I have seen some posts that resemble my issue.
I have learned to live with it so I just want to document that I have this issue to add to the reports of it.
I am on unstable and will include my latest system info below.
I don’t know if there is some settings to change to help this.
I’m on plasma and after waking up from closing the laptop lid which is set to put computer to sleep , not every time but most of the time when I either click the terminal or go to the upper left with the cursor the screen fills with triangle that move around and change shapes as I move the cursor around.
That is the best way I can describe it.
Sometimes if I get the upper left process to show the open windows correctly and click on the terminal one. I can’t see it but I can type sudo reboot and get the machine to reboot.
My work around right now is to just shut the machine down instead of letting it go to sleep.
Thanks
[demo@manjaro ventoy]$ inxi -Faz
Kernel: 6.0.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=45ca132d-4a37-4dc3-afa0-be2e80d6a4a2 rw quiet pci=nocrs
acpi=force "acpi_osi=Windows 2022" ibt=off mem_sleep_default=s2idle
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Convertible System: HP product: HP Spectre x360 Convertible 15-df1xxx
v: N/A serial: <superuser required> Chassis: type: 31
Mobo: HP model: 863F v: 54.24 serial: <superuser required> UEFI: AMI
v: F.28 date: 07/14/2022
ID-1: BAT0 charge: 66.9 Wh (100.0%) condition: 66.9/66.9 Wh (100.0%)
volts: 13.0 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
status: full cycles: 182
Device-1: hid-0018:04F3:2992.0001-battery model: ELAN2514:00 04F3:2992
serial: N/A charge: N/A status: N/A
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 10 level: v3 note: check
built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xF4
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2112 high: 2300 min/max: 400/4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 2300 2: 2300 3: 800
4: 2300 5: 2300 6: 2300 7: 2300 8: 2300 bogomips: 36812
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Hewlett-Packard
ports: active: eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:9b41
class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX250] vendor: Hewlett-Packard
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 4
bus-ID: 3b:00.0 chip-ID: 10de:1d13 class-ID: 0302
Device-3: Chicony HP Wide Vision FHD Camera type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 04f2:b67b class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.00x22.48")
s-diag: 1165mm (45.88")
Monitor-1: eDP-1 mapped: eDP-1-1 model: AU Optronics 0x30eb built: 2017
res: 3840x2160 hz: 60 dpi: 284 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: 3840x2160
API: OpenGL v: 4.6.0 NVIDIA 520.56.06 renderer: NVIDIA GeForce
MX250/PCIe/SSE2 direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Hewlett-Packard
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:02c8 class-ID: 0401
Sound API: ALSA v: k6.0.10-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.60 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Local Storage: total: 931.51 GiB used: 270.01 GiB (29.0%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 41.9 C scheme: GPT
ID-1: / raw-size: 239 GiB size: 234.94 GiB (98.30%) used: 44.47 GiB (18.9%)
fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
used: 68.8 MiB (71.6%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 415.57 GiB size: 407.98 GiB (98.17%)
used: 225.47 GiB (55.3%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
System Temperatures: cpu: 48.0 C pch: 46.0 C mobo: N/A gpu: nvidia
temp: 56 C
Processes: 241 Uptime: 42m wakeups: 2547 Memory: 15.26 GiB
used: 3.76 GiB (24.6%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1645
pm: pacman pkgs: 1639 libs: 432 tools: pamac,pikaur,yay pm: flatpak pkgs: 6
pm: snap pkgs: 0 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.23
