Hi. I can’t avoid my laptop to wake up from sleep when opening the lid.
I’ve tried the logind.conf
way and disabling everything in /proc/acpi/wakeup
with no luck:
[I] i ) cat /etc/systemd/logind.conf
# This file is part of systemd.
# systemd is free software; you can redistribute it and/or modify it under the
# terms of the GNU Lesser General Public License as published by the Free
# Software Foundation; either version 2.1 of the License, or (at your option)
# any later version.
# Entries in this file show the compile time defaults. Local configuration
# should be created by either modifying this file, or by creating "drop-ins" in
# the logind.conf.d/ subdirectory. The latter is generally recommended.
# Defaults can be restored by simply deleting this file and all drop-ins.
# Use 'systemd-analyze cat-config systemd/logind.conf' to display the full config.
# See logind.conf(5) for details.
[Login]
#NAutoVTs=6
#ReserveVT=6
#KillUserProcesses=no
#KillOnlyUsers=
#KillExcludeUsers=root
#InhibitDelayMaxSec=5
#UserStopDelaySec=10
#HandlePowerKey=poweroff
#HandleSuspendKey=suspend
#HandleHibernateKey=hibernate
HandleLidSwitch=ignore
HandleLidSwitchExternalPower=ignore
HandleLidSwitchDocked=ignore
#HandleRebootKey=reboot
#PowerKeyIgnoreInhibited=no
#SuspendKeyIgnoreInhibited=no
#HibernateKeyIgnoreInhibited=no
#LidSwitchIgnoreInhibited=no
#RebootKeyIgnoreInhibited=no
#HoldoffTimeoutSec=30s
#IdleAction=ignore
#IdleActionSec=30min
#RuntimeDirectorySize=10%
#RuntimeDirectoryInodes=400k
#RemoveIPC=yes
#InhibitorsMax=8192
#SessionsMax=8192
[I] i ) cat /proc/acpi/wakeup
Device S-state Status Sysfs node
GP17 S4 *disabled pci:0000:00:08.1
XHC0 S4 *disabled pci:0000:06:00.3
XHC1 S4 *disabled pci:0000:06:00.4
GP18 S4 *disabled pci:0000:00:08.2
GP19 S4 *disabled
PS2K S3 *disabled pnp:00:02
*enabled serio:serio0
GPP0 S4 *disabled pci:0000:00:01.1
GPP4 S4 *disabled pci:0000:00:02.2
GPP1 S4 *disabled pci:0000:00:01.2
XPDV S3 *disabled pci:0000:02:00.0
GPP5 S4 *disabled
TAAD S4 *disabled platform:ACPI000E:00
I’ve also tried disabling anything but LNXPWRBN:00
in /sys/bus/acpi/devices
[I] / ) cd /sys/bus/acpi/devices/
[I] devices ) for w in (find */power/wakeup); echo $w " - " (cat /sys/bus/acpi/devices/$w); end
LNXPWRBN:00/power/wakeup - enabled
PNP0C0A:00/power/wakeup - disabled
PNP0C0C:00/power/wakeup - disabled
PNP0C0D:00/power/wakeup - disabled
and in /sys/devices
[I] i ) cd /sys/devices
[I] devices ) for i in (ls)
cd $i
echo \n $i ; cat (find */power/wakeup)
cd /sys/devices
end
amd_iommu_0
breakpoint
cpu
ibs_fetch
ibs_op
isa
kprobe
LNXSYSTM:00
enabled
msr
pci0000:00
disabled
disabled
disabled
disabled
disabled
disabled
disabled
platform
disabled
pnp0
disabled
disabled
power
software
system
tracepoint
uprobe
virtual
What should I try next?
Systen info:
[I] i ) inxi --admin --verbosity=7 --filter --width
Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=019b262f-ae54-4129-a8ab-7a5227d2dfe6 rw loglevel=3
Desktop: i3 v: 4.20.1 info: i3bar vt: 7 dm: LightDM v: 1.30.0
Type: Laptop System: HP product: OMEN Laptop 15-en0xxx v: N/A
Mobo: HP model: 8787 v: 22.58 serial: <superuser required> UEFI: AMI
v: F.13 date: 03/04/2021
ID-1: BAT0 charge: 48.8 Wh (82.0%) condition: 59.5/59.5 Wh (100.0%)
volts: 12.8 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: N/A status: charging cycles: 535
RAM: total: 15.06 GiB used: 3.39 GiB (22.5%)
RAM Report:
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1396 high: 1397 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: powersave cores: 1: 1397 2: 1397
3: 1396 4: 1397 5: 1397 6: 1397 7: 1396 8: 1397 9: 1397 10: 1397 11: 1397
12: 1397 13: 1397 14: 1397 15: 1397 16: 1397 bogomips: 92660
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: none empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f15
class-ID: 0300
Device-2: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: eDP-1 empty: none bus-ID: 06:00.0 chip-ID: 1002:1636
class-ID: 0300
Device-3: Luxvisions Innotech HP Wide Vision HD Camera type: USB
driver: uvcvideo bus-ID: 3-3:2 chip-ID: 30c9:000e class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 compositor: Picom v: git-7e568
driver: X: loaded: amdgpu,nvidia gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0852 built: 2018
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.15.28-1-MANJARO LLVM 13.0.1)
v: 4.6 Mesa 21.3.7 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10f9 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x,snd_pci_acp5x
bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.48 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:3
Report: bt-adapter ID: hci0 rfk-id: 11 state: down
bt-service: enabled,running rfk-block: hardware: no software: no
address: <filter>
Local Storage: total: 476.94 GiB used: 111.22 GiB (23.3%)
model: PC SN730 SDBPNTY-512G-1006 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: HPS2 temp: 32.9 C scheme: GPT
ID-1: / raw-size: 146.48 GiB size: 143.13 GiB (97.71%)
used: 111.22 GiB (77.7%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: 019b262f-ae54-4129-a8ab-7a5227d2dfe6
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 260 MiB fs: vfat label: SYSTEM
uuid: E23D-37EB
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 329.67 GiB fs: ntfs
label: Windows uuid: D06EF8AA6EF88A8C
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 525 MiB fs: ntfs
label: Windows RE tools uuid: 44E2E965E2E95BA4
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Luxvisions Innotech HP Wide Vision HD Camera
type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 30c9:000e class-ID: 0e02
Device-2: 3-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 41.0 C mobo: N/A gpu: amdgpu temp: 41.0 C
Processes: 361 Uptime: 16h 10m wakeups: 11091 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1862
lib: 434 flatpak: 0 Shell: fish v: 3.3.1 running-in: urxvtd inxi: 3.3.15
