Hi Andreas, thanks for your response!
here is the xorg log:
[ 101.500]
X.Org X Server 1.21.1.3
[ 101.500] Current Operating System: Linux XPS15 5.15.19-1-MANJARO #1 SMP PREEMPT Tue Feb 1 16:58:17 UTC 2022 x86_64
[ 101.500] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=fff12115-1a7b-4355-b65b-f9776d6a8f7e rw quiet resume=UUID=51b44c6e-15fe-4fb0-b357-196438148de4
[ 101.500]
[ 101.500] Current version of pixman: 0.40.0
[ 101.500] Before reporting problems, check http://wiki.x.org
[ 101.500] Markers: (--) probed, (**) from config file, (==) default setting,
[ 101.500] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Feb 14 12:18:43 2022
[ 101.500] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 101.500] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 101.500] (==) ServerLayout "layout"
[ 101.500] (==) No screen section available. Using defaults.
[ 101.500] (**) |-->Screen "Default Screen Section" (0)
[ 101.500] (**) | |-->Monitor "<default monitor>"
[ 101.500] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 101.500] (**) | |-->Device "integrated"
[ 101.500] (==) No monitor specified for screen "Default Screen Section".
[ 101.500] (==) Automatically adding devices
[ 101.500] (==) Automatically enabling devices
[ 101.500] (==) Automatically adding GPU devices
[ 101.500] (==) Automatically binding GPU devices
[ 101.500] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 101.500] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 101.500] Entry deleted from font path.
[ 101.500] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 101.500] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 101.500] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF,
/usr/share/fonts/OTF
[ 101.500] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 101.500] (II) The server relies on udev to provide the list of input devices.
[ 101.500] (II) Module ABI versions:
[ 101.500] X.Org ANSI C Emulation: 0.4
[ 101.500] X.Org Video Driver: 25.2
[ 101.500] X.Org XInput driver : 24.4
[ 101.500] X.Org Server Extension : 10.0
[ 101.501] (++) using VT number 7
[ 101.501] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 101.501] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 101.501] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 101.510] (--) PCI:*(0@0:2:0) 8086:3e9b:1028:087c rev 0, Mem @ 0xeb000000/16777216, 0x80000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
[ 101.510] (--) PCI: (1@0:0:0) 10de:1c8c:1028:087c rev 161, Mem @ 0xec000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x00003000/128, BIOS @ 0x????????/524288
[ 101.510] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 101.510] (II) LoadModule: "glx"
[ 101.510] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 101.511] (II) Module glx: vendor="X.Org Foundation"
[ 101.511] compiled for 1.21.1.3, module version = 1.0.0
[ 101.511] ABI class: X.Org Server Extension, version 10.0
[ 101.511] (II) LoadModule: "modesetting"
[ 101.511] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 101.513] (II) Module modesetting: vendor="X.Org Foundation"
[ 101.513] compiled for 1.21.1.3, module version = 1.21.1
[ 101.513] Module class: X.Org Video Driver
[ 101.513] ABI class: X.Org Video Driver, version 25.2
[ 101.513] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 101.525] (II) modeset(0): using drv /dev/dri/card0
[ 101.525] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 101.525] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 101.525] (==) modeset(0): RGB weight 888
[ 101.525] (==) modeset(0): Default visual is TrueColor
[ 101.525] (II) Loading sub module "glamoregl"
[ 101.525] (II) LoadModule: "glamoregl"
[ 101.525] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 101.528] (II) Module glamoregl: vendor="X.Org Foundation"
[ 101.528] compiled for 1.21.1.3, module version = 1.0.1
[ 101.528] ABI class: X.Org ANSI C Emulation, version 0.4
[ 101.814] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics 630 (CFL GT2)
[ 101.814] (II) modeset(0): glamor initialized
[ 101.814] (==) modeset(0): VariableRefresh: disabled
[ 101.814] (==) modeset(0): AsyncFlipSecondaries: disabled
[ 101.816] (II) modeset(0): Output eDP-1 has no monitor section
[ 101.816] (II) modeset(0): Output DP-1 has no monitor section
[ 101.816] (II) modeset(0): Output DP-2 has no monitor section
[ 101.820] (II) modeset(0): Output DP-3 has no monitor section
[ 101.821] (II) modeset(0): EDID for output eDP-1
[ 101.821] (II) modeset(0): Manufacturer: SHP Model: 148d Serial#: 0
[ 101.821] (II) modeset(0): Year: 2018 Week: 5
[ 101.821] (II) modeset(0): EDID Version: 1.4
[ 101.821] (II) modeset(0): Digital Display Input
[ 101.821] (II) modeset(0): 8 bits per channel
[ 101.821] (II) modeset(0): Digital interface is DisplayPort
[ 101.821] (II) modeset(0): Max Image Size [cm]: horiz.: 34 vert.: 19
[ 101.821] (II) modeset(0): Gamma: 2.20
[ 101.821] (II) modeset(0): No DPMS capabilities specified
[ 101.821] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 101.821] (II) modeset(0): Default color space is primary color space
[ 101.821] (II) modeset(0): First detailed timing is preferred mode
[ 101.821] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 101.821] (II) modeset(0): redX: 0.661 redY: 0.325 greenX: 0.207 greenY: 0.737
[ 101.821] (II) modeset(0): blueX: 0.145 blueY: 0.047 whiteX: 0.312 whiteY: 0.320
[ 101.821] (II) modeset(0): Manufacturer's mask: 0
[ 101.821] (II) modeset(0): Supported detailed timing:
[ 101.821] (II) modeset(0): clock: 533.2 MHz Image Size: 344 x 194 mm
[ 101.821] (II) modeset(0): h_active: 3840 h_sync: 3888 h_sync_end 3920 h_blank_end 4000 h_border: 0
[ 101.821] (II) modeset(0): v_active: 2160 v_sync: 2163 v_sync_end 2168 v_blanking: 2222 v_border: 0
[ 101.821] (II) modeset(0): FNVDRLQ156D1
[ 101.821] (II) modeset(0): Unknown vendor-specific block 0
[ 101.821] (II) modeset(0): EDID (in hex):
[ 101.821] (II) modeset(0): 00ffffffffffff004d108d1400000000
[ 101.821] (II) modeset(0): 051c0104a52213780e5300a95335bc25
[ 101.821] (II) modeset(0): 0c505200000001010101010101010101
[ 101.821] (II) modeset(0): 0101010101014dd000a0f0703e803020
[ 101.821] (II) modeset(0): 350058c2100000180000000000000000
[ 101.821] (II) modeset(0): 00000000000000000000000000fe0046
[ 101.821] (II) modeset(0): 4e564452804c51313536443100000000
[ 101.821] (II) modeset(0): 0002410328011200000b010a2020003a
[ 101.821] (II) modeset(0): Printing probed modes for output eDP-1
[ 101.821] (II) modeset(0): Modeline "3840x2160"x60.0 533.25 3840 3888 3920 4000 2160 2163 2168 2222 -hsync -vsync (133.3 kHz eP)
[ 101.821] (II) modeset(0): Modeline "3840x2160"x60.0 712.75 3840 4160 4576 5312 2160 2163 2168 2237 -hsync +vsync (134.2 kHz d)
[ 101.822] (II) modeset(0): Modeline "3840x2160"x60.0 533.00 3840 3888 3920 4000 2160 2163 2168 2222 +hsync -vsync (133.2 kHz d)
[ 101.822] (II) modeset(0): Modeline "3200x1800"x60.0 492.00 3200 3456 3800 4400 1800 1803 1808 1865 -hsync +vsync (111.8 kHz d)
[ 101.822] (II) modeset(0): Modeline "3200x1800"x59.9 373.00 3200 3248 3280 3360 1800 1803 1808 1852 +hsync -vsync (111.0 kHz d)
[ 101.822] (II) modeset(0): Modeline "2880x1620"x60.0 396.25 2880 3096 3408 3936 1620 1623 1628 1679 -hsync +vsync (100.7 kHz d)
[ 101.822] (II) modeset(0): Modeline "2880x1620"x60.0 303.75 2880 2928 2960 3040 1620 1623 1628 1666 +hsync -vsync (99.9 kHz d)
[ 101.822] (II) modeset(0): Modeline "2560x1600"x60.0 348.50 2560 2760 3032 3504 1600 1603 1609 1658 -hsync +vsync (99.5 kHz d)
[ 101.822] (II) modeset(0): Modeline "2560x1600"x60.0 268.50 2560 2608 2640 2720 1600 1603 1609 1646 +hsync -vsync (98.7 kHz d)
[ 101.822] (II) modeset(0): Modeline "2560x1440"x120.0 638.25 2560 2780 3064 3568 1440 1441 1444 1491 doublescan -hsync +vsync (178.9 kHz d)
[ 101.822] (II) modeset(0): Modeline "2560x1440"x120.0 469.12 2560 2584 2600 2640 1440 1441 1444 1481 doublescan +hsync -vsync (177.7 kHz d)
[ 101.822] (II) modeset(0): Modeline "2560x1440"x60.0 312.25 2560 2752 3024 3488 1440 1443 1448 1493 -hsync +vsync (89.5 kHz d)
[ 101.822] (II) modeset(0): Modeline "2560x1440"x60.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz d)
[ 101.822] (II) modeset(0): Modeline "2048x1536"x60.0 266.95 2048 2200 2424 2800 1536 1537 1540 1589 -hsync +vsync (95.3 kHz d)
[ 101.822] (II) modeset(0): Modeline "1920x1440"x60.0 234.00 1920 2048 2256 2600 1440 1441 1444 1500 -hsync +vsync (90.0 kHz d)
[ 101.822] (II) modeset(0): Modeline "1856x1392"x60.0 218.30 1856 1952 2176 2528 1392 1393 1396 1439 -hsync +vsync (86.4 kHz d)
[ 101.822] (II) modeset(0): Modeline "1792x1344"x60.0 204.80 1792 1920 2120 2448 1344 1345 1348 1394 -hsync +vsync (83.7 kHz d)
[ 101.822] (II) modeset(0): Modeline "2048x1152"x120.0 406.50 2048 2220 2444 2840 1152 1153 1156 1193 doublescan -hsync +vsync (143.1 kHz d)
[ 101.822] (II) modeset(0): Modeline "2048x1152"x120.0 302.50 2048 2072 2088 2128 1152 1153 1156 1185 doublescan +hsync -vsync (142.2 kHz d)
[ 101.822] (II) modeset(0): Modeline "2048x1152"x59.9 197.00 2048 2184 2400 2752 1152 1155 1160 1195 -hsync +vsync (71.6 kHz d)
[ 101.822] (II) modeset(0): Modeline "2048x1152"x59.9 156.75 2048 2096 2128 2208 1152 1155 1160 1185 +hsync -vsync (71.0 kHz d)
[ 101.822] (II) modeset(0): Modeline "1920x1200"x59.9 193.25 1920 2056 2256 2592 1200 1203 1209 1245 -hsync +vsync (74.6 kHz d)
[ 101.822] (II) modeset(0): Modeline "1920x1200"x60.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz d)
[ 101.822] (II) modeset(0): Modeline "1920x1080"x120.0 356.38 1920 2080 2288 2656 1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[ 101.822] (II) modeset(0): Modeline "1920x1080"x119.9 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[ 101.822] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 101.822] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 101.822] (II) modeset(0): Modeline "1600x1200"x60.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz d)
[ 101.822] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 101.822] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 101.822] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 101.822] (II) modeset(0): Modeline "1600x900"x120.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 101.822] (II) modeset(0): Modeline "1600x900"x119.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 101.822] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 101.822] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 101.822] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 101.822] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 101.822] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 101.822] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 101.822] (II) modeset(0): Modeline "1440x810"x120.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 101.822] (II) modeset(0): Modeline "1440x810"x119.9 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 101.822] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 101.822] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 101.822] (II) modeset(0): Modeline "1280x800"x120.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 101.822] (II) modeset(0): Modeline "1280x800"x119.9 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 101.822] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 101.822] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 101.822] (II) modeset(0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 101.822] (II) modeset(0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 101.822] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 101.822] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 101.822] (II) modeset(0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 101.822] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 101.822] (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 101.822] (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 101.822] (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 101.822] (II) modeset(0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 101.822] (II) modeset(0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 101.822] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 101.822] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 101.822] (II) modeset(0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 101.822] (II) modeset(0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 101.822] (II) modeset(0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 101.822] (II) modeset(0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 101.822] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 101.822] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 101.822] (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 101.822] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 101.822] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 101.822] (II) modeset(0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 101.822] (II) modeset(0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 101.822] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 101.822] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 101.822] (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 101.822] (II) modeset(0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 101.822] (II) modeset(0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 101.822] (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 101.822] (II) modeset(0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 101.822] (II) modeset(0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 101.822] (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 101.822] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 101.822] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 101.822] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 101.822] (II) modeset(0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 101.822] (II) modeset(0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 101.822] (II) modeset(0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 101.822] (II) modeset(0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 101.822] (II) modeset(0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 101.822] (II) modeset(0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 101.822] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 101.822] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 101.822] (II) modeset(0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 101.822] (II) modeset(0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 101.822] (II) modeset(0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 101.822] (II) modeset(0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 101.822] (II) modeset(0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 101.822] (II) modeset(0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 101.822] (II) modeset(0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 101.822] (II) modeset(0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 101.822] (II) modeset(0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 101.822] (II) modeset(0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 101.822] (II) modeset(0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 101.822] (II) modeset(0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 101.822] (II) modeset(0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 101.822] (II) modeset(0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 101.822] (II) modeset(0): EDID for output DP-1
[ 101.822] (II) modeset(0): EDID for output DP-2
[ 101.826] (II) modeset(0): EDID for output DP-3
[ 101.826] (II) modeset(0): Output eDP-1 connected
[ 101.826] (II) modeset(0): Output DP-1 disconnected
[ 101.826] (II) modeset(0): Output DP-2 disconnected
[ 101.826] (II) modeset(0): Output DP-3 disconnected
[ 101.826] (II) modeset(0): Using exact sizes for initial modes
[ 101.826] (II) modeset(0): Output eDP-1 using initial mode 3840x2160 +0+0
[ 101.826] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 101.826] (==) modeset(0): DPI set to (96, 96)
[ 101.826] (II) Loading sub module "fb"
[ 101.826] (II) LoadModule: "fb"
[ 101.826] (II) Module "fb" already built-in
[ 101.838] (==) modeset(0): Backing store enabled
[ 101.838] (==) modeset(0): Silken mouse enabled
[ 101.909] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 101.909] (==) modeset(0): DPMS enabled
[ 101.909] (WW) modeset(0): Option "DRI" is not used
[ 101.909] (II) modeset(0): [DRI2] Setup complete
[ 101.909] (II) modeset(0): [DRI2] DRI driver: iris
[ 101.909] (II) modeset(0): [DRI2] VDPAU driver: va_gl
[ 101.909] (II) Initializing extension Generic Event Extension
[ 101.910] (II) Initializing extension SHAPE
[ 101.910] (II) Initializing extension MIT-SHM
[ 101.910] (II) Initializing extension XInputExtension
[ 101.910] (II) Initializing extension XTEST
[ 101.910] (II) Initializing extension BIG-REQUESTS
[ 101.911] (II) Initializing extension SYNC
[ 101.911] (II) Initializing extension XKEYBOARD
[ 101.911] (II) Initializing extension XC-MISC
[ 101.911] (II) Initializing extension SECURITY
[ 101.911] (II) Initializing extension XFIXES
[ 101.911] (II) Initializing extension RENDER
[ 101.911] (II) Initializing extension RANDR
[ 101.912] (II) Initializing extension COMPOSITE
[ 101.912] (II) Initializing extension DAMAGE
[ 101.912] (II) Initializing extension MIT-SCREEN-SAVER
[ 101.912] (II) Initializing extension DOUBLE-BUFFER
[ 101.912] (II) Initializing extension RECORD
[ 101.912] (II) Initializing extension DPMS
[ 101.913] (II) Initializing extension Present
[ 101.913] (II) Initializing extension DRI3
[ 101.913] (II) Initializing extension X-Resource
[ 101.913] (II) Initializing extension XVideo
[ 101.913] (II) Initializing extension XVideo-MotionCompensation
[ 101.913] (II) Initializing extension GLX
[ 101.926] (II) AIGLX: Loaded and initialized iris
[ 101.926] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 101.926] (II) Initializing extension XFree86-VidModeExtension
[ 101.926] (II) Initializing extension XFree86-DGA
[ 101.926] (II) Initializing extension XFree86-DRI
[ 101.926] (II) Initializing extension DRI2
[ 101.927] (II) modeset(0): Damage tracking initialized
[ 101.927] (II) modeset(0): Setting screen physical size to 1016 x 571
[ 101.986] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 101.986] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 101.986] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 101.986] (**) Power Button: Applying InputClass "system-keyboard"
[ 101.986] (II) LoadModule: "libinput"
[ 101.986] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 101.987] (II) Module libinput: vendor="X.Org Foundation"
[ 101.987] compiled for 1.21.1.3, module version = 1.2.1
[ 101.987] Module class: X.Org XInput Driver
[ 101.987] ABI class: X.Org XInput driver, version 24.4
[ 101.987] (II) Using input driver 'libinput' for 'Power Button'
[ 101.987] (**) Power Button: always reports core events
[ 101.987] (**) Option "Device" "/dev/input/event3"
[ 101.989] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 101.989] (II) event3 - Power Button: device is a keyboard
[ 101.989] (II) event3 - Power Button: device removed
[ 102.031] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 102.031] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 102.031] (**) Option "xkb_model" "pc105"
[ 102.031] (**) Option "xkb_layout" "ch"
[ 102.031] (**) Option "xkb_variant" "de_nodeadkeys"
[ 102.047] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 102.047] (II) event3 - Power Button: device is a keyboard
[ 102.047] (II) config/udev: Adding input device Video Bus (/dev/input/event15)
[ 102.047] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 102.047] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 102.047] (**) Video Bus: Applying InputClass "system-keyboard"
[ 102.047] (II) Using input driver 'libinput' for 'Video Bus'
[ 102.047] (**) Video Bus: always reports core events
[ 102.047] (**) Option "Device" "/dev/input/event15"
[ 102.048] (II) event15 - Video Bus: is tagged by udev as: Keyboard
[ 102.048] (II) event15 - Video Bus: device is a keyboard
[ 102.048] (II) event15 - Video Bus: device removed
[ 102.111] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input18/event15"
[ 102.111] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 102.111] (**) Option "xkb_model" "pc105"
[ 102.111] (**) Option "xkb_layout" "ch"
[ 102.111] (**) Option "xkb_variant" "de_nodeadkeys"
[ 102.114] (II) event15 - Video Bus: is tagged by udev as: Keyboard
[ 102.114] (II) event15 - Video Bus: device is a keyboard
[ 102.116] (II) config/udev: Adding input device Video Bus (/dev/input/event16)
[ 102.116] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 102.116] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 102.116] (**) Video Bus: Applying InputClass "system-keyboard"
[ 102.116] (II) Using input driver 'libinput' for 'Video Bus'
[ 102.116] (**) Video Bus: always reports core events
[ 102.116] (**) Option "Device" "/dev/input/event16"
[ 102.119] (II) event16 - Video Bus: is tagged by udev as: Keyboard
[ 102.119] (II) event16 - Video Bus: device is a keyboard
[ 102.120] (II) event16 - Video Bus: device removed
[ 102.177] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:0b/LNXVIDEO:01/input/input19/event16"
[ 102.177] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 102.177] (**) Option "xkb_model" "pc105"
[ 102.177] (**) Option "xkb_layout" "ch"
[ 102.178] (**) Option "xkb_variant" "de_nodeadkeys"
[ 102.181] (II) event16 - Video Bus: is tagged by udev as: Keyboard
[ 102.181] (II) event16 - Video Bus: device is a keyboard
[ 102.183] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 102.183] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 102.183] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 102.183] (**) Power Button: Applying InputClass "system-keyboard"
[ 102.183] (II) Using input driver 'libinput' for 'Power Button'
[ 102.183] (**) Power Button: always reports core events
[ 102.183] (**) Option "Device" "/dev/input/event1"
[ 102.185] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 102.186] (II) event1 - Power Button: device is a keyboard
[ 102.186] (II) event1 - Power Button: device removed
[ 102.217] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 102.217] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[ 102.217] (**) Option "xkb_model" "pc105"
[ 102.217] (**) Option "xkb_layout" "ch"
[ 102.218] (**) Option "xkb_variant" "de_nodeadkeys"
[ 102.220] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 102.220] (II) event1 - Power Button: device is a keyboard
[ 102.222] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 102.222] (II) No input driver specified, ignoring this device.
[ 102.222] (II) This device may have been added with another device file.
[ 102.224] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[ 102.224] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 102.224] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 102.224] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 102.224] (II) Using input driver 'libinput' for 'Sleep Button'
[ 102.224] (**) Sleep Button: always reports core events
[ 102.224] (**) Option "Device" "/dev/input/event2"
[ 102.226] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 102.226] (II) event2 - Sleep Button: device is a keyboard
[ 102.226] (II) event2 - Sleep Button: device removed
[ 102.257] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2/event2"
[ 102.257] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[ 102.257] (**) Option "xkb_model" "pc105"
[ 102.258] (**) Option "xkb_layout" "ch"
[ 102.258] (**) Option "xkb_variant" "de_nodeadkeys"
[ 102.260] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 102.261] (II) event2 - Sleep Button: device is a keyboard
[ 102.264] (II) config/udev: Adding input device Wacom HID 488E Pen (/dev/input/event10)
[ 102.264] (**) Wacom HID 488E Pen: Applying InputClass "evdev tablet catchall"
[ 102.264] (**) Wacom HID 488E Pen: Applying InputClass "libinput tablet catchall"
[ 102.264] (II) Using input driver 'libinput' for 'Wacom HID 488E Pen'
[ 102.264] (**) Wacom HID 488E Pen: always reports core events
[ 102.264] (**) Option "Device" "/dev/input/event10"
[ 102.267] (II) event10 - Wacom HID 488E Pen: is tagged by udev as: Tablet
[ 102.334] (II) event10 - Wacom HID 488E Pen: tablet 'Wacom HID 488E Pen' unknown to libwacom
[ 102.361] (II) event10 - Wacom HID 488E Pen: device is a tablet
[ 102.361] (II) event10 - Wacom HID 488E Pen: device removed
[ 102.417] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-WCOM488E:00/0018:056A:488E.0001/input/input24/event10"
[ 102.417] (II) XINPUT: Adding extended input device "Wacom HID 488E Pen" (type: TABLET, id 11)
[ 102.421] (II) event10 - Wacom HID 488E Pen: is tagged by udev as: Tablet
[ 102.448] (II) event10 - Wacom HID 488E Pen: tablet 'Wacom HID 488E Pen' unknown to libwacom
[ 102.475] (II) event10 - Wacom HID 488E Pen: device is a tablet
[ 102.476] (II) config/udev: Adding input device Wacom HID 488E Pen (/dev/input/mouse2)
[ 102.476] (II) No input driver specified, ignoring this device.
[ 102.476] (II) This device may have been added with another device file.
[ 102.478] (II) config/udev: Adding input device Wacom HID 488E Finger (/dev/input/event11)
[ 102.479] (**) Wacom HID 488E Finger: Applying InputClass "evdev touchscreen catchall"
[ 102.479] (**) Wacom HID 488E Finger: Applying InputClass "libinput touchscreen catchall"
[ 102.479] (II) Using input driver 'libinput' for 'Wacom HID 488E Finger'
[ 102.479] (**) Wacom HID 488E Finger: always reports core events
[ 102.479] (**) Option "Device" "/dev/input/event11"
[ 102.482] (II) event11 - Wacom HID 488E Finger: is tagged by udev as: Touchscreen
[ 102.482] (II) event11 - Wacom HID 488E Finger: device is a touch device
[ 102.483] (II) event11 - Wacom HID 488E Finger: device removed
[ 102.537] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-1/i2c-WCOM488E:00/0018:056A:488E.0001/input/input25/event11"
[ 102.537] (II) XINPUT: Adding extended input device "Wacom HID 488E Finger" (type: TOUCHSCREEN, id 12)
[ 102.538] (**) Option "AccelerationScheme" "none"
[ 102.538] (**) Wacom HID 488E Finger: (accel) selected scheme none/0
[ 102.538] (**) Wacom HID 488E Finger: (accel) acceleration factor: 2.000
[ 102.538] (**) Wacom HID 488E Finger: (accel) acceleration threshold: 4
[ 102.541] (II) event11 - Wacom HID 488E Finger: is tagged by udev as: Touchscreen
[ 102.542] (II) event11 - Wacom HID 488E Finger: device is a touch device
[ 102.544] (II) config/udev: Adding input device Wacom HID 488E Finger (/dev/input/mouse3)
[ 102.544] (II) No input driver specified, ignoring this device.
[ 102.544] (II) This device may have been added with another device file.
[ 102.546] (II) config/udev: Adding input device SYNA2393:00 06CB:7A13 Mouse (/dev/input/event8)
[ 102.546] (**) SYNA2393:00 06CB:7A13 Mouse: Applying InputClass "evdev pointer catchall"
[ 102.546] (**) SYNA2393:00 06CB:7A13 Mouse: Applying InputClass "libinput pointer catchall"
[ 102.546] (II) Using input driver 'libinput' for 'SYNA2393:00 06CB:7A13 Mouse'
[ 102.546] (**) SYNA2393:00 06CB:7A13 Mouse: always reports core events
[ 102.546] (**) Option "Device" "/dev/input/event8"
[ 102.549] (II) event8 - SYNA2393:00 06CB:7A13 Mouse: is tagged by udev as: Mouse Pointingstick
[ 102.550] (II) event8 - SYNA2393:00 06CB:7A13 Mouse: device is a pointer
[ 102.552] (II) event8 - SYNA2393:00 06CB:7A13 Mouse: device removed
[ 102.617] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-SYNA2393:00/0018:06CB:7A13.0002/input/input21/event8"
[ 102.618] (II) XINPUT: Adding extended input device "SYNA2393:00 06CB:7A13 Mouse" (type: MOUSE, id 13)
[ 102.618] (**) Option "AccelerationScheme" "none"
[ 102.618] (**) SYNA2393:00 06CB:7A13 Mouse: (accel) selected scheme none/0
[ 102.618] (**) SYNA2393:00 06CB:7A13 Mouse: (accel) acceleration factor: 2.000
[ 102.618] (**) SYNA2393:00 06CB:7A13 Mouse: (accel) acceleration threshold: 4
[ 102.621] (II) event8 - SYNA2393:00 06CB:7A13 Mouse: is tagged by udev as: Mouse Pointingstick
[ 102.622] (II) event8 - SYNA2393:00 06CB:7A13 Mouse: device is a pointer
[ 102.626] (II) config/udev: Adding input device SYNA2393:00 06CB:7A13 Mouse (/dev/input/mouse0)
[ 102.626] (II) No input driver specified, ignoring this device.
[ 102.626] (II) This device may have been added with another device file.
[ 102.628] (II) config/udev: Adding input device SYNA2393:00 06CB:7A13 Touchpad (/dev/input/event9)
[ 102.628] (**) SYNA2393:00 06CB:7A13 Touchpad: Applying InputClass "evdev touchpad catchall"
[ 102.628] (**) SYNA2393:00 06CB:7A13 Touchpad: Applying InputClass "libinput touchpad catchall"
[ 102.628] (**) SYNA2393:00 06CB:7A13 Touchpad: Applying InputClass "touchpad"
[ 102.628] (II) Using input driver 'libinput' for 'SYNA2393:00 06CB:7A13 Touchpad'
[ 102.628] (**) SYNA2393:00 06CB:7A13 Touchpad: always reports core events
[ 102.628] (**) Option "Device" "/dev/input/event9"
[ 102.632] (II) event9 - SYNA2393:00 06CB:7A13 Touchpad: is tagged by udev as: Touchpad
[ 102.636] (II) event9 - SYNA2393:00 06CB:7A13 Touchpad: device is a touchpad
[ 102.636] (II) event9 - SYNA2393:00 06CB:7A13 Touchpad: device removed
[ 102.697] (**) Option "Tapping" "on"
[ 102.697] (**) Option "TappingButtonMap" "lrm"
[ 102.697] (**) Option "AccelSpeed" "0.4"
[ 102.697] (**) Option "NaturalScrolling" "on"
[ 102.699] (**) Option "ClickMethod" "clickfinger"
[ 102.699] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-2/i2c-SYNA2393:00/0018:06CB:7A13.0002/input/input22/event9"
[ 102.699] (II) XINPUT: Adding extended input device "SYNA2393:00 06CB:7A13 Touchpad" (type: TOUCHPAD, id 14)
[ 102.703] (**) Option "AccelerationScheme" "none"
[ 102.703] (**) SYNA2393:00 06CB:7A13 Touchpad: (accel) selected scheme none/0
[ 102.703] (**) SYNA2393:00 06CB:7A13 Touchpad: (accel) acceleration factor: 2.000
[ 102.703] (**) SYNA2393:00 06CB:7A13 Touchpad: (accel) acceleration threshold: 4
[ 102.706] (II) event9 - SYNA2393:00 06CB:7A13 Touchpad: is tagged by udev as: Touchpad
[ 102.710] (II) event9 - SYNA2393:00 06CB:7A13 Touchpad: device is a touchpad
[ 102.713] (II) config/udev: Adding input device SYNA2393:00 06CB:7A13 Touchpad (/dev/input/mouse1)
[ 102.713] (**) SYNA2393:00 06CB:7A13 Touchpad: Applying InputClass "touchpad"
[ 102.713] (II) Using input driver 'libinput' for 'SYNA2393:00 06CB:7A13 Touchpad'
[ 102.713] (**) SYNA2393:00 06CB:7A13 Touchpad: always reports core events
[ 102.713] (**) Option "Device" "/dev/input/mouse1"
[ 102.777] (II) mouse1 - not using input device '/dev/input/mouse1'.
[ 102.777] (EE) libinput: SYNA2393:00 06CB:7A13 Touchpad: Failed to create a device for /dev/input/mouse1
[ 102.777] (EE) PreInit returned 2 for "SYNA2393:00 06CB:7A13 Touchpad"
[ 102.777] (II) UnloadModule: "libinput"
[ 102.779] (II) config/udev: Adding input device HDA Intel PCH Headphone Mic (/dev/input/event12)
[ 102.779] (II) No input driver specified, ignoring this device.
[ 102.779] (II) This device may have been added with another device file.
[ 102.780] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event13)
[ 102.780] (II) No input driver specified, ignoring this device.
[ 102.780] (II) This device may have been added with another device file.
[ 102.781] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event14)
[ 102.781] (II) No input driver specified, ignoring this device.
[ 102.781] (II) This device may have been added with another device file.
[ 102.782] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event18)
[ 102.782] (II) No input driver specified, ignoring this device.
[ 102.782] (II) This device may have been added with another device file.
[ 102.784] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event19)
[ 102.784] (II) No input driver specified, ignoring this device.
[ 102.784] (II) This device may have been added with another device file.
[ 102.785] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event20)
[ 102.785] (II) No input driver specified, ignoring this device.
[ 102.785] (II) This device may have been added with another device file.
[ 102.786] (II) config/udev: Adding input device Intel HID events (/dev/input/event5)
[ 102.786] (**) Intel HID events: Applying InputClass "evdev keyboard catchall"
[ 102.786] (**) Intel HID events: Applying InputClass "libinput keyboard catchall"
[ 102.786] (**) Intel HID events: Applying InputClass "system-keyboard"
[ 102.786] (II) Using input driver 'libinput' for 'Intel HID events'
[ 102.786] (**) Intel HID events: always reports core events
[ 102.786] (**) Option "Device" "/dev/input/event5"
[ 102.788] (II) event5 - Intel HID events: is tagged by udev as: Keyboard
[ 102.788] (II) event5 - Intel HID events: device is a keyboard
[ 102.789] (II) event5 - Intel HID events: device removed
[ 102.817] (**) Option "config_info" "udev:/sys/devices/platform/INT33D5:00/input/input6/event5"
[ 102.818] (II) XINPUT: Adding extended input device "Intel HID events" (type: KEYBOARD, id 15)
[ 102.818] (**) Option "xkb_model" "pc105"
[ 102.818] (**) Option "xkb_layout" "ch"
[ 102.818] (**) Option "xkb_variant" "de_nodeadkeys"
[ 102.820] (II) event5 - Intel HID events: is tagged by udev as: Keyboard
[ 102.820] (II) event5 - Intel HID events: device is a keyboard
[ 102.822] (II) config/udev: Adding input device Intel HID 5 button array (/dev/input/event6)
[ 102.822] (**) Intel HID 5 button array: Applying InputClass "evdev keyboard catchall"
[ 102.822] (**) Intel HID 5 button array: Applying InputClass "libinput keyboard catchall"
[ 102.822] (**) Intel HID 5 button array: Applying InputClass "system-keyboard"
[ 102.822] (II) Using input driver 'libinput' for 'Intel HID 5 button array'
[ 102.822] (**) Intel HID 5 button array: always reports core events
[ 102.822] (**) Option "Device" "/dev/input/event6"
[ 102.824] (II) event6 - Intel HID 5 button array: is tagged by udev as: Keyboard
[ 102.824] (II) event6 - Intel HID 5 button array: device is a keyboard
[ 102.825] (II) event6 - Intel HID 5 button array: device removed
[ 102.857] (**) Option "config_info" "udev:/sys/devices/platform/INT33D5:00/input/input7/event6"
[ 102.857] (II) XINPUT: Adding extended input device "Intel HID 5 button array" (type: KEYBOARD, id 16)
[ 102.857] (**) Option "xkb_model" "pc105"
[ 102.857] (**) Option "xkb_layout" "ch"
[ 102.857] (**) Option "xkb_variant" "de_nodeadkeys"
[ 102.860] (II) event6 - Intel HID 5 button array: is tagged by udev as: Keyboard
[ 102.860] (II) event6 - Intel HID 5 button array: device is a keyboard
[ 102.862] (II) config/udev: Adding input device Dell WMI hotkeys (/dev/input/event17)
[ 102.863] (**) Dell WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 102.863] (**) Dell WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 102.863] (**) Dell WMI hotkeys: Applying InputClass "system-keyboard"
[ 102.863] (II) Using input driver 'libinput' for 'Dell WMI hotkeys'
[ 102.863] (**) Dell WMI hotkeys: always reports core events
[ 102.863] (**) Option "Device" "/dev/input/event17"
[ 102.865] (II) event17 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 102.866] (II) event17 - Dell WMI hotkeys: device is a keyboard
[ 102.867] (II) event17 - Dell WMI hotkeys: device removed
[ 102.924] (**) Option "config_info" "udev:/sys/devices/platform/PNP0C14:05/wmi_bus/wmi_bus-PNP0C14:05/PNP0C14:05-9DBB5994-A997-11DA-B012-B622A1EF5492/input/input20/event17"
[ 102.924] (II) XINPUT: Adding extended input device "Dell WMI hotkeys" (type: KEYBOARD, id 17)
[ 102.924] (**) Option "xkb_model" "pc105"
[ 102.924] (**) Option "xkb_layout" "ch"
[ 102.924] (**) Option "xkb_variant" "de_nodeadkeys"
[ 102.928] (II) event17 - Dell WMI hotkeys: is tagged by udev as: Keyboard
[ 102.928] (II) event17 - Dell WMI hotkeys: device is a keyboard
[ 102.931] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[ 102.931] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 102.931] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 102.931] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 102.931] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 102.931] (**) AT Translated Set 2 keyboard: always reports core events
[ 102.931] (**) Option "Device" "/dev/input/event4"
[ 102.933] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 102.934] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 102.937] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 102.964] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[ 102.964] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 18)
[ 102.964] (**) Option "xkb_model" "pc105"
[ 102.964] (**) Option "xkb_layout" "ch"
[ 102.964] (**) Option "xkb_variant" "de_nodeadkeys"
[ 102.967] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 102.968] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 102.972] (II) config/udev: Adding input device PS/2 Synaptics TouchPad (/dev/input/event21)
[ 102.972] (**) PS/2 Synaptics TouchPad: Applying InputClass "evdev pointer catchall"
[ 102.972] (**) PS/2 Synaptics TouchPad: Applying InputClass "libinput pointer catchall"
[ 102.973] (**) PS/2 Synaptics TouchPad: Applying InputClass "libinput pointer catchall"
[ 102.973] (II) Using input driver 'libinput' for 'PS/2 Synaptics TouchPad'
[ 102.973] (**) PS/2 Synaptics TouchPad: always reports core events
[ 102.973] (**) Option "Device" "/dev/input/event21"
[ 102.975] (II) event21 - PS/2 Synaptics TouchPad: is tagged by udev as: Mouse
[ 102.975] (II) event21 - PS/2 Synaptics TouchPad: device is a pointer
[ 102.976] (II) event21 - PS/2 Synaptics TouchPad: device removed
[ 103.031] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input9/event21"
[ 103.031] (II) XINPUT: Adding extended input device "PS/2 Synaptics TouchPad" (type: MOUSE, id 19)
[ 103.031] (**) Option "AccelerationScheme" "none"
[ 103.031] (**) PS/2 Synaptics TouchPad: (accel) selected scheme none/0
[ 103.031] (**) PS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 103.031] (**) PS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 103.034] (II) event21 - PS/2 Synaptics TouchPad: is tagged by udev as: Mouse
[ 103.034] (II) event21 - PS/2 Synaptics TouchPad: device is a pointer
[ 103.036] (II) config/udev: Adding input device PS/2 Synaptics TouchPad (/dev/input/mouse4)
[ 103.036] (II) No input driver specified, ignoring this device.
[ 103.036] (II) This device may have been added with another device file.
[ 103.038] (II) config/udev: Adding input device PC Speaker (/dev/input/event7)
[ 103.038] (II) No input driver specified, ignoring this device.
[ 103.038] (II) This device may have been added with another device file.
[ 103.303] (II) event3 - Power Button: device removed
[ 103.321] (II) event15 - Video Bus: device removed
[ 103.351] (II) event16 - Video Bus: device removed
[ 103.404] (II) event1 - Power Button: device removed
[ 103.417] (II) event2 - Sleep Button: device removed
[ 103.444] (II) event10 - Wacom HID 488E Pen: device removed
[ 103.481] (II) event11 - Wacom HID 488E Finger: device removed
[ 103.551] (II) event8 - SYNA2393:00 06CB:7A13 Mouse: device removed
[ 103.604] (II) event9 - SYNA2393:00 06CB:7A13 Touchpad: device removed
[ 103.657] (II) event5 - Intel HID events: device removed
[ 103.681] (II) event6 - Intel HID 5 button array: device removed
[ 103.711] (II) event17 - Dell WMI hotkeys: device removed
[ 103.757] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 103.807] (II) event21 - PS/2 Synaptics TouchPad: device removed
[ 103.901] (II) UnloadModule: "libinput"
[ 103.902] (II) UnloadModule: "libinput"
[ 103.904] (II) UnloadModule: "libinput"
[ 104.017] (II) Server terminated successfully (0). Closing log file.
I am adding some inxi data. Let me know if I can add more.
~ $ inxi -G
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] driver: i915 v: kernel
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] driver: nvidia
v: 510.47.03
Display: server: X.Org 1.21.1.3 driver: loaded: modesetting
resolution: 3840x2160~60Hz
