Hello there!
I’m trying to be able to log into an XMonad session with gdm - or any display manager, I just want to be able to have xmonad as my window manager with all the bells and whistles of gnome (to take care of things like power management, display scaling, etc). It would also be nice to be able to transition to plane gnome when I want to.
What I tried so far, after a long googling session, is setting the contents of the following files:
/usr/share/applications/xmonad.desktop
[Desktop Entry]
Type=Application
Encoding=UTF-8
Name=XMonad
Exec=/home/yecinem/.local/bin/xmonad
/usr/share/gnome-session/sessions/xmonad.session
[GNOME Session]
Name=XMonad
RequiredComponents=gnome-panel;gnome-settings-daemon;xmonad;
/usr/share/xsessions/gnome-xmonad.desktop
[Desktop Entry]
Name=Gnome with XMonad
Comment=Gnome with XMonad as window manager
TryExec=gnome-session
Exec=gnome-session --session=XMonad
Type=Application
With that, I can choose Gnome with XMonad
session from the login screen, but I get greeted oh no something has gone wrong
with plane GNOME and a prompt to logout
Here is my system information
$ inxi -Faxxi
System: Host: yecine-xps159560 Kernel: 5.4.72-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=fa197283-acde-4f0e-966c-e1fc4f8f94df rw
acpi_rev_override=1 pcie_aspm=off acpi_blacklight=none acpi_osi=! "acpi_osi=Windows 2009" apparmor=1
security=apparmor resume=UUID=997a0a2e-1817-4b2e-8a35-0da6cbca7efe udev.log_priority=3
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 info: docker wm: gnome-shell dm: GDM 3.36.3 Distro: Manjaro Linux
Machine: Type: Laptop System: Dell product: XPS 15 9560 v: N/A serial: <superuser/root required> Chassis: type: 10
Mobo: Dell model: 05FFDN v: A00 serial: <superuser/root required> UEFI: Dell v: 1.19.2 date: 05/22/2020
Battery: ID-1: BAT0 charge: 67.6 Wh condition: 67.6/97.0 Wh (70%) volts: 12.7/11.4 model: SMP DELL GPM0365 type: Li-ion
serial: 419 status: Full
CPU: Topology: Quad Core model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake family: 6 model-id: 9E (158)
stepping: 9 microcode: D6 L2 cache: 6144 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 44817
Speed: 900 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 900 2: 900 3: 901 4: 900 5: 900 6: 900 7: 900 8: 900
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel HD Graphics 630 vendor: Dell driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:591b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Dell driver: nvidia v: 440.100
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1c8d
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB driver: uvcvideo bus ID: 1-12:6 chip ID: 1bcf:2b95
Display: x11 server: X.org 1.20.9 compositor: gnome-shell driver: modesetting alternate: fbdev,intel,vesa
resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 20.1.8 direct render: Yes
Audio: Device-1: Intel CM238 HD Audio vendor: Dell driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a171
Sound Server: ALSA v: k5.4.72-1-MANJARO
Network: Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter vendor: Bigfoot Networks driver: ath10k_pci
v: kernel port: e000 bus ID: 02:00.0 chip ID: 168c:003e
IF: wlp2s0 state: up mac: 9c:b6:d0:f3:d6:2b
IP v4: 192.168.1.6/24 type: dynamic noprefixroute scope: global broadcast: 192.168.1.255
IP v6: fe80::22d:5483:32ff:a374/64 type: noprefixroute scope: link
Device-2: Qualcomm Atheros QCA61x4 Bluetooth 4.0 type: USB driver: btusb bus ID: 1-4:4 chip ID: 0cf3:e300
IF-ID-1: br-1a722309b403 state: up speed: N/A duplex: N/A mac: 02:42:51:7b:d5:73
IP v4: 172.18.0.1/16 scope: global broadcast: 172.18.255.255
IP v6: fe80::42:51ff:fe7b:d573/64 scope: link
IF-ID-2: docker0 state: up speed: N/A duplex: N/A mac: 02:42:bb:a4:ef:03
IP v4: 172.17.0.1/16 scope: global broadcast: 172.17.255.255
IP v6: fe80::42:bbff:fea4:ef03/64 scope: link
IF-ID-3: vethc6f365c state: up speed: 10000 Mbps duplex: full mac: 56:9e:24:13:80:cd
IF-ID-4: vetheff34bc state: up speed: 10000 Mbps duplex: full mac: 86:77:54:42:e9:d3
WAN IP: 89.246.239.190
Drives: Local Storage: total: 953.87 GiB used: 33.70 GiB (3.5%)
ID-1: /dev/nvme0n1 vendor: Toshiba model: KXG50ZNV1T02 NVMe 1024GB size: 953.87 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: X7ES100ETYAT rev: AADA4102 scheme: GPT
Partition: ID-1: / raw size: 919.23 GiB size: 903.80 GiB (98.32%) used: 33.70 GiB (3.7%) fs: ext4 dev: /dev/nvme0n1p2
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 34.34 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 54.5 C mobo: N/A
Fan Speeds (RPM): cpu: 2512 fan-2: 2509
Info: Processes: 305 Uptime: 45m Memory: 31.22 GiB used: 2.90 GiB (9.3%) Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: pacman: 1433 lib: 316 flatpak: 0 Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.1.05
