Problems with Manjaro Linux on a HP Elitebook 755 G5 with Ryzen 7 and Vega 10
#41
@petsam There was nothing related to screens in those files (as expected).
I followed some instructions from https://www.linuxquestions.org/questions/slackware-14/slackware-multi-monitor-config-4175643001/page2.html#post5932671 to try to manually configure the screen:
inxi -Gxx:
Graphics:  Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series] vendor: Hewlett-Packard driver: amdgpu
           v: kernel bus ID: 04:00.0 chip ID: 1002:15dd
           Display: x11 server: X.Org 1.20.3 driver: amdgpu resolution: 1920x1080~60Hz
           OpenGL: renderer: AMD RAVEN (DRM 3.27.0 4.20.0-3-MANJARO LLVM 7.0.0) v: 4.5 Mesa 18.3.1 direct render: Yes
xrandr --listproviders:
Providers: number : 1
Provider 0: id: 0x57 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 4 outputs: 4 associated providers: 0 name:Unknown AMD Radeon GPU @ pci:0000:04:00.0
xrandr -q:
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
   1920x1080     60.03*+  40.02
   1680x1050     60.03
   1280x1024     60.03
   1440x900      60.03
   1280x800      60.03
   1280x720      60.03
   1024x768      60.03
   800x600       60.03
   640x480       60.03
DisplayPort-0 disconnected (normal left inverted right x axis y axis)
DisplayPort-1 disconnected (normal left inverted right x axis y axis)
DisplayPort-2 disconnected (normal left inverted right x axis y axis)
And created an /etc/X11/xorg.conf with:
Section "Device"
	Identifier "AMD"
	Driver "amdgpu"
EndSection
Section "Monitor"
	Identifier "ddvi"
	Option "Primary" "true"
	Option "DPMS" "off"
	Option "PreferredMode" "1920x1080"
EndSection
Section "Screen"
	Identifier "ScreenLeft"
	Device "AMD"
	Monitor "ddvi"
EndSection
Nothing changed in terms of success rate, but X11 does indeed recognize the config:
cat /var/log/Xorg.0.log.old:
[     4.461]
X.Org X Server 1.20.3
[     4.461] Build Operating System: Linux Arch Linux
[     4.461] Current Operating System: Linux my-pc 4.20.0-3-MANJARO #1 SMP PREEMPT Sun Jan 6 01:03:23 GMT 2019 x86_64
[     4.461] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.20-x86_64 root=UUID=a3f36aaf-235a-428c-b1b0-0a33e3c0b083 rw resume=UUID=80c72dde-c3fd-481d-b7ac-b30429b0b08d
[     4.461] Build Date: 25 October 2018  04:42:32PM
[     4.461]
[     4.461] Current version of pixman: 0.36.0
[     4.461] 	Before reporting problems, check http://wiki.x.org
[     4.461] Markers: (--) probed, (**) from config file, (==) default setting,
[     4.461] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Jan  6 10:44:20 2019
[     4.461] (==) Using config file: "/etc/X11/xorg.conf"
[     4.461] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     4.461] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     4.462] (==) No Layout section.  Using the first Screen section.
[     4.462] (**) |-->Screen "ScreenLeft" (0)
[     4.462] (**) |   |-->Monitor "ddvi"
[     4.462] (**) |   |-->Device "AMD"
[     4.462] (==) Automatically adding devices
[     4.462] (==) Automatically enabling devices
[     4.462] (==) Automatically adding GPU devices
[     4.462] (==) Automatically binding GPU devices
[     4.462] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     4.462] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     4.462] 	Entry deleted from font path.
[     4.462] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     4.462] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[     4.462] 	(Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[     4.462] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[     4.462] 	(Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[     4.462] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[     4.462] (==) ModulePath set to "/usr/lib/xorg/modules"
[     4.462] (II) The server relies on udev to provide the list of input devices.
[     4.462] (II) Module ABI versions:
[     4.462] 	X.Org ANSI C Emulation: 0.4
[     4.462] 	X.Org Video Driver: 24.0
[     4.462] 	X.Org XInput driver : 24.1
[     4.462] 	X.Org Server Extension : 10.0
[     4.463] (++) using VT number 7
[     4.463] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     4.469] (--) PCI:*(4@0:0:0) 1002:15dd:103c:83d5 rev 208, Mem @ 0xd0000000/268435456, 0xe0000000/2097152, 0xe0700000/524288, I/O @ 0x00002000/256, BIOS @ 0x????????/131072
[     4.469] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     4.469] (II) LoadModule: "glx"
[     4.469] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     4.472] (II) Module glx: vendor="X.Org Foundation"
[     4.472] 	compiled for 1.20.3, module version = 1.0.0
[     4.472] 	ABI class: X.Org Server Extension, version 10.0
[     4.472] (II) LoadModule: "amdgpu"
[     4.472] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[     4.472] (II) Module amdgpu: vendor="X.Org Foundation"
[     4.473] 	compiled for 1.20.1, module version = 18.1.0
[     4.473] 	Module class: X.Org Video Driver
[     4.473] 	ABI class: X.Org Video Driver, version 24.0
[     4.473] (II) AMDGPU: Driver for AMD Radeon:
	All GPUs supported by the amdgpu kernel driver
[     4.473] (II) AMDGPU(0): [KMS] drm report modesetting isn't supported.
[     4.473] (EE) Screen 0 deleted because of no matching config section.
[     4.473] (II) UnloadModule: "amdgpu"
[     4.473] (EE) Device(s) detected, but none match those in the config file.
[     4.473] (EE)
Fatal server error:
[     4.473] (EE) no screens found(EE)
[     4.473] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[     4.473] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[     4.473] (EE)
[     4.473] (EE) Server terminated with error (1). Closing log file.
Also I cloned https://gitlab.manjaro.org/packages/core/linux420 and modified the PKGBUILD with this diff to compile myself the latest kernel (as of 2019-01-05):
diff --git a/PKGBUILD b/PKGBUILD
index 72bb17d..dd885b0 100644
--- a/PKGBUILD
+++ b/PKGBUILD
@@ -14,17 +14,18 @@ _aufs=20181217
 _bfq=v9
 _bfqdate=20181212
 _sub=0
+_commit=a67012412e5a820c44239af9712a1a6037b33fd4
 pkgver=${_basekernel}.${_sub}
-pkgrel=2
+pkgrel=3
 arch=('i686' 'x86_64')
 url="http://www.kernel.org/"
 license=('GPL2')
 makedepends=('xmlto' 'docbook-xsl' 'kmod' 'inetutils' 'bc' 'elfutils' 'git')
 options=('!strip')
-source=("https://www.kernel.org/pub/linux/kernel/v4.x/linux-${_basekernel}.tar.xz"
+source=(#"https://www.kernel.org/pub/linux/kernel/v4.x/linux-${_basekernel}.tar.xz"
         #"https://www.kernel.org/pub/linux/kernel/v4.x/patch-${pkgver}.xz"
         #https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux-stable-rc.git/snapshot/linux-stable-rc-$_commit.tar.gz
-        #"linux-${pkgver}.tar.gz::https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/snapshot/linux-$_commit.tar.gz"
+        "linux-${pkgver}.tar.gz::https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/snapshot/linux-$_commit.tar.gz"
         # the main kernel config files
         'config.x86_64' 'config' 'config.aufs'
         "${pkgbase}.preset" # standard config files for mkinitcpio ramdisk
@@ -57,7 +58,7 @@ source=("https://www.kernel.org/pub/linux/kernel/v4.x/linux-${_basekernel}.tar.x
         '0011-bootsplash.patch'
         '0012-bootsplash.patch'
         '0013-bootsplash.patch')
-sha256sums=('ad0823183522e743972382df0aa08fb5ae3077f662b125f1e599b0b2aaa12438'
+sha256sums=('df2075ef05c30c2fb4c4b6d49611c6090f31b444beaf0faa008b7e8e0b9a2add'
             'ec835f6acf5d2bbd285a0e2f386d557995214973db3d7130126af4a57e7749c9'
             'f5903377d29fc538af98077b81982efdc091a8c628cb85566e88e1b5018f12bf'
             'b44d81446d8b53d5637287c30ae3eb64cae0078c3fbc45fcf1081dd6699818b5'
@@ -88,8 +89,9 @@ sha256sums=('ad0823183522e743972382df0aa08fb5ae3077f662b125f1e599b0b2aaa12438'
             '60e295601e4fb33d9bf65f198c54c7eb07c0d1e91e2ad1e0dd6cd6e142cb266d'
             '035ea4b2a7621054f4560471f45336b981538a40172d8f17285910d4e0e0b3ef')
 prepare() {
+  set -ex
   #mv "${srcdir}/linux-stable-rc-${_commit}" "${srcdir}/linux-${_basekernel}"
-  #mv "${srcdir}/linux-${_commit}" "${srcdir}/linux-${_basekernel}"
+  mv "${srcdir}/linux-${_commit}" "${srcdir}/linux-${_basekernel}"
   cd "${srcdir}/linux-${_basekernel}"
   # add upstream patch
@@ -104,33 +106,33 @@ prepare() {
   patch -Np1 -i ../0001-add-sysctl-to-disallow-unprivileged-CLONE_NEWUSER-by.patch
   # Add bootsplash - http://lkml.iu.edu/hypermail/linux/kernel/1710.3/01542.html
-  patch -Np1 -i "${srcdir}/0001-bootsplash.patch"
-  patch -Np1 -i "${srcdir}/0002-bootsplash.patch"
-  patch -Np1 -i "${srcdir}/0003-bootsplash.patch"
-  patch -Np1 -i "${srcdir}/0004-bootsplash.patch"
-  patch -Np1 -i "${srcdir}/0005-bootsplash.patch"
-  patch -Np1 -i "${srcdir}/0006-bootsplash.patch"
-  patch -Np1 -i "${srcdir}/0007-bootsplash.patch"
-  patch -Np1 -i "${srcdir}/0008-bootsplash.patch"
-  patch -Np1 -i "${srcdir}/0009-bootsplash.patch"
-  patch -Np1 -i "${srcdir}/0010-bootsplash.patch"
-  patch -Np1 -i "${srcdir}/0011-bootsplash.patch"
-  patch -Np1 -i "${srcdir}/0012-bootsplash.patch"
+  # patch -Np1 -i "${srcdir}/0001-bootsplash.patch"
+  # patch -Np1 -i "${srcdir}/0002-bootsplash.patch"
+  # patch -Np1 -i "${srcdir}/0003-bootsplash.patch"
+  # patch -Np1 -i "${srcdir}/0004-bootsplash.patch"
+  # patch -Np1 -i "${srcdir}/0005-bootsplash.patch"
+  # patch -Np1 -i "${srcdir}/0006-bootsplash.patch"
+  # patch -Np1 -i "${srcdir}/0007-bootsplash.patch"
+  # patch -Np1 -i "${srcdir}/0008-bootsplash.patch"
+  # patch -Np1 -i "${srcdir}/0009-bootsplash.patch"
+  # patch -Np1 -i "${srcdir}/0010-bootsplash.patch"
+  # patch -Np1 -i "${srcdir}/0011-bootsplash.patch"
+  # patch -Np1 -i "${srcdir}/0012-bootsplash.patch"
   # use git-apply to add binary files
-  git apply -p1 < "${srcdir}/0013-bootsplash.patch"
+  # git apply -p1 < "${srcdir}/0013-bootsplash.patch"
   # add aufs4 support
-  patch -Np1 -i "${srcdir}/aufs4.x-rcN-${_aufs}.patch"
-  patch -Np1 -i "${srcdir}/aufs4-base.patch"
-  patch -Np1 -i "${srcdir}/aufs4-kbuild.patch"
-  patch -Np1 -i "${srcdir}/aufs4-loopback.patch"
-  patch -Np1 -i "${srcdir}/aufs4-mmap.patch"
-  patch -Np1 -i "${srcdir}/aufs4-standalone.patch"
-  patch -Np1 -i "${srcdir}/tmpfs-idr.patch"
-  patch -Np1 -i "${srcdir}/vfs-ino.patch"
+  # patch -Np1 -i "${srcdir}/aufs4.x-rcN-${_aufs}.patch"
+  # patch -Np1 -i "${srcdir}/aufs4-base.patch"
+  # patch -Np1 -i "${srcdir}/aufs4-kbuild.patch"
+  # patch -Np1 -i "${srcdir}/aufs4-loopback.patch"
+  # patch -Np1 -i "${srcdir}/aufs4-mmap.patch"
+  # patch -Np1 -i "${srcdir}/aufs4-standalone.patch"
+  # patch -Np1 -i "${srcdir}/tmpfs-idr.patch"
+  # patch -Np1 -i "${srcdir}/vfs-ino.patch"
   # add BFQ scheduler
-  patch -Np1 -i "${srcdir}/0001-BFQ-${_bfq}-${_bfqdate}.patch"
+  # patch -Np1 -i "${srcdir}/0001-BFQ-${_bfq}-${_bfqdate}.patch"
   if [ "${CARCH}" = "x86_64" ]; then
     cat "${srcdir}/config.x86_64" > ./.config
@@ -138,7 +140,7 @@ prepare() {
     cat "${srcdir}/config" > ./.config
   fi
-  cat "${srcdir}/config.aufs" >> ./.config
+  # cat "${srcdir}/config.aufs" >> ./.config
   if [ "${_kernelname}" != "" ]; then
     sed -i "s|CONFIG_LOCALVERSION=.*|CONFIG_LOCALVERSION=\"${_kernelname}\"|g" ./.config
It’s not an elegant one but it does the job… nothing improved there.
#42
Also, something I just noticed in the diff between a successful run log and a failed one:
-(II) xfree86: Adding drm device (/dev/dri/card0)
@@ -57,501 +60,25 @@ Markers: (--) probed, (**) from config file, (==) default setting,
-(II) Applying OutputClass "AMDgpu" to /dev/dri/card0
-   loading driver: amdgpu
-(==) Matched amdgpu as autoconfigured driver 0
-(==) Matched ati as autoconfigured driver 1
-(==) Matched modesetting as autoconfigured driver 2
-(==) Matched fbdev as autoconfigured driver 3
-(==) Matched vesa as autoconfigured driver 4
-(==) Assigned the driver to the xf86ConfigLayout
The failed one’s logs has the first difference being:
#43
Is it possible to enable csm/legacy boot on your systems firmware configuration tool?
It could be just as simple as stupid, that hp actively disables hardware features if Windows is not detected. With a switch to old legacy boot this could be worked around maybe.
#44
From your 1st journal log
Have you tried pci=nocrs ?
I would add the PCI ID to the Device section of the driver
You might also add more monitor properties like Modeline
Just ideas to make kernel searches easier, if there is such thing :roll_eyes:
#45
He can not even load the Xorg driver, because the underlying kernel driver can not start up KMS for some reasons. Xorg will not work without KMS on amdgpu. We can stop to work on Xorg, to fix this. :joy:
journalctl -b | grep -i modesetting
should say something like:
Jan 06 19:08:17 manjaro kernel: [drm] amdgpu kernel modesetting enabled.
Jan 06 19:08:17 manjaro kernel: [drm] initializing kernel modesetting (...)
#46
Looks like I can no boot into legacy with the current install as it does not detect my OS. I guess I have to do a fresh install via Architect as it’s the only one that allows custom setttings for UEFI/Legacy (as far as I remember). Will try that in a few days and see what I get. Last time I tried booting legacy (before the fix that removed the need for mce=off) the kernel was segfaulting pretty quickly. I did not save a picture of the screen at that time as UEFI was kind of working…
#47
pci=nocrs did nothing, neither the BusID.
When I generate a X config via X :1 -configure I get the following file:
Section "ServerLayout"
	Identifier     "X.org Configured"
	Screen      0  "Screen0" 0 0
	Screen      1  "Screen1" RightOf "Screen0"
	InputDevice    "Mouse0" "CorePointer"
	InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
	ModulePath   "/usr/lib/xorg/modules"
	FontPath     "/usr/share/fonts/misc"
	FontPath     "/usr/share/fonts/TTF"
	FontPath     "/usr/share/fonts/OTF"
	FontPath     "/usr/share/fonts/Type1"
	FontPath     "/usr/share/fonts/100dpi"
	FontPath     "/usr/share/fonts/75dpi"
EndSection
Section "Module"
	Load  "glx"
EndSection
Section "InputDevice"
	Identifier  "Keyboard0"
	Driver      "kbd"
EndSection
	Identifier  "Mouse0"
	Driver      "mouse"
	Option	    "Protocol" "auto"
	Option	    "Device" "/dev/input/mice"
	Option	    "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
	Identifier   "Monitor0"
	VendorName   "Monitor Vendor"
	ModelName    "Monitor Model"
EndSection
Section "Monitor"
	Identifier   "Monitor1"
EndSection
Section "Device"
        ### Available Driver options are:-
        ### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
        ### <string>: "String", <freq>: "<f> Hz/kHz/MHz",
        ### <percent>: "<f>%"
        ### [arg]: arg optional
        #Option     "Accel"              	# [<bool>]
        #Option     "SWcursor"           	# [<bool>]
        #Option     "EnablePageFlip"     	# [<bool>]
        #Option     "SubPixelOrder"      	# [<str>]
        #Option     "ZaphodHeads"        	# <str>
        #Option     "AccelMethod"        	# <str>
        #Option     "DRI3"               	# [<bool>]
        #Option     "DRI"                	# <i>
        #Option     "ShadowPrimary"      	# [<bool>]
        #Option     "TearFree"           	# [<bool>]
        #Option     "DeleteUnusedDP12Displays" 	# [<bool>]
	Identifier  "Card0"
	Driver      "amdgpu"
	BusID       "PCI:4:0:0"
EndSection
Section "Device"
        #Option     "DRI"                	# <i>
	Identifier  "Card1"
	Driver      "amdgpu"
	BusID       "PCI:4:0:1"
EndSection
Section "Screen"
	Identifier "Screen0"
	Device     "Card0"
	Monitor    "Monitor0"
	SubSection "Display"
		Viewport   0 0
		Depth     1
	EndSubSection
		Viewport   0 0
		Depth     4
	EndSubSection
		Viewport   0 0
		Depth     8
	EndSubSection
		Viewport   0 0
		Depth     15
	EndSubSection
		Viewport   0 0
		Depth     16
	EndSubSection
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
Section "Screen"
	Identifier "Screen1"
	Device     "Card1"
	Monitor    "Monitor1"
		Viewport   0 0
		Depth     1
	EndSubSection
		Viewport   0 0
		Depth     4
	EndSubSection
		Viewport   0 0
		Depth     8
	EndSubSection
		Viewport   0 0
		Depth     15
	EndSubSection
		Viewport   0 0
		Depth     16
	EndSubSection
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
Looks like I have two sets of settings for Screen/Monitor/Card… I wonder what’s that about?
Anyway, installing the kernel from source did not help (yet). I’m going to try with 5.0 rc1 soon and see what get. The only thing I noticed was that the screen would not recover from sleep now… I guess that’s a regression in the kernel.
#48
journalcrl -b -1 | grep -i modesetting does indeed say that when successful, and those lines are missing from the unsuccessful one.
Do you have any tips on how to debug that particilar section? Or where to report problems related to it? (I really don’t know what I should do when encountering such problems).
#49
I suppose because you requested a second screen instead of the default (:0).
should be
X :0 -configure
It is recommended to include the driver to the kernel image.
Edit /etc/mkinitcpio.conf and add amdgpu at MODULES:
MODULES=(amdgpu radeon)
Note: radeon may not be needed.
Then re-create kernel images
sudo mkinitcpio -P
Funny Note: Surprisingly, the X configure command created a new PCI ID
I could never imagine this “The Creator” ability of Xorg!!!
Edit: You should review your Xorg conf files, so they are not overridden between
/etc/X11/xorg.conf
/etc/X11/xorg.conf.d/*.conf
The recommended path is the 2nd, so you might need to copy/merge the X-created one there…
#50
No success with adding amdgpu, radeon or both in /etc/mkinitcpio.conf. The only thing id does is moving the freeze earlier in the process so I get to notice it sooner, which kind of helps with the retry process :smile:.
Here are some pictures from the unsuccessful starts:
These are the errors from the start of the boot… I think they’re irrelevant as they appear even for successful builds, but I want to document them here.
This is starting only with radeon, it complains about missing /dev/dri/card0 which is the same ting I see in the logs between a successful and unsuccessful run:
cat /var/log/Xorg.0.log | grep card0
[     4.472] (II) xfree86: Adding drm device (/dev/dri/card0)
[     4.505] (II) Applying OutputClass "AMDgpu" to /dev/dri/card0
cat /var/log/Xorg.0.log.old | grep card0
[     5.484] (EE) open /dev/dri/card0: No such file or directory
#51
Not always occurred problems are a PITA. They seem to have to do more with hardware than with software.
Check the difference of cold boot (Shutdown->Power ON) and warm boot (Reboot). There should be some IMO…
#52
You could try to reach out to HP support and all how to install the latest firmware, maybe they even have an beta firmware for you
Also could you try boot Params
acpi_osi=windows iommu=soft
If this doesn’t do it, could you run memtest86
These mce errors don’t look nice, even for a not supported product.
#53
Restoring from hibernate works every time. Reboot vs cold boot, I don’t see any difference in startup success.
#54
I will reach out to them after I try legacy boot one more time this weekend, will have to summarize this entire post into an email in a way that makes sense and skips over all the parts tha’t did not lead anywhere.
acpi_osi=windows iommu=soft did not help.
Memtest86 shows no errors; mce was the reason it would not work with the 01.03 bios but that got fixed in the kernel., could those also be a kernel induced problem?
#55
mce wasn’t fixed in the kernel. It’s a hardware thing. It could mean a hardware defect
Hopefully it’s not.
But yet again, I don’t have an idea what to do :slightly_frowning_face:
#56
Some news:
  • I tried installing and booting in legacy mode, no change in success rate.
  • Installed the CLI version through Architect, it still has problems with amdgpu…
Here is the journalctl -b of a failed boot:
 kernel: Linux version 4.20.1-1-MANJARO (builduser@development) (gcc version 8.2.1 20181127 (GCC)) #1 SMP PREEMPT Wed Jan 9 17:43:49 UTC 2019
 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-4.20-x86_64 root=UUID=f24a6a1a-9470-4d51-abc2-a70edbc3cc1b rw intremap=off iommu=soft acpi=strict rd.udev.log-priority=3
 kernel: KERNEL supported cpus:
 kernel:   Intel GenuineIntel
 kernel:   AMD AuthenticAMD
 kernel:   Hygon HygonGenuine
 kernel:   Centaur CentaurHauls
 kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
 kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
 kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
 kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
 kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
 kernel: BIOS-provided physical RAM map:
 kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
 kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000003ffffff] usable
 kernel: BIOS-e820: [mem 0x0000000004000000-0x0000000004009fff] ACPI NVS
 kernel: BIOS-e820: [mem 0x000000000400a000-0x0000000079e7ffff] usable
 kernel: BIOS-e820: [mem 0x0000000079e80000-0x000000007a47ffff] type 20
 kernel: BIOS-e820: [mem 0x000000007a480000-0x000000007ac7ffff] reserved
 kernel: BIOS-e820: [mem 0x000000007ac80000-0x000000007b37ffff] ACPI NVS
 kernel: BIOS-e820: [mem 0x000000007b380000-0x000000007b3fffff] ACPI data
 kernel: BIOS-e820: [mem 0x000000007b400000-0x000000008dffffff] usable
 kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
 kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
 kernel: BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
 kernel: BIOS-e820: [mem 0x00000000fed80000-0x00000000fed80fff] reserved
 kernel: BIOS-e820: [mem 0x00000000fedf1000-0x00000000fedf1fff] reserved
 kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
 kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
 kernel: BIOS-e820: [mem 0x0000000100000000-0x000000022f33ffff] usable
 kernel: NX (Execute Disable) protection: active
 kernel: efi: EFI v2.50 by HP
 kernel: efi:  ACPI=0x7b3ff000  ACPI 2.0=0x7b3ff014  SMBIOS=0x7a57b000  SMBIOS 3.0=0x7a579000  ESRT=0x777f1d18  MEMATTR=0x76990018
 kernel: SMBIOS 3.1.0 present.
 kernel: DMI: HP HP EliteBook 755 G5/83D5, BIOS Q81 Ver. 01.03.01 07/26/2018
 kernel: tsc: Fast TSC calibration using PIT
 kernel: tsc: Detected 2195.748 MHz processor
 kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
 kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
 kernel: last_pfn = 0x22f340 max_arch_pfn = 0x400000000
 kernel: MTRR default type: uncachable
 kernel: MTRR fixed ranges enabled:
 kernel:   00000-9FFFF write-back
 kernel:   A0000-BFFFF uncachable
 kernel:   C0000-DFFFF write-protect
 kernel:   E0000-FFFFF uncachable
 kernel: MTRR variable ranges enabled:
 kernel:   0 base 0000FF000000 mask FFFFFF000000 write-protect
 kernel:   1 base 000000000000 mask FFFF80000000 write-back
 kernel:   2 base 000080000000 mask FFFFC0000000 write-back
 kernel:   3 base 0000C0000000 mask FFFFF0000000 write-back
 kernel:   4 disabled
 kernel:   5 disabled
 kernel:   6 disabled
 kernel:   7 disabled
 kernel: TOM2: 0000000230000000 aka 8960M
 kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
 kernel: last_pfn = 0x8e000 max_arch_pfn = 0x400000000
 kernel: esrt: Reserving ESRT space from 0x00000000777f1d18 to 0x00000000777f1d50.
 kernel: check: Scanning 1 areas for low memory corruption
 kernel: Base memory trampoline at [(____ptrval____)] 98000 size 24576
 kernel: Using GB pages for direct mapping
 kernel: BRK [0x1cca01000, 0x1cca01fff] PGTABLE
 kernel: BRK [0x1cca02000, 0x1cca02fff] PGTABLE
 kernel: BRK [0x1cca03000, 0x1cca03fff] PGTABLE
 kernel: BRK [0x1cca04000, 0x1cca04fff] PGTABLE
 kernel: BRK [0x1cca05000, 0x1cca05fff] PGTABLE
 kernel: BRK [0x1cca06000, 0x1cca06fff] PGTABLE
 kernel: BRK [0x1cca07000, 0x1cca07fff] PGTABLE
 kernel: BRK [0x1cca08000, 0x1cca08fff] PGTABLE
 kernel: BRK [0x1cca09000, 0x1cca09fff] PGTABLE
 kernel: BRK [0x1cca0a000, 0x1cca0afff] PGTABLE
 kernel: Secure boot could not be determined
 kernel: RAMDISK: [mem 0x36db1000-0x376cffff]
 kernel: ACPI: Early table checksum verification disabled
 kernel: ACPI: RSDP 0x000000007B3FF014 000024 (v02 HPQOEM)
 kernel: ACPI: XSDT 0x000000007B3D2188 0000FC (v01 HPQOEM SLIC-BPC 00000001      01000013)
 kernel: ACPI: FACP 0x000000007B3EC000 00010C (v05 HPQOEM SLIC-BPC 00000001 HP   00000001)
 kernel: ACPI: DSDT 0x000000007B3D4000 010625 (v02 HPQOEM 83D5     00000000 INTL 20160527)
 kernel: ACPI: FACS 0x000000007B2C6000 000040
 kernel: ACPI: SSDT 0x000000007B3FC000 00012A (v02 HP     ShmTable 00000001 INTL 20160527)
 kernel: ACPI: SSDT 0x000000007B3F6000 00533D (v02 AMD    AmdTable 00000002 MSFT 02000002)
 kernel: ACPI: SSDT 0x000000007B3F4000 00119C (v01 AMD    AMD CPU  00000001 AMD  00000001)
 kernel: ACPI: CRAT 0x000000007B3F3000 000810 (v01 AMD    AMD CRAT 00000001 AMD  00000001)
 kernel: ACPI: CDIT 0x000000007B3F2000 000029 (v01 AMD    AMD CDIT 00000001 AMD  00000001)
 kernel: ACPI: UEFI 0x000000007B2E3000 000042 (v01 HPQOEM EDK2     00000002      01000013)
 kernel: ACPI: SSDT 0x000000007B3F1000 000ECA (v02 HP     UcsiAcpi 00000001 INTL 20160527)
 kernel: ACPI: SSDT 0x000000007B3F0000 0000FB (v02 HP     UcsiCntr 00000001 INTL 20160527)
 kernel: ACPI: RTMA 0x000000007B3EF000 00009E (v01 HP     _HBMART_ 00001000 HP   00000001)
 kernel: ACPI: SSDT 0x000000007B3EE000 0003C8 (v02 HPQOEM Tpm2Tabl 00001000 INTL 20160527)
 kernel: ACPI: TPM2 0x000000007B3ED000 000034 (v03 HPQOEM EDK2     00000002      01000013)
 kernel: ACPI: ASF! 0x000000007B3EB000 00006E (v32 HPQOEM 83D5     00000001 HP   00000001)
 kernel: ACPI: MSDM 0x000000007B3EA000 000055 (v03 HPQOEM SLIC-BPC 00000000 HP   00000001)
 kernel: ACPI: SLIC 0x000000007B3E9000 000176 (v01 HPQOEM SLIC-BPC 00000001 HP   00000001)
 kernel: ACPI: WSMT 0x000000007B3E8000 000028 (v01 HPQOEM 83D5     00000001 HP   00000001)
 kernel: ACPI: HPET 0x000000007B3E7000 000038 (v01 HPQOEM 83D5     00000001 HP   00000001)
 kernel: ACPI: APIC 0x000000007B3E6000 000138 (v02 HPQOEM 83D5     00000001 HP   00000001)
 kernel: ACPI: MCFG 0x000000007B3E5000 00003C (v01 HPQOEM 83D5     00000001 HP   00000001)
 kernel: ACPI: IVRS 0x000000007B3FE000 0000D0 (v02 AMD    AMD IVRS 00000001 AMD  00000000)
 kernel: ACPI: SSDT 0x000000007B3D1000 000884 (v01 HP     HPADNBWL 00001000 INTL 20160527)
 kernel: ACPI: SSDT 0x000000007B3D0000 000032 (v01 HP     HPCONDEV 00001000 INTL 20160527)
 kernel: ACPI: SSDT 0x000000007B3D3000 0008CB (v01 AMD    AmdTable 00000001 INTL 20160527)
 kernel: ACPI: FPDT 0x000000007B3CF000 000044 (v01 HPQOEM EDK2     00000002      01000013)
 kernel: ACPI: SSDT 0x000000007B3CD000 001B93 (v01 AMD    AmdTable 00000001 INTL 20160527)
 kernel: ACPI: BGRT 0x000000007B3CC000 000038 (v01 HPQOEM EDK2     00000002      01000013)
 kernel: ACPI: SSDT 0x000000007B3FD000 0002F9 (v02 HP     PwrCtlEv 00000001 INTL 20160527)
 kernel: ACPI: Local APIC address 0xfee00000
 kernel: No NUMA configuration found
 kernel: Faking a node at [mem 0x0000000000000000-0x000000022f33ffff]
 kernel: NODE_DATA(0) allocated [mem 0x22f33c000-0x22f33ffff]
 kernel: Zone ranges:
 kernel:   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
 kernel:   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
 kernel:   Normal   [mem 0x0000000100000000-0x000000022f33ffff]
 kernel:   Device   empty
 kernel: Movable zone start for each node
 kernel: Early memory node ranges
 kernel:   node   0: [mem 0x0000000000001000-0x000000000009ffff]
 kernel:   node   0: [mem 0x0000000000100000-0x0000000003ffffff]
 kernel:   node   0: [mem 0x000000000400a000-0x0000000079e7ffff]
 kernel:   node   0: [mem 0x000000007b400000-0x000000008dffffff]
 kernel:   node   0: [mem 0x0000000100000000-0x000000022f33ffff]
 kernel: Zeroed struct page in unavailable ranges: 13803 pages
 kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000022f33ffff]
 kernel: On node 0 totalpages: 1817941
 kernel:   DMA zone: 64 pages used for memmap
 kernel:   DMA zone: 1076 pages reserved
 kernel:   DMA zone: 3999 pages, LIFO batch:0
 kernel:   DMA32 zone: 8938 pages used for memmap
 kernel:   DMA32 zone: 572022 pages, LIFO batch:63
 kernel:   Normal zone: 19405 pages used for memmap
 kernel:   Normal zone: 1241920 pages, LIFO batch:63
 kernel: ACPI: PM-Timer IO Port: 0x408
 kernel: ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
 kernel: IOAPIC[0]: apic_id 33, version 33, address 0xfec00000, GSI 0-23
 kernel: IOAPIC[1]: apic_id 34, version 33, address 0xfec01000, GSI 24-55
 kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
 kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
 kernel: ACPI: IRQ0 used by override.
 kernel: ACPI: IRQ9 used by override.
 kernel: Using ACPI (MADT) for SMP configuration information
 kernel: ACPI: HPET id: 0x10228210 base: 0xfed00000
 kernel: smpboot: Allowing 16 CPUs, 8 hotplug CPUs
 kernel: PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
 kernel: PM: Registered nosave memory: [mem 0x000a0000-0x000fffff]
 kernel: PM: Registered nosave memory: [mem 0x04000000-0x04009fff]
 kernel: PM: Registered nosave memory: [mem 0x79e80000-0x7a47ffff]
 kernel: PM: Registered nosave memory: [mem 0x7a480000-0x7ac7ffff]
 kernel: PM: Registered nosave memory: [mem 0x7ac80000-0x7b37ffff]
 kernel: PM: Registered nosave memory: [mem 0x7b380000-0x7b3fffff]
 kernel: PM: Registered nosave memory: [mem 0x8e000000-0xf7ffffff]
 kernel: PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
 kernel: PM: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
 kernel: PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
 kernel: PM: Registered nosave memory: [mem 0xfec01000-0xfec0ffff]
 kernel: PM: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
 kernel: PM: Registered nosave memory: [mem 0xfec11000-0xfed7ffff]
 kernel: PM: Registered nosave memory: [mem 0xfed80000-0xfed80fff]
 kernel: PM: Registered nosave memory: [mem 0xfed81000-0xfedf0fff]
 kernel: PM: Registered nosave memory: [mem 0xfedf1000-0xfedf1fff]
 kernel: PM: Registered nosave memory: [mem 0xfedf2000-0xfedfffff]
 kernel: PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
 kernel: PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
 kernel: PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
 kernel: [mem 0x8e000000-0xf7ffffff] available for PCI devices
 kernel: Booting paravirtualized kernel on bare hardware
 kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
 kernel: random: get_random_bytes called from start_kernel+0x95/0x54e with crng_init=0
 kernel: setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:16 nr_node_ids:1
 kernel: percpu: Embedded 45 pages/cpu @(____ptrval____) s147456 r8192 d28672 u262144
 kernel: pcpu-alloc: s147456 r8192 d28672 u262144 alloc=1*2097152
 kernel: pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
 kernel: Built 1 zonelists, mobility grouping on.  Total pages: 1788458
 kernel: Policy zone: Normal
 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.20-x86_64 root=UUID=f24a6a1a-9470-4d51-abc2-a70edbc3cc1b rw intremap=off iommu=soft acpi=strict rd.udev.log-priority=3
 kernel: Memory: 6952068K/7271764K available (12293K kernel code, 1277K rwdata, 3768K rodata, 1540K init, 3876K bss, 319696K reserved, 0K cma-reserved)
 kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
 kernel: ftrace: allocating 36346 entries in 142 pages
 kernel: rcu: Preemptible hierarchical RCU implementation.
 kernel: rcu:         CONFIG_RCU_FANOUT set to non-default value of 32.
 kernel: rcu:         RCU dyntick-idle grace-period acceleration is enabled.
 kernel: rcu:         RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=16.
 kernel: rcu:         RCU priority boosting: priority 1 delay 500 ms.
 kernel:         Tasks RCU enabled.
 kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
 kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
 kernel: NR_IRQS: 20736, nr_irqs: 1096, preallocated irqs: 16
 kernel: rcu:         Offload RCU callbacks from CPUs: (none).
 kernel: Console: colour dummy device 80x25
 kernel: printk: console [tty0] enabled
 kernel: ACPI: Core revision 20181003
 kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
 kernel: hpet clockevent registered
 kernel: APIC: Switch to symmetric I/O mode setup
 kernel: Switched APIC routing to physical flat.
 kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
 kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x1fa6820a3f5, max_idle_ns: 440795231324 ns
 kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 4393.47 BogoMIPS (lpj=7319160)
 kernel: pid_max: default: 32768 minimum: 301
 kernel: LSM: Security Framework initializing
 kernel: Yama: becoming mindful.
 kernel: AppArmor: AppArmor disabled by boot time parameter
 kernel: Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
 kernel: Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
 kernel: Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
 kernel: Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
 kernel: mce: CPU supports 23 MCE banks
 kernel: LVT offset 1 assigned for vector 0xf9
 kernel: LVT offset 2 assigned for vector 0xf4
 kernel: Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 512
 kernel: Last level dTLB entries: 4KB 1536, 2MB 1536, 4MB 768, 1GB 0
 kernel: Spectre V2 : Mitigation: Full AMD retpoline
 kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
 kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
 kernel: Spectre V2 : User space: Vulnerable
 kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
 kernel: Freeing SMP alternatives memory: 28K
 kernel: smpboot: CPU0: AMD Ryzen 7 PRO 2700U w/ Radeon Vega Mobile Gfx (family: 0x17, model: 0x11, stepping: 0x0)
 kernel: Performance Events: Fam17h core perfctr, AMD PMU driver.
 kernel: ... version:                0
 kernel: ... bit width:              48
 kernel: ... generic registers:      6
 kernel: ... value mask:             0000ffffffffffff
 kernel: ... max period:             00007fffffffffff
 kernel: ... fixed-purpose events:   0
 kernel: ... event mask:             000000000000003f
 kernel: rcu: Hierarchical SRCU implementation.
 kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
 kernel: smp: Bringing up secondary CPUs ...
 kernel: x86: Booting SMP configuration:
 kernel: .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6  #7
 kernel: smp: Brought up 1 node, 8 CPUs
 kernel: smpboot: Max logical packages: 2
 kernel: smpboot: Total of 8 processors activated (35146.80 BogoMIPS)
 kernel: devtmpfs: initialized
 kernel: x86/mm: Memory block size: 128MB
 kernel: PM: Registering ACPI NVS region [mem 0x04000000-0x04009fff] (40960 bytes)
 kernel: PM: Registering ACPI NVS region [mem 0x7ac80000-0x7b37ffff] (7340032 bytes)
 kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
 kernel: futex hash table entries: 4096 (order: 6, 262144 bytes)
 kernel: pinctrl core: initialized pinctrl subsystem
 kernel: RTC time: 20:28:55, date: 01/19/19
 kernel: NET: Registered protocol family 16
 kernel: audit: initializing netlink subsys (disabled)
 kernel: audit: type=2000 audit(1547929735.366:1): state=initialized audit_enabled=0 res=1
 kernel: cpuidle: using governor ladder
 kernel: cpuidle: using governor menu
 kernel: ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
 kernel: ACPI: bus type PCI registered
 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
 kernel: PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
 kernel: PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
 kernel: PCI: Using configuration type 1 for base access
 kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
 kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
 kernel: ACPI: Added _OSI(Module Device)
 kernel: ACPI: Added _OSI(Processor Device)
 kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
 kernel: ACPI: Added _OSI(Processor Aggregator Device)
 kernel: ACPI: Added _OSI(Linux-Dell-Video)
 kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
 kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
 kernel: ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.LPC0.EC0], AE_NOT_FOUND (20181003/dswload2-160)
 kernel: fbcon: Taking over console
 kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20181003/psobject-221)
 kernel: ACPI Error: Ignore error and continue table load (20181003/psobject-604)
 kernel: ACPI Error: Skip parsing opcode Scope (20181003/psloop-543)
 kernel: ACPI: 12 ACPI AML tables successfully acquired and loaded
 kernel: ACPI: EC: EC started
 kernel: ACPI: EC: interrupt blocked
 kernel: Unexpected threshold interrupt at vector f9
 kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: Used as first EC
 kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x3, EC_CMD/EC_SC=0x66, EC_DATA=0x62
 kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions
 kernel: ACPI: Interpreter enabled
 kernel: ACPI: (supports S0 S1 S3 S4 S5)
 kernel: ACPI: Using IOAPIC for interrupt routing
 kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
 kernel: ACPI: Enabled 8 GPEs in block 00 to 1F
 kernel: ACPI: Power Resource [PXP] (off)
 kernel: ACPI: Power Resource [APPR] (off)
 kernel: ACPI: Power Resource [P0ST] (on)
 kernel: ACPI: Power Resource [P3ST] (on)
 kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
 kernel: acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR]
 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
 kernel: acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
 kernel: acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
 kernel: acpi PNP0A08:00: ignoring host bridge window [mem 0x000cc000-0x000cffff window] (conflicts with Video ROM [mem 0x000c0000-0x000cd3ff])
 kernel: PCI host bridge to bus 0000:00
 kernel: pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
 kernel: pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0xd0000000-0xf7ffffff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0xfc000000-0xfeafffff window]
 kernel: pci_bus 0000:00: root bus resource [bus 00-ff]
 kernel: pci 0000:00:00.0: [1022:15d0] type 00 class 0x060000
 kernel: pci 0000:00:00.2: [1022:15d1] type 00 class 0x080600
 kernel: pci 0000:00:01.0: [1022:1452] type 00 class 0x060000
 kernel: pci 0000:00:01.3: [1022:15d3] type 01 class 0x060400
 kernel: pci 0000:00:01.3: PME# supported from D0 D3hot D3cold
 kernel: pci 0000:00:01.4: [1022:15d3] type 01 class 0x060400
 kernel: pci 0000:00:01.4: PME# supported from D0 D3hot D3cold
 kernel: pci 0000:00:01.7: [1022:15d3] type 01 class 0x060400
 kernel: pci 0000:00:01.7: PME# supported from D0 D3hot D3cold
 kernel: pci 0000:00:08.0: [1022:1452] type 00 class 0x060000
 kernel: pci 0000:00:08.1: [1022:15db] type 01 class 0x060400
 kernel: pci 0000:00:08.1: enabling Extended Tags
 kernel: pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
 kernel: pci 0000:00:08.2: [1022:15dc] type 01 class 0x060400
 kernel: pci 0000:00:08.2: enabling Extended Tags
 kernel: pci 0000:00:08.2: PME# supported from D0 D3hot D3cold
 kernel: pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
 kernel: pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
 kernel: pci 0000:00:18.0: [1022:15e8] type 00 class 0x060000
 kernel: pci 0000:00:18.1: [1022:15e9] type 00 class 0x060000
 kernel: pci 0000:00:18.2: [1022:15ea] type 00 class 0x060000
 kernel: pci 0000:00:18.3: [1022:15eb] type 00 class 0x060000
 kernel: pci 0000:00:18.4: [1022:15ec] type 00 class 0x060000
 kernel: pci 0000:00:18.5: [1022:15ed] type 00 class 0x060000
 kernel: pci 0000:00:18.6: [1022:15ee] type 00 class 0x060000
 kernel: pci 0000:00:18.7: [1022:15ef] type 00 class 0x060000
 kernel: pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
 kernel: pci 0000:01:00.0: reg 0x10: [io  0x3300-0x33ff]
 kernel: pci 0000:01:00.0: reg 0x18: [mem 0xe0a14000-0xe0a14fff 64bit]
 kernel: pci 0000:01:00.0: reg 0x20: [mem 0xe0a00000-0xe0a03fff 64bit]
 kernel: pci 0000:01:00.0: supports D1 D2
 kernel: pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
 kernel: pci 0000:01:00.1: [10ec:816a] type 00 class 0x070002
 kernel: pci 0000:01:00.1: reg 0x10: [io  0x3200-0x32ff]
 kernel: pci 0000:01:00.1: reg 0x18: [mem 0xe0a15000-0xe0a15fff 64bit]
 kernel: pci 0000:01:00.1: reg 0x20: [mem 0xe0a04000-0xe0a07fff 64bit]
 kernel: pci 0000:01:00.1: supports D1 D2
 kernel: pci 0000:01:00.1: PME# supported from D0 D1 D2 D3hot D3cold
 kernel: pci 0000:01:00.2: [10ec:816b] type 00 class 0x070002
 kernel: pci 0000:01:00.2: reg 0x10: [io  0x3100-0x31ff]
 kernel: pci 0000:01:00.2: reg 0x18: [mem 0xe0a16000-0xe0a16fff 64bit]
 kernel: pci 0000:01:00.2: reg 0x20: [mem 0xe0a08000-0xe0a0bfff 64bit]
 kernel: pci 0000:01:00.2: supports D1 D2
 kernel: pci 0000:01:00.2: PME# supported from D0 D1 D2 D3hot D3cold
 kernel: pci 0000:01:00.3: [10ec:816c] type 00 class 0x0c0701
 kernel: pci 0000:01:00.3: reg 0x10: [io  0x3000-0x30ff]
 kernel: pci 0000:01:00.3: reg 0x18: [mem 0xe0a17000-0xe0a17fff 64bit]
 kernel: pci 0000:01:00.3: reg 0x20: [mem 0xe0a0c000-0xe0a0ffff 64bit]
 kernel: pci 0000:01:00.3: supports D1 D2
 kernel: pci 0000:01:00.3: PME# supported from D0 D1 D2 D3hot D3cold
 kernel: pci 0000:01:00.4: [10ec:816d] type 00 class 0x0c0320
 kernel: pci 0000:01:00.4: reg 0x10: [mem 0xe0a18000-0xe0a18fff]
 kernel: pci 0000:01:00.4: reg 0x18: [mem 0xe0a10000-0xe0a13fff 64bit]
 kernel: pci 0000:01:00.4: PME# supported from D0 D3cold
 kernel: pci 0000:00:01.3: PCI bridge to [bus 01]
 kernel: pci 0000:00:01.3:   bridge window [io  0x3000-0x3fff]
 kernel: pci 0000:00:01.3:   bridge window [mem 0xe0a00000-0xe0afffff]
 kernel: pci 0000:02:00.0: [8086:24fd] type 00 class 0x028000
 kernel: pci 0000:02:00.0: reg 0x10: [mem 0xe0900000-0xe0901fff 64bit]
 kernel: pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
 kernel: pci 0000:00:01.4: PCI bridge to [bus 02]
 kernel: pci 0000:00:01.4:   bridge window [mem 0xe0900000-0xe09fffff]
 kernel: pci 0000:03:00.0: [1179:0113] type 00 class 0x010802
 kernel: pci 0000:03:00.0: reg 0x10: [mem 0xe0800000-0xe0803fff 64bit]
 kernel: pci 0000:03:00.0: PME# supported from D0 D3hot
 kernel: pci 0000:00:01.7: PCI bridge to [bus 03]
 kernel: pci 0000:00:01.7:   bridge window [mem 0xe0800000-0xe08fffff]
 kernel: pci 0000:04:00.0: [1002:15dd] type 00 class 0x030000
 kernel: pci 0000:04:00.0: reg 0x10: [mem 0xd0000000-0xdfffffff 64bit pref]
 kernel: pci 0000:04:00.0: reg 0x18: [mem 0xe0000000-0xe01fffff 64bit pref]
 kernel: pci 0000:04:00.0: reg 0x20: [io  0x2000-0x20ff]
 kernel: pci 0000:04:00.0: reg 0x24: [mem 0xe0700000-0xe077ffff]
 kernel: pci 0000:04:00.0: enabling Extended Tags
 kernel: pci 0000:04:00.0: BAR 0: assigned to efifb
 kernel: pci 0000:04:00.0: PME# supported from D1 D2 D3hot D3cold
 kernel: pci 0000:04:00.1: [1002:15de] type 00 class 0x040300
 kernel: pci 0000:04:00.1: reg 0x10: [mem 0xe0788000-0xe078bfff]
 kernel: pci 0000:04:00.1: enabling Extended Tags
 kernel: pci 0000:04:00.1: PME# supported from D1 D2 D3hot D3cold
 kernel: pci 0000:04:00.2: [1022:15df] type 00 class 0x108000
 kernel: pci 0000:04:00.2: reg 0x18: [mem 0xe0600000-0xe06fffff]
 kernel: pci 0000:04:00.2: reg 0x24: [mem 0xe078e000-0xe078ffff]
 kernel: pci 0000:04:00.2: enabling Extended Tags
 kernel: pci 0000:04:00.3: [1022:15e0] type 00 class 0x0c0330
 kernel: pci 0000:04:00.3: reg 0x10: [mem 0xe0300000-0xe03fffff 64bit]
 kernel: pci 0000:04:00.3: enabling Extended Tags
 kernel: pci 0000:04:00.3: PME# supported from D0 D3hot D3cold
 kernel: pci 0000:04:00.4: [1022:15e1] type 00 class 0x0c0330
 kernel: pci 0000:04:00.4: reg 0x10: [mem 0xe0400000-0xe04fffff 64bit]
 kernel: pci 0000:04:00.4: enabling Extended Tags
 kernel: pci 0000:04:00.4: PME# supported from D0 D3hot D3cold
 kernel: pci 0000:04:00.6: [1022:15e3] type 00 class 0x040300
 kernel: pci 0000:04:00.6: reg 0x10: [mem 0xe0780000-0xe0787fff]
 kernel: pci 0000:04:00.6: enabling Extended Tags
 kernel: pci 0000:04:00.6: PME# supported from D0 D3hot D3cold
 kernel: pci 0000:04:00.7: [1022:15e6] type 00 class 0x000000
 kernel: pci 0000:04:00.7: reg 0x18: [mem 0xe0500000-0xe05fffff]
 kernel: pci 0000:04:00.7: reg 0x24: [mem 0xe078c000-0xe078dfff]
 kernel: pci 0000:04:00.7: enabling Extended Tags
 kernel: pci 0000:00:08.1: PCI bridge to [bus 04]
 kernel: pci 0000:00:08.1:   bridge window [io  0x2000-0x2fff]
 kernel: pci 0000:00:08.1:   bridge window [mem 0xe0300000-0xe07fffff]
 kernel: pci 0000:00:08.1:   bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
 kernel: pci 0000:05:00.0: [1022:7901] type 00 class 0x010601
 kernel: pci 0000:05:00.0: reg 0x24: [mem 0xe0200000-0xe02007ff]
 kernel: pci 0000:05:00.0: enabling Extended Tags
 kernel: pci 0000:05:00.0: PME# supported from D3hot D3cold
 kernel: pci 0000:00:08.2: PCI bridge to [bus 05]
 kernel: pci 0000:00:08.2:   bridge window [mem 0xe0200000-0xe02fffff]
 kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 5 6 10 11) *0, disabled.
 kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 5 6 10 11) *0, disabled.
 kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 5 6 10 11) *0, disabled.
 kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 5 6 10 11) *0, disabled.
 kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 5 6 10 11) *0, disabled.
 kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 5 6 10 11) *0, disabled.
 kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 3 5 6 10 11) *0, disabled.
 kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 3 5 6 10 11) *0, disabled.
 kernel: ACPI: EC: interrupt unblocked
 kernel: ACPI: EC: event unblocked
 kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions and events
 kernel: pci 0000:04:00.0: vgaarb: setting as boot VGA device
 kernel: pci 0000:04:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
 kernel: pci 0000:04:00.0: vgaarb: bridge control possible
 kernel: vgaarb: loaded
 kernel: ACPI: bus type USB registered
 kernel: usbcore: registered new interface driver usbfs
 kernel: usbcore: registered new interface driver hub
 kernel: usbcore: registered new device driver usb
 kernel: pps_core: LinuxPPS API ver. 1 registered
 kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
 kernel: PTP clock support registered
 kernel: EDAC MC: Ver: 3.0.0
 kernel: Registered efivars operations
 kernel: PCI: Using ACPI for IRQ routing
 kernel: PCI: pci_cache_line_size set to 64 bytes
 kernel: e820: reserve RAM buffer [mem 0x79e80000-0x7bffffff]
 kernel: e820: reserve RAM buffer [mem 0x8e000000-0x8fffffff]
 kernel: e820: reserve RAM buffer [mem 0x22f340000-0x22fffffff]
 kernel: NetLabel: Initializing
 kernel: NetLabel:  domain hash size = 128
 kernel: NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
 kernel: NetLabel:  unlabeled traffic allowed by default
 kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
 kernel: hpet0: 3 comparators, 32-bit 14.318180 MHz counter
 kernel: clocksource: Switched to clocksource tsc-early
 kernel: VFS: Disk quotas dquot_6.6.0
 kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
 kernel: pnp: PnP ACPI init
 kernel: pnp 00:00: Plug and Play ACPI device, IDs PNP0b00 (active)
 kernel: system 00:01: [io  0x0400-0x04cf] has been reserved
 kernel: system 00:01: [io  0x04d0-0x04d1] has been reserved
 kernel: system 00:01: [io  0x04d6] has been reserved
 kernel: system 00:01: [io  0x0680-0x06ff] has been reserved
 kernel: system 00:01: [io  0x077a] has been reserved
 kernel: system 00:01: [io  0x0c00-0x0c01] has been reserved
 kernel: system 00:01: [io  0x0c14] has been reserved
 kernel: system 00:01: [io  0x0c50-0x0c52] has been reserved
 kernel: system 00:01: [io  0x0c6c] has been reserved
 kernel: system 00:01: [io  0x0c6f] has been reserved
 kernel: system 00:01: [io  0x0cd0-0x0cdb] has been reserved
 kernel: system 00:01: [io  0x0840-0x0847] has been reserved
 kernel: system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
 kernel: system 00:02: [mem 0x000e0000-0x000fffff] could not be reserved
 kernel: system 00:02: Plug and Play ACPI device, IDs PNP0c01 (active)
 kernel: pnp 00:03: Plug and Play ACPI device, IDs HPQ8002 PNP0303 (active)
 kernel: pnp 00:04: Plug and Play ACPI device, IDs SYN306f SYN0100 SYN0002 PNP0f13 (active)
 kernel: system 00:05: [io  0x0200-0x027f] has been reserved
 kernel: system 00:05: [mem 0xfedf1000-0xfedf1fff] has been reserved
 kernel: system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
 kernel: system 00:06: [mem 0xfec00000-0xfec00fff] could not be reserved
 kernel: system 00:06: [mem 0xfee00000-0xfee00fff] has been reserved
 kernel: system 00:06: [mem 0xfec20000-0xfec20fff] has been reserved
 kernel: system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
 kernel: pnp: PnP ACPI: found 7 devices
 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
 kernel: pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
 kernel: pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
 kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
 kernel: pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
 kernel: pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
 kernel: pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
 kernel: pci_bus 0000:00: resource 10 [mem 0x000d0000-0x000d3fff window]
 kernel: pci_bus 0000:00: resource 11 [mem 0x000d4000-0x000d7fff window]
 kernel: pci_bus 0000:00: resource 12 [mem 0x000d8000-0x000dbfff window]
 kernel: pci_bus 0000:00: resource 13 [mem 0x000dc000-0x000dffff window]
 kernel: pci_bus 0000:00: resource 14 [mem 0x000e0000-0x000e3fff window]
 kernel: pci_bus 0000:00: resource 15 [mem 0x000e4000-0x000e7fff window]
 kernel: pci_bus 0000:00: resource 16 [mem 0x000e8000-0x000ebfff window]
 kernel: pci_bus 0000:00: resource 17 [mem 0x000ec000-0x000effff window]
 kernel: pci_bus 0000:00: resource 18 [mem 0xd0000000-0xf7ffffff window]
 kernel: pci_bus 0000:00: resource 19 [mem 0xfc000000-0xfeafffff window]
 kernel: pci_bus 0000:01: resource 0 [io  0x3000-0x3fff]
 kernel: pci_bus 0000:01: resource 1 [mem 0xe0a00000-0xe0afffff]
 kernel: pci_bus 0000:02: resource 1 [mem 0xe0900000-0xe09fffff]
 kernel: pci_bus 0000:03: resource 1 [mem 0xe0800000-0xe08fffff]
 kernel: pci_bus 0000:04: resource 0 [io  0x2000-0x2fff]
 kernel: pci_bus 0000:04: resource 1 [mem 0xe0300000-0xe07fffff]
 kernel: pci_bus 0000:04: resource 2 [mem 0xd0000000-0xe01fffff 64bit pref]
 kernel: pci_bus 0000:05: resource 1 [mem 0xe0200000-0xe02fffff]
 kernel: NET: Registered protocol family 2
 kernel: tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes)
 kernel: TCP established hash table entries: 65536 (order: 7, 524288 bytes)
 kernel: TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
 kernel: TCP: Hash tables configured (established 65536 bind 65536)
 kernel: UDP hash table entries: 4096 (order: 5, 131072 bytes)
 kernel: UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
 kernel: NET: Registered protocol family 44
 kernel: pci 0000:04:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
 kernel: pci 0000:04:00.1: Linked as a consumer to 0000:04:00.0
 kernel: PCI: CLS 64 bytes, default 64
 kernel: Unpacking initramfs...
 kernel: Freeing initrd memory: 9340K
 kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
 kernel: software IO TLB: mapped [mem 0x8a000000-0x8e000000] (64MB)
 kernel: amd_uncore: AMD NB counters detected
 kernel: amd_uncore: AMD LLC counters detected
 kernel: check: Scanning for low memory corruption every 60 seconds
 kernel: Initialise system trusted keyrings
 kernel: Key type blacklist registered
 kernel: workingset: timestamp_bits=41 max_order=21 bucket_order=0
 kernel: zbud: loaded
 kernel: Key type asymmetric registered
 kernel: Asymmetric key parser 'x509' registered
 kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
 kernel: io scheduler noop registered
 kernel: io scheduler deadline registered
 kernel: io scheduler cfq registered (default)
 kernel: io scheduler mq-deadline registered
 kernel: io scheduler kyber registered
 kernel: io scheduler bfq registered
 kernel: io scheduler bfq-sq registered
 kernel: BFQ I/O-scheduler: v9 (with cgroups support)
 kernel: blkcg_policy_register: BLKCG_MAX_POLS too small
 kernel: pcieport 0000:00:01.3: Signaling PME with IRQ 25
 kernel: aer 0000:00:01.3:pcie002: AER enabled with IRQ 25
 kernel: pcieport 0000:00:01.4: Signaling PME with IRQ 26
 kernel: aer 0000:00:01.4:pcie002: AER enabled with IRQ 26
 kernel: pcieport 0000:00:01.7: Signaling PME with IRQ 27
 kernel: aer 0000:00:01.7:pcie002: AER enabled with IRQ 27
 kernel: pcieport 0000:00:08.1: Signaling PME with IRQ 28
 kernel: pcieport 0000:00:08.2: Signaling PME with IRQ 29
 kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
 kernel: efifb: probing for efifb
 kernel: efifb: framebuffer at 0xd0000000, using 3072k, total 3072k
 kernel: efifb: mode is 1024x768x32, linelength=4096, pages=1
 kernel: efifb: scrolling: redraw
 kernel: efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
 kernel: Console: switching to colour frame buffer device 128x48
 kernel: fb0: EFI VGA frame buffer device
 kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
 kernel: ACPI: Power Button [PWRB]
 kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
 kernel: ACPI: Sleep Button [SLPB]
 kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input2
 kernel: ACPI: Lid Switch [LID]
 kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
 kernel: ACPI: Power Button [PWRF]
 kernel: ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
 kernel: acpi device:0a: registered as cooling_device0
 kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:09/LNXVIDEO:00/input/input4
 kernel: Monitor-Mwait will be used to enter C-1 state
 kernel: thermal LNXTHERM:00: registered as thermal_zone0
 kernel: ACPI: Thermal Zone [HEPZ] (30 C)
 kernel: thermal LNXTHERM:01: registered as thermal_zone1
 kernel: ACPI: Thermal Zone [CPUZ] (44 C)
 kernel: thermal LNXTHERM:02: registered as thermal_zone2
 kernel: ACPI: Thermal Zone [GFXZ] (0 C)
 kernel: thermal LNXTHERM:03: registered as thermal_zone3
 kernel: ACPI: Thermal Zone [EXTZ] (42 C)
 kernel: thermal LNXTHERM:04: registered as thermal_zone4
 kernel: ACPI: Thermal Zone [LOCZ] (45 C)
 kernel: thermal LNXTHERM:05: registered as thermal_zone5
 kernel: ACPI: Thermal Zone [BATZ] (32 C)
 kernel: ACPI Error: AE_AML_PACKAGE_LIMIT, Index (0x000000005) is beyond end of object (length 0x5) (20181003/exoparg2-396)
 kernel: ACPI Error: Method parse/execution failed \_TZ.GETP, AE_AML_PACKAGE_LIMIT (20181003/psparse-516)
 kernel: ACPI Error: Method parse/execution failed \_TZ.CHGZ._CRT, AE_AML_PACKAGE_LIMIT (20181003/psparse-516)
 kernel: ACPI Error: Method parse/execution failed \_TZ.GTTP, AE_AML_PACKAGE_LIMIT (20181003/psparse-516)
 kernel: ACPI Error: Method parse/execution failed \_TZ.CHGZ._TMP, AE_AML_PACKAGE_LIMIT (20181003/psparse-516)
 kernel: [Firmware Bug]: No valid trip found
 kernel: Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
 kernel: nvme nvme0: pci function 0000:03:00.0
 kernel: usbcore: registered new interface driver usbserial_generic
 kernel: usbserial: USB Serial support registered for generic
 kernel: rtc_cmos 00:00: RTC can wake from S4
 kernel: rtc_cmos 00:00: registered as rtc0
 kernel: rtc_cmos 00:00: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
 kernel: ledtrig-cpu: registered to indicate activity on CPUs
 kernel: NET: Registered protocol family 10
 kernel: Segment Routing with IPv6
 kernel: NET: Registered protocol family 17
 kernel: RAS: Correctable Errors collector initialized.
 kernel: microcode: CPU0: patch_level=0x0810100b
 kernel: microcode: CPU1: patch_level=0x0810100b
 kernel: microcode: CPU2: patch_level=0x0810100b
 kernel: microcode: CPU3: patch_level=0x0810100b
 kernel: microcode: CPU4: patch_level=0x0810100b
 kernel: microcode: CPU5: patch_level=0x0810100b
 kernel: microcode: CPU6: patch_level=0x0810100b
 kernel: microcode: CPU7: patch_level=0x0810100b
 kernel: microcode: Microcode Update Driver: v2.2.
 kernel: sched_clock: Marking stable (843079437, 531874)->(959519429, -115908118)
 kernel: mce: [Hardware Error]: Machine check events logged
 kernel: mce: [Hardware Error]: CPU 2: Machine Check: 0 Bank 1: d8200000000a0151
 kernel: mce: [Hardware Error]: TSC 5c9a7ef58 MISC d01b0fff00000000 SYND 4a000000 IPID 100b000000000
 kernel: mce: [Hardware Error]: PROCESSOR 2:810f10 TIME 1547929735 SOCKET 0 APIC 2 microcode 810100b
 kernel: registered taskstats version 1
 kernel: Loading compiled-in X.509 certificates
 kernel: Loaded X.509 cert 'Build time autogenerated kernel key: ab661ea641a95c0f5645ba64ad792364a3f411ab'
 kernel: zswap: loaded using pool lzo/zbud
 kernel: Key type big_key registered
 kernel:   Magic number: 3:445:498
 kernel: rtc_cmos 00:00: setting system clock to 2019-01-19 20:28:55 UTC (1547929735)
 kernel: nvme nvme0: allocated 38 MiB host memory buffer.
 kernel:  nvme0n1: p1 p2
 kernel: Freeing unused decrypted memory: 2040K
 kernel: Freeing unused kernel image memory: 1540K
 kernel: Write protecting the kernel read-only data: 18432k
 kernel: Freeing unused kernel image memory: 2016K
 kernel: Freeing unused kernel image memory: 328K
 kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
 kernel: Run /init as init process
 kernel: mce: [Hardware Error]: CPU 3: Machine Check: 0 Bank 1: d8200000000a0151
 kernel: mce: [Hardware Error]: TSC 5f7fd7886 MISC d01b0fff00000000 SYND 4a000000 IPID 100b000000000
 kernel: mce: [Hardware Error]: PROCESSOR 2:810f10 TIME 1547929735 SOCKET 0 APIC 3 microcode 810100b
 kernel: i8042: PNP: PS/2 Controller [PNP0303:KBC0,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
 kernel: i8042: Detected active multiplexing controller, rev 1.1
 kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
 kernel: serio: i8042 AUX0 port at 0x60,0x64 irq 12
 kernel: serio: i8042 AUX1 port at 0x60,0x64 irq 12
 kernel: serio: i8042 AUX2 port at 0x60,0x64 irq 12
 kernel: serio: i8042 AUX3 port at 0x60,0x64 irq 12
 kernel: ehci-pci: EHCI PCI platform driver
 kernel: ehci-pci 0000:01:00.4: EHCI Host Controller
 kernel: ehci-pci 0000:01:00.4: new USB bus registered, assigned bus number 1
 kernel: ehci-pci 0000:01:00.4: irq 48, io mem 0xe0a18000
 kernel: SCSI subsystem initialized
 kernel: ehci-pci 0000:01:00.4: USB 0.0 started, EHCI 1.00
 kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.20
 kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 kernel: usb usb1: Product: EHCI Host Controller
 kernel: usb usb1: Manufacturer: Linux 4.20.1-1-MANJARO ehci_hcd
 kernel: usb usb1: SerialNumber: 0000:01:00.4
 kernel: hub 1-0:1.0: USB hub found
 kernel: hub 1-0:1.0: 1 port detected
 kernel: libata version 3.00 loaded.
 kernel: xhci_hcd 0000:04:00.3: xHCI Host Controller
 kernel: xhci_hcd 0000:04:00.3: new USB bus registered, assigned bus number 2
 kernel: xhci_hcd 0000:04:00.3: hcc params 0x0270ffe5 hci version 0x110 quirks 0x0000000840000410
 kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.20
 kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 kernel: usb usb2: Product: xHCI Host Controller
 kernel: usb usb2: Manufacturer: Linux 4.20.1-1-MANJARO xhci-hcd
 kernel: usb usb2: SerialNumber: 0000:04:00.3
 kernel: hub 2-0:1.0: USB hub found
 kernel: hub 2-0:1.0: 4 ports detected
 kernel: xhci_hcd 0000:04:00.3: new USB bus registered, assigned bus number 3
 kernel: xhci_hcd 0000:04:00.3: Host supports USB 3.10 Enhanced SuperSpeed
 kernel: usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
 kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.20
 kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 kernel: usb usb3: Product: xHCI Host Controller
 kernel: usb usb3: Manufacturer: Linux 4.20.1-1-MANJARO xhci-hcd
 kernel: usb usb3: SerialNumber: 0000:04:00.3
 kernel: hub 3-0:1.0: USB hub found
 kernel: hub 3-0:1.0: 4 ports detected
 kernel: xhci_hcd 0000:04:00.4: xHCI Host Controller
 kernel: xhci_hcd 0000:04:00.4: new USB bus registered, assigned bus number 4
 kernel: xhci_hcd 0000:04:00.4: hcc params 0x0260ffe5 hci version 0x110 quirks 0x0000000840000410
 kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.20
 kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 kernel: usb usb4: Product: xHCI Host Controller
 kernel: usb usb4: Manufacturer: Linux 4.20.1-1-MANJARO xhci-hcd
 kernel: usb usb4: SerialNumber: 0000:04:00.4
 kernel: hub 4-0:1.0: USB hub found
 kernel: hub 4-0:1.0: 2 ports detected
 kernel: ahci 0000:05:00.0: version 3.0
 kernel: xhci_hcd 0000:04:00.4: new USB bus registered, assigned bus number 5
 kernel: xhci_hcd 0000:04:00.4: Host supports USB 3.10 Enhanced SuperSpeed
 kernel: usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
 kernel: usb usb5: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.20
 kernel: usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 kernel: usb usb5: Product: xHCI Host Controller
 kernel: usb usb5: Manufacturer: Linux 4.20.1-1-MANJARO xhci-hcd
 kernel: usb usb5: SerialNumber: 0000:04:00.4
 kernel: hub 5-0:1.0: USB hub found
 kernel: hub 5-0:1.0: 1 port detected
 kernel: ahci 0000:05:00.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
 kernel: ahci 0000:05:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part deso sadm sds
 kernel: scsi host0: ahci
 kernel: scsi host1: ahci
 kernel: ata1: SATA max UDMA/133 abar m2048@0xe0200000 port 0xe0200100 irq 67
 kernel: ata2: SATA max UDMA/133 abar m2048@0xe0200000 port 0xe0200180 irq 67
 kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input5
 kernel: ata2: SATA link down (SStatus 0 SControl 300)
 kernel: ata1: SATA link down (SStatus 0 SControl 300)
 kernel: usb 4-1: new high-speed USB device number 2 using xhci_hcd
 kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
 kernel: random: fast init done
 systemd[1]: systemd 239 running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
 kernel: tsc: Refined TSC clocksource calibration: 2195.874 MHz
 kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x1fa6f9655b2, max_idle_ns: 440795314254 ns
 systemd[1]: Detected architecture x86-64.
 kernel: usb 4-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=88.32
 kernel: usb 4-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
 kernel: usb 4-1: Product: USB2.0 Hub
 systemd[1]: Set hostname to <manjaro>.
 kernel: hub 4-1:1.0: USB hub found
 kernel: hub 4-1:1.0: 4 ports detected
 kernel: random: systemd: uninitialized urandom read (16 bytes read)
 systemd[1]: Listening on Device-mapper event daemon FIFOs.
 systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
 systemd[1]: Listening on udev Kernel Socket.
 systemd[1]: Created slice system-getty.slice.
 systemd[1]: Reached target Swap.
 systemd[1]: Listening on udev Control Socket.
 systemd[1]: Listening on Journal Socket (/dev/log).
 kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: data=ordered
 kernel: audit: type=1130 audit(1547929736.528:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: audit: type=1130 audit(1547929736.528:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=kmod-static-nodes comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: audit: type=1130 audit(1547929736.535:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: audit: type=1130 audit(1547929736.545:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: audit: type=1130 audit(1547929736.555:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysusers comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: audit: type=1130 audit(1547929736.555:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd-journald[319]: Journal started
 systemd-journald[319]: Runtime journal (/run/log/journal/4bd9ff031c5e4c8792eaf6833a48b541) is 8.0M, max 344.9M, 336.9M free.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=kmod-static-nodes comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysusers comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Started Create Static Device Nodes in /dev.
 kernel: audit: type=1130 audit(1547929736.565:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: audit: type=1130 audit(1547929736.568:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Starting udev Kernel Device Manager...
 systemd[1]: Starting Flush Journal to Persistent Storage...
 systemd-journald[319]: Time spent on flushing to /var is 51.991ms for 790 entries.
 systemd-journald[319]: System journal (/var/log/journal/4bd9ff031c5e4c8792eaf6833a48b541) is 88.0M, max 4.0G, 3.9G free.
 kernel: audit: type=1130 audit(1547929736.585:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: usb 4-2: new high-speed USB device number 3 using xhci_hcd
 kernel: ACPI: AC Adapter [AC] (on-line)
 kernel: acpi_cpufreq: overriding BIOS provided _PSD data
 kernel: input: HP Wireless hotkeys as /devices/virtual/input/input10
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Started udev Coldplug all Devices.
 systemd[1]: Started udev Kernel Device Manager.
 kernel: hidraw: raw HID events driver (C) Jiri Kosina
 kernel: battery: ACPI: Battery Slot [BAT0] (battery present)
 kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
 systemd[1]: Started Flush Journal to Persistent Storage.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: tpm_tis IFX0763:00: 2.0 TPM (device-id 0x1B, rev-id 16)
 kernel: r8168: loading out-of-tree module taints kernel.
 systemd[1]: Found device KBG30ZMV256G TOSHIBA 1.
 kernel: r8168: module verification failed: signature and/or required key missing - tainting kernel
 kernel: ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B06 (\_SB.PCI0.SMBS.SMBO) (20181003/utaddress-213)
 kernel: ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
 kernel: r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
 kernel: r8168 0000:01:00.0: can't disable ASPM; OS doesn't have ASPM control
 kernel: IPMI message handler: version 39.2
 kernel: ipmi device interface
 kernel: sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
 kernel: sp5100-tco sp5100-tco: Using 0xfed80b00 for watchdog MMIO address
 kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
 kernel: r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
 kernel: r8168  Copyright (C) 2017  Realtek NIC software team <nicfae@realtek.com>
                                 This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                                 This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
 kernel: cryptd: max_cpu_qlen set to 1000
 systemd-udevd[344]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
 kernel: ipmi_si: IPMI System Interface driver
 kernel: ipmi_si: Unable to find any System Interface(s)
 kernel: input: PC Speaker as /devices/platform/pcspkr/input/input13
 systemd-vconsole-setup[367]: /usr/bin/setfont failed with exit status 66.
 kernel: Linux agpgart interface v0.103
 kernel: usb 4-2: New USB device found, idVendor=04f2, idProduct=b5ee, bcdDevice=92.37
 kernel: usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 kernel: usb 4-2: Product: HP HD Camera
 kernel: usb 4-2: Manufacturer: SunplusIT Inc
 kernel: AVX2 version of gcm_enc/dec engaged.
 kernel: AES CTR mode by8 optimization enabled
 kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
 kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
 systemd-vconsole-setup[367]: Setting source virtual console failed, ignoring remaining ones
 systemd-udevd[349]: Process '/usr/lib/systemd/systemd-vconsole-setup' failed with exit code 1.
 systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
 systemd-udevd[352]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
 kernel: r8168 0000:01:00.0 enp1s0f0: renamed from eth0
 systemd[1]: Started Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Reached target Local File Systems (Pre).
 systemd-udevd[348]: Process '/usr/bin/set-wireless-regdom' failed with exit code 1.
 systemd[1]: Mounting /boot/efi...
 kernel: ACPI Error: Method parse/execution failed \_SB.WMIV.WMPV, AE_AML_UNINITIALIZED_LOCAL (20181003/psparse-516)
 kernel: snd_hda_intel 0000:04:00.1: enabling device (0000 -> 0002)
 kernel: usb 4-1.3: new full-speed USB device number 4 using xhci_hcd
 kernel: snd_hda_intel 0000:04:00.1: Handle vga_switcheroo audio client
 kernel: snd_hda_intel 0000:04:00.6: enabling device (0000 -> 0002)
 kernel: Intel(R) Wireless WiFi driver for Linux
 kernel: Copyright(c) 2003- 2015 Intel Corporation
 kernel: iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
 kernel: input: HP WMI hotkeys as /devices/virtual/input/input14
 kernel: FAT-fs (nvme0n1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
 systemd[1]: Mounted /boot/efi.
 systemd[1]: Reached target Local File Systems.
 systemd[1]: Starting Rebuild Journal Catalog...
 systemd[1]: Starting Rebuild Dynamic Linker Cache...
 kernel: media: Linux media interface: v0.10
 kernel: iwlwifi 0000:02:00.0: loaded firmware version 36.9f0a2d68.0 op_mode iwlmvm
 systemd[1]: Starting Create Volatile Files and Directories...
 kernel: input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input15
 kernel: input: HD-Audio Generic HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input16
 kernel: input: HD-Audio Generic HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input17
 kernel: input: HD-Audio Generic HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input18
 kernel: snd_hda_codec_conexant hdaudioC1D0: CX8200: BIOS auto-probing.
 kernel: snd_hda_codec_conexant hdaudioC1D0: autoconfig for CX8200: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
 kernel: snd_hda_codec_conexant hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
 kernel: snd_hda_codec_conexant hdaudioC1D0:    hp_outs=1 (0x1d/0x0/0x0/0x0/0x0)
 kernel: snd_hda_codec_conexant hdaudioC1D0:    mono: mono_out=0x0
 kernel: snd_hda_codec_conexant hdaudioC1D0:    inputs:
 kernel: snd_hda_codec_conexant hdaudioC1D0:      Internal Mic=0x1a
 kernel: snd_hda_codec_conexant hdaudioC1D0:      Mic=0x19
 systemd[1]: Reached target Sound Card.
 systemd[1]: Started Create Volatile Files and Directories.
 systemd-udevd[344]: Process '/usr/bin/tlp auto' failed with exit code 4.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: videodev: Linux video capture interface: v2.00
 kernel: input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:08.1/0000:04:00.6/sound/card1/input19
 kernel: input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:08.1/0000:04:00.6/sound/card1/input20
 systemd[1]: Started Rebuild Journal Catalog.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-catalog-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Starting Update UTMP about System Boot/Shutdown...
 audit[480]: SYSTEM_BOOT pid=480 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
 kernel: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
 kernel: AMD IOMMUv2 functionality not available on this system
 systemd[1]: Started Rebuild Dynamic Linker Cache.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ldconfig comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Starting Update is Completed...
 systemd[1]: Started Update UTMP about System Boot/Shutdown.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Started Update is Completed.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-done comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Reached target System Initialization.
 systemd[1]: Started Daily Cleanup of Temporary Directories.
 systemd[1]: Starting Mark boot as indeterminate...
 systemd[1]: Listening on D-Bus System Message Bus Socket.
 kernel: uvcvideo: Found UVC 1.00 device HP HD Camera (04f2:b5ee)
 systemd[1]: Reached target Sockets.
 systemd[1]: Reached target Basic System.
 systemd[1]: Starting Login Service...
 systemd[1]: Started D-Bus System Message Bus.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Starting Permit User Sessions...
 systemd[1]: Started Daily rotation of log files.
 systemd[1]: Started Daily verification of password and group files.
 systemd[1]: Reached target Timers.
 dbus-daemon[485]: dbus[485]: Unknown username "systemd-resolve" in message bus configuration file
 systemd[1]: Started Mark boot as indeterminate.
 dbus-daemon[485]: dbus[485]: Unknown username "systemd-network" in message bus configuration file
 dbus-daemon[485]: dbus[485]: Unknown username "systemd-timesync" in message bus configuration file
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=grub-boot-indeterminate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=grub-boot-indeterminate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Started Permit User Sessions.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Started Getty on tty1.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=getty@tty1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd-logind[484]: New seat seat0.
 systemd[1]: Reached target Login Prompts.
 systemd-logind[484]: Watching system buttons on /dev/input/event3 (Power Button)
 systemd[1]: Reached target Offline System Update (Pre).
 kernel: usb 4-1.3: New USB device found, idVendor=138a, idProduct=00ab, bcdDevice= 1.64
 kernel: usb 4-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=1
 kernel: usb 4-1.3: SerialNumber: 9689a40797e0
 kernel: iwlwifi 0000:02:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
 kernel: kvm: Nested Virtualization enabled
 kernel: kvm: Nested Paging enabled
 kernel: SVM: Virtual VMLOAD VMSAVE supported
 kernel: SVM: Virtual GIF supported
 kernel: MCE: In-kernel MCE decoding enabled.
 kernel: EDAC amd64: Node 0: DRAM ECC disabled.
 kernel: EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
                                 Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
                                 (Note that use of the override may cause unknown side effects.)
 systemd-logind[484]: Watching system buttons on /dev/input/event0 (Power Button)
 systemd-logind[484]: Watching system buttons on /dev/input/event2 (Lid Switch)
 systemd-logind[484]: Watching system buttons on /dev/input/event1 (Sleep Button)
 kernel: iwlwifi 0000:02:00.0: base HW address: 00:bb:60:6c:ae:da
 systemd-logind[484]: Watching system buttons on /dev/input/event5 (AT Translated Set 2 keyboard)
 kernel: uvcvideo 4-2:1.0: Entity type for entity Extension 4 was not initialized!
 kernel: uvcvideo 4-2:1.0: Entity type for entity Extension 3 was not initialized!
 kernel: uvcvideo 4-2:1.0: Entity type for entity Processing 2 was not initialized!
 kernel: uvcvideo 4-2:1.0: Entity type for entity Camera 1 was not initialized!
 kernel: input: HP HD Camera: HP HD Camera as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb4/4-2/4-2:1.0/input/input21
 kernel: usbcore: registered new interface driver uvcvideo
 kernel: USB Video Class driver (1.1.1)
 kernel: [drm] amdgpu kernel modesetting enabled.
 kernel: Parsing CRAT table with 1 nodes
 kernel: Creating topology SYSFS entries
 kernel: Topology: Add APU node [0x0:0x0]
 kernel: Finished initializing topology
 kernel: checking generic (d0000000 300000) vs hw (d0000000 10000000)
 kernel: fb0: switching to amdgpudrmfb from EFI VGA
 kernel: Console: switching to colour dummy device 80x25
 kernel: [drm] initializing kernel modesetting (RAVEN 0x1002:0x15DD 0x103C:0x83D5 0xD0).
 kernel: [drm] register mmio base: 0xE0700000
 kernel: [drm] register mmio size: 524288
 kernel: [drm] add ip block number 0 <soc15_common>
 kernel: [drm] add ip block number 1 <gmc_v9_0>
 kernel: [drm] add ip block number 2 <vega10_ih>
 kernel: [drm] add ip block number 3 <psp>
 kernel: [drm] add ip block number 4 <gfx_v9_0>
 kernel: [drm] add ip block number 5 <sdma_v4_0>
 kernel: [drm] add ip block number 6 <powerplay>
 kernel: [drm] add ip block number 7 <dm>
 kernel: [drm] add ip block number 8 <vcn_v1_0>
 kernel: [drm] VCN decode is enabled in VM mode
 kernel: [drm] VCN encode is enabled in VM mode
 kernel: [drm] VCN jpeg decode is enabled in VM mode
 systemd[1]: Starting Load/Save RF Kill Switch Status...
 systemd[1]: Started Load/Save RF Kill Switch Status.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
 kernel: thermal thermal_zone6: failed to read out thermal zone (-61)
 systemd-udevd[354]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
 kernel: iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
 kernel: [drm] BIOS signature incorrect 0 0
 kernel: resource sanity check: requesting [mem 0x000c0000-0x000dffff], which spans more than PCI Bus 0000:00 [mem 0x000c0000-0x000c3fff window]
 kernel: caller pci_map_rom+0x6a/0x1b0 mapping multiple BARs
 kernel: amdgpu 0000:04:00.0: Invalid PCI ROM header signature: expecting 0xaa55, got 0xffff
 systemd[1]: Started Login Service.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Reached target Multi-User System.
 systemd[1]: Reached target Graphical Interface.
 systemd[1]: Startup finished in 8.201s (firmware) + 1.276s (loader) + 1.741s (kernel) + 752ms (userspace) = 11.971s.
 kernel: [drm:amdgpu_get_bios [amdgpu]] *ERROR* Unable to locate a BIOS ROM
 kernel: amdgpu 0000:04:00.0: Fatal error during GPU init
 kernel: [drm] amdgpu: finishing device.
 kernel: amdgpu: probe of 0000:04:00.0 failed with error -22
 systemd[1]: Created slice system-systemd\x2dbacklight.slice.
 systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:acpi_video0...
 systemd[1]: Started Load/Save Screen Backlight Brightness of backlight:acpi_video0.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:acpi_video0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: input: PS/2 Generic Mouse as /devices/platform/i8042/serio2/input/input12
 kernel: mousedev: PS/2 mouse device common for all mice
 kernel: input: AlpsPS/2 ALPS GlidePoint as /devices/platform/i8042/serio3/input/input22
 kernel: random: crng init done
 kernel: random: 7 urandom warning(s) missed due to ratelimiting
 systemd-logind[484]: Power key pressed.
 systemd-logind[484]: Powering Off...
 systemd-logind[484]: System is powering down.
 systemd[1]: Stopping Load/Save RF Kill Switch Status...
 systemd[1]: Stopped target Offline System Update (Pre).
 systemd[1]: Stopped target Timers.
 systemd[1]: Stopped Daily Cleanup of Temporary Directories.
 systemd[1]: Stopped Daily rotation of log files.
 systemd[1]: Stopped Daily verification of password and group files.
 systemd[1]: Starting Generate shutdown-ramfs...
 systemd[1]: Closed LVM2 poll daemon socket.
 systemd[1]: Stopped target Graphical Interface.
 systemd[1]: Stopped target Multi-User System.
 systemd[1]: Stopped target Login Prompts.
 systemd[1]: Stopping Getty on tty1...
 systemd[1]: Stopping Login Service...
 systemd[1]: Stopping D-Bus System Message Bus...
 systemd[1]: Stopped target Sound Card.
 systemd[1]: Stopped Load/Save RF Kill Switch Status.
 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: kauditd_printk_skb: 17 callbacks suppressed
 kernel: audit: type=1131 audit(1547929740.355:28): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
 systemd[1]: Stopped D-Bus System Message Bus.
 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Stopped Getty on tty1.
 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=getty@tty1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Removed slice system-getty.slice.
 kernel: audit: type=1131 audit(1547929740.361:29): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: audit: type=1131 audit(1547929740.361:30): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=getty@tty1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Stopping Permit User Sessions...
 systemd[1]: Stopped Permit User Sessions.
 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Stopped target Remote File Systems.
 kernel: audit: type=1131 audit(1547929740.371:31): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 mkinitcpio[638]: ==> Starting build: none
 mkinitcpio[638]:   -> Running build hook: [sd-shutdown]
 mkinitcpio[638]: ==> Build complete.
 systemd[1]: Started Generate shutdown-ramfs.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: audit: type=1130 audit(1547929740.478:32): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: audit: type=1131 audit(1547929740.478:33): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Stopped Login Service.
 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Stopped target Basic System.
 systemd[1]: Stopped target Slices.
 systemd[1]: Stopped target Sockets.
 systemd[1]: Stopped target Paths.
 systemd[1]: Closed D-Bus System Message Bus Socket.
 systemd[1]: Stopped target System Initialization.
 systemd[1]: Stopped target Local Encrypted Volumes.
 systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
 kernel: audit: type=1131 audit(1547929740.591:34): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
 systemd[1]: Stopping Load/Save Screen Backlight Brightness of backlight:acpi_video0...
 systemd[1]: Stopping Load/Save Random Seed...
 systemd[1]: Stopped Apply Kernel Variables.
 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Stopped Load Kernel Modules.
 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Stopped Update is Completed.
 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-done comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Stopped Rebuild Journal Catalog.
 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-catalog-update comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Stopped Rebuild Dynamic Linker Cache.
 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ldconfig comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Stopping Update UTMP about System Boot/Shutdown...
 systemd[1]: Removed slice User and Session Slice.
 kernel: audit: type=1131 audit(1547929740.605:35): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: audit: type=1131 audit(1547929740.605:36): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: audit: type=1131 audit(1547929740.605:37): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-done comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Stopped Load/Save Screen Backlight Brightness of backlight:acpi_video0.
 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:acpi_video0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Stopped Load/Save Random Seed.
 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Removed slice system-systemd\x2dbacklight.slice.
 audit[725]: SYSTEM_SHUTDOWN pid=725 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
 systemd[1]: Stopped Update UTMP about System Boot/Shutdown.
 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Stopped Create Volatile Files and Directories.
 systemd[1]: Stopped target Local File Systems.
 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Unmounting Temporary Directory (/tmp)...
 systemd[1]: Unmounting /boot/efi...
 systemd[1]: Unmounted Temporary Directory (/tmp).
 systemd[1]: Unmounted /boot/efi.
 systemd[1]: Stopped target Local File Systems (Pre).
 systemd[1]: Stopped Create Static Device Nodes in /dev.
 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysusers comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Stopped Create System Users.
 systemd[1]: Stopped Remount Root and Kernel File Systems.
 systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
 systemd[1]: Reached target Unmount All Filesystems.
 systemd[1]: Stopped target Swap.
 systemd[1]: Reached target Shutdown.
 systemd[1]: Reached target Final Step.
 systemd[1]: Starting Power-Off...
 systemd[1]: Shutting down.
 kernel: printk: systemd-shutdow: 41 output lines suppressed due to ratelimiting
 systemd-shutdown[1]: Syncing filesystems and block devices.
 systemd-shutdown[1]: Sending SIGTERM to remaining processes...
 systemd-journald[319]: Journal stopped
Continued in the next post…
#57
And here is the journalctl -b of a successful boot:
 kernel: Linux version 4.20.1-1-MANJARO (builduser@development) (gcc version 8.2.1 20181127 (GCC)) #1 SMP PREEMPT Wed Jan 9 17:43:49 UTC 2019
 kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-4.20-x86_64 root=UUID=f24a6a1a-9470-4d51-abc2-a70edbc3cc1b rw intremap=off iommu=soft acpi=strict rd.udev.log-priority=3
 kernel: KERNEL supported cpus:
 kernel:   Intel GenuineIntel
 kernel:   AMD AuthenticAMD
 kernel:   Hygon HygonGenuine
 kernel:   Centaur CentaurHauls
 kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
 kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
 kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
 kernel: x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
 kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
 kernel: BIOS-provided physical RAM map:
 kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
 kernel: BIOS-e820: [mem 0x0000000000100000-0x0000000003ffffff] usable
 kernel: BIOS-e820: [mem 0x0000000004000000-0x0000000004009fff] ACPI NVS
 kernel: BIOS-e820: [mem 0x000000000400a000-0x0000000079e7ffff] usable
 kernel: BIOS-e820: [mem 0x0000000079e80000-0x000000007a47ffff] type 20
 kernel: BIOS-e820: [mem 0x000000007a480000-0x000000007ac7ffff] reserved
 kernel: BIOS-e820: [mem 0x000000007ac80000-0x000000007b37ffff] ACPI NVS
 kernel: BIOS-e820: [mem 0x000000007b380000-0x000000007b3fffff] ACPI data
 kernel: BIOS-e820: [mem 0x000000007b400000-0x000000008dffffff] usable
 kernel: BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
 kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
 kernel: BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
 kernel: BIOS-e820: [mem 0x00000000fed80000-0x00000000fed80fff] reserved
 kernel: BIOS-e820: [mem 0x00000000fedf1000-0x00000000fedf1fff] reserved
 kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
 kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
 kernel: BIOS-e820: [mem 0x0000000100000000-0x000000022f33ffff] usable
 kernel: NX (Execute Disable) protection: active
 kernel: efi: EFI v2.50 by HP
 kernel: efi:  ACPI=0x7b3ff000  ACPI 2.0=0x7b3ff014  SMBIOS=0x7a57b000  SMBIOS 3.0=0x7a579000  ESRT=0x777f1d18  MEMATTR=0x76990018
 kernel: SMBIOS 3.1.0 present.
 kernel: DMI: HP HP EliteBook 755 G5/83D5, BIOS Q81 Ver. 01.03.01 07/26/2018
 kernel: tsc: Fast TSC calibration using PIT
 kernel: tsc: Detected 2195.805 MHz processor
 kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
 kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
 kernel: last_pfn = 0x22f340 max_arch_pfn = 0x400000000
 kernel: MTRR default type: uncachable
 kernel: MTRR fixed ranges enabled:
 kernel:   00000-9FFFF write-back
 kernel:   A0000-BFFFF uncachable
 kernel:   C0000-DFFFF write-protect
 kernel:   E0000-FFFFF uncachable
 kernel: MTRR variable ranges enabled:
 kernel:   0 base 0000FF000000 mask FFFFFF000000 write-protect
 kernel:   1 base 000000000000 mask FFFF80000000 write-back
 kernel:   2 base 000080000000 mask FFFFC0000000 write-back
 kernel:   3 base 0000C0000000 mask FFFFF0000000 write-back
 kernel:   4 disabled
 kernel:   5 disabled
 kernel:   6 disabled
 kernel:   7 disabled
 kernel: TOM2: 0000000230000000 aka 8960M
 kernel: x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
 kernel: last_pfn = 0x8e000 max_arch_pfn = 0x400000000
 kernel: esrt: Reserving ESRT space from 0x00000000777f1d18 to 0x00000000777f1d50.
 kernel: check: Scanning 1 areas for low memory corruption
 kernel: Base memory trampoline at [(____ptrval____)] 98000 size 24576
 kernel: Using GB pages for direct mapping
 kernel: BRK [0x1d5601000, 0x1d5601fff] PGTABLE
 kernel: BRK [0x1d5602000, 0x1d5602fff] PGTABLE
 kernel: BRK [0x1d5603000, 0x1d5603fff] PGTABLE
 kernel: BRK [0x1d5604000, 0x1d5604fff] PGTABLE
 kernel: BRK [0x1d5605000, 0x1d5605fff] PGTABLE
 kernel: BRK [0x1d5606000, 0x1d5606fff] PGTABLE
 kernel: BRK [0x1d5607000, 0x1d5607fff] PGTABLE
 kernel: BRK [0x1d5608000, 0x1d5608fff] PGTABLE
 kernel: BRK [0x1d5609000, 0x1d5609fff] PGTABLE
 kernel: BRK [0x1d560a000, 0x1d560afff] PGTABLE
 kernel: Secure boot could not be determined
 kernel: RAMDISK: [mem 0x36db1000-0x376cffff]
 kernel: ACPI: Early table checksum verification disabled
 kernel: ACPI: RSDP 0x000000007B3FF014 000024 (v02 HPQOEM)
 kernel: ACPI: XSDT 0x000000007B3D2188 0000FC (v01 HPQOEM SLIC-BPC 00000001      01000013)
 kernel: ACPI: FACP 0x000000007B3EC000 00010C (v05 HPQOEM SLIC-BPC 00000001 HP   00000001)
 kernel: ACPI: DSDT 0x000000007B3D4000 010625 (v02 HPQOEM 83D5     00000000 INTL 20160527)
 kernel: ACPI: FACS 0x000000007B2C6000 000040
 kernel: ACPI: SSDT 0x000000007B3FC000 00012A (v02 HP     ShmTable 00000001 INTL 20160527)
 kernel: ACPI: SSDT 0x000000007B3F6000 00533D (v02 AMD    AmdTable 00000002 MSFT 02000002)
 kernel: ACPI: SSDT 0x000000007B3F4000 00119C (v01 AMD    AMD CPU  00000001 AMD  00000001)
 kernel: ACPI: CRAT 0x000000007B3F3000 000810 (v01 AMD    AMD CRAT 00000001 AMD  00000001)
 kernel: ACPI: CDIT 0x000000007B3F2000 000029 (v01 AMD    AMD CDIT 00000001 AMD  00000001)
 kernel: ACPI: UEFI 0x000000007B2E3000 000042 (v01 HPQOEM EDK2     00000002      01000013)
 kernel: ACPI: SSDT 0x000000007B3F1000 000ECA (v02 HP     UcsiAcpi 00000001 INTL 20160527)
 kernel: ACPI: SSDT 0x000000007B3F0000 0000FB (v02 HP     UcsiCntr 00000001 INTL 20160527)
 kernel: ACPI: RTMA 0x000000007B3EF000 00009E (v01 HP     _HBMART_ 00001000 HP   00000001)
 kernel: ACPI: SSDT 0x000000007B3EE000 0003C8 (v02 HPQOEM Tpm2Tabl 00001000 INTL 20160527)
 kernel: ACPI: TPM2 0x000000007B3ED000 000034 (v03 HPQOEM EDK2     00000002      01000013)
 kernel: ACPI: ASF! 0x000000007B3EB000 00006E (v32 HPQOEM 83D5     00000001 HP   00000001)
 kernel: ACPI: MSDM 0x000000007B3EA000 000055 (v03 HPQOEM SLIC-BPC 00000000 HP   00000001)
 kernel: ACPI: SLIC 0x000000007B3E9000 000176 (v01 HPQOEM SLIC-BPC 00000001 HP   00000001)
 kernel: ACPI: WSMT 0x000000007B3E8000 000028 (v01 HPQOEM 83D5     00000001 HP   00000001)
 kernel: ACPI: HPET 0x000000007B3E7000 000038 (v01 HPQOEM 83D5     00000001 HP   00000001)
 kernel: ACPI: APIC 0x000000007B3E6000 000138 (v02 HPQOEM 83D5     00000001 HP   00000001)
 kernel: ACPI: MCFG 0x000000007B3E5000 00003C (v01 HPQOEM 83D5     00000001 HP   00000001)
 kernel: ACPI: IVRS 0x000000007B3FE000 0000D0 (v02 AMD    AMD IVRS 00000001 AMD  00000000)
 kernel: ACPI: SSDT 0x000000007B3D1000 000884 (v01 HP     HPADNBWL 00001000 INTL 20160527)
 kernel: ACPI: SSDT 0x000000007B3D0000 000032 (v01 HP     HPCONDEV 00001000 INTL 20160527)
 kernel: ACPI: SSDT 0x000000007B3D3000 0008CB (v01 AMD    AmdTable 00000001 INTL 20160527)
 kernel: ACPI: FPDT 0x000000007B3CF000 000044 (v01 HPQOEM EDK2     00000002      01000013)
 kernel: ACPI: SSDT 0x000000007B3CD000 001B93 (v01 AMD    AmdTable 00000001 INTL 20160527)
 kernel: ACPI: BGRT 0x000000007B3CC000 000038 (v01 HPQOEM EDK2     00000002      01000013)
 kernel: ACPI: SSDT 0x000000007B3FD000 0002F9 (v02 HP     PwrCtlEv 00000001 INTL 20160527)
 kernel: ACPI: Local APIC address 0xfee00000
 kernel: No NUMA configuration found
 kernel: Faking a node at [mem 0x0000000000000000-0x000000022f33ffff]
 kernel: NODE_DATA(0) allocated [mem 0x22f33c000-0x22f33ffff]
 kernel: Zone ranges:
 kernel:   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
 kernel:   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
 kernel:   Normal   [mem 0x0000000100000000-0x000000022f33ffff]
 kernel:   Device   empty
 kernel: Movable zone start for each node
 kernel: Early memory node ranges
 kernel:   node   0: [mem 0x0000000000001000-0x000000000009ffff]
 kernel:   node   0: [mem 0x0000000000100000-0x0000000003ffffff]
 kernel:   node   0: [mem 0x000000000400a000-0x0000000079e7ffff]
 kernel:   node   0: [mem 0x000000007b400000-0x000000008dffffff]
 kernel:   node   0: [mem 0x0000000100000000-0x000000022f33ffff]
 kernel: Zeroed struct page in unavailable ranges: 13803 pages
 kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000022f33ffff]
 kernel: On node 0 totalpages: 1817941
 kernel:   DMA zone: 64 pages used for memmap
 kernel:   DMA zone: 1076 pages reserved
 kernel:   DMA zone: 3999 pages, LIFO batch:0
 kernel:   DMA32 zone: 8938 pages used for memmap
 kernel:   DMA32 zone: 572022 pages, LIFO batch:63
 kernel:   Normal zone: 19405 pages used for memmap
 kernel:   Normal zone: 1241920 pages, LIFO batch:63
 kernel: ACPI: PM-Timer IO Port: 0x408
 kernel: ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
 kernel: ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
 kernel: IOAPIC[0]: apic_id 33, version 33, address 0xfec00000, GSI 0-23
 kernel: IOAPIC[1]: apic_id 34, version 33, address 0xfec01000, GSI 24-55
 kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
 kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
 kernel: ACPI: IRQ0 used by override.
 kernel: ACPI: IRQ9 used by override.
 kernel: Using ACPI (MADT) for SMP configuration information
 kernel: ACPI: HPET id: 0x10228210 base: 0xfed00000
 kernel: smpboot: Allowing 16 CPUs, 8 hotplug CPUs
 kernel: PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
 kernel: PM: Registered nosave memory: [mem 0x000a0000-0x000fffff]
 kernel: PM: Registered nosave memory: [mem 0x04000000-0x04009fff]
 kernel: PM: Registered nosave memory: [mem 0x79e80000-0x7a47ffff]
 kernel: PM: Registered nosave memory: [mem 0x7a480000-0x7ac7ffff]
 kernel: PM: Registered nosave memory: [mem 0x7ac80000-0x7b37ffff]
 kernel: PM: Registered nosave memory: [mem 0x7b380000-0x7b3fffff]
 kernel: PM: Registered nosave memory: [mem 0x8e000000-0xf7ffffff]
 kernel: PM: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
 kernel: PM: Registered nosave memory: [mem 0xfc000000-0xfebfffff]
 kernel: PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
 kernel: PM: Registered nosave memory: [mem 0xfec01000-0xfec0ffff]
 kernel: PM: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
 kernel: PM: Registered nosave memory: [mem 0xfec11000-0xfed7ffff]
 kernel: PM: Registered nosave memory: [mem 0xfed80000-0xfed80fff]
 kernel: PM: Registered nosave memory: [mem 0xfed81000-0xfedf0fff]
 kernel: PM: Registered nosave memory: [mem 0xfedf1000-0xfedf1fff]
 kernel: PM: Registered nosave memory: [mem 0xfedf2000-0xfedfffff]
 kernel: PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
 kernel: PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
 kernel: PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
 kernel: [mem 0x8e000000-0xf7ffffff] available for PCI devices
 kernel: Booting paravirtualized kernel on bare hardware
 kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
 kernel: random: get_random_bytes called from start_kernel+0x95/0x54e with crng_init=0
 kernel: setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:16 nr_node_ids:1
 kernel: percpu: Embedded 45 pages/cpu @(____ptrval____) s147456 r8192 d28672 u262144
 kernel: pcpu-alloc: s147456 r8192 d28672 u262144 alloc=1*2097152
 kernel: pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
 kernel: Built 1 zonelists, mobility grouping on.  Total pages: 1788458
 kernel: Policy zone: Normal
 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.20-x86_64 root=UUID=f24a6a1a-9470-4d51-abc2-a70edbc3cc1b rw intremap=off iommu=soft acpi=strict rd.udev.log-priority=3
 kernel: Memory: 6952068K/7271764K available (12293K kernel code, 1277K rwdata, 3768K rodata, 1540K init, 3876K bss, 319696K reserved, 0K cma-reserved)
 kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
 kernel: ftrace: allocating 36346 entries in 142 pages
 kernel: rcu: Preemptible hierarchical RCU implementation.
 kernel: rcu:         CONFIG_RCU_FANOUT set to non-default value of 32.
 kernel: rcu:         RCU dyntick-idle grace-period acceleration is enabled.
 kernel: rcu:         RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=16.
 kernel: rcu:         RCU priority boosting: priority 1 delay 500 ms.
 kernel:         Tasks RCU enabled.
 kernel: rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
 kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
 kernel: NR_IRQS: 20736, nr_irqs: 1096, preallocated irqs: 16
 kernel: rcu:         Offload RCU callbacks from CPUs: (none).
 kernel: Console: colour dummy device 80x25
 kernel: printk: console [tty0] enabled
 kernel: ACPI: Core revision 20181003
 kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
 kernel: hpet clockevent registered
 kernel: APIC: Switch to symmetric I/O mode setup
 kernel: Switched APIC routing to physical flat.
 kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
 kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x1fa6b81744c, max_idle_ns: 440795244172 ns
 kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 4393.59 BogoMIPS (lpj=7319350)
 kernel: pid_max: default: 32768 minimum: 301
 kernel: LSM: Security Framework initializing
 kernel: Yama: becoming mindful.
 kernel: AppArmor: AppArmor disabled by boot time parameter
 kernel: Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
 kernel: Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
 kernel: Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
 kernel: Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
 kernel: mce: CPU supports 23 MCE banks
 kernel: LVT offset 1 assigned for vector 0xf9
 kernel: LVT offset 2 assigned for vector 0xf4
 kernel: Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 512
 kernel: Last level dTLB entries: 4KB 1536, 2MB 1536, 4MB 768, 1GB 0
 kernel: Spectre V2 : Mitigation: Full AMD retpoline
 kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
 kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
 kernel: Spectre V2 : User space: Vulnerable
 kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
 kernel: Freeing SMP alternatives memory: 28K
 kernel: smpboot: CPU0: AMD Ryzen 7 PRO 2700U w/ Radeon Vega Mobile Gfx (family: 0x17, model: 0x11, stepping: 0x0)
 kernel: Performance Events: Fam17h core perfctr, AMD PMU driver.
 kernel: ... version:                0
 kernel: ... bit width:              48
 kernel: ... generic registers:      6
 kernel: ... value mask:             0000ffffffffffff
 kernel: ... max period:             00007fffffffffff
 kernel: ... fixed-purpose events:   0
 kernel: ... event mask:             000000000000003f
 kernel: rcu: Hierarchical SRCU implementation.
 kernel: NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
 kernel: smp: Bringing up secondary CPUs ...
 kernel: x86: Booting SMP configuration:
 kernel: .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6  #7
 kernel: smp: Brought up 1 node, 8 CPUs
 kernel: smpboot: Max logical packages: 2
 kernel: smpboot: Total of 8 processors activated (35146.75 BogoMIPS)
 kernel: devtmpfs: initialized
 kernel: x86/mm: Memory block size: 128MB
 kernel: PM: Registering ACPI NVS region [mem 0x04000000-0x04009fff] (40960 bytes)
 kernel: PM: Registering ACPI NVS region [mem 0x7ac80000-0x7b37ffff] (7340032 bytes)
 kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
 kernel: futex hash table entries: 4096 (order: 6, 262144 bytes)
 kernel: pinctrl core: initialized pinctrl subsystem
 kernel: RTC time: 20:29:17, date: 01/19/19
 kernel: NET: Registered protocol family 16
 kernel: audit: initializing netlink subsys (disabled)
 kernel: audit: type=2000 audit(1547929757.369:1): state=initialized audit_enabled=0 res=1
 kernel: cpuidle: using governor ladder
 kernel: cpuidle: using governor menu
 kernel: ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
 kernel: ACPI: bus type PCI registered
 kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
 kernel: PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
 kernel: PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
 kernel: PCI: Using configuration type 1 for base access
 kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
 kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
 kernel: ACPI: Added _OSI(Module Device)
 kernel: ACPI: Added _OSI(Processor Device)
 kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
 kernel: ACPI: Added _OSI(Processor Aggregator Device)
 kernel: ACPI: Added _OSI(Linux-Dell-Video)
 kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
 kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
 kernel: ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.LPC0.EC0], AE_NOT_FOUND (20181003/dswload2-160)
 kernel: fbcon: Taking over console
 kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20181003/psobject-221)
 kernel: ACPI Error: Ignore error and continue table load (20181003/psobject-604)
 kernel: ACPI Error: Skip parsing opcode Scope (20181003/psloop-543)
 kernel: ACPI: 12 ACPI AML tables successfully acquired and loaded
 kernel: ACPI: EC: EC started
 kernel: ACPI: EC: interrupt blocked
 kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: Used as first EC
 kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x3, EC_CMD/EC_SC=0x66, EC_DATA=0x62
 kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions
 kernel: ACPI: Interpreter enabled
 kernel: ACPI: (supports S0 S1 S3 S4 S5)
 kernel: ACPI: Using IOAPIC for interrupt routing
 kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
 kernel: ACPI: Enabled 8 GPEs in block 00 to 1F
 kernel: ACPI: Power Resource [PXP] (off)
 kernel: ACPI: Power Resource [APPR] (off)
 kernel: ACPI: Power Resource [P0ST] (on)
 kernel: ACPI: Power Resource [P3ST] (on)
 kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
 kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI]
 kernel: acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR]
 kernel: acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
 kernel: acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
 kernel: acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
 kernel: acpi PNP0A08:00: ignoring host bridge window [mem 0x000cc000-0x000cffff window] (conflicts with Video ROM [mem 0x000c0000-0x000cd3ff])
 kernel: PCI host bridge to bus 0000:00
 kernel: pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
 kernel: pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0xd0000000-0xf7ffffff window]
 kernel: pci_bus 0000:00: root bus resource [mem 0xfc000000-0xfeafffff window]
 kernel: pci_bus 0000:00: root bus resource [bus 00-ff]
 kernel: pci 0000:00:00.0: [1022:15d0] type 00 class 0x060000
 kernel: pci 0000:00:00.2: [1022:15d1] type 00 class 0x080600
 kernel: pci 0000:00:01.0: [1022:1452] type 00 class 0x060000
 kernel: pci 0000:00:01.3: [1022:15d3] type 01 class 0x060400
 kernel: pci 0000:00:01.3: PME# supported from D0 D3hot D3cold
 kernel: pci 0000:00:01.4: [1022:15d3] type 01 class 0x060400
 kernel: pci 0000:00:01.4: PME# supported from D0 D3hot D3cold
 kernel: pci 0000:00:01.7: [1022:15d3] type 01 class 0x060400
 kernel: pci 0000:00:01.7: PME# supported from D0 D3hot D3cold
 kernel: pci 0000:00:08.0: [1022:1452] type 00 class 0x060000
 kernel: pci 0000:00:08.1: [1022:15db] type 01 class 0x060400
 kernel: pci 0000:00:08.1: enabling Extended Tags
 kernel: pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
 kernel: pci 0000:00:08.2: [1022:15dc] type 01 class 0x060400
 kernel: pci 0000:00:08.2: enabling Extended Tags
 kernel: pci 0000:00:08.2: PME# supported from D0 D3hot D3cold
 kernel: pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
 kernel: pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
 kernel: pci 0000:00:18.0: [1022:15e8] type 00 class 0x060000
 kernel: pci 0000:00:18.1: [1022:15e9] type 00 class 0x060000
 kernel: pci 0000:00:18.2: [1022:15ea] type 00 class 0x060000
 kernel: pci 0000:00:18.3: [1022:15eb] type 00 class 0x060000
 kernel: pci 0000:00:18.4: [1022:15ec] type 00 class 0x060000
 kernel: pci 0000:00:18.5: [1022:15ed] type 00 class 0x060000
 kernel: pci 0000:00:18.6: [1022:15ee] type 00 class 0x060000
 kernel: pci 0000:00:18.7: [1022:15ef] type 00 class 0x060000
 kernel: pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
 kernel: pci 0000:01:00.0: reg 0x10: [io  0x3300-0x33ff]
 kernel: pci 0000:01:00.0: reg 0x18: [mem 0xe0a14000-0xe0a14fff 64bit]
 kernel: pci 0000:01:00.0: reg 0x20: [mem 0xe0a00000-0xe0a03fff 64bit]
 kernel: pci 0000:01:00.0: supports D1 D2
 kernel: pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
 kernel: pci 0000:01:00.1: [10ec:816a] type 00 class 0x070002
 kernel: pci 0000:01:00.1: reg 0x10: [io  0x3200-0x32ff]
 kernel: pci 0000:01:00.1: reg 0x18: [mem 0xe0a15000-0xe0a15fff 64bit]
 kernel: pci 0000:01:00.1: reg 0x20: [mem 0xe0a04000-0xe0a07fff 64bit]
 kernel: pci 0000:01:00.1: supports D1 D2
 kernel: pci 0000:01:00.1: PME# supported from D0 D1 D2 D3hot D3cold
 kernel: pci 0000:01:00.2: [10ec:816b] type 00 class 0x070002
 kernel: pci 0000:01:00.2: reg 0x10: [io  0x3100-0x31ff]
 kernel: pci 0000:01:00.2: reg 0x18: [mem 0xe0a16000-0xe0a16fff 64bit]
 kernel: pci 0000:01:00.2: reg 0x20: [mem 0xe0a08000-0xe0a0bfff 64bit]
 kernel: pci 0000:01:00.2: supports D1 D2
 kernel: pci 0000:01:00.2: PME# supported from D0 D1 D2 D3hot D3cold
 kernel: pci 0000:01:00.3: [10ec:816c] type 00 class 0x0c0701
 kernel: pci 0000:01:00.3: reg 0x10: [io  0x3000-0x30ff]
 kernel: pci 0000:01:00.3: reg 0x18: [mem 0xe0a17000-0xe0a17fff 64bit]
 kernel: pci 0000:01:00.3: reg 0x20: [mem 0xe0a0c000-0xe0a0ffff 64bit]
 kernel: pci 0000:01:00.3: supports D1 D2
 kernel: pci 0000:01:00.3: PME# supported from D0 D1 D2 D3hot D3cold
 kernel: pci 0000:01:00.4: [10ec:816d] type 00 class 0x0c0320
 kernel: pci 0000:01:00.4: reg 0x10: [mem 0xe0a18000-0xe0a18fff]
 kernel: pci 0000:01:00.4: reg 0x18: [mem 0xe0a10000-0xe0a13fff 64bit]
 kernel: pci 0000:01:00.4: PME# supported from D0 D3cold
 kernel: pci 0000:00:01.3: PCI bridge to [bus 01]
 kernel: pci 0000:00:01.3:   bridge window [io  0x3000-0x3fff]
 kernel: pci 0000:00:01.3:   bridge window [mem 0xe0a00000-0xe0afffff]
 kernel: pci 0000:02:00.0: [8086:24fd] type 00 class 0x028000
 kernel: pci 0000:02:00.0: reg 0x10: [mem 0xe0900000-0xe0901fff 64bit]
 kernel: pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
 kernel: pci 0000:00:01.4: PCI bridge to [bus 02]
 kernel: pci 0000:00:01.4:   bridge window [mem 0xe0900000-0xe09fffff]
 kernel: pci 0000:03:00.0: [1179:0113] type 00 class 0x010802
 kernel: pci 0000:03:00.0: reg 0x10: [mem 0xe0800000-0xe0803fff 64bit]
 kernel: pci 0000:03:00.0: PME# supported from D0 D3hot
 kernel: pci 0000:00:01.7: PCI bridge to [bus 03]
 kernel: pci 0000:00:01.7:   bridge window [mem 0xe0800000-0xe08fffff]
 kernel: pci 0000:04:00.0: [1002:15dd] type 00 class 0x030000
 kernel: pci 0000:04:00.0: reg 0x10: [mem 0xd0000000-0xdfffffff 64bit pref]
 kernel: pci 0000:04:00.0: reg 0x18: [mem 0xe0000000-0xe01fffff 64bit pref]
 kernel: pci 0000:04:00.0: reg 0x20: [io  0x2000-0x20ff]
 kernel: pci 0000:04:00.0: reg 0x24: [mem 0xe0700000-0xe077ffff]
 kernel: pci 0000:04:00.0: enabling Extended Tags
 kernel: pci 0000:04:00.0: BAR 0: assigned to efifb
 kernel: pci 0000:04:00.0: PME# supported from D1 D2 D3hot D3cold
 kernel: pci 0000:04:00.1: [1002:15de] type 00 class 0x040300
 kernel: pci 0000:04:00.1: reg 0x10: [mem 0xe0788000-0xe078bfff]
 kernel: pci 0000:04:00.1: enabling Extended Tags
 kernel: pci 0000:04:00.1: PME# supported from D1 D2 D3hot D3cold
 kernel: pci 0000:04:00.2: [1022:15df] type 00 class 0x108000
 kernel: pci 0000:04:00.2: reg 0x18: [mem 0xe0600000-0xe06fffff]
 kernel: pci 0000:04:00.2: reg 0x24: [mem 0xe078e000-0xe078ffff]
 kernel: pci 0000:04:00.2: enabling Extended Tags
 kernel: pci 0000:04:00.3: [1022:15e0] type 00 class 0x0c0330
 kernel: pci 0000:04:00.3: reg 0x10: [mem 0xe0300000-0xe03fffff 64bit]
 kernel: pci 0000:04:00.3: enabling Extended Tags
 kernel: pci 0000:04:00.3: PME# supported from D0 D3hot D3cold
 kernel: pci 0000:04:00.4: [1022:15e1] type 00 class 0x0c0330
 kernel: pci 0000:04:00.4: reg 0x10: [mem 0xe0400000-0xe04fffff 64bit]
 kernel: pci 0000:04:00.4: enabling Extended Tags
 kernel: pci 0000:04:00.4: PME# supported from D0 D3hot D3cold
 kernel: pci 0000:04:00.6: [1022:15e3] type 00 class 0x040300
 kernel: pci 0000:04:00.6: reg 0x10: [mem 0xe0780000-0xe0787fff]
 kernel: pci 0000:04:00.6: enabling Extended Tags
 kernel: pci 0000:04:00.6: PME# supported from D0 D3hot D3cold
 kernel: pci 0000:04:00.7: [1022:15e6] type 00 class 0x000000
 kernel: pci 0000:04:00.7: reg 0x18: [mem 0xe0500000-0xe05fffff]
 kernel: pci 0000:04:00.7: reg 0x24: [mem 0xe078c000-0xe078dfff]
 kernel: pci 0000:04:00.7: enabling Extended Tags
 kernel: pci 0000:00:08.1: PCI bridge to [bus 04]
 kernel: pci 0000:00:08.1:   bridge window [io  0x2000-0x2fff]
 kernel: pci 0000:00:08.1:   bridge window [mem 0xe0300000-0xe07fffff]
 kernel: pci 0000:00:08.1:   bridge window [mem 0xd0000000-0xe01fffff 64bit pref]
 kernel: pci 0000:05:00.0: [1022:7901] type 00 class 0x010601
 kernel: pci 0000:05:00.0: reg 0x24: [mem 0xe0200000-0xe02007ff]
 kernel: pci 0000:05:00.0: enabling Extended Tags
 kernel: pci 0000:05:00.0: PME# supported from D3hot D3cold
 kernel: pci 0000:00:08.2: PCI bridge to [bus 05]
 kernel: pci 0000:00:08.2:   bridge window [mem 0xe0200000-0xe02fffff]
 kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 5 6 10 11) *0, disabled.
 kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 5 6 10 11) *0, disabled.
 kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 5 6 10 11) *0, disabled.
 kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 5 6 10 11) *0, disabled.
 kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 5 6 10 11) *0, disabled.
 kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 5 6 10 11) *0, disabled.
 kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 3 5 6 10 11) *0, disabled.
 kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 3 5 6 10 11) *0, disabled.
 kernel: ACPI: EC: interrupt unblocked
 kernel: ACPI: EC: event unblocked
 kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions and events
 kernel: pci 0000:04:00.0: vgaarb: setting as boot VGA device
 kernel: pci 0000:04:00.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
 kernel: pci 0000:04:00.0: vgaarb: bridge control possible
 kernel: vgaarb: loaded
 kernel: ACPI: bus type USB registered
 kernel: usbcore: registered new interface driver usbfs
 kernel: usbcore: registered new interface driver hub
 kernel: usbcore: registered new device driver usb
 kernel: pps_core: LinuxPPS API ver. 1 registered
 kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
 kernel: PTP clock support registered
 kernel: EDAC MC: Ver: 3.0.0
 kernel: Registered efivars operations
 kernel: Unexpected threshold interrupt at vector f9
 kernel: PCI: Using ACPI for IRQ routing
 kernel: PCI: pci_cache_line_size set to 64 bytes
 kernel: e820: reserve RAM buffer [mem 0x79e80000-0x7bffffff]
 kernel: e820: reserve RAM buffer [mem 0x8e000000-0x8fffffff]
 kernel: e820: reserve RAM buffer [mem 0x22f340000-0x22fffffff]
 kernel: NetLabel: Initializing
 kernel: NetLabel:  domain hash size = 128
 kernel: NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
 kernel: NetLabel:  unlabeled traffic allowed by default
 kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
 kernel: hpet0: 3 comparators, 32-bit 14.318180 MHz counter
 kernel: clocksource: Switched to clocksource tsc-early
 kernel: VFS: Disk quotas dquot_6.6.0
 kernel: VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
 kernel: pnp: PnP ACPI init
 kernel: pnp 00:00: Plug and Play ACPI device, IDs PNP0b00 (active)
 kernel: system 00:01: [io  0x0400-0x04cf] has been reserved
 kernel: system 00:01: [io  0x04d0-0x04d1] has been reserved
 kernel: system 00:01: [io  0x04d6] has been reserved
 kernel: system 00:01: [io  0x0680-0x06ff] has been reserved
 kernel: system 00:01: [io  0x077a] has been reserved
 kernel: system 00:01: [io  0x0c00-0x0c01] has been reserved
 kernel: system 00:01: [io  0x0c14] has been reserved
 kernel: system 00:01: [io  0x0c50-0x0c52] has been reserved
 kernel: system 00:01: [io  0x0c6c] has been reserved
 kernel: system 00:01: [io  0x0c6f] has been reserved
 kernel: system 00:01: [io  0x0cd0-0x0cdb] has been reserved
 kernel: system 00:01: [io  0x0840-0x0847] has been reserved
 kernel: system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
 kernel: system 00:02: [mem 0x000e0000-0x000fffff] could not be reserved
 kernel: system 00:02: Plug and Play ACPI device, IDs PNP0c01 (active)
 kernel: pnp 00:03: Plug and Play ACPI device, IDs HPQ8002 PNP0303 (active)
 kernel: pnp 00:04: Plug and Play ACPI device, IDs SYN306f SYN0100 SYN0002 PNP0f13 (active)
 kernel: system 00:05: [io  0x0200-0x027f] has been reserved
 kernel: system 00:05: [mem 0xfedf1000-0xfedf1fff] has been reserved
 kernel: system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
 kernel: system 00:06: [mem 0xfec00000-0xfec00fff] could not be reserved
 kernel: system 00:06: [mem 0xfee00000-0xfee00fff] has been reserved
 kernel: system 00:06: [mem 0xfec20000-0xfec20fff] has been reserved
 kernel: system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
 kernel: pnp: PnP ACPI: found 7 devices
 kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
 kernel: pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
 kernel: pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
 kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
 kernel: pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
 kernel: pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
 kernel: pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
 kernel: pci_bus 0000:00: resource 10 [mem 0x000d0000-0x000d3fff window]
 kernel: pci_bus 0000:00: resource 11 [mem 0x000d4000-0x000d7fff window]
 kernel: pci_bus 0000:00: resource 12 [mem 0x000d8000-0x000dbfff window]
 kernel: pci_bus 0000:00: resource 13 [mem 0x000dc000-0x000dffff window]
 kernel: pci_bus 0000:00: resource 14 [mem 0x000e0000-0x000e3fff window]
 kernel: pci_bus 0000:00: resource 15 [mem 0x000e4000-0x000e7fff window]
 kernel: pci_bus 0000:00: resource 16 [mem 0x000e8000-0x000ebfff window]
 kernel: pci_bus 0000:00: resource 17 [mem 0x000ec000-0x000effff window]
 kernel: pci_bus 0000:00: resource 18 [mem 0xd0000000-0xf7ffffff window]
 kernel: pci_bus 0000:00: resource 19 [mem 0xfc000000-0xfeafffff window]
 kernel: pci_bus 0000:01: resource 0 [io  0x3000-0x3fff]
 kernel: pci_bus 0000:01: resource 1 [mem 0xe0a00000-0xe0afffff]
 kernel: pci_bus 0000:02: resource 1 [mem 0xe0900000-0xe09fffff]
 kernel: pci_bus 0000:03: resource 1 [mem 0xe0800000-0xe08fffff]
 kernel: pci_bus 0000:04: resource 0 [io  0x2000-0x2fff]
 kernel: pci_bus 0000:04: resource 1 [mem 0xe0300000-0xe07fffff]
 kernel: pci_bus 0000:04: resource 2 [mem 0xd0000000-0xe01fffff 64bit pref]
 kernel: pci_bus 0000:05: resource 1 [mem 0xe0200000-0xe02fffff]
 kernel: NET: Registered protocol family 2
 kernel: tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes)
 kernel: TCP established hash table entries: 65536 (order: 7, 524288 bytes)
 kernel: TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
 kernel: TCP: Hash tables configured (established 65536 bind 65536)
 kernel: UDP hash table entries: 4096 (order: 5, 131072 bytes)
 kernel: UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
 kernel: NET: Registered protocol family 44
 kernel: pci 0000:04:00.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
 kernel: pci 0000:04:00.1: Linked as a consumer to 0000:04:00.0
 kernel: PCI: CLS 64 bytes, default 64
 kernel: Unpacking initramfs...
 kernel: Freeing initrd memory: 9340K
 kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
 kernel: software IO TLB: mapped [mem 0x8a000000-0x8e000000] (64MB)
 kernel: amd_uncore: AMD NB counters detected
 kernel: amd_uncore: AMD LLC counters detected
 kernel: check: Scanning for low memory corruption every 60 seconds
 kernel: Initialise system trusted keyrings
 kernel: Key type blacklist registered
 kernel: workingset: timestamp_bits=41 max_order=21 bucket_order=0
 kernel: zbud: loaded
 kernel: Key type asymmetric registered
 kernel: Asymmetric key parser 'x509' registered
 kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
 kernel: io scheduler noop registered
 kernel: io scheduler deadline registered
 kernel: io scheduler cfq registered (default)
 kernel: io scheduler mq-deadline registered
 kernel: io scheduler kyber registered
 kernel: io scheduler bfq registered
 kernel: io scheduler bfq-sq registered
 kernel: BFQ I/O-scheduler: v9 (with cgroups support)
 kernel: blkcg_policy_register: BLKCG_MAX_POLS too small
 kernel: pcieport 0000:00:01.3: Signaling PME with IRQ 25
 kernel: aer 0000:00:01.3:pcie002: AER enabled with IRQ 25
 kernel: pcieport 0000:00:01.4: Signaling PME with IRQ 26
 kernel: aer 0000:00:01.4:pcie002: AER enabled with IRQ 26
 kernel: pcieport 0000:00:01.7: Signaling PME with IRQ 27
 kernel: aer 0000:00:01.7:pcie002: AER enabled with IRQ 27
 kernel: pcieport 0000:00:08.1: Signaling PME with IRQ 28
 kernel: pcieport 0000:00:08.2: Signaling PME with IRQ 29
 kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
 kernel: efifb: probing for efifb
 kernel: efifb: framebuffer at 0xd0000000, using 3072k, total 3072k
 kernel: efifb: mode is 1024x768x32, linelength=4096, pages=1
 kernel: efifb: scrolling: redraw
 kernel: efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
 kernel: Console: switching to colour frame buffer device 128x48
 kernel: fb0: EFI VGA frame buffer device
 kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
 kernel: ACPI: Power Button [PWRB]
 kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
 kernel: ACPI: Sleep Button [SLPB]
 kernel: input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input2
 kernel: ACPI: Lid Switch [LID]
 kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
 kernel: ACPI: Power Button [PWRF]
 kernel: ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
 kernel: acpi device:0a: registered as cooling_device0
 kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:09/LNXVIDEO:00/input/input4
 kernel: Monitor-Mwait will be used to enter C-1 state
 kernel: thermal LNXTHERM:00: registered as thermal_zone0
 kernel: ACPI: Thermal Zone [HEPZ] (30 C)
 kernel: thermal LNXTHERM:01: registered as thermal_zone1
 kernel: ACPI: Thermal Zone [CPUZ] (0 C)
 kernel: thermal LNXTHERM:02: registered as thermal_zone2
 kernel: ACPI: Thermal Zone [GFXZ] (0 C)
 kernel: thermal LNXTHERM:03: registered as thermal_zone3
 kernel: ACPI: Thermal Zone [EXTZ] (0 C)
 kernel: thermal LNXTHERM:04: registered as thermal_zone4
 kernel: ACPI: Thermal Zone [LOCZ] (45 C)
 kernel: thermal LNXTHERM:05: registered as thermal_zone5
 kernel: ACPI: Thermal Zone [BATZ] (32 C)
 kernel: ACPI Error: AE_AML_PACKAGE_LIMIT, Index (0x000000005) is beyond end of object (length 0x5) (20181003/exoparg2-396)
 kernel: ACPI Error: Method parse/execution failed \_TZ.GETP, AE_AML_PACKAGE_LIMIT (20181003/psparse-516)
 kernel: ACPI Error: Method parse/execution failed \_TZ.CHGZ._CRT, AE_AML_PACKAGE_LIMIT (20181003/psparse-516)
 kernel: ACPI Error: Method parse/execution failed \_TZ.GTTP, AE_AML_PACKAGE_LIMIT (20181003/psparse-516)
 kernel: ACPI Error: Method parse/execution failed \_TZ.CHGZ._TMP, AE_AML_PACKAGE_LIMIT (20181003/psparse-516)
 kernel: [Firmware Bug]: No valid trip found
 kernel: Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
 kernel: nvme nvme0: pci function 0000:03:00.0
 kernel: usbcore: registered new interface driver usbserial_generic
 kernel: usbserial: USB Serial support registered for generic
 kernel: rtc_cmos 00:00: RTC can wake from S4
 kernel: rtc_cmos 00:00: registered as rtc0
 kernel: rtc_cmos 00:00: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
 kernel: ledtrig-cpu: registered to indicate activity on CPUs
 kernel: NET: Registered protocol family 10
 kernel: Segment Routing with IPv6
 kernel: NET: Registered protocol family 17
 kernel: RAS: Correctable Errors collector initialized.
 kernel: microcode: CPU0: patch_level=0x0810100b
 kernel: microcode: CPU1: patch_level=0x0810100b
 kernel: microcode: CPU2: patch_level=0x0810100b
 kernel: microcode: CPU3: patch_level=0x0810100b
 kernel: microcode: CPU4: patch_level=0x0810100b
 kernel: microcode: CPU5: patch_level=0x0810100b
 kernel: microcode: CPU6: patch_level=0x0810100b
 kernel: microcode: CPU7: patch_level=0x0810100b
 kernel: microcode: Microcode Update Driver: v2.2.
 kernel: sched_clock: Marking stable (865012097, 524965)->(980596269, -115059207)
 kernel: registered taskstats version 1
 kernel: Loading compiled-in X.509 certificates
 kernel: Loaded X.509 cert 'Build time autogenerated kernel key: ab661ea641a95c0f5645ba64ad792364a3f411ab'
 kernel: zswap: loaded using pool lzo/zbud
 kernel: Key type big_key registered
 kernel:   Magic number: 3:445:498
 kernel: rtc_cmos 00:00: setting system clock to 2019-01-19 20:29:18 UTC (1547929758)
 kernel: nvme nvme0: allocated 38 MiB host memory buffer.
 kernel: mce: [Hardware Error]: Machine check events logged
 kernel: mce: [Hardware Error]: CPU 2: Machine Check: 0 Bank 1: d8200000000a0151
 kernel: mce: [Hardware Error]: TSC 5efe65410 MISC d01b0fff00000000 SYND 4a000000 IPID 100b000000000
 kernel: mce: [Hardware Error]: PROCESSOR 2:810f10 TIME 1547929758 SOCKET 0 APIC 2 microcode 810100b
 kernel:  nvme0n1: p1 p2
 kernel: Freeing unused decrypted memory: 2040K
 kernel: Freeing unused kernel image memory: 1540K
 kernel: Write protecting the kernel read-only data: 18432k
 kernel: Freeing unused kernel image memory: 2016K
 kernel: Freeing unused kernel image memory: 328K
 kernel: x86/mm: Checked W+X mappings: passed, no W+X pages found.
 kernel: Run /init as init process
 kernel: mce: [Hardware Error]: CPU 5: Machine Check: 0 Bank 1: d8200000000a0151
 kernel: mce: [Hardware Error]: TSC 5f588c1d0 MISC d01b0fff00000000 SYND 4a000000 IPID 100b000000000
 kernel: mce: [Hardware Error]: PROCESSOR 2:810f10 TIME 1547929758 SOCKET 0 APIC 5 microcode 810100b
 kernel: i8042: PNP: PS/2 Controller [PNP0303:KBC0,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
 kernel: i8042: Detected active multiplexing controller, rev 1.1
 kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
 kernel: serio: i8042 AUX0 port at 0x60,0x64 irq 12
 kernel: serio: i8042 AUX1 port at 0x60,0x64 irq 12
 kernel: serio: i8042 AUX2 port at 0x60,0x64 irq 12
 kernel: serio: i8042 AUX3 port at 0x60,0x64 irq 12
 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
 kernel: ehci-pci: EHCI PCI platform driver
 kernel: ehci-pci 0000:01:00.4: EHCI Host Controller
 kernel: ehci-pci 0000:01:00.4: new USB bus registered, assigned bus number 1
 kernel: ehci-pci 0000:01:00.4: irq 48, io mem 0xe0a18000
 kernel: SCSI subsystem initialized
 kernel: ehci-pci 0000:01:00.4: USB 0.0 started, EHCI 1.00
 kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.20
 kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 kernel: usb usb1: Product: EHCI Host Controller
 kernel: usb usb1: Manufacturer: Linux 4.20.1-1-MANJARO ehci_hcd
 kernel: usb usb1: SerialNumber: 0000:01:00.4
 kernel: hub 1-0:1.0: USB hub found
 kernel: hub 1-0:1.0: 1 port detected
 kernel: xhci_hcd 0000:04:00.3: xHCI Host Controller
 kernel: xhci_hcd 0000:04:00.3: new USB bus registered, assigned bus number 2
 kernel: xhci_hcd 0000:04:00.3: hcc params 0x0270ffe5 hci version 0x110 quirks 0x0000000840000410
 kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.20
 kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 kernel: usb usb2: Product: xHCI Host Controller
 kernel: usb usb2: Manufacturer: Linux 4.20.1-1-MANJARO xhci-hcd
 kernel: usb usb2: SerialNumber: 0000:04:00.3
 kernel: hub 2-0:1.0: USB hub found
 kernel: hub 2-0:1.0: 4 ports detected
 kernel: libata version 3.00 loaded.
 kernel: xhci_hcd 0000:04:00.3: new USB bus registered, assigned bus number 3
 kernel: xhci_hcd 0000:04:00.3: Host supports USB 3.10 Enhanced SuperSpeed
 kernel: usb usb3: We don't know the algorithms for LPM for this host, disabling LPM.
 kernel: usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.20
 kernel: usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 kernel: usb usb3: Product: xHCI Host Controller
 kernel: usb usb3: Manufacturer: Linux 4.20.1-1-MANJARO xhci-hcd
 kernel: usb usb3: SerialNumber: 0000:04:00.3
 kernel: hub 3-0:1.0: USB hub found
 kernel: hub 3-0:1.0: 4 ports detected
 kernel: xhci_hcd 0000:04:00.4: xHCI Host Controller
 kernel: xhci_hcd 0000:04:00.4: new USB bus registered, assigned bus number 4
 kernel: xhci_hcd 0000:04:00.4: hcc params 0x0260ffe5 hci version 0x110 quirks 0x0000000840000410
 kernel: usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.20
 kernel: usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 kernel: usb usb4: Product: xHCI Host Controller
 kernel: usb usb4: Manufacturer: Linux 4.20.1-1-MANJARO xhci-hcd
 kernel: usb usb4: SerialNumber: 0000:04:00.4
 kernel: hub 4-0:1.0: USB hub found
 kernel: hub 4-0:1.0: 2 ports detected
 kernel: xhci_hcd 0000:04:00.4: new USB bus registered, assigned bus number 5
 kernel: xhci_hcd 0000:04:00.4: Host supports USB 3.10 Enhanced SuperSpeed
 kernel: usb usb5: We don't know the algorithms for LPM for this host, disabling LPM.
 kernel: usb usb5: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.20
 kernel: usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
 kernel: usb usb5: Product: xHCI Host Controller
 kernel: usb usb5: Manufacturer: Linux 4.20.1-1-MANJARO xhci-hcd
 kernel: usb usb5: SerialNumber: 0000:04:00.4
 kernel: hub 5-0:1.0: USB hub found
 kernel: hub 5-0:1.0: 1 port detected
 kernel: ahci 0000:05:00.0: version 3.0
 kernel: ahci 0000:05:00.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
 kernel: ahci 0000:05:00.0: flags: 64bit ncq sntf ilck pm led clo only pmp fbs pio slum part deso sadm sds
 kernel: scsi host0: ahci
 kernel: scsi host1: ahci
 kernel: ata1: SATA max UDMA/133 abar m2048@0xe0200000 port 0xe0200100 irq 67
 kernel: ata2: SATA max UDMA/133 abar m2048@0xe0200000 port 0xe0200180 irq 67
 kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input5
 kernel: usb 4-1: new high-speed USB device number 2 using xhci_hcd
 kernel: ata2: SATA link down (SStatus 0 SControl 300)
 kernel: ata1: SATA link down (SStatus 0 SControl 300)
 kernel: random: fast init done
 kernel: EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Opts: (null)
 kernel: mce: [Hardware Error]: CPU 3: Machine Check: 0 Bank 1: d8200000000a0151
 kernel: mce: [Hardware Error]: TSC 640866742 MISC d01b0fff00000000 SYND 4a000000 IPID 100b000000000
 kernel: mce: [Hardware Error]: PROCESSOR 2:810f10 TIME 1547929759 SOCKET 0 APIC 3 microcode 810100b
 systemd[1]: systemd 239 running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
 kernel: usb 4-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=88.32
 kernel: usb 4-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
 kernel: usb 4-1: Product: USB2.0 Hub
 kernel: tsc: Refined TSC clocksource calibration: 2195.861 MHz
 kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x1fa6ecad510, max_idle_ns: 440795204462 ns
 systemd[1]: Detected architecture x86-64.
 systemd[1]: Set hostname to <manjaro>.
 kernel: hub 4-1:1.0: USB hub found
 kernel: hub 4-1:1.0: 4 ports detected
 kernel: random: systemd: uninitialized urandom read (16 bytes read)
 systemd[1]: Listening on LVM2 metadata daemon socket.
 systemd[1]: Listening on initctl Compatibility Named Pipe.
 systemd[1]: Reached target Remote File Systems.
 systemd[1]: Listening on Journal Socket.
 systemd[1]: Starting Load Kernel Modules...
 systemd[1]: Listening on udev Control Socket.
 systemd[1]: Listening on Process Core Dump Socket.
 kernel: EXT4-fs (nvme0n1p2): re-mounted. Opts: data=ordered
 kernel: audit: type=1130 audit(1547929759.527:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: audit: type=1130 audit(1547929759.530:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=kmod-static-nodes comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: audit: type=1130 audit(1547929759.534:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: audit: type=1130 audit(1547929759.547:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: audit: type=1130 audit(1547929759.547:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: audit: type=1130 audit(1547929759.547:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd-journald[314]: Journal started
 systemd-journald[314]: Runtime journal (/run/log/journal/4bd9ff031c5e4c8792eaf6833a48b541) is 8.0M, max 344.9M, 336.9M free.
 kernel: audit: type=1130 audit(1547929759.570:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=kmod-static-nodes comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: audit: type=1130 audit(1547929759.570:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Starting Flush Journal to Persistent Storage...
 systemd[1]: Started udev Coldplug all Devices.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: audit: type=1130 audit(1547929759.580:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd-journald[314]: Time spent on flushing to /var is 57.427ms for 795 entries.
 systemd-journald[314]: System journal (/var/log/journal/4bd9ff031c5e4c8792eaf6833a48b541) is 88.0M, max 4.0G, 3.9G free.
 kernel: usb 4-2: new high-speed USB device number 3 using xhci_hcd
 kernel: acpi_cpufreq: overriding BIOS provided _PSD data
 kernel: ACPI: AC Adapter [AC] (on-line)
 kernel: input: HP Wireless hotkeys as /devices/virtual/input/input10
 kernel: hidraw: raw HID events driver (C) Jiri Kosina
 kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
 kernel: tpm_tis IFX0763:00: 2.0 TPM (device-id 0x1B, rev-id 16)
 kernel: battery: ACPI: Battery Slot [BAT0] (battery present)
 kernel: IPMI message handler: version 39.2
 kernel: r8168: loading out-of-tree module taints kernel.
 kernel: r8168: module verification failed: signature and/or required key missing - tainting kernel
 kernel: ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B06 (\_SB.PCI0.SMBS.SMBO) (20181003/utaddress-213)
 kernel: ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
 kernel: ipmi device interface
 kernel: sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
 kernel: sp5100-tco sp5100-tco: Using 0xfed80b00 for watchdog MMIO address
 kernel: sp5100-tco sp5100-tco: Watchdog hardware is disabled
 systemd[1]: Started Flush Journal to Persistent Storage.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: ipmi_si: IPMI System Interface driver
 kernel: ipmi_si: Unable to find any System Interface(s)
 kernel: r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
 kernel: r8168 0000:01:00.0: can't disable ASPM; OS doesn't have ASPM control
 kernel: Linux agpgart interface v0.103
 kernel: input: PC Speaker as /devices/platform/pcspkr/input/input11
 systemd[1]: Found device KBG30ZMV256G TOSHIBA 1.
 kernel: r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
 kernel: r8168  Copyright (C) 2017  Realtek NIC software team <nicfae@realtek.com>
                                 This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                                 This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
 systemd-udevd[329]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
 systemd-vconsole-setup[361]: /usr/bin/setfont failed with exit status 66.
 kernel: cryptd: max_cpu_qlen set to 1000
 kernel: ACPI Error: Method parse/execution failed \_SB.WMIV.WMPV, AE_AML_UNINITIALIZED_LOCAL (20181003/psparse-516)
 kernel: usb 4-2: New USB device found, idVendor=04f2, idProduct=b5ee, bcdDevice=92.37
 kernel: usb 4-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
 kernel: usb 4-2: Product: HP HD Camera
 kernel: usb 4-2: Manufacturer: SunplusIT Inc
 systemd-vconsole-setup[361]: Setting source virtual console failed, ignoring remaining ones
 systemd-udevd[328]: Process '/usr/lib/systemd/systemd-vconsole-setup' failed with exit code 1.
 kernel: input: HP WMI hotkeys as /devices/virtual/input/input14
 kernel: AVX2 version of gcm_enc/dec engaged.
 kernel: AES CTR mode by8 optimization enabled
 kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
 kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
 systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
 systemd-udevd[349]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
 kernel: snd_hda_intel 0000:04:00.1: enabling device (0000 -> 0002)
 kernel: snd_hda_intel 0000:04:00.1: Handle vga_switcheroo audio client
 kernel: snd_hda_intel 0000:04:00.6: enabling device (0000 -> 0002)
 kernel: r8168 0000:01:00.0 enp1s0f0: renamed from eth0
 systemd-udevd[333]: Process '/usr/bin/set-wireless-regdom' failed with exit code 1.
 kernel: Intel(R) Wireless WiFi driver for Linux
 kernel: Copyright(c) 2003- 2015 Intel Corporation
 kernel: iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
 kernel: input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input15
 kernel: input: HD-Audio Generic HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input16
 kernel: input: HD-Audio Generic HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input17
 kernel: input: HD-Audio Generic HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:08.1/0000:04:00.1/sound/card0/input18
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Started Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
 systemd[1]: Reached target Local File Systems (Pre).
 kernel: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
 kernel: AMD IOMMUv2 functionality not available on this system
 systemd[1]: Mounting /boot/efi...
 kernel: iwlwifi 0000:02:00.0: loaded firmware version 36.9f0a2d68.0 op_mode iwlmvm
 kernel: snd_hda_codec_conexant hdaudioC1D0: CX8200: BIOS auto-probing.
 systemd[1]: Reached target Sound Card.
 kernel: snd_hda_codec_conexant hdaudioC1D0: autoconfig for CX8200: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
 kernel: snd_hda_codec_conexant hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
 kernel: snd_hda_codec_conexant hdaudioC1D0:    hp_outs=1 (0x1d/0x0/0x0/0x0/0x0)
 kernel: snd_hda_codec_conexant hdaudioC1D0:    mono: mono_out=0x0
 kernel: snd_hda_codec_conexant hdaudioC1D0:    inputs:
 kernel: snd_hda_codec_conexant hdaudioC1D0:      Internal Mic=0x1a
 kernel: snd_hda_codec_conexant hdaudioC1D0:      Mic=0x19
 kernel: usb 4-1.3: new full-speed USB device number 4 using xhci_hcd
 kernel: input: HD-Audio Generic Mic as /devices/pci0000:00/0000:00:08.1/0000:04:00.6/sound/card1/input19
 kernel: input: HD-Audio Generic Headphone as /devices/pci0000:00/0000:00:08.1/0000:04:00.6/sound/card1/input20
 systemd-udevd[343]: Process '/usr/bin/tlp auto' failed with exit code 4.
 kernel: FAT-fs (nvme0n1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
 systemd[1]: Mounted /boot/efi.
 kernel: media: Linux media interface: v0.10
 systemd[1]: Reached target Local File Systems.
 systemd[1]: Starting Create Volatile Files and Directories...
 systemd[1]: Started Create Volatile Files and Directories.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Starting Update UTMP about System Boot/Shutdown...
 audit[466]: SYSTEM_BOOT pid=466 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
 kernel: videodev: Linux video capture interface: v2.00
 systemd[1]: Started Update UTMP about System Boot/Shutdown.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Reached target System Initialization.
 systemd[1]: Listening on D-Bus System Message Bus Socket.
 systemd[1]: Reached target Sockets.
 systemd[1]: Reached target Basic System.
 systemd[1]: Starting Permit User Sessions...
 systemd[1]: Starting Login Service...
 systemd[1]: Starting Mark boot as indeterminate...
 systemd[1]: Started Daily rotation of log files.
 systemd[1]: Started Daily verification of password and group files.
 systemd[1]: Started D-Bus System Message Bus.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Started Daily Cleanup of Temporary Directories.
 systemd[1]: Reached target Timers.
 systemd[1]: Started Permit User Sessions.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Started Mark boot as indeterminate.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=grub-boot-indeterminate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=grub-boot-indeterminate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Reached target Offline System Update (Pre).
 dbus-daemon[486]: dbus[486]: Unknown username "systemd-resolve" in message bus configuration file
 systemd[1]: Started Getty on tty1.
 systemd-logind[478]: New seat seat0.
 dbus-daemon[486]: dbus[486]: Unknown username "systemd-network" in message bus configuration file
 dbus-daemon[486]: dbus[486]: Unknown username "systemd-timesync" in message bus configuration file
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=getty@tty1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Reached target Login Prompts.
 systemd-logind[478]: Watching system buttons on /dev/input/event3 (Power Button)
 kernel: uvcvideo: Found UVC 1.00 device HP HD Camera (04f2:b5ee)
 kernel: iwlwifi 0000:02:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
 kernel: uvcvideo 4-2:1.0: Entity type for entity Extension 4 was not initialized!
 kernel: uvcvideo 4-2:1.0: Entity type for entity Extension 3 was not initialized!
 kernel: uvcvideo 4-2:1.0: Entity type for entity Processing 2 was not initialized!
 kernel: uvcvideo 4-2:1.0: Entity type for entity Camera 1 was not initialized!
 kernel: input: HP HD Camera: HP HD Camera as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb4/4-2/4-2:1.0/input/input21
 kernel: usbcore: registered new interface driver uvcvideo
 kernel: USB Video Class driver (1.1.1)
 kernel: usb 4-1.3: New USB device found, idVendor=138a, idProduct=00ab, bcdDevice= 1.64
 kernel: usb 4-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=1
 kernel: usb 4-1.3: SerialNumber: 9689a40797e0
 kernel: kvm: Nested Virtualization enabled
 kernel: kvm: Nested Paging enabled
 kernel: SVM: Virtual VMLOAD VMSAVE supported
 kernel: SVM: Virtual GIF supported
 kernel: MCE: In-kernel MCE decoding enabled.
 kernel: EDAC amd64: Node 0: DRAM ECC disabled.
 kernel: EDAC amd64: ECC disabled in the BIOS or no ECC capability, module will not load.
                                 Either enable ECC checking or force module loading by setting 'ecc_enable_override'.
                                 (Note that use of the override may cause unknown side effects.)
 kernel: iwlwifi 0000:02:00.0: base HW address: 00:bb:60:6c:ae:da
 systemd-logind[478]: Watching system buttons on /dev/input/event0 (Power Button)
 systemd-logind[478]: Watching system buttons on /dev/input/event2 (Lid Switch)
 systemd-logind[478]: Watching system buttons on /dev/input/event1 (Sleep Button)
 systemd[1]: Starting Load/Save RF Kill Switch Status...
 kernel: [drm] amdgpu kernel modesetting enabled.
 kernel: Parsing CRAT table with 1 nodes
 kernel: Creating topology SYSFS entries
 kernel: Topology: Add APU node [0x0:0x0]
 kernel: Finished initializing topology
 kernel: checking generic (d0000000 300000) vs hw (d0000000 10000000)
 kernel: fb0: switching to amdgpudrmfb from EFI VGA
 kernel: Console: switching to colour dummy device 80x25
 kernel: [drm] initializing kernel modesetting (RAVEN 0x1002:0x15DD 0x103C:0x83D5 0xD0).
 kernel: [drm] register mmio base: 0xE0700000
 kernel: [drm] register mmio size: 524288
 kernel: [drm] add ip block number 0 <soc15_common>
 kernel: [drm] add ip block number 1 <gmc_v9_0>
 kernel: [drm] add ip block number 2 <vega10_ih>
 kernel: [drm] add ip block number 3 <psp>
 kernel: [drm] add ip block number 4 <gfx_v9_0>
 kernel: [drm] add ip block number 5 <sdma_v4_0>
 kernel: [drm] add ip block number 6 <powerplay>
 kernel: [drm] add ip block number 7 <dm>
 kernel: [drm] add ip block number 8 <vcn_v1_0>
 systemd[1]: Started Load/Save RF Kill Switch Status.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: [drm] VCN decode is enabled in VM mode
 kernel: [drm] VCN encode is enabled in VM mode
 kernel: [drm] VCN jpeg decode is enabled in VM mode
 kernel: ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
 kernel: thermal thermal_zone6: failed to read out thermal zone (-61)
 systemd-udevd[328]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
 kernel: iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
 kernel: [drm] BIOS signature incorrect 0 0
 kernel: resource sanity check: requesting [mem 0x000c0000-0x000dffff], which spans more than PCI Bus 0000:00 [mem 0x000c0000-0x000c3fff window]
 kernel: caller pci_map_rom+0x6a/0x1b0 mapping multiple BARs
 kernel: ATOM BIOS: SWBRT32481.001
 kernel: [drm] vm size is 262144 GB, 4 levels, block size is 9-bit, fragment size is 9-bit
 kernel: amdgpu 0000:04:00.0: VRAM: 1024M 0x000000F400000000 - 0x000000F43FFFFFFF (1024M used)
 kernel: amdgpu 0000:04:00.0: GART: 1024M 0x0000000000000000 - 0x000000003FFFFFFF
 kernel: amdgpu 0000:04:00.0: AGP: 267419648M 0x000000F800000000 - 0x0000FFFFFFFFFFFF
 kernel: [drm] Detected VRAM RAM=1024M, BAR=1024M
 kernel: [drm] RAM width 64bits DDR4
 kernel: [TTM] Zone  kernel: Available graphics memory: 3532176 kiB
 kernel: [TTM] Zone   dma32: Available graphics memory: 2097152 kiB
 kernel: [TTM] Initializing pool allocator
 kernel: [TTM] Initializing DMA pool allocator
 kernel: [drm] amdgpu: 1024M of VRAM memory ready
 kernel: [drm] amdgpu: 3072M of GTT memory ready.
 kernel: [drm] GART: num cpu pages 262144, num gpu pages 262144
 kernel: [drm] PCIE GART of 1024M enabled (table at 0x000000F400300000).
 kernel: [drm] use_doorbell being set to: [true]
 kernel: [drm] Found VCN firmware Version: 1.73 Family ID: 18
 kernel: [drm] PSP loading VCN firmware
 kernel: [drm] reserve 0x400000 from 0xf400600000 for PSP TMR SIZE
 systemd-logind[478]: Watching system buttons on /dev/input/event5 (AT Translated Set 2 keyboard)
 kernel: [drm] DM_PPLIB: values for Invalid clock
 kernel: [drm] DM_PPLIB:         400000 in kHz
 kernel: [drm] DM_PPLIB:         933000 in kHz
 kernel: [drm] DM_PPLIB:         1067000 in kHz
 kernel: [drm] DM_PPLIB:         1200000 in kHz
 kernel: [drm] DM_PPLIB:         300000 in kHz
 kernel: [drm] DM_PPLIB:         600000 in kHz
 kernel: [drm] DM_PPLIB:         626000 in kHz
 kernel: [drm] DM_PPLIB:         654000 in kHz
 kernel: [drm] Display Core initialized with v3.1.68!
 kernel: [drm] SADs count is: -2, don't need to read it
 kernel: [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
 kernel: [drm] Driver supports precise vblank timestamp query.
 kernel: [drm] VCN decode and encode initialized successfully(under SPG Mode).
 kernel: kfd kfd: Allocated 3969056 bytes on gart
 kernel: Topology: Add APU node [0x15dd:0x1002]
 kernel: kfd kfd: error getting iommu info. is the iommu enabled?
 kernel: kfd kfd: Error initializing iommuv2
 kernel: kfd kfd: device 1002:15dd NOT added due to errors
 kernel: [drm] fb mappable at 0x90A00000
 kernel: [drm] vram apper at 0x90000000
 kernel: [drm] size 8294400
 kernel: [drm] fb depth is 24
 kernel: [drm]    pitch is 7680
 kernel: fbcon: amdgpudrmfb (fb0) is primary device
 kernel: Console: switching to colour frame buffer device 240x67
 systemd-vconsole-setup[637]: /usr/bin/setfont failed with exit status 66.
 kernel: amdgpu 0000:04:00.0: fb0: amdgpudrmfb frame buffer device
 systemd-vconsole-setup[637]: Setting source virtual console failed, ignoring remaining ones
 systemd-udevd[342]: Process '/usr/lib/systemd/systemd-vconsole-setup' failed with exit code 1.
 systemd[1]: Started Login Service.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Reached target Multi-User System.
 systemd[1]: Reached target Graphical Interface.
 systemd[1]: Startup finished in 8.240s (firmware) + 1.266s (loader) + 1.762s (kernel) + 1.083s (userspace) = 12.352s.
 kernel: amdgpu 0000:04:00.0: ring 0(gfx) uses VM inv eng 4 on hub 0
 kernel: amdgpu 0000:04:00.0: ring 1(comp_1.0.0) uses VM inv eng 5 on hub 0
 kernel: amdgpu 0000:04:00.0: ring 2(comp_1.1.0) uses VM inv eng 6 on hub 0
 kernel: amdgpu 0000:04:00.0: ring 3(comp_1.2.0) uses VM inv eng 7 on hub 0
 kernel: amdgpu 0000:04:00.0: ring 4(comp_1.3.0) uses VM inv eng 8 on hub 0
 kernel: amdgpu 0000:04:00.0: ring 5(comp_1.0.1) uses VM inv eng 9 on hub 0
 kernel: amdgpu 0000:04:00.0: ring 6(comp_1.1.1) uses VM inv eng 10 on hub 0
 kernel: amdgpu 0000:04:00.0: ring 7(comp_1.2.1) uses VM inv eng 11 on hub 0
 kernel: amdgpu 0000:04:00.0: ring 8(comp_1.3.1) uses VM inv eng 12 on hub 0
 kernel: amdgpu 0000:04:00.0: ring 9(kiq_2.1.0) uses VM inv eng 13 on hub 0
 kernel: amdgpu 0000:04:00.0: ring 10(sdma0) uses VM inv eng 4 on hub 1
 kernel: amdgpu 0000:04:00.0: ring 11(vcn_dec) uses VM inv eng 5 on hub 1
 kernel: amdgpu 0000:04:00.0: ring 12(vcn_enc0) uses VM inv eng 6 on hub 1
 kernel: amdgpu 0000:04:00.0: ring 13(vcn_enc1) uses VM inv eng 7 on hub 1
 kernel: amdgpu 0000:04:00.0: ring 14(vcn_jpeg) uses VM inv eng 8 on hub 1
 kernel: [drm] Initialized amdgpu 3.27.0 20150101 for 0000:04:00.0 on minor 0
 systemd[1]: Created slice system-systemd\x2dbacklight.slice.
 systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0...
 systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:acpi_video0...
 systemd-backlight[643]: Failed to get backlight or LED device 'backlight:acpi_video0': No such device
 systemd[1]: systemd-backlight@backlight:acpi_video0.service: Main process exited, code=exited, status=1/FAILURE
 systemd[1]: systemd-backlight@backlight:acpi_video0.service: Failed with result 'exit-code'.
 systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:acpi_video0.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:acpi_video0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
 systemd[1]: Started Load/Save Screen Backlight Brightness of backlight:amdgpu_bl0.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:amdgpu_bl0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: input: PS/2 Generic Mouse as /devices/platform/i8042/serio2/input/input13
 kernel: mousedev: PS/2 mouse device common for all mice
 kernel: input: AlpsPS/2 ALPS GlidePoint as /devices/platform/i8042/serio3/input/input22
 kernel: random: crng init done
 kernel: random: 7 urandom warning(s) missed due to ratelimiting
 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 kernel: kauditd_printk_skb: 14 callbacks suppressed
 kernel: audit: type=1131 audit(1547929765.044:25): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 login[499]: pam_unix(login:session): session opened for user me by LOGIN(uid=0)
 kernel: audit: type=1006 audit(1547929766.104:26): pid=499 uid=0 old-auid=4294967295 auid=1000 tty=tty1 old-ses=4294967295 ses=1 res=1
 systemd[1]: Created slice system-user\x2druntime\x2ddir.slice.
 systemd[1]: Started /run/user/1000 mount wrapper.
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd[1]: Created slice User Slice of UID 1000.
 systemd[1]: Starting User Manager for UID 1000...
 kernel: audit: type=1130 audit(1547929766.114:27): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 systemd-logind[478]: New session 1 of user me.
 systemd[1]: Started Session 1 of user me.
 systemd[653]: pam_unix(systemd-user:session): session opened for user me by (uid=0)
 kernel: audit: type=1006 audit(1547929766.124:28): pid=653 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
 systemd[653]: Listening on GnuPG cryptographic agent (ssh-agent emulation).
 kernel: audit: type=1130 audit(1547929766.164:29): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
 login[499]: LOGIN ON tty1 BY me
 systemd[653]: Listening on GnuPG cryptographic agent and passphrase cache.
 systemd[653]: Starting D-Bus User Message Bus Socket.
 systemd[653]: Listening on p11-kit server.
 systemd[653]: Reached target Paths.
 systemd[653]: Listening on GnuPG cryptographic agent and passphrase cache (restricted).
 systemd[653]: Listening on GnuPG cryptographic agent and passphrase cache (access for web browsers).
 systemd[653]: Started Mark boot as successful after the user session has run 2 minutes.
 systemd[653]: Reached target Timers.
 systemd[653]: Listening on GnuPG network certificate management daemon.
 systemd[653]: Listening on D-Bus User Message Bus Socket.
 systemd[653]: Reached target Sockets.
 systemd[653]: Reached target Basic System.
 systemd[653]: Reached target Default.
 systemd[653]: Startup finished in 31ms.
 systemd[1]: Started User Manager for UID 1000.
The diff between them shows where it’s failing:
 kernel: [drm:amdgpu_get_bios [amdgpu]] *ERROR* Unable to locate a BIOS ROM
 kernel: amdgpu 0000:04:00.0: Fatal error during GPU init
 kernel: [drm] amdgpu: finishing device.
 kernel: amdgpu: probe of 0000:04:00.0 failed with error -22
Versus the successful:
Now… this error is pretty generic… searching online for it shows posts from years before with people encountaring it in different situations. This one might be relevant: https://bugzilla.kernel.org/show_bug.cgi?id=200087
According to the last messages there, gentoo should be able to boot on similar APUs without any parameters, and there is something in the latest kernel (as of 17’th of January) and int the kernel’s .config that allows that. I will keep an eye on that post to see what happens, as installing gentoo is beyond my abilities right now, and the other distribution they mentioned, Calculate Linux, did not manage to boot for me at all.
  • There is a kernel parameter that seems to help a bit: intremap=off. With this one I believe the boot is successful every time, with a CLI install, but only the screen freezes. I assume this because I can now press the shutdown button once and the laptop actually shuts down, instead of needing to hold down that button for multiple seconds to force a shutdown. Also if I blindly type in the username and password to log in and press TAB I hear a beeping sound I normally hear in the tty when I do the same actions with the screan working (and the sound does not play for a random set of keystrokes). So my assumption is that it’s just the pixels that don’t get drawn on the screen now.
Anyway, the only thing that’s left for me now is to contact HP’s support and ask them about those hardware errors that keep popping up in the logs and tty… I have low expectiations from them since I’ve read posts on their forum from other people that bought a simmilar laptop and were trying out linux and nothing resulted.
#58
im really sorry for you :slightly_frowning_face:
have you tried other operating systems on this laptop? what was that like , did any of them work properly?
#59
The laptop came with Windows preinstalled which booted up normally, and I tried installing Ubuntu, Debian, Manjaro and Calculate Linux on it so far, only Manjaro actually managed to boot properly, but only sometimes, the reset just froze every time.
From what I understand this is an issue with Linux in general and the AMD mobile APUs, since simmilar laptops from other vendors also have the problem of not being able to boot. So I doubt switching distros would help… although I’m curious if anybody ever managed to boot a Linux properly on this exact model.
#60
could be that some features are locked to windows os.
have you checked AMD’s forum/support for a solution ?
if nothing helps, search and ask on reddit. :nerd_face:
