I’m using a notebook and another monitor. Then I use the option to extend the screen to use the system. However, sometimes out of the blue my monitor stops being recognized so I have to go to settings and enable it again. But when I enable, his image doesn’t come back. So I need to restart Manjaro for the image to come back. This problem only happens when I lock the screen. It doesn’t happen all the time, but at least it does happen once or twice a day.
It is quite inconvenient to use Manjaro with this problem happening, how can I solve it?
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=f49fd7b0-0507-4b07-a9a7-92c83878841d rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor
resume=UUID=eac7d739-2bd9-4618-a49b-3387fa9fc41d udev.log_priority=3
Desktop: GNOME v: 42.4 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X515JA_X515JA
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: X515JA v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X515JA.306 date: 06/02/2021
ID-1: BAT0 charge: 35.2 Wh (100.0%) condition: 35.2/37.1 Wh (94.7%)
volts: 7.8 min: 7.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: not charging cycles: 29
RAM: total: 7.51 GiB used: 2.53 GiB (33.7%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i5-1035G1 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 built: 2019-21 process: Intel 10nm family: 6
model-id: 0x7E (126) stepping: 5 microcode: 0xB2
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 3049 high: 3390 min/max: 400/3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 3007 2: 2774 3: 2887
4: 3079 5: 3390 6: 3233 7: 3128 8: 2896 bogomips: 19048
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma
avx512vbmi avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid
x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel Iris Plus Graphics G1 vendor: ASUSTeK driver: i915 v: kernel
arch: Gen-11 process: Intel 10nm built: 2019-21 ports:
active: HDMI-A-1,eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:8a56
class-ID: 0300
Device-2: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 13d3:5a11 class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: HDMI-A-1 model: LG (GoldStar) FULL HD serial: <filter>
built: 2016 res: 1920x1080 dpi: 102 gamma: 1.2 size: 480x270mm (18.9x10.63")
diag: 551mm (21.7") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: eDP-1 model: ChiMei InnoLux 0x15f5 built: 2017 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 22.1.6
direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
bus-ID: 00:1f.3 chip-ID: 8086:34c8 class-ID: 0403
Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0
chip-ID: 10ec:c821 class-ID: 0280
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-10:5 chip-ID: 13d3:3529 class-ID: e001 serial: <filter>
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 4060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 476.94 GiB used: 13.34 GiB (2.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: WinMemory model: SWG512G-114HI
lanes: 4 type: SSD serial: <filter> rev: EDFM60.0 temp: 18.9 C scheme: GPT
ID-1: / raw-size: 190.73 GiB size: 190.73 GiB (100.00%) used: 13.34 GiB
(7.0%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: f49fd7b0-0507-4b07-a9a7-92c83878841d
ID-2: /boot/efi raw-size: 600 MiB size: 598.8 MiB (99.80%) used: 608 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5 label: NO_LABEL
uuid: 8800-531D
ID-3: /home raw-size: 190.73 GiB size: 190.73 GiB (100.00%) used: 13.34
GiB (7.0%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
ID-4: /var/cache raw-size: 190.73 GiB size: 190.73 GiB (100.00%) used: 13.34
ID-5: /var/log raw-size: 190.73 GiB size: 190.73 GiB (100.00%) used: 13.34
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: eac7d739-2bd9-4618-a49b-3387fa9fc41d
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: E82C-D62B
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 280.92 GiB fs: ntfs label: N/A
uuid: D4422FB4422F9A6E
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 604 MiB fs: ntfs label: N/A
uuid: 149AAFC59AAFA22A
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-2:2 info: Logitech Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046d:c077 class-ID: 0301
Device-2: 1-5:3 info: IMC Networks USB2.0 VGA UVC WebCam type: Video
Device-3: 1-6:4 info: BY Tech Gaming Keyboard type: Keyboard,HID
power: 500mA chip-ID: 258a:0049 class-ID: 0300
Device-4: 1-10:5 info: IMC Networks Bluetooth Radio type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 500mA
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 63.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2300
Processes: 302 Uptime: 5m wakeups: 1 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 1211
lib: 307 flatpak: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal
inxi: 3.3.20
Display settings:
