Hello guys.
I am trying to connect 2 monitors. So far no problems, the problem appears when i leave the pc for some moments the screen goes off, when i come back nothing works. I have to do a hard shutdown to my pc. Pls can someone explain to me why this is happening because is very frustrating and i don’t want other distros in my computer. I have tried xfce same problems, i have tried windows works perfectly fine
Thank you guys for your time
3 ideas to be checked:
check and modify energy save mode in your bios
check energy save settings, if needed switch from hibernation to sleep in (KDE?) settings
try an other kernel
try an lts first further down the list, and work your way up, or the direction, stick with the one with no problem
