(base) [daniel@daniel-pc ~]$ yay -Syu
[sudo] password for daniel:
core is up to date
extra is up to date
community is up to date
multilib is up to date
warning: python-pyqt5: local (5.15.6-7.1) is newer than extra (5.15.6-7)
there is nothing to do
:: Searching databases for updates...
:: Searching AUR for updates...
-> python-pyqt5: local (5.15.6-7.1) is newer than extra (5.15.6-7)
-> libdbusmenu-qt4: local (0.9.3+16.04.20160218-2) is newer than AUR (0.9.3+16.04.20160218-1)
-> Missing AUR Packages: linux511 linux511-r8168 xf86-input-keyboard xf86-input-mouse
-> Orphaned AUR Packages: intel-ipsec-mb libdbusmenu-qt4 sni-qt
-> Flagged Out Of Date AUR Packages: intel-ipsec-mb
:: 1 Packages to upgrade.
1 aur/qt4 4.8.7-33 -> 4.8.7-35
==> Packages to exclude: (eg: "1 2 3", "1-3", "^4" or repo name)
:: Checking for conflicts...
:: Checking for inner conflicts...
[Aur:1] qt4-4.8.7-35
1 qt4 (Installed) (Build Files Exist)
==> Packages to cleanBuild?
==> [N]one [A]ll [Ab]ort [I]nstalled [No]tInstalled or (1 2 3, 1-3, ^4)
==> A
:: Deleting (1/1): /home/daniel/.cache/yay/qt4
:: (1/1) Downloaded PKGBUILD: qt4
==> Diffs to show?
:: (1/1) Parsing SRCINFO: qt4
==> Making package: qt4 4.8.7-35 (Tue 07 Jun 2022 23:02:33)
==> Retrieving sources...
-> Downloading qt-everywhere-opensource-src-4.8.7.tar.gz...
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 229M 100 229M 0 0 4396k 0 0:00:53 0:00:53 --:--:-- 5714k
-> Found qtconfig-qt4.desktop
-> Found assistant-qt4.desktop
-> Found designer-qt4.desktop
-> Found linguist-qt4.desktop
-> Found qdbusviewer-qt4.desktop
-> Found improve-cups-support.patch
-> Found moc-boost-workaround.patch
-> Found kubuntu_14_systemtrayicon.diff
-> Found kde4-settings.patch
-> Found glib-honor-ExcludeSocketNotifiers-flag.diff
-> Found disable-sslv3.patch
-> Found l-qclipboard_fix_recursive.patch
-> Found l-qclipboard_delay.patch
-> Found qt4-gcc6.patch
-> Found qt4-gcc8.patch
-> Found qt4-gcc9.patch
-> Found qt4-gcc11.patch
-> Found qt4-glibc-2.25.patch
-> Found qt4-icu59.patch
-> Found qt4-openssl-1.1.patch
-> Found fix_jit.patch
qt-everywhere-opensource-src-4.8.7.tar.gz ... Passed
qtconfig-qt4.desktop ... Passed
assistant-qt4.desktop ... Passed
designer-qt4.desktop ... Passed
linguist-qt4.desktop ... Passed
qdbusviewer-qt4.desktop ... Passed
improve-cups-support.patch ... Passed
moc-boost-workaround.patch ... Passed
kubuntu_14_systemtrayicon.diff ... Passed
kde4-settings.patch ... Passed
glib-honor-ExcludeSocketNotifiers-flag.diff ... Passed
disable-sslv3.patch ... Passed
l-qclipboard_fix_recursive.patch ... Passed
l-qclipboard_delay.patch ... Passed
qt4-gcc6.patch ... Passed
qt4-gcc8.patch ... Passed
qt4-gcc9.patch ... Passed
qt4-gcc11.patch ... Passed
qt4-glibc-2.25.patch ... Passed
qt4-icu59.patch ... Passed
qt4-openssl-1.1.patch ... Passed
fix_jit.patch ... Passed
==> Making package: qt4 4.8.7-35 (Tue 07 Jun 2022 23:03:29)
-> Found qt-everywhere-opensource-src-4.8.7.tar.gz
==> Extracting sources...
-> Extracting qt-everywhere-opensource-src-4.8.7.tar.gz with bsdtar
==> Starting prepare()...
patching file src/gui/dialogs/qprintdialog_unix.cpp
Hunk #1 succeeded at 579 (offset 10 lines).
patching file src/gui/painting/qprinter.cpp
Hunk #1 succeeded at 609 (offset -18 lines).
patching file src/tools/moc/main.cpp
patching file examples/desktop/systray/window.cpp
patching file examples/desktop/systray/window.h
patching file src/gui/util/qabstractsystemtrayiconsys.cpp
patching file src/gui/util/qabstractsystemtrayiconsys_p.h
patching file src/gui/util/qsystemtrayicon.cpp
patching file src/gui/util/qsystemtrayicon_p.h
patching file src/gui/util/qsystemtrayicon_x11.cpp
patching file src/gui/util/qxembedsystemtrayicon_x11.cpp
patching file src/gui/util/qxembedsystemtrayicon_x11_p.h
patching file src/gui/util/util.pri
patching file src/gui/kernel/qkde.cpp
patching file src/corelib/kernel/qeventdispatcher_glib.cpp
Hunk #4 succeeded at 338 (offset 1 line).
Hunk #5 succeeded at 424 (offset 1 line).
Hunk #6 succeeded at 436 (offset 1 line).
patching file src/corelib/kernel/qeventdispatcher_unix.cpp
patching file src/gui/kernel/qclipboard_x11.cpp
patching file src/network/ssl/qsslsocket_openssl.cpp
patching file src/network/ssl/qsslsocket_openssl_symbols.cpp
patching file configure
Hunk #1 succeeded at 7734 (offset -10 lines).
Hunk #2 succeeded at 8050 (offset -10 lines).
patching file src/xmlpatterns/api/qcoloroutput_p.h
patching file src/3rdparty/javascriptcore/JavaScriptCore/jit/JITStubs.cpp
patching file src/corelib/global/qglobal.h
patching file tools/linguist/linguist/messagemodel.cpp
patching file src/corelib/tools/qlocale_icu.cpp
patching file src/network/ssl/qsslcertificate.cpp
patching file src/network/ssl/qsslkey.cpp
patching file src/network/ssl/qsslsocket_openssl_symbols_p.h
Hunk #2 succeeded at 304 (offset 4 lines).
patching file src/3rdparty/javascriptcore/JavaScriptCore/jit/JITStubs.h
==> Sources are ready.
==> Making package: qt4 4.8.7-35 (Tue 07 Jun 2022 23:03:38)
==> WARNING: Using existing $srcdir/ tree
==> Starting build()...
This is the Open Source Edition.
You are licensed to use this software under the terms of
the Lesser GNU General Public License (LGPL) versions 2.1.
You are also licensed to use this software under the terms of
the GNU General Public License (GPL) versions 3.
You have already accepted the terms of the license.
Creating qmake. Please wait...
/home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/corelib/io/qfilesystemiterator_unix.cpp: In member function ‘bool QFileSystemIterator::advance(QFileSystemEntry&, QFileSystemMetaData&)’:
/home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/corelib/io/qfilesystemiterator_unix.cpp:114:29: warning: ‘int readdir_r(DIR*, dirent*, dirent**)’ is deprecated [-Wdeprecated-declarations]
114 | lastError = QT_READDIR_R(dir, mt_file.data(), &dirEntry);
In file included from /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/mkspecs/linux-g++/qplatformdefs.h:65,
from /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/corelib/io/qfilesystemiterator_unix.cpp:42:
/usr/include/dirent.h:183:12: note: declared here
183 | extern int readdir_r (DIR *__restrict __dirp,
In file included from /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/include/QtCore/private/qcore_unix_p.h:1,
from /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/corelib/io/qfsfileengine_unix.cpp:45:
/home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/include/QtCore/private/../../../src/corelib/kernel/qcore_unix_p.h: In function ‘int qt_safe_execve(const char*, char* const*, char* const*)’:
/home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/include/QtCore/private/../../../src/corelib/kernel/qcore_unix_p.h:312:18: warning: ISO C++17 does not allow ‘register’ storage class specifier [-Wregister]
312 | register int ret;
/home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/include/QtCore/private/../../../src/corelib/kernel/qcore_unix_p.h: In function ‘int qt_safe_execv(const char*, char* const*)’:
/home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/include/QtCore/private/../../../src/corelib/kernel/qcore_unix_p.h:319:18: warning: ISO C++17 does not allow ‘register’ storage class specifier [-Wregister]
319 | register int ret;
/home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/include/QtCore/private/../../../src/corelib/kernel/qcore_unix_p.h: In function ‘int qt_safe_execvp(const char*, char* const*)’:
/home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/include/QtCore/private/../../../src/corelib/kernel/qcore_unix_p.h:326:18: warning: ISO C++17 does not allow ‘register’ storage class specifier [-Wregister]
326 | register int ret;
/home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/include/QtCore/private/../../../src/corelib/kernel/qcore_unix_p.h: In function ‘pid_t qt_safe_waitpid(pid_t, int*, int)’:
/home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/include/QtCore/private/../../../src/corelib/kernel/qcore_unix_p.h:335:18: warning: ISO C++17 does not allow ‘register’ storage class specifier [-Wregister]
335 | register int ret;
from /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/corelib/io/qfsfileengine.cpp:56:
from /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/corelib/io/qtemporaryfile.cpp:57:
In file included from /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/corelib/tools/qcryptographichash.cpp:49:
/home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/corelib/tools/../../3rdparty/md5/md5.cpp: In function ‘void MD5Transform(UWORD32*, const UWORD32*)’:
/home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/corelib/tools/../../3rdparty/md5/md5.cpp:164:26: warning: ISO C++17 does not allow ‘register’ storage class specifier [-Wregister]
164 | register UWORD32 a, b, c, d;
/home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/corelib/tools/../../3rdparty/md5/md5.cpp:164:29: warning: ISO C++17 does not allow ‘register’ storage class specifier [-Wregister]
/home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/corelib/tools/../../3rdparty/md5/md5.cpp:164:32: warning: ISO C++17 does not allow ‘register’ storage class specifier [-Wregister]
/home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/corelib/tools/../../3rdparty/md5/md5.cpp:164:35: warning: ISO C++17 does not allow ‘register’ storage class specifier [-Wregister]
ln: failed to create symbolic link '/home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/include/QtCore/qconfig.h': File exists
ln: failed to create symbolic link '/home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/include/Qt/qconfig.h': File exists
This target is using the GNU C++ compiler (linux-g++).
Recent versions of this compiler automatically include code for
exceptions, which increase both the size of the Qt libraries and
the amount of memory taken by your applications.
You may choose to re-run configure with the -no-exceptions
option to compile Qt without exceptions. This is completely binary
compatible, and existing applications will continue to work.
Build type: linux-g++
Architecture: x86_64
Platform notes:
- Also available for Linux: linux-kcc linux-icc linux-cxx
Build .................. libs tools translations
Configuration .......... silent system-sqlite release largefile stl precompile_header mmx 3dnow sse sse2 sse3 ssse3 sse4_1 sse4_2 avx minimal-config small-config medium-config large-config full-config qt3support accessibility opengl shared reduce_exports ipv6 clock-gettime clock-monotonic mremap getaddrinfo ipv6ifname getifaddrs inotify system-jpeg system-mng system-png png system-tiff system-freetype system-zlib cups iconv glib dbus dbus-linked openssl-linked x11sm xshape xvideo xsync xrender mitshm fontconfig xkb pulseaudio icu concurrent xmlpatterns multimedia audio-backend svg script scripttools declarative release
Debug .................. no
Qt 3 compatibility ..... yes
QtDBus module .......... yes (linked)
QtConcurrent code ...... yes
QtGui module ........... yes
QtScript module ........ yes
QtScriptTools module ... yes
QtXmlPatterns module ... yes
Phonon module .......... no
Multimedia module ...... auto
SVG module ............. yes
WebKit module .......... no
JavaScriptCore JIT ..... To be decided by JavaScriptCore
Declarative module ..... yes
Declarative debugging ...yes
Support for S60 ........ no
Symbian DEF files ...... no
STL support ............ yes
PCH support ............ yes
MMX/3DNOW/SSE/SSE2/SSE3. yes/yes/yes/yes/yes
SSSE3/SSE4.1/SSE4.2..... yes/yes/yes
AVX..................... yes
Graphics System ........ raster
IPv6 support ........... yes
IPv6 ifname support .... yes
getaddrinfo support .... yes
getifaddrs support ..... yes
Accessibility .......... yes
NIS support ............ no
CUPS support ........... yes
Iconv support .......... yes
Glib support ........... yes
GStreamer support ...... no
PulseAudio support ..... yes
Large File support ..... yes
GIF support ............ plugin
TIFF support ........... plugin (system)
JPEG support ........... plugin (system)
PNG support ............ yes (system)
MNG support ............ plugin (system)
zlib support ........... system
Session management ..... yes
OpenGL support ......... yes (Desktop OpenGL)
OpenVG support ......... no
NAS sound support ...... no
XShape support ......... yes
XVideo support ......... yes
XSync support .......... yes
Xinerama support ....... runtime
Xcursor support ........ runtime
Xfixes support ......... runtime
Xrandr support ......... runtime
Xrender support ........ yes
Xi support ............. runtime
MIT-SHM support ........ yes
FontConfig support ..... yes
XKB Support ............ yes
immodule support ....... yes
GTK theme support ...... yes
MySQL support .......... plugin
PostgreSQL support ..... plugin
ODBC support ........... plugin
InterBase support ...... plugin
SQLite support ......... plugin (system)
OpenSSL support ........ linked (linked)
Alsa support ........... no
ICD support ............ no
libICU support ......... yes
Use system proxies ..... no
NOTE: When linking against OpenSSL, you can override the default
library names through OPENSSL_LIBS.
For example:
OPENSSL_LIBS='-L/opt/ssl/lib -lssl -lcrypto' ./configure -openssl-linked
Finding project files. Please wait...
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/tools/bootstrap/bootstrap.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/tools/moc/moc.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/tools/rcc/rcc.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/tools/uic/uic.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/corelib/corelib.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/xml/xml.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/network/network.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/sql/sql.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/testlib/testlib.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/dbus/dbus.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/gui/gui.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/qt3support/qt3support.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/tools/uic3/uic3.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/opengl/opengl.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/xmlpatterns/xmlpatterns.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/multimedia/multimedia.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/svg/svg.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/script/script.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/declarative/declarative.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/scripttools/scripttools.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/plugins.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/sqldrivers/sqldrivers.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/sqldrivers/psql/psql.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/sqldrivers/mysql/mysql.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/sqldrivers/odbc/odbc.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/sqldrivers/sqlite/sqlite.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/sqldrivers/ibase/ibase.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/script/script.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/script/qtdbus/qtdbus.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/bearer/bearer.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/bearer/generic/generic.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/bearer/connman/connman.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/bearer/networkmanager/networkmanager.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/codecs/codecs.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/codecs/cn/cn.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/codecs/jp/jp.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/codecs/tw/tw.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/codecs/kr/kr.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/imageformats/imageformats.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/imageformats/jpeg/jpeg.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/imageformats/gif/gif.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/imageformats/mng/mng.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/imageformats/svg/svg.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/imageformats/tiff/tiff.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/imageformats/ico/ico.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/imageformats/tga/tga.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/iconengines/iconengines.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/iconengines/svgiconengine/svgiconengine.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/graphicssystems/graphicssystems.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/graphicssystems/trace/trace.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/graphicssystems/opengl/opengl.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/inputmethods/inputmethods.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/inputmethods/imsw-multi/imsw-multi.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/accessible/accessible.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/accessible/widgets/widgets.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/accessible/compat/compat.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/qmltooling/qmltooling.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/qmltooling/qmldbg_tcp/qmldbg_tcp.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/qmltooling/qmldbg_inspector/qmldbg_inspector.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/imports/imports.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/imports/folderlistmodel/folderlistmodel.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/imports/particles/particles.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/imports/gestures/gestures.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/imports/shaders/shaders.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/tools.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/assistant/assistant.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/assistant/lib/fulltextsearch/fulltextsearch.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/assistant/lib/lib.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/assistant/tools/tools.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/assistant/tools/assistant/assistant.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/assistant/tools/qhelpgenerator/qhelpgenerator.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/assistant/tools/qcollectiongenerator/qcollectiongenerator.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/assistant/tools/qhelpconverter/qhelpconverter.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/pixeltool/pixeltool.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/porting/porting.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/porting/src/src.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qtestlib/qtestlib.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qtestlib/updater/updater.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qttracereplay/qttracereplay.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/designer.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/src/src.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/src/uitools/uitools.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/src/lib/lib.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/src/components/components.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/src/components/lib/lib.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/src/designer/designer.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/src/plugins/plugins.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/src/plugins/widgets/widgets.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/src/plugins/qdeclarativeview/qdeclarativeview.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qtconfig/qtconfig.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qml/qml.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qmlplugindump/qmlplugindump.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/linguist/linguist.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/linguist/lrelease/lrelease.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/linguist/lupdate/lupdate.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/linguist/lconvert/lconvert.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/linguist/linguist/linguist.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qdbus/qdbus.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qdbus/qdbus/qdbus.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qdbus/qdbusxml2cpp/qdbusxml2cpp.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qdbus/qdbuscpp2xml/qdbuscpp2xml.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qdbus/qdbusviewer/qdbusviewer.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/xmlpatterns/xmlpatterns.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/xmlpatternsvalidator/xmlpatternsvalidator.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qdoc3/qdoc3.pro
Reading /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/translations/translations.pro
1088 projects found.
Creating makefiles. Please wait...
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/dbus/dbus.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit2/WebProcess.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/QtWebKit.pro
Project MESSAGE: Disabling video due the lack of GLib/Gio/GStreamer.
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/declarative/declarative.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/symbian/platformplugin/platformplugin.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/opengl/opengl.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/imports/folderlistmodel/folderlistmodel.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/imports/gestures/gestures.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/imports/shaders/shaders.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/imports/particles/particles.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/declarative/declarative.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/xml/xml.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/corelib/corelib.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/sql/sql.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/scripttools/scripttools.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/xmlpatterns/xmlpatterns.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/network/network.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/script/script.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/tools/moc/moc.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/multimedia/multimedia.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/testlib/testlib.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/qt3support/qt3support.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/openvg/openvg.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/gui/gui.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/svg/svg.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/src/components/lib/lib.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/src/uitools/uitools.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qtestlib/wince/remotelib/remotelib.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/assistant/lib/lib.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/assistant/lib/fulltextsearch/fulltextsearch.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qmeegographicssystemhelper/qmeegographicssystemhelper.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/translations/translations.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/src.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/activeqt/activeqt.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/activeqt/control/control.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/activeqt/container/container.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit2/WebKit2.pro
WARNING: Failure to find: generated/AuthenticationManagerMessageReceiver.cpp
WARNING: Failure to find: generated/DownloadProxyMessageReceiver.cpp
WARNING: Failure to find: generated/DrawingAreaMessageReceiver.cpp
WARNING: Failure to find: generated/DrawingAreaProxyMessageReceiver.cpp
WARNING: Failure to find: generated/NPObjectMessageReceiverMessageReceiver.cpp
WARNING: Failure to find: generated/PluginControllerProxyMessageReceiver.cpp
WARNING: Failure to find: generated/PluginProcessMessageReceiver.cpp
WARNING: Failure to find: generated/PluginProcessProxyMessageReceiver.cpp
WARNING: Failure to find: generated/PluginProxyMessageReceiver.cpp
WARNING: Failure to find: generated/WebApplicationCacheManagerMessageReceiver.cpp
WARNING: Failure to find: generated/WebApplicationCacheManagerProxyMessageReceiver.cpp
WARNING: Failure to find: generated/WebContextMessageReceiver.cpp
WARNING: Failure to find: generated/WebCookieManagerMessageReceiver.cpp
WARNING: Failure to find: generated/WebCookieManagerProxyMessageReceiver.cpp
WARNING: Failure to find: generated/WebDatabaseManagerMessageReceiver.cpp
WARNING: Failure to find: generated/WebDatabaseManagerProxyMessageReceiver.cpp
WARNING: Failure to find: generated/WebFullScreenManagerMessageReceiver.cpp
WARNING: Failure to find: generated/WebFullScreenManagerProxyMessageReceiver.cpp
WARNING: Failure to find: generated/WebGeolocationManagerMessageReceiver.cpp
WARNING: Failure to find: generated/WebGeolocationManagerProxyMessageReceiver.cpp
WARNING: Failure to find: generated/WebIconDatabaseMessageReceiver.cpp
WARNING: Failure to find: generated/WebIconDatabaseProxyMessageReceiver.cpp
WARNING: Failure to find: generated/WebInspectorMessageReceiver.cpp
WARNING: Failure to find: generated/WebInspectorProxyMessageReceiver.cpp
WARNING: Failure to find: generated/WebKeyValueStorageManagerMessageReceiver.cpp
WARNING: Failure to find: generated/WebKeyValueStorageManagerProxyMessageReceiver.cpp
WARNING: Failure to find: generated/WebMediaCacheManagerMessageReceiver.cpp
WARNING: Failure to find: generated/WebMediaCacheManagerProxyMessageReceiver.cpp
WARNING: Failure to find: generated/WebPageMessageReceiver.cpp
WARNING: Failure to find: generated/WebPageProxyMessageReceiver.cpp
WARNING: Failure to find: generated/WebProcessConnectionMessageReceiver.cpp
WARNING: Failure to find: generated/WebProcessMessageReceiver.cpp
WARNING: Failure to find: generated/WebProcessProxyMessageReceiver.cpp
WARNING: Failure to find: generated/WebResourceCacheManagerMessageReceiver.cpp
WARNING: Failure to find: generated/WebResourceCacheManagerProxyMessageReceiver.cpp
WARNING: Failure to find: generated/AuthenticationManagerMessages.h
WARNING: Failure to find: generated/DownloadProxyMessages.h
WARNING: Failure to find: generated/NPObjectMessageReceiverMessages.h
WARNING: Failure to find: generated/PluginControllerProxyMessages.h
WARNING: Failure to find: generated/PluginProcessMessages.h
WARNING: Failure to find: generated/PluginProcessProxyMessages.h
WARNING: Failure to find: generated/PluginProxyMessages.h
WARNING: Failure to find: generated/WebApplicationCacheManagerMessages.h
WARNING: Failure to find: generated/WebApplicationCacheManagerProxyMessages.h
WARNING: Failure to find: generated/WebContextMessages.h
WARNING: Failure to find: generated/WebCookieManagerMessages.h
WARNING: Failure to find: generated/WebCookieManagerProxyMessages.h
WARNING: Failure to find: generated/WebDatabaseManagerMessages.h
WARNING: Failure to find: generated/WebDatabaseManagerProxyMessages.h
WARNING: Failure to find: generated/WebFullScreenManagerMessages.h
WARNING: Failure to find: generated/WebFullScreenManagerProxyMessages.h
WARNING: Failure to find: generated/WebGeolocationManagerMessages.h
WARNING: Failure to find: generated/WebGeolocationManagerProxyMessages.h
WARNING: Failure to find: generated/WebIconDatabaseMessages.h
WARNING: Failure to find: generated/WebIconDatabaseProxyMessages.h
WARNING: Failure to find: generated/WebInspectorMessages.h
WARNING: Failure to find: generated/WebInspectorProxyMessages.h
WARNING: Failure to find: generated/WebKeyValueStorageManagerMessages.h
WARNING: Failure to find: generated/WebKeyValueStorageManagerProxyMessages.h
WARNING: Failure to find: generated/WebMediaCacheManagerMessages.h
WARNING: Failure to find: generated/WebMediaCacheManagerProxyMessages.h
WARNING: Failure to find: generated/WebPageMessages.h
WARNING: Failure to find: generated/WebPageProxyMessages.h
WARNING: Failure to find: generated/WebProcessConnectionMessages.h
WARNING: Failure to find: generated/WebProcessMessages.h
WARNING: Failure to find: generated/WebProcessProxyMessages.h
WARNING: Failure to find: generated/WebResourceCacheManagerMessages.h
WARNING: Failure to find: generated/WebResourceCacheManagerProxyMessages.h
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit2/UIProcess/API/qt/tests/tests.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit2/DerivedSources.pro
WARNING: DESTDIR: Cannot access directory '/include/WebCore'
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/JavaScriptCore/JavaScriptCore.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebCore/WebCore.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/tests/tests.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/examples/examples.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/imports/imports.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/s60installs/s60installs.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/imageformats/imageformats.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/qmltooling/qmltooling.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/mousedrivers/mousedrivers.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/decorations/decorations.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/graphicssystems/graphicssystems.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/kbddrivers/kbddrivers.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/platforms/fb_base/fb_base.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/platforms/uikit/uikit.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/platforms/platforms.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/script/script.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/phonon/phonon.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/iconengines/iconengines.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/plugins.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/codecs/codecs.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/gfxdrivers/powervr/powervr.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/gfxdrivers/powervr/QWSWSEGL/QWSWSEGL.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/gfxdrivers/gfxdrivers.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/bearer/symbian/symbian.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/bearer/bearer.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/sqldrivers/sqldrivers.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/sqldrivers/sqlite_symbian/sqlite_symbian.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/inputmethods/inputmethods.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/accessible/accessible.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/tools/tools.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/tools/bootstrap/bootstrap.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/macdeployqt/macdeployqt.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/activeqt/activeqt.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/linguist/lrelease/lrelease.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/linguist/linguist.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/src/src.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/src/plugins/widgets/widgets.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/src/plugins/plugins.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/src/components/components.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/designer.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qdbus/qdbus.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qtestlib/wince/wince.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qtestlib/qtestlib.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/tools.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/assistant/assistant.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/assistant/tools/tools.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/porting/porting.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit2/UIProcess/API/qt/tests/qgraphicswkview/qgraphicswkview.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit2/UIProcess/API/qt/tests/qwkpage/qwkpage.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/docs/webkitsnippets/webelement/webelement.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/docs/webkitsnippets/webpage/webpage.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/docs/webkitsnippets/simple/simple.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/tests/qwebplugindatabase/qwebplugindatabase.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/tests/MIMESniffing/MIMESniffing.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/tests/benchmarks/webgl/webgl.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/tests/benchmarks/painting/painting.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/tests/benchmarks/loading/loading.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/tests/qgraphicswebview/qgraphicswebview.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/tests/qwebframe/qwebframe.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/tests/qwebelement/qwebelement.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/tests/qwebpage/qwebpage.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/tests/hybridPixmap/hybridPixmap.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/tests/qwebhistoryinterface/qwebhistoryinterface.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/tests/qdeclarativewebview/qdeclarativewebview.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/tests/qwebview/qwebview.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/tests/qwebinspector/qwebinspector.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/tests/qwebhistory/qwebhistory.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/3rdparty/webkit/Source/WebKit/qt/examples/platformplugin/platformplugin.pro
WARNING: DESTDIR: Cannot access directory '/usr/lib/qt4/plugins/webkit'
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/opengl/util/meego/shader-cache-introspector.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/opengl/util/generator.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/imageformats/ico/ico.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/imageformats/gif/gif.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/imageformats/jpeg/jpeg.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/imageformats/mng/mng.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/imageformats/tga/tga.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/imageformats/tiff/tiff.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/imageformats/svg/svg.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/qmltooling/qmldbg_ost/qmldbg_ost.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/qmltooling/qmldbg_tcp/qmldbg_tcp.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/qmltooling/qmldbg_inspector/qmldbg_inspector.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/mousedrivers/pc/pc.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/mousedrivers/linuxtp/linuxtp.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/mousedrivers/tslib/tslib.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/decorations/windows/windows.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/decorations/styled/styled.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/decorations/default/default.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/graphicssystems/opengl/opengl.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/graphicssystems/meego/meego.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/graphicssystems/shivavg/shivavg.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/graphicssystems/openvg/openvg.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/graphicssystems/trace/trace.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/kbddrivers/linuxinput/linuxinput.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/s60/feedback/feedback.pro
WARNING: /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/s60/feedback/feedback.pro:16: Unable to find file for inclusion data_caging_paths
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/platforms/blackberry/blackberry.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/platforms/vnc/vnc.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/platforms/eglfs/eglfs.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/platforms/qvfb/qvfb.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/platforms/xcb/xcb.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/platforms/uikit/phonon_av/phonon_av.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/platforms/uikit/platform.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/platforms/directfb/directfb.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/platforms/xlib/xlib.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/platforms/cocoa/cocoa.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/platforms/minimal/minimal.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/platforms/linuxfb/linuxfb.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/platforms/openkode/openkode.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/platforms/wayland/wayland.pro
Project MESSAGE: Wayland GL Integration: xcomposite_glx
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/script/qtdbus/qtdbus.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/phonon/mmf/mmf.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/phonon/ds9/ds9.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/phonon/gstreamer/gstreamer.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/phonon/qt7/qt7.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/phonon/waveout/waveout.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/iconengines/svgiconengine/svgiconengine.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/codecs/kr/kr.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/codecs/tw/tw.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/codecs/cn/cn.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/codecs/jp/jp.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/generic/linuxinput/linuxinput.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/generic/tslib/tslib.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/gfxdrivers/ahi/ahi.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/gfxdrivers/vnc/vnc.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/gfxdrivers/transformed/transformed.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/gfxdrivers/qvfb/qvfb.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/gfxdrivers/powervr/pvreglscreen/pvreglscreen.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/gfxdrivers/directfb/directfb.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/gfxdrivers/eglnullws/eglnullws.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/gfxdrivers/linuxfb/linuxfb.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/bearer/nativewifi/nativewifi.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/bearer/icd/icd.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/bearer/connman/connman.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/bearer/blackberry/blackberry.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/bearer/nla/nla.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/bearer/networkmanager/networkmanager.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/bearer/symbian/3_2/3_2.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/bearer/symbian/symbian_3/symbian_3.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/bearer/symbian/3_1/3_1.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/bearer/corewlan/corewlan.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/bearer/generic/generic.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/sqldrivers/sqlite2/sqlite2.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/sqldrivers/db2/db2.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/sqldrivers/ibase/ibase.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/sqldrivers/tds/tds.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/sqldrivers/symsql/symsql.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/sqldrivers/mysql/mysql.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/sqldrivers/odbc/odbc.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/sqldrivers/oci/oci.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/sqldrivers/psql/psql.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/sqldrivers/sqlite/sqlite.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/inputmethods/imsw-multi/imsw-multi.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/accessible/widgets/widgets.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/plugins/accessible/compat/compat.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/tools/rcc/rcc.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/tools/uic3/uic3.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/tools/idc/idc.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/tools/moc/util/generate_keywords.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/tools/uic/uic.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/phonon/phonon.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/checksdk/checksdk.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/macdeployqt/macdeployqt/macdeployqt.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/macdeployqt/macchangeqt/macchangeqt.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/macdeployqt/tests/deployment_mac.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qconfig/qconfig.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qtconfig/qtconfig.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/activeqt/dumpcpp/dumpcpp.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/activeqt/testcon/testcon.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/activeqt/dumpdoc/dumpdoc.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/configure/configure.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/linguist/lconvert/lconvert.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/linguist/linguist/linguist.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/linguist/lupdate/lupdate.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/src/designer/designer.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/src/plugins/activeqt/activeqt.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/src/plugins/qdeclarativeview/qdeclarativeview.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/src/plugins/phononwidgets/phononwidgets.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/src/plugins/tools/view3d/view3d.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/src/plugins/qwebview/qwebview.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/designer/src/lib/lib.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/xmlpatternsvalidator/xmlpatternsvalidator.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qml/qml.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/pixeltool/pixeltool.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qdoc3/qdoc3.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qvfb/qvfb.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qmlplugindump/qmlplugindump.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/runonphone/runonphone.pro
Project MESSAGE: Trk: Console ...
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qdbus/qdbuscpp2xml/qdbuscpp2xml.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qdbus/qdbusxml2cpp/qdbusxml2cpp.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qdbus/qdbus/qdbus.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qdbus/qdbusviewer/qdbusviewer.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qtestlib/wince/cetest/cetest.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qtestlib/wince/cetcpsyncserver/cetcpsyncserver.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qtestlib/wince/cetcpsync/cetcpsync.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qtestlib/updater/updater.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/xmlpatterns/xmlpatterns.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qtconcurrent/generaterun/run.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qtconcurrent/codegenerator/example/example.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/makeqpf/makeqpf.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/kmap2qmap/kmap2qmap.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/qttracereplay/qttracereplay.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/assistant/tools/qcollectiongenerator/qcollectiongenerator.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/assistant/tools/qhelpgenerator/qhelpgenerator.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/assistant/tools/qhelpconverter/qhelpconverter.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/assistant/tools/assistant/assistant.pro
for /home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/tools/porting/src/src.pro
Qt is now configured for building. Just run 'make'.
Once everything is built, you must run 'make install'.
Qt will be installed into /usr
To reconfigure, run 'make confclean' and 'configure'.
cd src/tools/bootstrap/ && make -f Makefile
make[1]: Entering directory '/home/daniel/.cache/yay/qt4/src/qt-everywhere-opensource-src-4.8.7/src/tools/bootstrap'
compiling ../../corelib/codecs/qlatincodec.cpp
compiling ../../corelib/codecs/qisciicodec.cpp
compiling ../../corelib/codecs/qsimplecodec.cpp
compiling ../../corelib/codecs/qtextcodec.cpp
compiling ../../corelib/codecs/qtsciicodec.cpp
compiling ../../corelib/codecs/qutfcodec.cpp
compiling ../../corelib/global/qglobal.cpp
compiling ../../corelib/global/qmalloc.cpp
compiling ../../corelib/global/qnumeric.cpp
compiling ../../corelib/io/qabstractfileengine.cpp
In file included from ../../../include/QtCore/qstring.h:1,
from ../../../include/QtCore/../../src/corelib/codecs/qtextcodec.h:45,
from ../../../include/QtCore/qtextcodec.h:1,
from ../../corelib/codecs/qlatincodec_p.h:56,
from ../../corelib/codecs/qlatincodec.cpp:42:
../../../include/QtCore/../../src/corelib/tools/qstring.h: In member function ‘int QStringRef::compare(QLatin1String, Qt::CaseSensitivity) const’:
../../../include/QtCore/../../src/corelib/tools/qstring.h:1254:33: warning: implicitly-declared ‘constexpr QLatin1String::QLatin1String(const QLatin1String&)’ is deprecated [-Wdeprecated-copy]
1254 | { return QString::compare_helper(constData(), length(), s, cs); }
../../../include/QtCore/../../src/corelib/tools/qstring.h:658:27: note: because ‘QLatin1String’ has user-provided ‘QLatin1String& QLatin1String::operator=(const QLatin1String&)’
658 | inline QLatin1String &operator=(const QLatin1String &other)
../../../include/QtCore/../../src/corelib/tools/qstring.h:634:45: note: initializing argument 3 of ‘static int QString::compare_helper(const QChar*, int, QLatin1String, Qt::CaseSensitivity)’
634 | QLatin1String s2,
../../../include/QtCore/../../src/corelib/tools/qstring.h: In static member function ‘static int QStringRef::compare(const QStringRef&, QLatin1String, Qt::CaseSensitivity)’:
../../../include/QtCore/../../src/corelib/tools/qstring.h:1260:33: warning: implicitly-declared ‘constexpr QLatin1String::QLatin1String(const QLatin1String&)’ is deprecated [-Wdeprecated-copy]
1260 | { return QString::compare_helper(s1.constData(), s1.length(), s2, cs); }
../../../include/QtCore/../../src/corelib/tools/qstring.h: In member function ‘QBool QStringRef::contains(QLatin1String, Qt::CaseSensitivity) const’:
../../../include/QtCore/../../src/corelib/tools/qstring.h:1278:23: warning: implicitly-declared ‘constexpr QLatin1String::QLatin1String(const QLatin1String&)’ is deprecated [-Wdeprecated-copy]
1278 | { return QBool(indexOf(s, 0, cs) != -1); }
../../../include/QtCore/../../src/corelib/tools/qstring.h:1125:31: note: initializing argument 1 of ‘int QStringRef::indexOf(QLatin1String, int, Qt::CaseSensitivity) const’
1125 | int indexOf(QLatin1String str, int from = 0, Qt::CaseSensitivity cs = Qt::CaseSensitive) const;
from ../../corelib/codecs/qutfcodec_p.h:56,
from ../../corelib/codecs/qutfcodec.cpp:42:
from ../../corelib/codecs/qisciicodec_p.h:56,
from ../../corelib/codecs/qisciicodec.cpp:41:
from ../../corelib/codecs/qtsciicodec_p.h:85,
from ../../corelib/codecs/qtsciicodec.cpp:46:
from ../../corelib/codecs/qtextcodec.h:45,
from ../../corelib/codecs/qtextcodec.cpp:43:
from ../../corelib/codecs/qsimplecodec_p.h:56,
from ../../corelib/codecs/qsimplecodec.cpp:42:
compiling ../../corelib/io/qbuffer.cpp
from ../../../include/QtCore/../../src/corelib/io/qdir.h:45,
from ../../../include/QtCore/qdir.h:1,
from ../../corelib/io/qabstractfileengine.h:45,
from ../../corelib/io/qabstractfileengine.cpp:42:
from ../../corelib/global/qglobal.cpp:43:
from ../../../include/QtCore/../../src/corelib/io/qiodevice.h:51,
from ../../../include/QtCore/qiodevice.h:1,
from ../../corelib/io/qbuffer.h:45,
from ../../corelib/io/qbuffer.cpp:42:
../../corelib/codecs/qtextcodec.cpp: At global scope:
../../corelib/codecs/qtextcodec.cpp:119:36: warning: ISO C++17 does not allow ‘register’ storage class specifier [-Wregister]
119 | static char qtolower(register char c)
../../corelib/codecs/qtextcodec.cpp:121:36: warning: ISO C++17 does not allow ‘register’ storage class specifier [-Wregister]
121 | static bool qisalnum(register char c)
compiling ../../corelib/io/qdatastream.cpp
compiling ../../corelib/io/qdir.cpp
In file included from ../../../include/QtCore/qglobal.h:1,
from ../../../mkspecs/linux-g++/qplatformdefs.h:47,
from ../../corelib/codecs/qtextcodec.cpp:42:
../../../include/QtCore/../../src/corelib/global/qglobal.h: In instantiation of ‘void qSwap(T&, T&) [with T = QVariant::Private]’:
../../../include/QtCore/../../src/corelib/kernel/qvariant.h:224:12: required from here
../../../include/QtCore/../../src/corelib/global/qglobal.h:2300:12: warning: implicitly-declared ‘constexpr QVariant::Private& QVariant::Private::operator=(const QVariant::Private&)’ is deprecated [-Wdeprecated-copy]
2300 | value1 = value2;
In file included from ../../../include/QtCore/qvariant.h:1,
from ../../../include/QtCore/../../src/corelib/tools/qlocale.h:45,
from ../../../include/QtCore/qlocale.h:1,
from ../../corelib/codecs/qtextcodec.cpp:84:
../../../include/QtCore/../../src/corelib/kernel/qvariant.h:354:16: note: because ‘QVariant::Private’ has user-provided ‘QVariant::Private::Private(const QVariant::Private&)’
354 | inline Private(const Private &other)
../../../include/QtCore/../../src/corelib/global/qglobal.h:2301:12: warning: implicitly-declared ‘constexpr QVariant::Private& QVariant::Private::operator=(const QVariant::Private&)’ is deprecated [-Wdeprecated-copy]
2301 | value2 = t;
../../corelib/io/qabstractfileengine.cpp: In constructor ‘QAbstractFileEngineIterator::QAbstractFileEngineIterator(QDir::Filters, const QStringList&)’:
../../corelib/io/qabstractfileengine.cpp:888:22: warning: implicitly-declared ‘QStringList& QStringList::operator=(const QStringList&)’ is deprecated [-Wdeprecated-copy]
888 | d->nameFilters = nameFilters;
In file included from ../../../include/QtCore/qstringlist.h:1,
from ../../../include/QtCore/../../src/corelib/io/qdir.h:47:
../../../include/QtCore/../../src/corelib/tools/qstringlist.h:71:12: note: because ‘QStringList’ has user-provided ‘QStringList::QStringList(const QStringList&)’
71 | inline QStringList(const QStringList &l) : QList<QString>(l) { }
compiling ../../corelib/io/qdiriterator.cpp
In file included from ../../../include/QtCore/qvector.h:1,
from ../../corelib/global/qglobal.cpp:44:
../../../include/QtCore/../../src/corelib/tools/qvector.h: In instantiation of ‘void QVector<T>::realloc(int, int) [with T = QList<bool (*)(void**)>]’:
../../../include/QtCore/../../src/corelib/tools/qvector.h:343:3: required from ‘void QVector<T>::resize(int) [with T = QList<bool (*)(void**)>]’
../../corelib/global/qglobal.cpp:3210:30: required from here
../../../include/QtCore/../../src/corelib/tools/qvector.h:503:25: warning: ‘void* memcpy(void*, const void*, size_t)’ writing to an object of type ‘QVector<QList<bool (*)(void**)> >::Data’ {aka ‘struct QVectorTypedData<QList<bool (*)(void**)> >’} with no trivial copy-assignment; use copy-assignment or copy-initialization instead [-Wclass-memaccess]
503 | ::memcpy(x.p, p, sizeOfTypedData() + (qMin(aalloc, d->alloc) - 1) * sizeof(T));
../../../include/QtCore/../../src/corelib/tools/qvector.h:94:8: note: ‘QVector<QList<bool (*)(void**)> >::Data’ {aka ‘struct QVectorTypedData<QList<bool (*)(void**)> >’} declared here
94 | struct QVectorTypedData : private QVectorData
from ../../corelib/io/qdatastream.h:46,
from ../../corelib/io/qdatastream.cpp:42:
from ../../../include/QtCore/../../src/corelib/tools/qchar.h:45,
from ../../../include/QtCore/qchar.h:1,
from ../../../include/QtCore/../../src/corelib/tools/qstring.h:45:
from ../../corelib/io/qabstractfileengine.cpp:49:
2301 | value2 = t;
from ../../corelib/io/qdir.h:45,
from ../../corelib/io/qdir.cpp:43:
compiling ../../corelib/io/qfile.cpp
compiling ../../corelib/io/qfileinfo.cpp
compiling ../../corelib/io/qfilesystementry.cpp
from ../../corelib/io/qdiriterator.h:45,
from ../../corelib/io/qdiriterator.cpp:92:
compiling ../../corelib/io/qfilesystemengine.cpp
compiling ../../corelib/io/qfsfileengine.cpp
from ../../corelib/io/qfilesystementry_p.h:56,
from ../../corelib/io/qfilesystementry.cpp:42:
from ../../corelib/io/qfile.h:45,
from ../../corelib/io/qfilesystemengine_p.h:56,
from ../../corelib/io/qfilesystemengine.cpp:42:
from ../../../include/QtCore/../../src/corelib/io/qfile.h:45,
from ../../../include/QtCore/qfile.h:1,
from ../../corelib/io/qfileinfo.h:45,
from ../../corelib/io/qfileinfo.cpp:43:
../../corelib/io/qdir.cpp: In constructor ‘QDirPrivate::QDirPrivate(const QString&, const QStringList&, QDir::SortFlags, QDir::Filters)’:
../../corelib/io/qdir.cpp:113:59: warning: implicitly-declared ‘QStringList& QStringList::operator=(const QStringList&)’ is deprecated [-Wdeprecated-copy]
113 | nameFilters = QStringList(QString::fromLatin1("*"));
from ../../corelib/io/qdir.h:47:
compiling ../../corelib/io/qfsfileengine_iterator.cpp
../../corelib/io/qdir.cpp: In member function ‘void QDir::setNameFilters(const QStringList&)’:
../../corelib/io/qdir.cpp:960:22: warning: implicitly-declared ‘QStringList& QStringList::operator=(const QStringList&)’ is deprecated [-Wdeprecated-copy]
960 | d->nameFilters = nameFilters;
from ../../../include/QtCore/../../src/corelib/io/qabstractfileengine.h:45,
from ../../../include/QtCore/qabstractfileengine.h:1,
from ../../../include/QtCore/../../src/corelib/io/qfsfileengine.h:45,
from ../../../include/QtCore/qfsfileengine.h:1,
from ../../corelib/io/qfsfileengine_p.h:57,
from ../../corelib/io/qfsfileengine.cpp:42:
from ../../../include/QtCore/../../src/corelib/io/qdatastream.h:46,
from ../../../include/QtCore/qdatastream.h:1,
from ../../../include/QtCore/../../src/corelib/tools/qpair.h:45,
from ../../../include/QtCore/qpair.h:1,
from ../../../include/QtCore/../../src/corelib/tools/qhash.h:49,
from ../../../include/QtCore/qhash.h:1,
from ../../corelib/io/qdebug.h:46,
from ../../corelib/io/qfile.cpp:43:
compiling ../../corelib/io/qiodevice.cpp
from ../../corelib/io/qfsfileengine_iterator_p.h:56,
from ../../corelib/io/qfsfileengine_iterator.cpp:42:
from ../../corelib/io/qdiriterator.cpp:99:
2301 | value2 = t;
from ../../../include/QtCore/../../src/corelib/tools/qstack.h:45,
from ../../../include/QtCore/qstack.h:1,
from ../../corelib/io/qdiriterator.cpp:98:
../../../include/QtCore/../../src/corelib/tools/qvector.h: In instantiation of ‘void QVector<T>::realloc(int, int) [with T = QRegExp]’:
../../../include/QtCore/../../src/corelib/tools/qvector.h:340:25: required from ‘void QVector<T>::reserve(int) [with T = QRegExp]’
../../corelib/io/qdiriterator.cpp:167:24: required from here
../../../include/QtCore/../../src/corelib/tools/qvector.h:503:25: warning: ‘void* memcpy(void*, const void*, size_t)’ writing to an object of type ‘QVector<QRegExp>::Data’ {aka ‘struct QVectorTypedData<QRegExp>’} with no trivial copy-assignment; use copy-assignment or copy-initialization instead [-Wclass-memaccess]
../../../include/QtCore/../../src/corelib/tools/qvector.h:94:8: note: ‘QVector<QRegExp>::Data’ {aka ‘struct QVectorTypedData<QRegExp>’} declared here
from ../../corelib/io/qfile.cpp:42:
from ../../../include/QtCore/../../src/corelib/io/qtextstream.h:48,
from ../../../include/QtCore/qtextstream.h:1,
from ../../corelib/io/qdebug.h:50:
2301 | value2 = t;
In file included from ../../../include/QtCore/private/qcore_unix_p.h:1,
from ../../corelib/io/qfsfileengine.cpp:56:
../../../include/QtCore/private/../../../src/corelib/kernel/qcore_unix_p.h: In function ‘int qt_safe_execve(const char*, char* const*, char* const*)’:
../../../include/QtCore/private/../../../src/corelib/kernel/qcore_unix_p.h:312:18: warning: ISO C++17 does not allow ‘register’ storage class specifier [-Wregister]
312 | register int ret;
../../../include/QtCore/private/../../../src/corelib/kernel/qcore_unix_p.h: In function ‘int qt_safe_execv(const char*, char* const*)’:
../../../include/QtCore/private/../../../src/corelib/kernel/qcore_unix_p.h:319:18: warning: ISO C++17 does not allow ‘register’ storage class specifier [-Wregister]
319 | register int ret;
../../../include/QtCore/private/../../../src/corelib/kernel/qcore_unix_p.h: In function ‘int qt_safe_execvp(const char*, char* const*)’:
../../../include/QtCore/private/../../../src/corelib/kernel/qcore_unix_p.h:326:18: warning: ISO C++17 does not allow ‘register’ storage class specifier [-Wregister]
326 | register int ret;
../../../include/QtCore/private/../../../src/corelib/kernel/qcore_unix_p.h: In function ‘pid_t qt_safe_waitpid(pid_t, int*, int)’:
../../../include/QtCore/private/../../../src/corelib/kernel/qcore_unix_p.h:335:18: warning: ISO C++17 does not allow ‘register’ storage class specifier [-Wregister]
335 | register int ret;
compiling ../../corelib/io/qtemporaryfile.cpp
from ../../corelib/io/qfsfileengine_p.h:56:
from ../../../include/QtCore/../../src/corelib/io/qdebug.h:50,
from ../../../include/QtCore/qdebug.h:1,
from ../../corelib/io/qfsfileengine.cpp:48:
2301 | value2 = t;
from ../../corelib/io/qiodevice.cpp:45:
compiling ../../corelib/io/qtextstream.cpp
from ../../corelib/io/qtemporaryfile.h:45,
from ../../corelib/io/qtemporaryfile.cpp:42:
[I removed a few lines here because of the character limit, but the above “QtCore” style warnings loop basically infinitely. I don’t know how/when I put this on my system or how to bypass it to get the update finished]
^Cmake[1]: *** Deleting file '.obj/release-static/qfsfileengine.o'
make[1]: *** [Makefile:1680: .obj/release-static/qdir.o] Interrupt
make[1]: *** [Makefile:1843: .obj/release-static/qdiriterator.o] Interrupt
make[1]: *** [Makefile:2016: .obj/release-static/qfile.o] Interrupt
make[1]: *** [Makefile:2166: .obj/release-static/qfileinfo.o] Interrupt
make[1]: *** [Makefile:2643: .obj/release-static/qfsfileengine.o] Interrupt
make[1]: *** [Makefile:2797: .obj/release-static/qfsfileengine_iterator.o] Interrupt
make[1]: *** [Makefile:2953: .obj/release-static/qiodevice.o] Interrupt
make[1]: *** [Makefile:3142: .obj/release-static/qtemporaryfile.o] Interrupt
make[1]: *** [Makefile:3263: .obj/release-static/qtextstream.o] Interrupt
make: *** [Makefile:62: sub-tools-bootstrap-make_default-ordered] Interrupt
(base) [daniel@daniel-pc ~]$ ==> ERROR: Aborted by user! Exiting...
^C
