD-18 Amplifier type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-7:4 chip-ID: 040d:3400
class-ID: 0300
Sound Server-1: ALSA v: k5.11.10-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: no
Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-2: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-703a6885df06 state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
IF-ID-3: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:9 chip-ID: 8087:0aaa class-ID: e001
Report: ID: hci0 state: up address: <filter> bt-v: 3.0 lmp-v: 5.1 sub-v: 100
hci-v: 5.1 rev: 100
Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff
link-mode: slave accept
service-classes: rendering, capturing, object transfer, audio
Hardware-1: Intel SATA Controller [RAID mode] driver: ahci v: 3.0 port: 4020
bus-ID: 00:17.0 chip-ID: 8086.2822 rev: 10 class-ID: 0104
Local Storage: total: 1.35 TiB used: 93.25 GiB (6.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: R013 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SDSSDHII240G
rotation: SSD serial: <filter> rev: 00RL scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD10EZEX-00WN4A0
rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: MBR
ID-1: / raw-size: 206.14 GiB size: 201.91 GiB (97.94%)
used: 93.25 GiB (46.2%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-0ad6ed0a-4e5b-4534-9f70-b7f1a4f5a0b4
used: 428 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 17.13 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-139bcda6-74f1-4678-8cea-cb94f58c5ccf
System Temperatures: cpu: 31.0 C mobo: N/A gpu: nouveau temp: 34.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 438
Processes: 451 Uptime: 36m wakeups: 3 Memory: 15.57 GiB
used: 8.04 GiB (51.6%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 Packages: pacman: 1446 lib: 419 flatpak: 0 Shell: Zsh v: 5.8
running-in: konsole inxi: 3.3.03
