Problems with Manjaro Linux on a HP Elitebook 755 G5 with Ryzen 7 and Vega 10
#21
@Newmaz That’s some crazy parameter you got there, I’ll give it a try over the weekend and let you know if it works. The APU might be the same but the BIOS is different between lenovo and hp, but I hope this works.
How do you even debug stuff like this and find solutions?
#22
@sdwolf Let me know, I really do hope it works !
I tested with 4+ O.S. (Fedora, Ubuntu, Debian, ArchLinux and more). I have encounter the same problem each time, my boot process didn’t go further, even from CLI installation. That narrowed the possibilities. From there, I did some research to see if people encountered similar issues as me. And finally, some people from my school helped me out to get through it.
I have not enabled Secure Boot and all the Windows settings are set to off.
*EDIT : (From /etc/default/grub – when installation is done and before rebooting, they modified this line.) GRUB_CMDLINE_LINUX_DEFAULT=“quiet resume=UUID=0b34h567-66c4-4f8a-913a-0700c1a610f9 ivrs_ioapic[32]=00:14.0”
#23
@Newmaz Unfortunately ivrs_ioapic[32]=00:14.0 did not do anything for me.
But I managed to progress, found from https://www.reddit.com/r/Hewlett_Packard/comments/9jjndg/elitebook_745_g5_wont_install_linux/ and https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1796443 that adding mce=off allows me to boot with BIOS version 01.03.01.
Here are my kernel parameters so far:
iommu=soft mce=off acpi=strict processor.max_cstate=5 idle=nomwait
With these I managed to install XFCE from an USB, switched to testing branch and installed the latest kernel (4.19.6).
I still get freezes at startup, yet they are less frequent now.
One thing that I notice, every time it freezez I have this error in systemd logs:
ACPI Error: Method parse/execution failed \_SB.WMIV.WMPV, AE_AML_UNINITIALIZED_LOCAL (20180810/psparse-516)
I don’t know if it’s indeed the true cause since I see it in journalctl even for successful boots, but I definitely don’t see that during the boot itself.
Vega 64 installation problems
#24
@sdwolf I will have to look at what those command does. I have no clue what could cause that type of issues. If you find an answer, keep me up-to-date, I would like to know.
*EDIT : I have found that command on a french website (https://debian-facile.org/viewtopic.php?id=17677), try that out : dmidecode -t bios. I do see that ACPI is supported on my side.
Characteristics:
PCI is supported
PNP is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
EDD is supported
3.5"/720 kB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
UEFI is supported
#25
Here is my dmidecode -t bios:
# dmidecode 3.2
Getting SMBIOS data from sysfs.
SMBIOS 3.1.0 present.
Handle 0x000F, DMI type 0, 26 bytes
BIOS Information
        Vendor: HP
        Version: Q81 Ver. 01.03.01
        Release Date: 07/26/2018
        Address: 0xF0000
        Runtime Size: 64 kB
        ROM Size: 16 MB
        Characteristics:
                PCI is supported
                PC Card (PCMCIA) is supported
                BIOS is upgradeable
                EDD is supported
                ACPI is supported
                Function key-initiated network boot is supported
                UEFI is supported
        BIOS Revision: 3.1
        Firmware Revision: 8.71
Handle 0x0014, DMI type 13, 22 bytes
BIOS Language Information
        Language Description Format: Abbreviated
        Installable Languages: 14
                enUS
                deDE
                esES
                itIT
                frFR
                jaJA
                ptPT
                daDA
                svSV
                nlBE
                noNO
                fiFI
                zhCN
                zhTW
        Currently Installed Language: enUS
Also dmesg | grep "ACPI Error":
[    0.556894] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20180810/psobject-221)
[    0.556898] ACPI Error: Ignore error and continue table load (20180810/psobject-604)
[    0.556902] ACPI Error: Skip parsing opcode Scope (20180810/psloop-543)
[    0.800169] ACPI Error: AE_AML_PACKAGE_LIMIT, Index (0x000000005) is beyond end of object (length 0x5) (20180810/exoparg2-396)
[    0.800215] ACPI Error: Method parse/execution failed \_TZ.GETP, AE_AML_PACKAGE_LIMIT (20180810/psparse-516)
[    0.800247] ACPI Error: Method parse/execution failed \_TZ.CHGZ._CRT, AE_AML_PACKAGE_LIMIT (20180810/psparse-516)
[    0.801633] ACPI Error: AE_AML_PACKAGE_LIMIT, Index (0x000000005) is beyond end of object (length 0x5) (20180810/exoparg2-396)
[    0.801682] ACPI Error: Method parse/execution failed \_TZ.GTTP, AE_AML_PACKAGE_LIMIT (20180810/psparse-516)
[    0.801713] ACPI Error: Method parse/execution failed \_TZ.CHGZ._TMP, AE_AML_PACKAGE_LIMIT (20180810/psparse-516)
[    0.801762] ACPI Error: AE_AML_PACKAGE_LIMIT, Index (0x000000005) is beyond end of object (length 0x5) (20180810/exoparg2-396)
[    0.801798] ACPI Error: Method parse/execution failed \_TZ.GETP, AE_AML_PACKAGE_LIMIT (20180810/psparse-516)
[    0.801829] ACPI Error: Method parse/execution failed \_TZ.CHGZ._CRT, AE_AML_PACKAGE_LIMIT (20180810/psparse-516)
[    2.215544] ACPI Error: Method parse/execution failed \_SB.WMIV.WMPV, AE_AML_UNINITIALIZED_LOCAL (20180810/psparse-516)
[    2.220719] ACPI Error: Method parse/execution failed \_SB.WMIV.WMPV, AE_AML_UNINITIALIZED_LOCAL (20180810/psparse-516)
[    2.225929] ACPI Error: Method parse/execution failed \_SB.WMIV.WMPV, AE_AML_UNINITIALIZED_LOCAL (20180810/psparse-516)
[    2.292646] ACPI Error: Method parse/execution failed \_SB.WMIV.WMPV, AE_AML_UNINITIALIZED_LOCAL (20180810/psparse-516)
ACPI might be supported but is sure is buggy.
#26
With further research, some says that it’s a BIOS bug that has been around since 4.9 kernel. On a forum, they added that line to their grub and apparently, it fixes the bug : libata.noacpi=1. Therefore, they say that it disabled the kernel warning for that particular issue.
https://forums.archlinux.fr/viewtopic.php?t=18872
https://bbs.archlinux.org/viewtopic.php?id=223804
#27
Any updates ?
#28
i see HP and their BIOS shenanigans are still going strong.
had some issues myself a few years back with a HP notebook, no working wifi, so i installed all sorts of drivers but still nothing, i was advised to get a newer bios so i updated the bios which made my cpu speed drop when it got to hot, then i installed linux to try and see whats up with my wifi and still nothing, later i took it apart and guess what… i dont even have wifi, but the model clearly says WITH WIFI, even has a dedicated button for it.
online support was not possible since i did not register my device with them(and give them phone numbers, name, address, email , place of work, what i use it for, etc, they were asking for everything exept my passwords), and it was an enterprise series, not personal.
and the store i bought it from refused me servising it, reason? i had unauthorized upgrade in another store (just added more RAM), 2 years later that store closed.
so they sold me a notebook with a dud wifi, and from what i read, there were about 300,000 units sold, that had the same issue, mostly in developing countries.
oh did i mention i payed about 700 euros for it ?
#29
I do not know where you bought it from, but I do not think HP has the right to refuse serving you based on that. Anyway, I had a nightmare scenario with MSI too. Some keys from my keyboard stopped working out of nowhere. They told me I had to send my pc and wait around a month. All the fees were on me. If the computer gets broken during transport, all my fault. I’ve never seen that type of customer service in my life. I had an issue with a laptop once, the company took care of everything.
#30
No progress unfortunately, I’m on 4.19.8-2 testing branch. Still not able to get to lightdm every time.
But when I do, everything is fine, I can watch videos, play steam games without a problem, no unusual fan activity, USBs and wireless mouse work OK, and apart for some abstract art for a fraction of a second right after I transition from login screen to desktop I see no glitches.
Also note, restoring from hibernate seems to work past the issue (although it happened once that I could not restore, but all the other times it worked).
#31
Actually I do have an update!
According to this comment: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1796443/comments/16 the mce problem has been fixed in the latest kernels. So I removed mce=off from the kernel parameters and now I can actually boot with the 01.03.01 bios version.
That’s one problem down, may still to go.
Current kernel parameters look like this:
iommu=soft acpi=strict processor.max_cstate=5 idle=nomwait
Still have ACPI Errors:
Dec 11 22:44:57 my-pc kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20180810/psobject-221)
Dec 11 22:44:57 my-pc kernel: ACPI Error: Ignore error and continue table load (20180810/psobject-604)
Dec 11 22:44:57 my-pc kernel: ACPI Error: Skip parsing opcode Scope (20180810/psloop-543)
Dec 11 22:44:57 my-pc kernel: ACPI Error: AE_AML_PACKAGE_LIMIT, Index (0x000000005) is beyond end of object (length 0x5) (20180810/exoparg2-396)
Dec 11 22:44:57 my-pc kernel: ACPI Error: Method parse/execution failed \_TZ.GETP, AE_AML_PACKAGE_LIMIT (20180810/psparse-516)
Dec 11 22:44:57 my-pc kernel: ACPI Error: Method parse/execution failed \_TZ.CHGZ._CRT, AE_AML_PACKAGE_LIMIT (20180810/psparse-516)
Dec 11 22:44:57 my-pc kernel: ACPI Error: Method parse/execution failed \_TZ.GTTP, AE_AML_PACKAGE_LIMIT (20180810/psparse-516)
Dec 11 22:44:57 my-pc kernel: ACPI Error: Method parse/execution failed \_TZ.CHGZ._TMP, AE_AML_PACKAGE_LIMIT (20180810/psparse-516)
Dec 11 22:44:57 my-pc kernel: ACPI Error: Method parse/execution failed \_SB.WMIV.WMPV, AE_AML_UNINITIALIZED_LOCAL (20180810/psparse-516)
#32
I tried removing all kernel parameters to see what’s happening now and it looks like the success rate improved a bit…
Anyway I noticed a weird error right before systemd’s output begins (before there was mce’s error and now it looks like it’s ACPI related.
Here’s the output of journalctl -b -1 | grep "ACPI"
Dec 11 22:56:57 my-pc kernel: BIOS-e820: [mem 0x0000000004000000-0x0000000004009fff] ACPI NVS
Dec 11 22:56:57 my-pc kernel: BIOS-e820: [mem 0x000000007ac80000-0x000000007b37ffff] ACPI NVS
Dec 11 22:56:57 my-pc kernel: BIOS-e820: [mem 0x000000007b380000-0x000000007b3fffff] ACPI data
Dec 11 22:56:57 my-pc kernel: efi:  ACPI=0x7b3ff000  ACPI 2.0=0x7b3ff014  SMBIOS=0x7a57b000  SMBIOS 3.0=0x7a579000  ESRT=0x777f5f18  MEMATTR=0x7697a018
Dec 11 22:56:57 my-pc kernel: ACPI: Early table checksum verification disabled
Dec 11 22:56:57 my-pc kernel: ACPI: RSDP 0x000000007B3FF014 000024 (v02 HPQOEM)
Dec 11 22:56:57 my-pc kernel: ACPI: XSDT 0x000000007B3D2188 0000FC (v01 HPQOEM SLIC-BPC 00000001      01000013)
Dec 11 22:56:57 my-pc kernel: ACPI: FACP 0x000000007B3EC000 00010C (v05 HPQOEM SLIC-BPC 00000001 HP   00000001)
Dec 11 22:56:57 my-pc kernel: ACPI: DSDT 0x000000007B3D4000 010625 (v02 HPQOEM 83D5     00000000 INTL 20160527)
Dec 11 22:56:57 my-pc kernel: ACPI: FACS 0x000000007B2C6000 000040
Dec 11 22:56:57 my-pc kernel: ACPI: SSDT 0x000000007B3FC000 00012A (v02 HP     ShmTable 00000001 INTL 20160527)
Dec 11 22:56:57 my-pc kernel: ACPI: SSDT 0x000000007B3F6000 00533D (v02 AMD    AmdTable 00000002 MSFT 02000002)
Dec 11 22:56:57 my-pc kernel: ACPI: SSDT 0x000000007B3F4000 00119C (v01 AMD    AMD CPU  00000001 AMD  00000001)
Dec 11 22:56:57 my-pc kernel: ACPI: CRAT 0x000000007B3F3000 000810 (v01 AMD    AMD CRAT 00000001 AMD  00000001)
Dec 11 22:56:57 my-pc kernel: ACPI: CDIT 0x000000007B3F2000 000029 (v01 AMD    AMD CDIT 00000001 AMD  00000001)
Dec 11 22:56:57 my-pc kernel: ACPI: UEFI 0x000000007B2E3000 000042 (v01 HPQOEM EDK2     00000002      01000013)
Dec 11 22:56:57 my-pc kernel: ACPI: SSDT 0x000000007B3F1000 000ECA (v02 HP     UcsiAcpi 00000001 INTL 20160527)
Dec 11 22:56:57 my-pc kernel: ACPI: SSDT 0x000000007B3F0000 0000FB (v02 HP     UcsiCntr 00000001 INTL 20160527)
Dec 11 22:56:57 my-pc kernel: ACPI: RTMA 0x000000007B3EF000 00009E (v01 HP     _HBMART_ 00001000 HP   00000001)
Dec 11 22:56:57 my-pc kernel: ACPI: SSDT 0x000000007B3EE000 0003C8 (v02 HPQOEM Tpm2Tabl 00001000 INTL 20160527)
Dec 11 22:56:57 my-pc kernel: ACPI: TPM2 0x000000007B3ED000 000034 (v03 HPQOEM EDK2     00000002      01000013)
Dec 11 22:56:57 my-pc kernel: ACPI: ASF! 0x000000007B3EB000 00006E (v32 HPQOEM 83D5     00000001 HP   00000001)
Dec 11 22:56:57 my-pc kernel: ACPI: MSDM 0x000000007B3EA000 000055 (v03 HPQOEM SLIC-BPC 00000000 HP   00000001)
Dec 11 22:56:57 my-pc kernel: ACPI: SLIC 0x000000007B3E9000 000176 (v01 HPQOEM SLIC-BPC 00000001 HP   00000001)
Dec 11 22:56:57 my-pc kernel: ACPI: WSMT 0x000000007B3E8000 000028 (v01 HPQOEM 83D5     00000001 HP   00000001)
Dec 11 22:56:57 my-pc kernel: ACPI: HPET 0x000000007B3E7000 000038 (v01 HPQOEM 83D5     00000001 HP   00000001)
Dec 11 22:56:57 my-pc kernel: ACPI: APIC 0x000000007B3E6000 000138 (v02 HPQOEM 83D5     00000001 HP   00000001)
Dec 11 22:56:57 my-pc kernel: ACPI: MCFG 0x000000007B3E5000 00003C (v01 HPQOEM 83D5     00000001 HP   00000001)
Dec 11 22:56:57 my-pc kernel: ACPI: IVRS 0x000000007B3FE000 0000D0 (v02 AMD    AMD IVRS 00000001 AMD  00000000)
Dec 11 22:56:57 my-pc kernel: ACPI: SSDT 0x000000007B3D1000 000884 (v01 HP     HPADNBWL 00001000 INTL 20160527)
Dec 11 22:56:57 my-pc kernel: ACPI: SSDT 0x000000007B3D0000 000032 (v01 HP     HPCONDEV 00001000 INTL 20160527)
Dec 11 22:56:57 my-pc kernel: ACPI: SSDT 0x000000007B3D3000 0008CB (v01 AMD    AmdTable 00000001 INTL 20160527)
Dec 11 22:56:57 my-pc kernel: ACPI: FPDT 0x000000007B3CF000 000044 (v01 HPQOEM EDK2     00000002      01000013)
Dec 11 22:56:57 my-pc kernel: ACPI: SSDT 0x000000007B3CD000 001B93 (v01 AMD    AmdTable 00000001 INTL 20160527)
Dec 11 22:56:57 my-pc kernel: ACPI: BGRT 0x000000007B3CC000 000038 (v01 HPQOEM EDK2     00000002      01000013)
Dec 11 22:56:57 my-pc kernel: ACPI: SSDT 0x000000007B3FD000 0002F9 (v02 HP     PwrCtlEv 00000001 INTL 20160527)
Dec 11 22:56:57 my-pc kernel: ACPI: Local APIC address 0xfee00000
Dec 11 22:56:57 my-pc kernel: ACPI: PM-Timer IO Port: 0x408
Dec 11 22:56:57 my-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
Dec 11 22:56:57 my-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Dec 11 22:56:57 my-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
Dec 11 22:56:57 my-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
Dec 11 22:56:57 my-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
Dec 11 22:56:57 my-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
Dec 11 22:56:57 my-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
Dec 11 22:56:57 my-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
Dec 11 22:56:57 my-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
Dec 11 22:56:57 my-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x09] high edge lint[0x1])
Dec 11 22:56:57 my-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x0a] high edge lint[0x1])
Dec 11 22:56:57 my-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x0b] high edge lint[0x1])
Dec 11 22:56:57 my-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x0c] high edge lint[0x1])
Dec 11 22:56:57 my-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x0d] high edge lint[0x1])
Dec 11 22:56:57 my-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x0e] high edge lint[0x1])
Dec 11 22:56:57 my-pc kernel: ACPI: LAPIC_NMI (acpi_id[0x0f] high edge lint[0x1])
Dec 11 22:56:57 my-pc kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Dec 11 22:56:57 my-pc kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
Dec 11 22:56:57 my-pc kernel: ACPI: IRQ0 used by override.
Dec 11 22:56:57 my-pc kernel: ACPI: IRQ9 used by override.
Dec 11 22:56:57 my-pc kernel: Using ACPI (MADT) for SMP configuration information
Dec 11 22:56:57 my-pc kernel: ACPI: HPET id: 0x10228210 base: 0xfed00000
Dec 11 22:56:57 my-pc kernel: ACPI: Core revision 20180810
Dec 11 22:56:57 my-pc kernel: PM: Registering ACPI NVS region [mem 0x04000000-0x04009fff] (40960 bytes)
Dec 11 22:56:57 my-pc kernel: PM: Registering ACPI NVS region [mem 0x7ac80000-0x7b37ffff] (7340032 bytes)
Dec 11 22:56:57 my-pc kernel: ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
Dec 11 22:56:57 my-pc kernel: ACPI: bus type PCI registered
Dec 11 22:56:57 my-pc kernel: acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
Dec 11 22:56:57 my-pc kernel: ACPI: Added _OSI(Module Device)
Dec 11 22:56:57 my-pc kernel: ACPI: Added _OSI(Processor Device)
Dec 11 22:56:57 my-pc kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
Dec 11 22:56:57 my-pc kernel: ACPI: Added _OSI(Processor Aggregator Device)
Dec 11 22:56:57 my-pc kernel: ACPI: Added _OSI(Linux-Dell-Video)
Dec 11 22:56:57 my-pc kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
Dec 11 22:56:57 my-pc kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Dec 11 22:56:57 my-pc kernel: ACPI BIOS Error (bug): Could not resolve [\_SB.PCI0.LPC0.EC0], AE_NOT_FOUND (20180810/dswload2-160)
Dec 11 22:56:57 my-pc kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20180810/psobject-221)
Dec 11 22:56:57 my-pc kernel: ACPI Error: Ignore error and continue table load (20180810/psobject-604)
Dec 11 22:56:57 my-pc kernel: ACPI Error: Skip parsing opcode Scope (20180810/psloop-543)
Dec 11 22:56:57 my-pc kernel: ACPI: 12 ACPI AML tables successfully acquired and loaded
Dec 11 22:56:57 my-pc kernel: ACPI: EC: EC started
Dec 11 22:56:57 my-pc kernel: ACPI: EC: interrupt blocked
Dec 11 22:56:57 my-pc kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: Used as first EC
Dec 11 22:56:57 my-pc kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x3, EC_CMD/EC_SC=0x66, EC_DATA=0x62
Dec 11 22:56:57 my-pc kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions
Dec 11 22:56:57 my-pc kernel: ACPI: Interpreter enabled
Dec 11 22:56:57 my-pc kernel: ACPI: (supports S0 S1 S3 S4 S5)
Dec 11 22:56:57 my-pc kernel: ACPI: Using IOAPIC for interrupt routing
Dec 11 22:56:57 my-pc kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Dec 11 22:56:57 my-pc kernel: ACPI: Enabled 8 GPEs in block 00 to 1F
Dec 11 22:56:57 my-pc kernel: ACPI: Power Resource [PXP] (off)
Dec 11 22:56:57 my-pc kernel: ACPI: Power Resource [APPR] (off)
Dec 11 22:56:57 my-pc kernel: ACPI: Power Resource [P0ST] (on)
Dec 11 22:56:57 my-pc kernel: ACPI: Power Resource [P3ST] (on)
Dec 11 22:56:57 my-pc kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
Dec 11 22:56:57 my-pc kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 5 6 10 11) *0, disabled.
Dec 11 22:56:57 my-pc kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 5 6 10 11) *0, disabled.
Dec 11 22:56:57 my-pc kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 5 6 10 11) *0, disabled.
Dec 11 22:56:57 my-pc kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 5 6 10 11) *0, disabled.
Dec 11 22:56:57 my-pc kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 5 6 10 11) *0, disabled.
Dec 11 22:56:57 my-pc kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 5 6 10 11) *0, disabled.
Dec 11 22:56:57 my-pc kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 3 5 6 10 11) *0, disabled.
Dec 11 22:56:57 my-pc kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 3 5 6 10 11) *0, disabled.
Dec 11 22:56:57 my-pc kernel: ACPI: EC: interrupt unblocked
Dec 11 22:56:57 my-pc kernel: ACPI: EC: event unblocked
Dec 11 22:56:57 my-pc kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: Used as boot DSDT EC to handle transactions and events
Dec 11 22:56:57 my-pc kernel: ACPI: bus type USB registered
Dec 11 22:56:57 my-pc kernel: PCI: Using ACPI for IRQ routing
Dec 11 22:56:57 my-pc kernel: pnp: PnP ACPI init
Dec 11 22:56:57 my-pc kernel: pnp 00:00: Plug and Play ACPI device, IDs PNP0b00 (active)
Dec 11 22:56:57 my-pc kernel: system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
Dec 11 22:56:57 my-pc kernel: system 00:02: Plug and Play ACPI device, IDs PNP0c01 (active)
Dec 11 22:56:57 my-pc kernel: pnp 00:03: Plug and Play ACPI device, IDs HPQ8002 PNP0303 (active)
Dec 11 22:56:57 my-pc kernel: pnp 00:04: Plug and Play ACPI device, IDs SYN306f SYN0100 SYN0002 PNP0f13 (active)
Dec 11 22:56:57 my-pc kernel: system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
Dec 11 22:56:57 my-pc kernel: system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
Dec 11 22:56:57 my-pc kernel: pnp: PnP ACPI: found 7 devices
Dec 11 22:56:57 my-pc kernel: ACPI: Power Button [PWRB]
Dec 11 22:56:57 my-pc kernel: ACPI: Sleep Button [SLPB]
Dec 11 22:56:57 my-pc kernel: ACPI: Lid Switch [LID]
Dec 11 22:56:57 my-pc kernel: ACPI: Power Button [PWRF]
Dec 11 22:56:57 my-pc kernel: ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
Dec 11 22:56:57 my-pc kernel: ACPI: Thermal Zone [HEPZ] (30 C)
Dec 11 22:56:57 my-pc kernel: ACPI: Thermal Zone [CPUZ] (0 C)
Dec 11 22:56:57 my-pc kernel: ACPI: Thermal Zone [GFXZ] (0 C)
Dec 11 22:56:57 my-pc kernel: ACPI: Thermal Zone [EXTZ] (38 C)
Dec 11 22:56:57 my-pc kernel: ACPI: Thermal Zone [LOCZ] (42 C)
Dec 11 22:56:57 my-pc kernel: ACPI: Thermal Zone [BATZ] (31 C)
Dec 11 22:56:57 my-pc kernel: ACPI Error: AE_AML_PACKAGE_LIMIT, Index (0x000000005) is beyond end of object (length 0x5) (20180810/exoparg2-396)
Dec 11 22:56:57 my-pc kernel: ACPI Error: Method parse/execution failed \_TZ.GETP, AE_AML_PACKAGE_LIMIT (20180810/psparse-516)
Dec 11 22:56:57 my-pc kernel: ACPI Error: Method parse/execution failed \_TZ.CHGZ._CRT, AE_AML_PACKAGE_LIMIT (20180810/psparse-516)
Dec 11 22:56:57 my-pc kernel: ACPI Error: Method parse/execution failed \_TZ.GTTP, AE_AML_PACKAGE_LIMIT (20180810/psparse-516)
Dec 11 22:56:57 my-pc kernel: ACPI Error: Method parse/execution failed \_TZ.CHGZ._TMP, AE_AML_PACKAGE_LIMIT (20180810/psparse-516)
Dec 11 22:56:57 my-pc kernel: ACPI: AC Adapter [AC] (off-line)
Dec 11 22:56:57 my-pc kernel: ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B06 (\_SB.PCI0.SMBS.SMBO) (20180810/utaddress-213)
Dec 11 22:56:57 my-pc kernel: ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
Dec 11 22:56:57 my-pc kernel: battery: ACPI: Battery Slot [BAT0] (battery present)
The interesting bits are:
Not sure if this is the cause of my remaining problems but they look incriminating.
#33
I found some error logs about lightdm/xorg not starting properly when freezes happen:
/var/log/lightdm/lightdm.log.old:
[+0.00s] DEBUG: Logging to /var/log/lightdm/lightdm.log
[+0.00s] DEBUG: Starting Light Display Manager 1.28.0, UID=0 PID=760
[+0.00s] DEBUG: Loading configuration dirs from /usr/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration dirs from /usr/local/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration dirs from /etc/xdg/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration from /etc/lightdm/lightdm.conf[+0.00s] DEBUG: Registered seat module local
[+0.00s] DEBUG: Registered seat module xremote
[+0.00s] DEBUG: Registered seat module unity
[+0.00s] DEBUG: Using D-Bus name org.freedesktop.DisplayManager
[+0.01s] DEBUG: Monitoring logind for seats
[+0.01s] DEBUG: New seat added from logind: seat0
[+0.01s] DEBUG: Seat seat0: Loading properties from config section Seat:*
[+0.01s] DEBUG: Seat seat0: Starting
[+0.01s] DEBUG: Seat seat0: Creating greeter session
[+0.01s] DEBUG: Seat seat0: Creating display server of type x
[+0.01s] DEBUG: posix_spawn avoided (fd close requested)
[+0.01s] DEBUG: Could not run plymouth --ping: Failed to execute child process “plymouth” (No such file or directory)
[+0.01s] DEBUG: Using VT 7
[+0.01s] DEBUG: Seat seat0: Starting local X display on VT 7
[+0.01s] DEBUG: XServer 0: Logging to /var/log/lightdm/x-0.log
[+0.01s] DEBUG: XServer 0: Writing X server authority to /run/lightdm/root/:0
[+0.01s] DEBUG: XServer 0: Launching X Server
[+0.01s] DEBUG: Launching process 766: /usr/bin/X :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
[+0.01s] DEBUG: XServer 0: Waiting for ready signal from X server :0
[+0.01s] DEBUG: Acquired bus name org.freedesktop.DisplayManager
[+0.01s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0
[+0.01s] DEBUG: Loading users from org.freedesktop.Accounts
[+0.01s] DEBUG: User /org/freedesktop/Accounts/User1000 added
[+0.03s] DEBUG: Process 766 exited with return value 1
[+0.03s] DEBUG: XServer 0: X server stopped
[+0.03s] DEBUG: Releasing VT 7
[+0.03s] DEBUG: XServer 0: Removing X server authority /run/lightdm/root/:0
[+0.03s] DEBUG: Seat seat0: Display server stopped
[+0.03s] DEBUG: Seat seat0: Stopping session
[+0.03s] DEBUG: Seat seat0: Session stopped
[+0.03s] DEBUG: Seat seat0: Stopping display server, no sessions require it
[+0.03s] DEBUG: Seat seat0: Stopping; greeter display server failed to start
[+0.03s] DEBUG: Seat seat0: Stopped
[+0.03s] DEBUG: Required seat has stopped
[+0.03s] DEBUG: Stopping display manager
[+0.03s] DEBUG: Display manager stopped
[+0.03s] DEBUG: Stopping daemon
[+0.04s] DEBUG: Exiting with return value 1
/var/log/lightdm/x-0.log.old
X.Org X Server 1.20.3
Build Operating System: Linux Arch Linux
Current Operating System: Linux my-pc 4.19.8-2-MANJARO #1 SMP PREEMPT Sat Dec 8 14:45:36 UTC 2018 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=af6fcf2f-f348-4b66-859e-003f931e18b0 rw resume=UUID=5ed5f99a-e9f1-4897-8e2a-a33b50406c12 iommu=soft acpi=strict processor.max_cstate=5 idle=nomwait
Build Date: 25 October 2018  04:42:32PM
Current version of pixman: 0.36.0
        Before reporting problems, check http://wiki.x.org
Markers: (--) probed, (**) from config file, (==) default setting,
(==) Log file: "/var/log/Xorg.0.log", Time: Mon Dec 17 19:00:36 2018
(==) Using config directory: "/etc/X11/xorg.conf.d"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(EE)
Fatal server error:
(EE) no screens found(EE)
(EE)
Please consult the The X.Org Foundation support
         at http://wiki.x.org
 for help.
(EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
There is also a file /var/log/lightdm/x-1.log.old and compared to it’s counterpart x-1.log it’s missing these lines:
(II) AMDGPU(0): [KMS] Kernel modesetting enabled.
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning:          Unsupported high keycode 372 for name <I372> ignored
>                   X11 cannot support keycodes above 255.
>                   This warning only shows for the first high keycode.
Errors from xkbcomp are not fatal to the X server
(II) AIGLX: Suspending AIGLX clients for VT switch
(II) Server terminated successfully (0). Closing log file.
Here’s the xorg logs from /var/log/Xorg.0.log.old:
[     5.111]
[     5.111] Build Operating System: Linux Arch Linux
[     5.111] Current Operating System: Linux my-pc 4.19.8-2-MANJARO #1 SMP PREEMPT Sat Dec 8 14:45:36 UTC 2018 x86_64
[     5.111] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=af6fcf2f-f348-4b66-859e-003f931e18b0 rw resume=UUID=5ed5f99a-e9f1-4897-8e2a-a33b50406c12 iommu=soft acpi=strict processor.max_cstate=5 idle=nomwait
[     5.111] Build Date: 25 October 2018  04:42:32PM
[     5.111]
[     5.111] Current version of pixman: 0.36.0
[     5.111]    Before reporting problems, check http://wiki.x.org
[     5.111] Markers: (--) probed, (**) from config file, (==) default setting,
[     5.111] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Dec 17 19:00:36 2018
[     5.112] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     5.112] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     5.112] (==) No Layout section.  Using the first Screen section.
[     5.112] (==) No screen section available. Using defaults.
[     5.112] (**) |-->Screen "Default Screen Section" (0)
[     5.112] (**) |   |-->Monitor "<default monitor>"
[     5.112] (==) No monitor specified for screen "Default Screen Section".
[     5.112] (==) Automatically adding devices
[     5.112] (==) Automatically enabling devices
[     5.112] (==) Automatically adding GPU devices
[     5.112] (==) Automatically binding GPU devices
[     5.112] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     5.112] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     5.112]    Entry deleted from font path.
[     5.112] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     5.112] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[     5.112]    (Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[     5.112] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[     5.112]    (Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[     5.112] (==) FontPath set to:
        /usr/share/fonts/misc,
        /usr/share/fonts/TTF
[     5.112] (==) ModulePath set to "/usr/lib/xorg/modules"
[     5.112] (II) The server relies on udev to provide the list of input devices.
[     5.112] (II) Module ABI versions:
[     5.112]    X.Org ANSI C Emulation: 0.4
[     5.112]    X.Org Video Driver: 24.0
[     5.112]    X.Org XInput driver : 24.1
[     5.112]    X.Org Server Extension : 10.0
[     5.113] (++) using VT number 7
[     5.113] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     5.117] (--) PCI:*(4@0:0:0) 1002:15dd:103c:83d5 rev 208, Mem @ 0xd0000000/268435456, 0xe0000000/2097152, 0xe0700000/524288, I/O @ 0x00002000/256, BIOS @ 0x????????/131072
[     5.118] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     5.118] (II) LoadModule: "glx"
[     5.118] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     5.120] (II) Module glx: vendor="X.Org Foundation"
[     5.120]    compiled for 1.20.3, module version = 1.0.0
[     5.120]    ABI class: X.Org Server Extension, version 10.0
[     5.120] (==) Matched ati as autoconfigured driver 0
[     5.120] (==) Matched modesetting as autoconfigured driver 1
[     5.120] (==) Matched fbdev as autoconfigured driver 2
[     5.120] (==) Matched vesa as autoconfigured driver 3
[     5.120] (==) Assigned the driver to the xf86ConfigLayout
[     5.120] (II) LoadModule: "ati"
[     5.120] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[     5.120] (II) Module ati: vendor="X.Org Foundation"
[     5.120]    compiled for 1.20.1, module version = 18.1.0
[     5.120]    Module class: X.Org Video Driver
[     5.120]    ABI class: X.Org Video Driver, version 24.0
[     5.121] (II) LoadModule: "radeon"
[     5.121] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[     5.121] (II) Module radeon: vendor="X.Org Foundation"
[     5.121]    compiled for 1.20.1, module version = 18.1.0
[     5.121]    Module class: X.Org Video Driver
[     5.121]    ABI class: X.Org Video Driver, version 24.0
[     5.121] (II) LoadModule: "modesetting"
[     5.121] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     5.121] (II) Module modesetting: vendor="X.Org Foundation"
[     5.121]    compiled for 1.20.3, module version = 1.20.3
[     5.121] (II) LoadModule: "fbdev"
[     5.122] (WW) Warning, couldn't open module fbdev
[     5.122] (EE) Failed to load module "fbdev" (module does not exist, 0)
[     5.122] (II) LoadModule: "vesa"
[     5.122] (WW) Warning, couldn't open module vesa
[     5.122] (EE) Failed to load module "vesa" (module does not exist, 0)
[     5.122] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
        ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
        ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
        ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
        ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
        ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
        ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
        ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
        ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
        ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
        ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
        ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
        ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
        ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
        ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
        ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
        ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
        ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
        ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
        ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
        ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
        ATI Radeon 9800PRO, ATI Radeon 9800XT,
        ATI Radeon Mobility 9600/9700 (M10/M11),
        ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
        ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
        ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
        ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
        ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
        ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
        ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
        ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
        ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
        ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
        ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
        ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
        ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
        ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
        ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
        ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
        ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
        ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
        ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
        ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
        ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
        ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
        ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
        ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
        ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
        ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
        ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
        ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
        ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
        ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
        ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
        ATI FireGL V3350, ATI Mobility Radeon X1450,
        ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
        ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
        ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
        ATI FireGL V3400, ATI Mobility FireGL V5250,
        ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
        ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
        ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
        ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
        ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
        ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
        ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
        ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
        ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
        ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
        ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
        ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
        AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
        ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
        ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
        ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
        ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
        ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
        ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
        ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
        ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
        ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
        ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
        ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
        ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
        ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
        ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
        ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
        ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
        ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
        ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
        ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
        ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
        ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
        ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
        ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
        ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
        ATI FireGL V3600, ATI Radeon HD 2600 LE,
        ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
        ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
        ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
        ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
        ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
        ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
        ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
        ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
        ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
        ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
        ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
        AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
        AMD Radeon HD 6300 Series Graphics,
        AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
        ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
        AMD Firestream 9350, ATI Radeon HD 5800 Series,
        ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
        ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
        ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
        ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
        REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
        ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
        AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
        AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
        ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
        MULLINS, KAVERI, HAWAII
[     5.123] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     5.124] (EE) open /dev/dri/card0: No such file or directory
[     5.124] (WW) Falling back to old probe method for modesetting
[     5.124] (EE) Screen 0 deleted because of no matching config section.
[     5.124] (II) UnloadModule: "modesetting"
[     5.124] (EE) Device(s) detected, but none match those in the config file.
[     5.124] (EE)
Fatal server error:
[     5.124] (EE) no screens found(EE)
[     5.124] (EE)
 for help.
[     5.124] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[     5.124] (EE)
[     5.124] (EE) Server terminated with error (1). Closing log file.
And here is the logs for a successful run /var/log/Xorg.0.log:
[     3.554]
[     3.554] Build Operating System: Linux Arch Linux
[     3.554] Current Operating System: Linux my-pc 4.19.8-2-MANJARO #1 SMP PREEMPT Sat Dec 8 14:45:36 UTC 2018 x86_64
[     3.554] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=af6fcf2f-f348-4b66-859e-003f931e18b0 rw resume=UUID=5ed5f99a-e9f1-4897-8e2a-a33b50406c12 iommu=soft acpi=strict processor.max_cstate=5 idle=nomwait
[     3.554] Build Date: 25 October 2018  04:42:32PM
[     3.554]
[     3.554] Current version of pixman: 0.36.0
[     3.554]    Before reporting problems, check http://wiki.x.org
[     3.554] Markers: (--) probed, (**) from config file, (==) default setting,
[     3.554] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Dec 17 19:00:57 2018
[     3.555] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     3.555] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     3.556] (==) No Layout section.  Using the first Screen section.
[     3.556] (==) No screen section available. Using defaults.
[     3.556] (**) |-->Screen "Default Screen Section" (0)
[     3.556] (**) |   |-->Monitor "<default monitor>"
[     3.557] (==) No monitor specified for screen "Default Screen Section".
[     3.557] (==) Automatically adding devices
[     3.557] (==) Automatically enabling devices
[     3.557] (==) Automatically adding GPU devices
[     3.557] (==) Automatically binding GPU devices
[     3.557] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     3.559] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     3.559]    Entry deleted from font path.
[     3.559] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     3.559] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[     3.559]    (Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[     3.559] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[     3.559]    (Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[     3.559] (==) FontPath set to:
[     3.559] (==) ModulePath set to "/usr/lib/xorg/modules"
[     3.559] (II) The server relies on udev to provide the list of input devices.
[     3.559] (II) Module ABI versions:
[     3.559]    X.Org ANSI C Emulation: 0.4
[     3.559]    X.Org Video Driver: 24.0
[     3.559]    X.Org XInput driver : 24.1
[     3.559]    X.Org Server Extension : 10.0
[     3.560] (++) using VT number 7
[     3.560] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     3.561] (II) xfree86: Adding drm device (/dev/dri/card0)
[     3.570] (--) PCI:*(4@0:0:0) 1002:15dd:103c:83d5 rev 208, Mem @ 0xd0000000/268435456, 0xe0000000/2097152, 0xe0700000/524288, I/O @ 0x00002000/256, BIOS @ 0x????????/131072
[     3.570] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     3.570] (II) LoadModule: "glx"
[     3.574] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     3.582] (II) Module glx: vendor="X.Org Foundation"
[     3.582]    compiled for 1.20.3, module version = 1.0.0
[     3.582]    ABI class: X.Org Server Extension, version 10.0
[     3.582] (II) Applying OutputClass "AMDgpu" to /dev/dri/card0
[     3.582]    loading driver: amdgpu
[     3.582] (==) Matched amdgpu as autoconfigured driver 0
[     3.582] (==) Matched ati as autoconfigured driver 1
[     3.582] (==) Matched modesetting as autoconfigured driver 2
[     3.582] (==) Matched fbdev as autoconfigured driver 3
[     3.582] (==) Matched vesa as autoconfigured driver 4
[     3.582] (==) Assigned the driver to the xf86ConfigLayout
[     3.582] (II) LoadModule: "amdgpu"
[     3.582] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[     3.585] (II) Module amdgpu: vendor="X.Org Foundation"
[     3.585]    compiled for 1.20.1, module version = 18.1.0
[     3.585]    Module class: X.Org Video Driver
[     3.585]    ABI class: X.Org Video Driver, version 24.0
[     3.585] (II) LoadModule: "ati"
[     3.585] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[     3.585] (II) Module ati: vendor="X.Org Foundation"
[     3.617] (II) LoadModule: "modesetting"
[     3.617] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     3.618] (II) Module modesetting: vendor="X.Org Foundation"
[     3.618]    compiled for 1.20.3, module version = 1.20.3
[     3.618]    Module class: X.Org Video Driver
[     3.618]    ABI class: X.Org Video Driver, version 24.0
[     3.618] (II) LoadModule: "fbdev"
[     3.618] (WW) Warning, couldn't open module fbdev
[     3.618] (EE) Failed to load module "fbdev" (module does not exist, 0)
[     3.618] (II) LoadModule: "vesa"
[     3.618] (WW) Warning, couldn't open module vesa
[     3.618] (EE) Failed to load module "vesa" (module does not exist, 0)
[     3.618] (II) AMDGPU: Driver for AMD Radeon:
        All GPUs supported by the amdgpu kernel driver
[     3.618] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     3.639] (II) AMDGPU(0): [KMS] Kernel modesetting enabled.
[     4.173] (WW) Falling back to old probe method for modesetting
[     4.173] (II) AMDGPU(0): Creating default Display subsection in Screen section
        "Default Screen Section" for depth/fbbpp 24/32
[     4.173] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[     4.173] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[     4.173] (==) AMDGPU(0): Default visual is TrueColor
[     4.174] (==) AMDGPU(0): RGB weight 888
[     4.174] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[     4.174] (--) AMDGPU(0): Chipset: "Unknown AMD Radeon GPU" (ChipID = 0x15dd)
[     4.174] (II) Loading sub module "fb"
[     4.174] (II) LoadModule: "fb"
[     4.174] (II) Loading /usr/lib/xorg/modules/libfb.so
[     4.174] (II) Module fb: vendor="X.Org Foundation"
[     4.174]    compiled for 1.20.3, module version = 1.0.0
[     4.174]    ABI class: X.Org ANSI C Emulation, version 0.4
[     4.174] (II) Loading sub module "dri2"
[     4.174] (II) LoadModule: "dri2"
[     4.174] (II) Module "dri2" already built-in
[     4.356] (II) Loading sub module "glamoregl"
[     4.356] (II) LoadModule: "glamoregl"
[     4.356] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[     4.363] (II) Module glamoregl: vendor="X.Org Foundation"
[     4.363]    compiled for 1.20.3, module version = 1.0.1
[     4.363]    ABI class: X.Org ANSI C Emulation, version 0.4
[     4.383] (II) AMDGPU(0): glamor X acceleration enabled on AMD RAVEN (DRM 3.27.0, 4.19.8-2-MANJARO, LLVM 7.0.0)
[     4.383] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[     4.383] (==) AMDGPU(0): TearFree property default: auto
[     4.383] (II) AMDGPU(0): KMS Pageflipping: enabled
[     4.383] (II) AMDGPU(0): Output eDP has no monitor section
[     4.383] (II) AMDGPU(0): Output DisplayPort-0 has no monitor section
[     4.383] (II) AMDGPU(0): Output DisplayPort-1 has no monitor section
[     4.383] (II) AMDGPU(0): Output DisplayPort-2 has no monitor section
[     4.400] (II) AMDGPU(0): EDID for output eDP
[     4.400] (II) AMDGPU(0): Manufacturer: AUO  Model: 23ed  Serial#: 0
[     4.400] (II) AMDGPU(0): Year: 2016  Week: 0
[     4.400] (II) AMDGPU(0): EDID Version: 1.4
[     4.400] (II) AMDGPU(0): Digital Display Input
[     4.400] (II) AMDGPU(0): 6 bits per channel
[     4.400] (II) AMDGPU(0): Digital interface is DisplayPort
[     4.400] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 34  vert.: 19
[     4.400] (II) AMDGPU(0): Gamma: 2.20
[     4.400] (II) AMDGPU(0): No DPMS capabilities specified
[     4.400] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:2:2
[     4.400] (II) AMDGPU(0): First detailed timing is preferred mode
[     4.400] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[     4.400] (II) AMDGPU(0): Display is continuous-frequency
[     4.400] (II) AMDGPU(0): redX: 0.575 redY: 0.346   greenX: 0.347 greenY: 0.572
[     4.400] (II) AMDGPU(0): blueX: 0.158 blueY: 0.117   whiteX: 0.313 whiteY: 0.329
[     4.400] (II) AMDGPU(0): Manufacturer's mask: 0
[     4.400] (II) AMDGPU(0): Supported detailed timing:
[     4.400] (II) AMDGPU(0): clock: 141.0 MHz   Image Size:  344 x 193 mm
[     4.400] (II) AMDGPU(0): h_active: 1920  h_sync: 2028  h_sync_end 2076 h_blank_end 2086 h_border: 0
[     4.400] (II) AMDGPU(0): v_active: 1080  v_sync: 1090  v_sync_end 1100 v_blanking: 1126 v_border: 0
[     4.400] (II) AMDGPU(0): clock: 94.0 MHz   Image Size:  344 x 193 mm
[     4.400] (II) AMDGPU(0): Unknown vendor-specific block 2
[     4.400] (II) AMDGPU(0): EDID (in hex):
[     4.400] (II) AMDGPU(0):    00ffffffffffff0006afed2300000000
[     4.401] (II) AMDGPU(0):    001a010495221378116e859358589228
[     4.401] (II) AMDGPU(0):    1e505400000001010101010101010101
[     4.401] (II) AMDGPU(0):    010101010101143780a670382e406c30
[     4.401] (II) AMDGPU(0):    aa0058c110000018b82480a670382e40
[     4.401] (II) AMDGPU(0):    6c30aa0058c110000018000000000000
[     4.401] (II) AMDGPU(0):    00000000000000000000000000000002
[     4.401] (II) AMDGPU(0):    001048ff0f3c6e0f16286e2020200033
[     4.401] (II) AMDGPU(0): Printing probed modes for output eDP
[     4.401] (II) AMDGPU(0): Modeline "1920x1080"x60.0  141.00  1920 2028 2076 2086  1080 1090 1100 1126 -hsync -vsync (67.6 kHz eP)
[     4.401] (II) AMDGPU(0): Modeline "1920x1080"x40.0   94.00  1920 2028 2076 2086  1080 1090 1100 1126 -hsync -vsync (45.1 kHz e)
[     4.401] (II) AMDGPU(0): Modeline "1680x1050"x60.0  141.00  1680 2028 2076 2086  1050 1090 1100 1126 -hsync -vsync (67.6 kHz e)
[     4.401] (II) AMDGPU(0): Modeline "1280x1024"x60.0  141.00  1280 2028 2076 2086  1024 1090 1100 1126 -hsync -vsync (67.6 kHz e)
[     4.401] (II) AMDGPU(0): Modeline "1440x900"x60.0  141.00  1440 2028 2076 2086  900 1090 1100 1126 -hsync -vsync (67.6 kHz e)
[     4.401] (II) AMDGPU(0): Modeline "1280x800"x60.0  141.00  1280 2028 2076 2086  800 1090 1100 1126 -hsync -vsync (67.6 kHz e)
[     4.401] (II) AMDGPU(0): Modeline "1280x720"x60.0  141.00  1280 2028 2076 2086  720 1090 1100 1126 -hsync -vsync (67.6 kHz e)
[     4.401] (II) AMDGPU(0): Modeline "1024x768"x60.0  141.00  1024 2028 2076 2086  768 1090 1100 1126 -hsync -vsync (67.6 kHz e)
[     4.401] (II) AMDGPU(0): Modeline "800x600"x60.0  141.00  800 2028 2076 2086  600 1090 1100 1126 -hsync -vsync (67.6 kHz e)
[     4.401] (II) AMDGPU(0): Modeline "640x480"x60.0  141.00  640 2028 2076 2086  480 1090 1100 1126 -hsync -vsync (67.6 kHz e)
[     4.401] (II) AMDGPU(0): EDID for output DisplayPort-0
[     4.401] (II) AMDGPU(0): EDID for output DisplayPort-1
[     4.401] (II) AMDGPU(0): EDID for output DisplayPort-2
[     4.401] (II) AMDGPU(0): Output eDP connected
[     4.401] (II) AMDGPU(0): Output DisplayPort-0 disconnected
[     4.401] (II) AMDGPU(0): Output DisplayPort-1 disconnected
[     4.401] (II) AMDGPU(0): Output DisplayPort-2 disconnected
[     4.401] (II) AMDGPU(0): Using exact sizes for initial modes
[     4.401] (II) AMDGPU(0): Output eDP using initial mode 1920x1080 +0+0
[     4.401] (II) AMDGPU(0): mem size init: gart size :bfba0000 vram size: s:3e794000 visible:3e794000
[     4.401] (==) AMDGPU(0): DPI set to (96, 96)
[     4.401] (==) AMDGPU(0): Using gamma correction (1.0, 1.0, 1.0)
[     4.401] (II) Loading sub module "ramdac"
[     4.401] (II) LoadModule: "ramdac"
[     4.401] (II) Module "ramdac" already built-in
[     4.401] (II) UnloadModule: "modesetting"
[     4.401] (II) Unloading modesetting
[     4.401] (II) AMDGPU(0): [DRI2] Setup complete
[     4.401] (II) AMDGPU(0): [DRI2]   DRI driver: radeonsi
[     4.401] (II) AMDGPU(0): [DRI2]   VDPAU driver: radeonsi
[     4.401] (II) AMDGPU(0): Front buffer pitch: 7680 bytes
[     4.403] (II) AMDGPU(0): SYNC extension fences enabled
[     4.403] (II) AMDGPU(0): Present extension enabled
[     4.403] (==) AMDGPU(0): DRI3 enabled
[     4.403] (==) AMDGPU(0): Backing store enabled
[     4.403] (II) AMDGPU(0): Direct rendering enabled
[     4.410] (II) AMDGPU(0): Use GLAMOR acceleration.
[     4.410] (II) AMDGPU(0): Acceleration enabled
[     4.410] (==) AMDGPU(0): DPMS enabled
[     4.410] (==) AMDGPU(0): Silken mouse disabled
[     4.410] (II) AMDGPU(0): Set up textured video (glamor)
[     4.417] (II) Initializing extension Generic Event Extension
[     4.417] (II) Initializing extension SHAPE
[     4.417] (II) Initializing extension MIT-SHM
[     4.417] (II) Initializing extension XInputExtension
[     4.417] (II) Initializing extension XTEST
[     4.417] (II) Initializing extension BIG-REQUESTS
[     4.418] (II) Initializing extension SYNC
[     4.418] (II) Initializing extension XKEYBOARD
[     4.418] (II) Initializing extension XC-MISC
[     4.418] (II) Initializing extension SECURITY
[     4.418] (II) Initializing extension XFIXES
[     4.418] (II) Initializing extension RENDER
[     4.418] (II) Initializing extension RANDR
[     4.418] (II) Initializing extension COMPOSITE
[     4.418] (II) Initializing extension DAMAGE
[     4.418] (II) Initializing extension MIT-SCREEN-SAVER
[     4.418] (II) Initializing extension DOUBLE-BUFFER
[     4.419] (II) Initializing extension RECORD
[     4.419] (II) Initializing extension DPMS
[     4.419] (II) Initializing extension Present
[     4.419] (II) Initializing extension DRI3
[     4.419] (II) Initializing extension X-Resource
[     4.419] (II) Initializing extension XVideo
[     4.419] (II) Initializing extension XVideo-MotionCompensation
[     4.419] (II) Initializing extension GLX
[     4.423] (II) AIGLX: Loaded and initialized radeonsi
[     4.423] (II) GLX: Initialized DRI2 GL provider for screen 0
[     4.423] (II) Initializing extension XFree86-VidModeExtension
[     4.423] (II) Initializing extension XFree86-DGA
[     4.423] (II) Initializing extension XFree86-DRI
[     4.423] (II) Initializing extension DRI2
[     4.425] (II) AMDGPU(0): Setting screen physical size to 508 x 285
[     4.511] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[     4.511] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     4.511] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     4.511] (**) Power Button: Applying InputClass "system-keyboard"
[     4.511] (II) LoadModule: "libinput"
[     4.511] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[     4.514] (II) Module libinput: vendor="X.Org Foundation"
[     4.514]    compiled for 1.20.1, module version = 0.28.1
[     4.514]    Module class: X.Org XInput Driver
[     4.514]    ABI class: X.Org XInput driver, version 24.1
[     4.514] (II) Using input driver 'libinput' for 'Power Button'
[     4.514] (**) Power Button: always reports core events
[     4.514] (**) Option "Device" "/dev/input/event3"
[     4.514] (**) Option "_source" "server/udev"
[     4.518] (II) event3  - Power Button: is tagged by udev as: Keyboard
[     4.518] (II) event3  - Power Button: device is a keyboard
[     4.518] (II) event3  - Power Button: device removed
[     4.545] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[     4.545] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[     4.545] (**) Option "xkb_model" "pc105"
[     4.545] (**) Option "xkb_layout" "gb"
[     4.566] (II) event3  - Power Button: is tagged by udev as: Keyboard
[     4.566] (II) event3  - Power Button: device is a keyboard
[     4.566] (II) config/udev: Adding input device Video Bus (/dev/input/event4)
[     4.566] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[     4.566] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[     4.566] (**) Video Bus: Applying InputClass "system-keyboard"
[     4.566] (II) Using input driver 'libinput' for 'Video Bus'
[     4.566] (**) Video Bus: always reports core events
[     4.567] (**) Option "Device" "/dev/input/event4"
[     4.567] (**) Option "_source" "server/udev"
[     4.567] (II) event4  - Video Bus: is tagged by udev as: Keyboard
[     4.567] (II) event4  - Video Bus: device is a keyboard
[     4.567] (II) event4  - Video Bus: device removed
[     4.651] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:09/LNXVIDEO:00/input/input4/event4"
[     4.651] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[     4.651] (**) Option "xkb_model" "pc105"
[     4.651] (**) Option "xkb_layout" "gb"
[     4.652] (II) event4  - Video Bus: is tagged by udev as: Keyboard
[     4.652] (II) event4  - Video Bus: device is a keyboard
[     4.653] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[     4.653] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[     4.653] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[     4.653] (**) Power Button: Applying InputClass "system-keyboard"
[     4.653] (II) Using input driver 'libinput' for 'Power Button'
[     4.653] (**) Power Button: always reports core events
[     4.653] (**) Option "Device" "/dev/input/event0"
[     4.653] (**) Option "_source" "server/udev"
[     4.653] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     4.653] (II) event0  - Power Button: device is a keyboard
[     4.653] (II) event0  - Power Button: device removed
[     4.678] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[     4.678] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[     4.678] (**) Option "xkb_model" "pc105"
[     4.678] (**) Option "xkb_layout" "gb"
[     4.679] (II) event0  - Power Button: is tagged by udev as: Keyboard
[     4.679] (II) event0  - Power Button: device is a keyboard
[     4.680] (II) config/udev: Adding input device Lid Switch (/dev/input/event2)
[     4.680] (II) No input driver specified, ignoring this device.
[     4.680] (II) This device may have been added with another device file.
[     4.680] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[     4.680] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[     4.680] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[     4.680] (**) Sleep Button: Applying InputClass "system-keyboard"
[     4.680] (II) Using input driver 'libinput' for 'Sleep Button'
[     4.680] (**) Sleep Button: always reports core events
[     4.680] (**) Option "Device" "/dev/input/event1"
[     4.680] (**) Option "_source" "server/udev"
[     4.681] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[     4.681] (II) event1  - Sleep Button: device is a keyboard
[     4.681] (II) event1  - Sleep Button: device removed
[     4.704] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[     4.704] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[     4.704] (**) Option "xkb_model" "pc105"
[     4.704] (**) Option "xkb_layout" "gb"
[     4.705] (II) event1  - Sleep Button: is tagged by udev as: Keyboard
[     4.705] (II) event1  - Sleep Button: device is a keyboard
[     4.706] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=3 (/dev/input/event9)
[     4.706] (II) No input driver specified, ignoring this device.
[     4.706] (II) This device may have been added with another device file.
[     4.706] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=7 (/dev/input/event10)
[     4.706] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=8 (/dev/input/event11)
[     4.707] (II) config/udev: Adding input device HD-Audio Generic HDMI/DP,pcm=9 (/dev/input/event12)
[     4.707] (II) No input driver specified, ignoring this device.
[     4.707] (II) This device may have been added with another device file.
[     4.707] (II) config/udev: Adding input device 2.4G Mouse (/dev/input/event15)
[     4.708] (II) config/udev: Adding input device 2.4G Mouse Mouse (/dev/input/event16)
[     4.708] (**) 2.4G Mouse Mouse: Applying InputClass "evdev pointer catchall"
[     4.708] (**) 2.4G Mouse Mouse: Applying InputClass "libinput pointer catchall"
[     4.708] (II) Using input driver 'libinput' for '2.4G Mouse Mouse'
[     4.708] (**) 2.4G Mouse Mouse: always reports core events
[     4.708] (**) Option "Device" "/dev/input/event16"
[     4.708] (**) Option "_source" "server/udev"
[     4.766] (II) event16 - 2.4G Mouse Mouse: is tagged by udev as: Mouse
[     4.766] (II) event16 - 2.4G Mouse Mouse: device is a pointer
[     4.766] (II) event16 - 2.4G Mouse Mouse: device removed
[     4.824] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb2/2-2/2-2:1.0/0003:1EA7:0064.0001/input/input22/event16"
[     4.824] (II) XINPUT: Adding extended input device "2.4G Mouse Mouse" (type: MOUSE, id 10)
[     4.824] (**) Option "AccelerationScheme" "none"
[     4.824] (**) 2.4G Mouse Mouse: (accel) selected scheme none/0
[     4.824] (**) 2.4G Mouse Mouse: (accel) acceleration factor: 2.000
[     4.824] (**) 2.4G Mouse Mouse: (accel) acceleration threshold: 4
[     4.882] (II) event16 - 2.4G Mouse Mouse: is tagged by udev as: Mouse
[     4.882] (II) event16 - 2.4G Mouse Mouse: device is a pointer
[     4.883] (II) config/udev: Adding input device 2.4G Mouse Mouse (/dev/input/mouse0)
[     4.883] (II) No input driver specified, ignoring this device.
[     4.883] (II) This device may have been added with another device file.
[     4.884] (II) config/udev: Adding input device HP HD Camera: HP HD Camera (/dev/input/event17)
[     4.884] (**) HP HD Camera: HP HD Camera: Applying InputClass "evdev keyboard catchall"
[     4.884] (**) HP HD Camera: HP HD Camera: Applying InputClass "libinput keyboard catchall"
[     4.884] (**) HP HD Camera: HP HD Camera: Applying InputClass "system-keyboard"
[     4.884] (II) Using input driver 'libinput' for 'HP HD Camera: HP HD Camera'
[     4.884] (**) HP HD Camera: HP HD Camera: always reports core events
[     4.885] (**) Option "Device" "/dev/input/event17"
[     4.885] (**) Option "_source" "server/udev"
[     4.886] (II) event17 - HP HD Camera: HP HD Camera: is tagged by udev as: Keyboard
[     4.886] (II) event17 - HP HD Camera: HP HD Camera: device is a keyboard
[     4.886] (II) event17 - HP HD Camera: HP HD Camera: device removed
[     4.944] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb4/4-2/4-2:1.0/input/input23/event17"
[     4.944] (II) XINPUT: Adding extended input device "HP HD Camera: HP HD Camera" (type: KEYBOARD, id 11)
[     4.944] (**) Option "xkb_model" "pc105"
[     4.944] (**) Option "xkb_layout" "gb"
[     4.946] (II) event17 - HP HD Camera: HP HD Camera: is tagged by udev as: Keyboard
[     4.946] (II) event17 - HP HD Camera: HP HD Camera: device is a keyboard
[     4.947] (II) config/udev: Adding input device HD-Audio Generic Mic (/dev/input/event13)
[     4.947] (II) No input driver specified, ignoring this device.
[     4.947] (II) This device may have been added with another device file.
[     4.947] (II) config/udev: Adding input device HD-Audio Generic Headphone (/dev/input/event14)
[     4.948] (II) No input driver specified, ignoring this device.
[     4.948] (II) This device may have been added with another device file.
[     4.948] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event5)
[     4.948] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[     4.948] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[     4.948] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[     4.948] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[     4.948] (**) AT Translated Set 2 keyboard: always reports core events
[     4.948] (**) Option "Device" "/dev/input/event5"
[     4.948] (**) Option "_source" "server/udev"
[     4.949] (II) event5  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[     4.949] (II) event5  - AT Translated Set 2 keyboard: device is a keyboard
[     4.950] (II) event5  - AT Translated Set 2 keyboard: device removed
[     4.984] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input5/event5"
[     4.984] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 12)
[     4.984] (**) Option "xkb_model" "pc105"
[     4.984] (**) Option "xkb_layout" "gb"
[     4.985] (II) event5  - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[     4.985] (II) event5  - AT Translated Set 2 keyboard: device is a keyboard
[     4.986] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/event18)
[     4.986] (**) PS/2 Generic Mouse: Applying InputClass "evdev pointer catchall"
[     4.986] (**) PS/2 Generic Mouse: Applying InputClass "libinput pointer catchall"
[     4.986] (II) Using input driver 'libinput' for 'PS/2 Generic Mouse'
[     4.986] (**) PS/2 Generic Mouse: always reports core events
[     4.986] (**) Option "Device" "/dev/input/event18"
[     4.986] (**) Option "_source" "server/udev"
[     4.986] (II) event18 - PS/2 Generic Mouse: is tagged by udev as: Mouse
[     4.986] (II) event18 - PS/2 Generic Mouse: device is a pointer
[     4.986] (II) event18 - PS/2 Generic Mouse: device removed
[     5.037] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio2/input/input12/event18"
[     5.037] (II) XINPUT: Adding extended input device "PS/2 Generic Mouse" (type: MOUSE, id 13)
[     5.038] (**) Option "AccelerationScheme" "none"
[     5.038] (**) PS/2 Generic Mouse: (accel) selected scheme none/0
[     5.038] (**) PS/2 Generic Mouse: (accel) acceleration factor: 2.000
[     5.038] (**) PS/2 Generic Mouse: (accel) acceleration threshold: 4
[     5.039] (II) event18 - PS/2 Generic Mouse: is tagged by udev as: Mouse
[     5.039] (II) event18 - PS/2 Generic Mouse: device is a pointer
[     5.039] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/mouse1)
[     5.039] (II) No input driver specified, ignoring this device.
[     5.039] (II) This device may have been added with another device file.
[     5.039] (II) config/udev: Adding input device AlpsPS/2 ALPS GlidePoint (/dev/input/event19)
[     5.039] (**) AlpsPS/2 ALPS GlidePoint: Applying InputClass "evdev touchpad catchall"
[     5.039] (**) AlpsPS/2 ALPS GlidePoint: Applying InputClass "libinput touchpad catchall"
[     5.039] (**) AlpsPS/2 ALPS GlidePoint: Applying InputClass "touchpad catchall"
[     5.039] (**) AlpsPS/2 ALPS GlidePoint: Applying InputClass "Default clickpad buttons"
[     5.039] (II) LoadModule: "synaptics"
[     5.040] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[     5.044] (II) Module synaptics: vendor="X.Org Foundation"
[     5.044]    compiled for 1.20.0, module version = 1.9.1
[     5.044]    Module class: X.Org XInput Driver
[     5.044]    ABI class: X.Org XInput driver, version 24.1
[     5.044] (II) Using input driver 'synaptics' for 'AlpsPS/2 ALPS GlidePoint'
[     5.044] (**) AlpsPS/2 ALPS GlidePoint: always reports core events
[     5.044] (**) Option "Device" "/dev/input/event19"
[     5.104] (II) synaptics: AlpsPS/2 ALPS GlidePoint: found clickpad property
[     5.104] (--) synaptics: AlpsPS/2 ALPS GlidePoint: x-axis range 0 - 3328 (res 31)
[     5.104] (--) synaptics: AlpsPS/2 ALPS GlidePoint: y-axis range 0 - 1920 (res 31)
[     5.104] (--) synaptics: AlpsPS/2 ALPS GlidePoint: pressure range 0 - 127
[     5.104] (II) synaptics: AlpsPS/2 ALPS GlidePoint: device does not report finger width.
[     5.104] (--) synaptics: AlpsPS/2 ALPS GlidePoint: buttons: left double triple
[     5.104] (--) synaptics: AlpsPS/2 ALPS GlidePoint: Vendor 0x2 Product 0x8
[     5.104] (--) synaptics: AlpsPS/2 ALPS GlidePoint: invalid finger width range.  defaulting to 0 - 15
[     5.104] (**) Option "SoftButtonAreas" "50% 0 82% 0 0 0 0 0"
[     5.104] (--) synaptics: AlpsPS/2 ALPS GlidePoint: touchpad found
[     5.104] (**) AlpsPS/2 ALPS GlidePoint: always reports core events
[     5.157] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio3/input/input24/event19"
[     5.157] (II) XINPUT: Adding extended input device "AlpsPS/2 ALPS GlidePoint" (type: TOUCHPAD, id 14)
[     5.158] (**) synaptics: AlpsPS/2 ALPS GlidePoint: (accel) MinSpeed is now constant deceleration 2.5
[     5.158] (**) synaptics: AlpsPS/2 ALPS GlidePoint: (accel) MaxSpeed is now 1.75
[     5.158] (**) synaptics: AlpsPS/2 ALPS GlidePoint: (accel) AccelFactor is now 0.052
[     5.158] (**) AlpsPS/2 ALPS GlidePoint: (accel) keeping acceleration scheme 1
[     5.158] (**) AlpsPS/2 ALPS GlidePoint: (accel) acceleration profile 1
[     5.158] (**) AlpsPS/2 ALPS GlidePoint: (accel) acceleration factor: 2.000
[     5.158] (**) AlpsPS/2 ALPS GlidePoint: (accel) acceleration threshold: 4
[     5.158] (--) synaptics: AlpsPS/2 ALPS GlidePoint: touchpad found
[     5.158] (II) config/udev: Adding input device AlpsPS/2 ALPS GlidePoint (/dev/input/mouse2)
[     5.158] (**) AlpsPS/2 ALPS GlidePoint: Ignoring device from InputClass "touchpad ignore duplicates"
[     5.159] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[     5.159] (II) No input driver specified, ignoring this device.
[     5.159] (II) This device may have been added with another device file.
[     5.159] (II) config/udev: Adding input device HP Wireless hotkeys (/dev/input/event6)
[     5.159] (**) HP Wireless hotkeys: Applying InputClass "evdev keyboard catchall"
[     5.159] (**) HP Wireless hotkeys: Applying InputClass "libinput keyboard catchall"
[     5.159] (**) HP Wireless hotkeys: Applying InputClass "system-keyboard"
[     5.159] (II) Using input driver 'libinput' for 'HP Wireless hotkeys'
[     5.159] (**) HP Wireless hotkeys: always reports core events
[     5.159] (**) Option "Device" "/dev/input/event6"
[     5.159] (**) Option "_source" "server/udev"
[     5.160] (II) event6  - HP Wireless hotkeys: is tagged by udev as: Keyboard
[     5.160] (II) event6  - HP Wireless hotkeys: device is a keyboard
[     5.160] (II) event6  - HP Wireless hotkeys: device removed
[     5.211] (**) Option "config_info" "udev:/sys/devices/virtual/input/input10/event6"
[     5.211] (II) XINPUT: Adding extended input device "HP Wireless hotkeys" (type: KEYBOARD, id 15)
[     5.211] (**) Option "xkb_model" "pc105"
[     5.211] (**) Option "xkb_layout" "gb"
[     5.212] (II) event6  - HP Wireless hotkeys: is tagged by udev as: Keyboard
[     5.212] (II) event6  - HP Wireless hotkeys: device is a keyboard
[     5.213] (II) config/udev: Adding input device HP WMI hotkeys (/dev/input/event8)
[     5.213] (**) HP WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[     5.213] (**) HP WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[     5.213] (**) HP WMI hotkeys: Applying InputClass "system-keyboard"
[     5.213] (II) Using input driver 'libinput' for 'HP WMI hotkeys'
[     5.213] (**) HP WMI hotkeys: always reports core events
[     5.213] (**) Option "Device" "/dev/input/event8"
[     5.213] (**) Option "_source" "server/udev"
[     5.214] (II) event8  - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[     5.214] (II) event8  - HP WMI hotkeys: device is a keyboard
[     5.214] (II) event8  - HP WMI hotkeys: device removed
[     5.264] (**) Option "config_info" "udev:/sys/devices/virtual/input/input14/event8"
[     5.264] (II) XINPUT: Adding extended input device "HP WMI hotkeys" (type: KEYBOARD, id 16)
[     5.264] (**) Option "xkb_model" "pc105"
[     5.265] (**) Option "xkb_layout" "gb"
[     5.266] (II) event8  - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[     5.266] (II) event8  - HP WMI hotkeys: device is a keyboard
[     5.271] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/mouse1)
[     5.271] (II) No input driver specified, ignoring this device.
[     5.271] (II) This device may have been added with another device file.
[     5.271] (II) config/udev: removing device PS/2 Generic Mouse
[     5.271] (II) event18 - PS/2 Generic Mouse: device removed
[     5.331] (II) UnloadModule: "libinput"
[     5.332] (II) config/udev: Adding input device PS/2 Generic Mouse (/dev/input/event18)
[     5.332] (**) PS/2 Generic Mouse: Applying InputClass "evdev pointer catchall"
[     5.332] (**) PS/2 Generic Mouse: Applying InputClass "libinput pointer catchall"
[     5.332] (II) Using input driver 'libinput' for 'PS/2 Generic Mouse'
[     5.332] (**) PS/2 Generic Mouse: always reports core events
[     5.332] (**) Option "Device" "/dev/input/event18"
[     5.332] (**) Option "_source" "server/udev"
[     5.333] (II) event18 - PS/2 Generic Mouse: is tagged by udev as: Mouse
[     5.333] (II) event18 - PS/2 Generic Mouse: device is a pointer
[     5.333] (II) event18 - PS/2 Generic Mouse: device removed
[     5.411] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio2/input/input12/event18"
[     5.411] (II) XINPUT: Adding extended input device "PS/2 Generic Mouse" (type: MOUSE, id 13)
[     5.411] (**) Option "AccelerationScheme" "none"
[     5.411] (**) PS/2 Generic Mouse: (accel) selected scheme none/0
[     5.411] (**) PS/2 Generic Mouse: (accel) acceleration factor: 2.000
[     5.411] (**) PS/2 Generic Mouse: (accel) acceleration threshold: 4
[     5.412] (II) event18 - PS/2 Generic Mouse: is tagged by udev as: Mouse
[     5.412] (II) event18 - PS/2 Generic Mouse: device is a pointer
[     5.413] (II) config/udev: Adding input device AlpsPS/2 ALPS GlidePoint (/dev/input/mouse2)
[     5.413] (**) AlpsPS/2 ALPS GlidePoint: Ignoring device from InputClass "touchpad ignore duplicates"
[     5.413] (II) config/udev: removing device AlpsPS/2 ALPS GlidePoint
[     5.457] (II) UnloadModule: "synaptics"
[     5.458] (II) config/udev: Adding input device AlpsPS/2 ALPS GlidePoint (/dev/input/event19)
[     5.458] (**) AlpsPS/2 ALPS GlidePoint: Applying InputClass "evdev touchpad catchall"
[     5.458] (**) AlpsPS/2 ALPS GlidePoint: Applying InputClass "libinput touchpad catchall"
[     5.458] (**) AlpsPS/2 ALPS GlidePoint: Applying InputClass "touchpad catchall"
[     5.458] (**) AlpsPS/2 ALPS GlidePoint: Applying InputClass "Default clickpad buttons"
[     5.458] (II) Using input driver 'synaptics' for 'AlpsPS/2 ALPS GlidePoint'
[     5.458] (**) AlpsPS/2 ALPS GlidePoint: always reports core events
[     5.458] (**) Option "Device" "/dev/input/event19"
[     5.517] (II) synaptics: AlpsPS/2 ALPS GlidePoint: found clickpad property
[     5.517] (--) synaptics: AlpsPS/2 ALPS GlidePoint: x-axis range 0 - 3328 (res 31)
[     5.517] (--) synaptics: AlpsPS/2 ALPS GlidePoint: y-axis range 0 - 1920 (res 31)
[     5.518] (--) synaptics: AlpsPS/2 ALPS GlidePoint: pressure range 0 - 127
[     5.518] (II) synaptics: AlpsPS/2 ALPS GlidePoint: device does not report finger width.
[     5.518] (--) synaptics: AlpsPS/2 ALPS GlidePoint: buttons: left double triple
[     5.518] (--) synaptics: AlpsPS/2 ALPS GlidePoint: Vendor 0x2 Product 0x8
[     5.518] (--) synaptics: AlpsPS/2 ALPS GlidePoint: invalid finger width range.  defaulting to 0 - 15
[     5.518] (**) Option "SoftButtonAreas" "50% 0 82% 0 0 0 0 0"
[     5.518] (--) synaptics: AlpsPS/2 ALPS GlidePoint: touchpad found
[     5.518] (**) AlpsPS/2 ALPS GlidePoint: always reports core events
[     5.585] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio3/input/input24/event19"
[     5.585] (II) XINPUT: Adding extended input device "AlpsPS/2 ALPS GlidePoint" (type: TOUCHPAD, id 14)
[     5.585] (**) synaptics: AlpsPS/2 ALPS GlidePoint: (accel) MinSpeed is now constant deceleration 2.5
[     5.585] (**) synaptics: AlpsPS/2 ALPS GlidePoint: (accel) MaxSpeed is now 1.75
[     5.585] (**) synaptics: AlpsPS/2 ALPS GlidePoint: (accel) AccelFactor is now 0.052
[     5.585] (**) AlpsPS/2 ALPS GlidePoint: (accel) keeping acceleration scheme 1
[     5.585] (**) AlpsPS/2 ALPS GlidePoint: (accel) acceleration profile 1
[     5.585] (**) AlpsPS/2 ALPS GlidePoint: (accel) acceleration factor: 2.000
[     5.585] (**) AlpsPS/2 ALPS GlidePoint: (accel) acceleration threshold: 4
[     5.585] (--) synaptics: AlpsPS/2 ALPS GlidePoint: touchpad found
[    12.146] (II) AMDGPU(0): EDID vendor "AUO", prod id 9197
[    12.146] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    12.146] (II) AMDGPU(0): Modeline "1920x1080"x0.0  141.00  1920 2028 2076 2086  1080 1090 1100 1126 -hsync -vsync (67.6 kHz eP)
[    12.146] (II) AMDGPU(0): Modeline "1920x1080"x0.0   94.00  1920 2028 2076 2086  1080 1090 1100 1126 -hsync -vsync (45.1 kHz e)
[    17.199] (II) AMDGPU(0): EDID vendor "AUO", prod id 9197
[    17.199] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    17.199] (II) AMDGPU(0): Modeline "1920x1080"x0.0  141.00  1920 2028 2076 2086  1080 1090 1100 1126 -hsync -vsync (67.6 kHz eP)
[    17.199] (II) AMDGPU(0): Modeline "1920x1080"x0.0   94.00  1920 2028 2076 2086  1080 1090 1100 1126 -hsync -vsync (45.1 kHz e)
[    32.245] (II) AMDGPU(0): EDID vendor "AUO", prod id 9197
[    32.245] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    32.245] (II) AMDGPU(0): Modeline "1920x1080"x0.0  141.00  1920 2028 2076 2086  1080 1090 1100 1126 -hsync -vsync (67.6 kHz eP)
[    32.245] (II) AMDGPU(0): Modeline "1920x1080"x0.0   94.00  1920 2028 2076 2086  1080 1090 1100 1126 -hsync -vsync (45.1 kHz e)
[    57.245] (II) AMDGPU(0): EDID vendor "AUO", prod id 9197
[    57.245] (II) AMDGPU(0): Printing DDC gathered Modelines:
[    57.245] (II) AMDGPU(0): Modeline "1920x1080"x0.0  141.00  1920 2028 2076 2086  1080 1090 1100 1126 -hsync -vsync (67.6 kHz eP)
[    57.245] (II) AMDGPU(0): Modeline "1920x1080"x0.0   94.00  1920 2028 2076 2086  1080 1090 1100 1126 -hsync -vsync (45.1 kHz e)
#34
Based on the Xorg logs I assume when it’s successful it loads the amdgpu driver and when it’s not it loads the radeon driver.
I tried removing /usr/share/X11/xorg.conf.d/10-radeon.conf and it seems to have improved the overall success rate but there are still bad starts.
Any suggestion on how to force it to always use amdgpu?
#35
I created the file: /etc/X11/xorg.conf.d/20-amdgpu.conf:
Section "Device"
     Identifier "AMD"
     Driver "amdgpu"
     Option "TearFree" "true"
EndSection
And it looks like this forces it to use amdgpu, but the problems don’t go away:
[     5.085]
[     5.085] Build Operating System: Linux Arch Linux
[     5.085] Current Operating System: Linux my-pc 4.19.8-2-MANJARO #1 SMP PREEMPT Sat Dec 8 14:45:36 UTC 2018 x86_64
[     5.085] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19-x86_64 root=UUID=af6fcf2f-f348-4b66-859e-003f931e18b0 rw resume=UUID=5ed5f99a-e9f1-4897-8e2a-a33b50406c12
[     5.085] Build Date: 25 October 2018  04:42:32PM
[     5.085]
[     5.085] Current version of pixman: 0.36.0
[     5.085]    Before reporting problems, check http://wiki.x.org
[     5.085] Markers: (--) probed, (**) from config file, (==) default setting,
[     5.085] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Dec 17 20:04:12 2018
[     5.085] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     5.085] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     5.086] (==) No Layout section.  Using the first Screen section.
[     5.086] (==) No screen section available. Using defaults.
[     5.086] (**) |-->Screen "Default Screen Section" (0)
[     5.086] (**) |   |-->Monitor "<default monitor>"
[     5.086] (==) No device specified for screen "Default Screen Section".
        Using the first device section listed.
[     5.086] (**) |   |-->Device "AMD"
[     5.086] (==) No monitor specified for screen "Default Screen Section".
[     5.086] (==) Automatically adding devices
[     5.086] (==) Automatically enabling devices
[     5.086] (==) Automatically adding GPU devices
[     5.086] (==) Automatically binding GPU devices
[     5.086] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     5.086] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     5.086]    Entry deleted from font path.
[     5.086] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     5.086] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[     5.086]    (Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[     5.086] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[     5.086]    (Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[     5.086] (==) FontPath set to:
[     5.086] (==) ModulePath set to "/usr/lib/xorg/modules"
[     5.086] (II) The server relies on udev to provide the list of input devices.
[     5.086] (II) Module ABI versions:
[     5.086]    X.Org ANSI C Emulation: 0.4
[     5.086]    X.Org Video Driver: 24.0
[     5.086]    X.Org XInput driver : 24.1
[     5.086]    X.Org Server Extension : 10.0
[     5.087] (++) using VT number 7
[     5.087] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     5.091] (--) PCI:*(4@0:0:0) 1002:15dd:103c:83d5 rev 208, Mem @ 0xd0000000/268435456, 0xe0000000/2097152, 0xe0700000/524288, I/O @ 0x00002000/256, BIOS @ 0x????????/131072
[     5.091] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     5.091] (II) LoadModule: "glx"
[     5.091] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     5.092] (II) Module glx: vendor="X.Org Foundation"
[     5.093]    compiled for 1.20.3, module version = 1.0.0
[     5.093]    ABI class: X.Org Server Extension, version 10.0
[     5.093] (II) LoadModule: "amdgpu"
[     5.093] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[     5.093] (II) Module amdgpu: vendor="X.Org Foundation"
[     5.093]    compiled for 1.20.1, module version = 18.1.0
[     5.093]    Module class: X.Org Video Driver
[     5.093]    ABI class: X.Org Video Driver, version 24.0
[     5.093] (II) AMDGPU: Driver for AMD Radeon:
[     5.093] (II) AMDGPU(0): [KMS] drm report modesetting isn't supported.
[     5.093] (EE) Screen 0 deleted because of no matching config section.
[     5.093] (II) UnloadModule: "amdgpu"
[     5.093] (EE) Device(s) detected, but none match those in the config file.
[     5.093] (EE)
Fatal server error:
[     5.093] (EE) no screens found(EE)
[     5.093] (EE)
 for help.
[     5.093] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[     5.093] (EE)
[     5.093] (EE) Server terminated with error (1). Closing log file.
I’m hoping the 4.20 kernel (released next week?) has some goodies that help… otherwise it’s going to be a sad Christmas :cry:.
#36
There is no Problem on the Xorg side. Yours is a level higher. Kernel level. Sometimes I’t seems to be unable to load KMS, sometimes it cant find screens. I’d say if you’re lucky there will be a change with 4.21 next year.
The good thing is, that you do mistakes like this only once. On Linux, you have to look what you buy before you buy something and some vendors you have to ignore (like HP and Sony).
You could try the linux-amd-staging-drm-next-git
#37
The linux-amd-staging-drm-next-git package breaks the install and I had to chroot and uninstall it.
I wish I could debug this further but I have absolutely no idea how… if waiting for a newer kernel with a potential fix is the only chance I got then I guess I’ll have to work with it this way.
#38
Updated to linux 4.20 (via unstable branch), still have freezez, only now I no longer have any output in /var/log/Xorg.0.log.old, it’s empty.
#39
Another kernel parameter I tried ant noticed it caused different freezes: amdgpu.dpm=0. So this strategy is clearly not working (and I’m basically taking random bits from searches and trying them out so there’s no wonder it’s failing).
Somehow I got my Xorg logs working again and I have the same:
[     4.230] (II) AMDGPU(0): [KMS] drm report modesetting isn't supported.
[     4.230] (EE) Screen 0 deleted because of no matching config section.
[     4.230] (II) UnloadModule: "amdgpu"
[     4.230] (EE) Device(s) detected, but none match those in the config file.
[     4.230] (EE)
Fatal server error:
[     4.230] (EE) no screens found(EE)
Anybody know how I could debug this further? from Screen 0 deleted because of no matching config section I understand it has a screen with a configuration that does not match what amdgpu expects? How can I see this configuration? And how can I see what it’s supposed to be? Can I write that config manually somewhere?
Or another strategy, how/where would I report a bug like this in the hopes someone could help with the driver?
I really want to do everything I can to help get this sorted, O just don’t know how…
#40
Admin/user configs are at
/etc/X11/xorg.conf.d/*.conf
Also check (not that you will find…) relevant configs at
/usr/share/X11/xorg.conf.d/*.conf
Other relevant configuration is at modules
/etc/modules-load.d/*.conf
/etc/modprobe.d/*.conf
