Kernel: 5.15.50-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=de_DE keytable=de tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2132 quiet
systemd.show_status=1 driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
Type: Server System: Supermicro product: X10SRA v: 0123456789
serial: <filter> Chassis: type: 17 v: 0123456789 serial: <filter>
Mobo: Supermicro model: X10SRA v: 1.01 serial: <filter>
UEFI-[Legacy]: American Megatrends v: 2.1a date: 10/24/2018
Info: model: Intel Core i7-6800K socket: LGA2011-3 bits: 64 type: MT MCP
arch: Broadwell gen: core 6 built: 2015-18 process: Intel 14nm family: 6
model-id: 0x4F (79) stepping: 1 microcode: 0xB00002E
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 15 MiB desc: 1x15 MiB
Speed (MHz): avg: 1217 high: 1400 min/max: 1200/3800
base/boost: 3400/4000 scaling: driver: intel_cpufreq governor: schedutil
volts: 1.8 V ext-clock: 100 MHz cores: 1: 1201 2: 1201 3: 1200 4: 1201
5: 1201 6: 1201 7: 1400 8: 1200 9: 1201 10: 1200 11: 1202 12: 1200
bogomips: 81634
Type: l1tf
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
Type: mmio_stale_data status: Vulnerable: Clear CPU buffers attempted, no
microcode; SMT vulnerable
Type: tsx_async_abort status: Vulnerable: Clear CPU buffers attempted, no
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: Micro-Star MSI
driver: nouveau v: kernel non-free: 515.xx+ status: current (as of 2022-06)
arch: Turing process: TSMC 12nm built: 2018-22 pcie: gen: 1
speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: DP-1 empty: DVI-D-1,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 10de:1f82
class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: nouveau display-ID: :0
screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
s-diag: 777mm (30.58")
Monitor-1: DP-1 model: Dell U2713HM serial: <filter> built: 2012
res: 2560x1440 hz: 60 dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23")
diag: 685mm (27") ratio: 16:9 modes: max: 2560x1440 min: 720x400
OpenGL: renderer: NV167 v: 4.3 Mesa 22.1.2 direct render: Yes
Device-1: Intel C610/X99 series HD Audio vendor: Super Micro
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8d20
class-ID: 0403
Device-2: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
bus-ID: 03:00.1 chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.15.50-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Intel I210 Gigabit Network vendor: Super Micro driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0
chip-ID: 8086:1533 class-ID: 0200
Device-2: Intel I210 Gigabit Network vendor: Super Micro driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 06:00.0
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.39 TiB used: 0 KiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: 5B2QGXA7
temp: 22.9 C scheme: GPT
SMART: yes health: PASSED on: 10d 13h cycles: 2,721
read-units: 22,409,816 [11.4 TB] written-units: 6,831,248 [3.49 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 PRO 512GB
family: based SSDs size: 476.94 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 4B6Q temp: 22 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 374d 13h cycles: 23522
written: 6.61 TiB
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Ultra Fit
size: 14.32 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
Message: No partition data found.
System Temperatures: cpu: 17.0 C mobo: N/A gpu: nouveau temp: 21.0 C
Processes: 283 Uptime: 1m wakeups: 0 Memory: 31.23 GiB
used: 1.54 GiB (4.9%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1195
lib: 321 flatpak: 0 Shell: Bash (su) v: 5.1.16 running-in: konsole
inxi: 3.3.19
test -d /sys/firmware/efi && echo efi || echo bios
bios
sudo efibootmgr -v
```EFi variables are not supported on this system```
parted -l
Model: ATA Samsung SSD 850 (scsi)
Disk /dev/sda: 512GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 512GB 512GB ext4
Model: SanDisk Ultra Fit (scsi)
Disk /dev/sdb: 15,4GB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 15,3GB 15,3GB primary boot
2 15,3GB 15,4GB 33,6MB primary fat16 esp
Model: Samsung SSD 980 PRO 1TB (nvme)
Disk /dev/nvme0n1: 1000GB
Disk Flags:
1 1049kB 106MB 105MB fat32 EFI system partition boot, esp
2 106MB 123MB 16,8MB Microsoft reserved partition msftres
3 123MB 500GB 499GB ntfs Basic data partition msftdata
4 500GB 500GB 551MB ntfs hidden, diag
5 500GB 500GB 315MB fat32 boot, esp
6 500GB 501GB 1074MB ext4
7 501GB 536GB 34,4GB linux-swap(v1) swap
8 536GB 643GB 107GB ext4
9 643GB 965GB 322GB ext4
10 965GB 1000GB 34,9GB ext4
