Problems after system update
Because I don’t know which information from there is important. I have written here every information of which I think that it is helpful.
Normally that would just be the grub package, and possibly os-prober, although the grub package should normally pull that in as a dependency. I would suggest rolling back os-prober first and grub afterwards, just to be sure.
output from
inxi -zv8
would be a good start. Then post that using the </> button.
Thank you!
The rollback helped; more or less. Grub seems to work. When I booted Manjaro the first time after the rollback I got a black screen just after the login and the monitor showed that there was no signal. After I rebooted the system I found out that the system wanted to start Kodi instead of the desktop. After I had chosen Wayland Linux started normal. To be safe I shall test the system the next days. Than I shall report, if the problem is solved.
If the old grub works, the problem has to be the version discrepancy between the mbr part of grub and the root partition part. Which should have been fixed with reinstallation of the newer grub on the mbr from chroot, as per wiki, posted in the second post. But you said it had not worked so… :man_shrugging:
@Umbra_noctis
I believe @Molski asked whether you simply replaced the content of mkinitcpio.conf with that of mkinitcpio.conf.pacnew, in an attempt to establish whether that might have been the cause of the subsequent boot failure.
Once the large update has been performed, use of the following ISO file might be prudent from that point on, or until the respective ISOs are made available from Manjaro Downloads.
Links to the Anh-Linh 25.1-pre1 (2025-12-08) ISO for your preferred Manjaro edition can be found in the Stable Update 2025-12-08 thread under the heading Additional Info.
I did nothing but a normal update.
So the update 100% successfully completed, you rebooted, and nothing but a black screen. (Using the old mkinitcpio configuration, as you do not do know how to deal with pacnew files.)
You can’t run Manjaro for long until you learn how to handle configuration changes via pacnew files. It will most likely break, it will just take a matter of time.
Almost all booting problems with this update, are related to this one certain change. I know other systems boot fine not using the new format, but not much beyond that. But you didn’t even implement it, so I think it should still boot just fine.
In the other thread, we disabled os-prober, and got the menu hard coded booting MBR via UUID. So it should be solid there, with nothing tampering with grub. And I don’t know what would make it not boot off hand. There is not much to go off of to be honest.
Umbra_noctis provide everyone this information, and copy and paste the output. It is hard for anyone to help with no information. (You can’t just say, “Just go look at the 100+ messages over there.”)
Last thing I knew, was helping you get manjaro-chroot working. Did that work? I’m lost.
I have been using manjaro since 2017. It has been working on 4 Computers and I hardly ever had a problem. To be honest the only major problem was an update in Decembre 2018.
I have never heard about pacnew-files until you mentioned them.
I was so happy about the working Grub that I have forgotten this:
  Kernel: 6.12.61-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=7577eecb-23f7-4a07-8eac-a01a3d8d9240 rw quiet splash
    resume=UUID=8708d9e9-4e5b-490b-b93e-465abbd4a30a udev.log_priority=3
  Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A info: frameworks v: 6.20.0
  Type: Desktop Mobo: Micro-Star model: X399 SLI PLUS (MS-7B09) v: 2.0
    serial: <superuser required> uuid: <superuser required>
    Firmware: UEFI-[Legacy] vendor: American Megatrends v: A.00
    date: 09/21/2017
  System RAM: total: 128 GiB available: 125.69 GiB used: 3.05 GiB (2.4%)
  Array-1: capacity: 512 GiB slots: 8 modules: 4 EC: None
    max-module-size: 64 GiB note: est.
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 32 GiB speed: spec: 2133 MT/s actual: 1067 MT/s
    volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Corsair part-no: CMK128GX4M4A2666C16 serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Device-5: Channel-C DIMM 0 type: no module installed
  Device-6: Channel-C DIMM 1 type: DDR4 detail: synchronous unbuffered
  Device-7: Channel-D DIMM 0 type: no module installed
  Device-8: Channel-D DIMM 1 type: DDR4 detail: synchronous unbuffered
  Info: model: AMD Ryzen Threadripper 1920X bits: 64 type: MT MCP arch: Zen
    level: v3 note: check built: 2017-19 process: GF 14nm family: 0x17 (23)
    model-id: 1 stepping: 1 microcode: 0x8001129
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
    smt: enabled cache: L1: 1.1 MiB desc: d-12x32 KiB; i-12x64 KiB L2: 6 MiB
    desc: 12x512 KiB L3: 32 MiB desc: 4x8 MiB
  Speed (MHz): avg: 2200 min/max: 2200/3500 boost: disabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200 3: 2200
    4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200
    13: 2200 14: 2200 15: 2200 16: 2200 17: 2200 18: 2200 19: 2200 20: 2200
    21: 2200 22: 2200 23: 2200 24: 2200 bogomips: 168036
  Flags: 3dnowprefetch abm adx aes amd_dcm aperfmperf apic arat avic avx
    avx2 bmi1 bmi2 bpext clflush clflushopt clzero cmov cmp_legacy
    constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate
    lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
    sep sev sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a
    ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
    v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
    xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
  Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
  Type: vmscape status: Vulnerable
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
    XT/9070 GRE] vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-4
    code: Navi-4x process: TSMC n4 (4nm) built: 2025+ pcie: gen: 5
    speed: 32 GT/s lanes: 16 ports: active: DP-1 empty: DP-2, HDMI-A-1,
    HDMI-A-2, Writeback-1 bus-ID: 0c:00.0 chip-ID: 1002:7550 class-ID: 0300
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-1 model: EIZO NANAO S2233W serial: <filter> built: 2009 res:
    mode: 1680x1050 hz: 60 scale: 100% (1) dpi: 89 gamma: 1.2 chroma: red:
    x: 0.659 y: 0.325 green: x: 0.216 y: 0.682 blue: x: 0.145 y: 0.071 white:
    x: 0.314 y: 0.329 size: 474x297mm (18.66x11.69") diag: 566mm (22.3")
    ratio: 16:10 modes: 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800,
    1152x864, 1280x720, 1024x768, 800x600, 640x480, 720x400
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.1-arch1.2
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 9070 (radeonsi
    gfx1201 LLVM 21.1.6 DRM 3.61 6.12.61-1-MANJARO) device-ID: 1002:7550
    memory: 15.62 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.328 layers: 9 device: 0 type: discrete-gpu name: AMD
    Radeon RX 9070 (RADV GFX1201) driver: mesa radv v: 25.3.1-arch1.2
    device-ID: 1002:7550 surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: lact,radeontop wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
    Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 1102:0012 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
    driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
    bus-ID: 0c:00.1 chip-ID: 1002:ab40 class-ID: 0403
  API: ALSA v: k6.12.61-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
  Device-1: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 7000 bus-ID: 08:00.0
  IF: enp8s0 state: down mac: <filter>
    vendor: TP-LINK TG-3468 driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: f000 bus-ID: 43:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp67s0 state: down mac: <filter>
  Info: services: NetworkManager
  WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
  Local Storage: total: 10.92 TiB used: 385.88 GiB (3.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Western Digital
    model: WD BLACK SN770 2TB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 731130WD temp: 32.9 C scheme: MBR
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 24.9 C
    scheme: MBR
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST8000NM000A-2KE101
    size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: SC03 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD1003FZEX-00MK2A0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
    fw-rev: 1A01 scheme: MBR
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSD1 rev: LG00
    dev-links: cdrom
  Features: speed: 12 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 1.81 TiB size: 1.78 TiB (98.37%) used: 385.88 GiB (21.2%)
    fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:5 label: N/A
    uuid: 7577eecb-23f7-4a07-8eac-a01a3d8d9240
    dev: /dev/nvme0n1p2 maj-min: 259:6 label: swap
    uuid: 8708d9e9-4e5b-490b-b93e-465abbd4a30a
  ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 549 MiB fs: ntfs
    label: System-reserviert uuid: 707C2F317C2EF190
  ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 930.46 GiB fs: ntfs label: N/A
    uuid: 886E30756E305E5E
  ID-3: /dev/nvme1n1p3 maj-min: 259:3 size: 530 MiB fs: ntfs label: N/A
    uuid: 1CB842C1B84298E2
  ID-4: /dev/sda1 maj-min: 8:1 size: 128 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-5: /dev/sda2 maj-min: 8:2 size: 7.28 TiB fs: ntfs label: Volume
    uuid: C8465A87465A7662
  ID-6: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ntfs label: Volume
    uuid: 3AFD0023FCFFD6DB
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 14 rev: 2.0
  Device-1: 1-12:2 info: [Maxxter] USB GAMING MOUSE type: mouse,keyboard
    chip-ID: 18f8:1286 class-ID: 0300
  Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 4 rev: 3.0
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-8: 8-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 25.4 C mobo: N/A gpu: amdgpu temp: 27.0 C
    mem: 26.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Packages: pm: pacman pkgs: 1888 libs: 453 tools: octopi,pamac,yay
    pm: flatpak pkgs: 0
    1: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    2: https://mirror.init7.net/manjaro/stable/$repo/$arch
    3: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    4: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    5: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    7: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    8: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 492
  1: cpu: 13.1% command: plasmashell pid: 1401 mem: 387.7 MiB (0.3%)
  2: cpu: 3.6% command: kwin_wayland pid: 1160 mem: 229.7 MiB (0.1%)
  3: cpu: 1.9% command: init pid: 1 mem: 13.4 MiB (0.0%)
  4: cpu: 1.6% command: konsole pid: 2308 mem: 137.4 MiB (0.1%)
  5: cpu: 1.6% command: zsh pid: 2334 mem: 10.2 MiB (0.0%)
  Memory top: 5 of 492
  1: mem: 387.7 MiB (0.3%) command: plasmashell pid: 1401 cpu: 13.1%
  2: mem: 229.7 MiB (0.1%) command: kwin_wayland pid: 1160 cpu: 3.6%
  3: mem: 146.8 MiB (0.1%) command: akonadi_mailfilter_agent pid: 2009
    cpu: 1.0%
  4: mem: 146.1 MiB (0.1%) command: akonadi_archivemail_agent pid: 2001
    cpu: 1.0%
  5: mem: 146.0 MiB (0.1%) command: kalendarac pid: 1654 cpu: 1.1%
  Processes: 492 Power: uptime: 1m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 50.25 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.3.8 running-in: konsole inxi: 3.3.40
manjaro-chroot worked. I have used it to use pacman -U to undo the grub-update.
Then you never paid any attention to the messages pertaining to them that surely where many over the course of all those years.
granted:
the pamac-GUI does nothing to alert you to these - as far as I kow
unless you watch the terminal output of the update process
one more reason to not like it - why I don’t use it …
The version I have used is still provided by the official Manjaro-homepage. I thought this is the only place to find the official mirrors.
But the main problem: The computer that I wasn’t able to boot is the only one, that can create a bootable USB-Stick. And the ISO-file is too big for a DVD.
pamac-GUI
What is this? I am using Octopi or for a simple update just pacman -Syu.
the arguably best way would be to use Ventoy
  • install it (not even really needed - just download, unpack and run from there …)
  • use it to prepare your USB stick
  • copy the ISO to it
The very easy way is:
sudo cp Manjaro.iso /dev/sdy
where you need to adapt the PATH to your Manjaro ISO as well as the device name of your USB stick
(/dev/sdy is just an example here)
pamac-manager is what I mean by pamac GUI
It’s the Manjaro default package manager - Octopi does the same.
And better, as some would argue.
If you often or always used
pacman -Syu
you’d have seen the messages about .pacnew files for sure
The strange program with the green arrow that never works as it should?
that is probably right :wink:
supposed to be a distinct good feature of Manjaro
but it failed me too many times and I now don’t even bother to even think of using it :wink:
… I came from ARCH
pacman always worked and I’m used to it as well
so: I use it …
If you don’t know what is important and what is not you will most likely not recognise it as long as everything works fine.
That may be true -
and it will indeed keep working for some time, most of the time
but eventually it will break … assume that to be sooner rather than later
I, myself, would have been curious about messages along the lines:
… has been installed as … .pacnew
I guess these where prepended by “Warning” … - not sure now from memory
they where definitely there
and for quite some time a year or two ago you would also have seen messages that the community repo was invalid
even errors because of it
That should have ticked you off - but you may have missed that when not updating during that time.
just tend to them now … better late than never :wink:
Well, 6 years… I haven’t expect a problem after using the updates so long this way.
BTW: What shall I do with a pacnew file?
When a new configuration file gets installed, it won’t overwrite yours. It installs it beside it as filename.pacnew. You have to manually bring over the changes, making sure they don’t conflict with your own.
The good news is, this can be very easy to do with tools out there meant for this.
This is the quick run down of what most people just need to know:
Meld is a program just to compare two files.
(I’ve always just used vim -d/vimdiff, which is the Arch default. But I would not recommend this!) So many people use the GUI program: meld.
As this is new for you, just install meld: sudo -S meld. Try it out. Don’t even use sudo pacdiff until you understand exactly what meld is and does.
Except you can run:
pacdiff -o
pacdiff --output
This shows you what pacnew files you need to deal with.
No sudo needed, this will list all the pacnew files you need to deal with, you will have a lot.
But you could copy one of the files from above, say:
/etc/default/grub.pacnew
Your actual config is without the .pacnew at the end:
/etc/default/grub
If you copied these two files to your Documents, you could load them both in Meld to see how it works.
After dealing with the changes, copying that file back to /etc/default, and deleting the original pacnew file is one manual way to deal with that particular pacnew.
Once you are comfortable there, pacdiff has ways to make this quicker.
