keos
7 September 2020 13:10
1
Hello,
I’m having problems to update the system.
error: failed retrieving file 'archlinuxfr.db' from repo.archlinux.fr : Failed to connect to repo.archlinux.fr port 80: Connection timed out
error: failed to update archlinuxfr (download library error)
error: failed to synchronize all databases
And for some reason i’m not able to post the whole outcome here at the forum.
[“No links allow in your post”] (?).
And … [“You can not embed media in yours …”]
Thanks.
visone
7 September 2020 13:16
2
Hi!
try to change the country ant check if it work.
sudo pacman-mirrors -c Belgium && sudo pacman -Syyu
bill_t
7 September 2020 13:24
3
keos:
repo.archlinux.fr
This is an unofficial user repository for Arch as mentioned here:
https://wiki.archlinux.org/index.php/Unofficial_user_repositories#archlinuxfr
It seems to be down at the moment, that’s probably why you get the Connection timed out error.
You can comment the lines referring to this repository you added in the /etc/pacman.conf
file and try to update your system again.
keos
7 September 2020 13:30
4
[keoss keos]# pacman -Syyu
core 168.7 KiB 734 KiB/s 00:00 [#####################] 100%
extra 2013.9 KiB 1316 KiB/s 00:02 [#####################] 100%
community 6.1 MiB 558 KiB/s 00:11 [#####################] 100%
multilib 194.9 KiB 974 KiB/s 00:00 [#####################] 100%
error: failed to update archlinuxfr (no servers configured for repository)
[keoss keos]#
This is after commented the … as you indicated …
sudo pacman-mirrors -f 5 && sudo pacman -Syyu
keos
7 September 2020 13:42
6
[keoss keos]# sudo pacman-mirrors -f 5 && sudo pacman -Syyu
@Aragorn The same windows saying i’m not able to post links …
so i can’t post the outcome …
Click on the </> button in the toolbar. You will see two lines of three backticks (```) appear. Paste the output in between those two lines.
keos
7 September 2020 13:47
8
that is what i have been doing all the times …
visone
7 September 2020 13:48
9
Hi!
Did you able to update correctly?
If not, copy the error with Ctrl+alt+c paste it here
If it the same error, edit /etc/pacman.conf as root and comment the lines of that repo, like @bill_t told you before
keos
7 September 2020 13:49
10
i already commented the line … got the same thing
visone
7 September 2020 13:51
11
Hi!
Any other lines referring to that server?
Can you upload the file to some paste in and post the link like this http : // link
jabber
7 September 2020 13:52
12
Are you sure you commented the lines out?
You add a # sign in front of the lines. This is what commenting the lines out should look like:
# [archlinuxfr]
# Server = http://repo.archlinux.fr/$arch
keos
7 September 2020 13:54
13
i went back and uncomented the line…
At the end we can read this:
error: failed retrieving ... 'archlinuxfr.db' from repo.archlinux.fr ... Failed to connect to repo.archlinux.fr port 80: Connection refused
[keoss keos]#
keos
7 September 2020 13:59
14
@jabber there is another line too
SigLevel = never
do i have to comment this line too?
Look in your /etc/pacman.d/mirrorlist
and see if the server is listed there. If it is, comment it out.
jabber
7 September 2020 14:05
16
Probably not, but you might as well comment it out too, just for clarity.
keos
7 September 2020 14:08
17
Aragorn:
@jabber now it is “updated”:
Starting full system upgrade…
there is nothing to do
jabber
7 September 2020 14:09
18
The last Stable update was 2020-08-28.
keos
7 September 2020 14:12
19
It is impossible to continue like this … Why i cant post anything here at the forum?. is it a new regulation?
jabber
7 September 2020 14:14
20
Do this:
If the output says there’s nothing to update, then you’re up to date.
