Problems installing Manjaro on an SSD that previously had a different distro
Greetings everyone,
As the title states, I have problems installing Manjaro. The SSD in question currently has Windows 10 1903 installed, and it previously had Solus 4. I'm confident this error is happening because I didn't format the drive when installing W10, I just deleted the partitions (dumb mistake). The problem in question can be seen in the following picture:
Thanks in advance.
You probably need to restore GRUB:
https://wiki.manjaro.org/index.php/Restore_the_GRUB_Bootloader
There's another guide here:
can you lauch an de reboot
with USB install manjaro
open a terminal
fdisk -l
efibootmgr
Is this when you try to boot from USB or after install?
Because if it's after then yes, as @jonathon says a Grub2 restore seems to be the cure. If it's before then it seems your computer can't find / can't boot from the usb in which case remaking the USB and be sure it's done right is the way to go.
Hi! :slightly_smiling_face:
I think :thinking: ... you can try to restore with "parted ".
@jonathon @Beardedgeek72 He deleted the partitions! I dont know why but he did. "grub" restore will not work. Seen on the picture. "Grub" says "Eat my shorts!". He can try to restore partitions. Thats all, i think.
Use this.
